Results 1 to 9 of 9
Thread: Teensyduino 1.41 Beta #2
    Administrator Paul's Avatar
    Oct 2012
    338
    Here is a second beta test for Teensyduino 1.41.
    Since Arduino's 1.9 betas are a moving target, I've included copies of
    beta build #31 which this Teensyduino version expects.
    Changes since Teensyduino 1.41-beta1
    Support for Arduino 1.9.0-beta31
    Accept String in Stream find() and findUntil()
    Update LedDisplay library
    USBHost_t36 Fix device status functions usage in polling loops
    USBHost_t36 Clean up bandwidth usage info when deleting a pipe
    20,581
    I had a strange compile error when trying with 1.9-beta on Macintosh. Can anyone else running on a Mac give this a try on the Arduino 1.9 beta?
    Senior Member duff's Avatar
    Las Vegas
    969
    Las Vegas
    969
    Just downloaded beta31 and teensyduino beta2 and compiled a bunch of sketches with muiltiple teensy boards w/ no errors. Looks like they fixed the mac bugs that I got last time I tried the new Arduino beta with teensy. OSX 10.12.6.
    5,424
    FYI - I installed on my windows machine after I uninstalled McAfee and installed Norton 360... When I installed the Windows zip file, norton decided that the arduinopreprocessor... exe file was unsafe and removed it...
    Needless to say build did not work. I found where it quarantined it and restored it and it now build.
    Kurt
    9,739
    Did the IDE 1.9B31 unzip, then TD 1.42b2 install with no problems ( per usual had to unblock the IDE Arduino.exe to run it but TDInstall ran ).
    Win 10 PROx64 machine with Windows Defender active and running - Installs and runs and builds [TEMP] on SSD Drive "T:" that I told Malwarebytes to not do ransomware Monitor.
    FYI :: The only issue I see { Arduino IDE Pre-Processor not Teensy } is that a missing semi-Colon on line 157 shows for line 226 as:
    RTC_ISR_Ccnt:226: error: expected declaration before '}' token
    Did an IDE Ctrl+T format and looked for bad indent and saw the naked line.
    Same bad line # ref with misnamed variable, or this on line 156 [10 0's should be only 8]: static uint32_t vals[8] = { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 };
    RTC_ISR_Ccnt:276: error: too many initializers for 'uint32_t [8] {aka long unsigned int [8]}'
    <edit> - of course this doesn't work with some errors - write a new batch of code and have to comment out chunkc/functions to know where to find the error . . . .
    Nov 2017
    Belgium
    104
    mac osx 10.10.5, arduino 1.9.0 beta31, teensyduino 1.41 beta2.
    no compile errors. all my current projects compile without a hitch.
    Quote Originally Posted by Paul View Post
    Changes since Teensyduino 1.40:
    Add AudioConnection disconnect() (thanks b0rg3rt)
    Does this mean we can now reroute or repatch audio objects at runtime?
    20,581
    Quote Originally Posted by neurofun View Post
    Maybe. Can you give it a try?
    Honestly, I accepted this patch and really only tested to make sure it didn't break existing functionality.
    Nov 2017
    Belgium
    104
    It took me a while to figure out how to properly use this function. Here is how I did it.
    Instantiate all possible AudioConnections needed in the project, in the global scope as usual. Multiple sources to one destination is ok.
    In Setup() disconnect all AudioConnections except the ones that will never change, before enabling the audio engine.
    In loop() connect and disconnect all you want while still following the connection rules & guidelines.
    So yes, changing connections at runtime works.
