Results 1 to 12 of 12
Thread: SN74HC165 shift register revisited
    Jan 2017
    Maastricht
    84
    The SN74HC165 shift register makes it easy to add digital input to a Teensy/Arduino. On the Arduino playground a description can be found: SN74HC165N, a Sparkfun tutorial relies on the same approach.
    It always seemed strange to me that shifting in would require 4 wires, whereas shifting out can make do with three. Turns out that you only need three wires, the clock inhibit is superfluous. The tutorial mentioned refer to the timing diagram:
    The way I interpret the datasheet this diagram refers to the case where there's a continuously running clock, not when you have full control over the clock. Also in the datasheet is an example of a typical application with a microcontroller:
    In this example the clock inhibit (pin 15) is connected to ground and just three wires are used.
    The tutorials also make use of delay() statements for timing purposes.
    /* Width of pulse to trigger the shift register to read and latch.
    #define PULSE_WIDTH_USEC   5
    BYTES_VAL_T read_shift_regs()
        long bitVal;
        BYTES_VAL_T bytesVal = 0;
        /* Trigger a parallel Load to latch the state of the data lines,
        digitalWrite(clockEnablePin, HIGH);
        digitalWrite(ploadPin, LOW);
        delayMicroseconds(PULSE_WIDTH_USEC);
        digitalWrite(ploadPin, HIGH);
        digitalWrite(clockEnablePin, LOW);
        /* Loop to read each bit value from the serial out line
         * of the SN74HC165N.
        for(int i = 0; i < DATA_WIDTH; i++)
            bitVal = digitalRead(dataPin);
            /* Set the corresponding bit in bytesVal.
            bytesVal |= (bitVal << ((DATA_WIDTH-1) - i));
            /* Pulse the Clock (rising edge shifts the next bit).
            digitalWrite(clockPin, HIGH);
            digitalWrite(clockPin, LOW);
        return(bytesVal);
    Using an oscilloscope I performed some tests to see whether the delay is actually required. The test setup (alle delay statements removed and clock inhibit connected to ground) is shown in the following picture:
    The stripboard contains four 74HC165 shift registers for the buttons and three 74HC595 shift registers for the leds, the other buttons are on two separate boards. Alle the IC sockets have 100nF decoupling caps build in. A Teensy 3.6 is mounted on a Tall Dog extension board, it is mounted on its side for easy access to all the pins.
    I'm no electrical engineer but this looks like a decent clock pulse to me. Here's a screenprint showing the clock measured at the last IC in the chain:
    The clock frequency is just over 2MHz, pulse width is about 175ns. From the datasheet:
    Worst case is a maximum of 6MHz and a minimum pulse width of 80ns so we're well in the clear. No need for any delays in the code.
    The code running in the test:
    unsigned long readShiftRegisters()
        int bitVal;
        unsigned long bytesVal = 0;
        // Trigger a parallel Load to latch the state of the data lines
        // Loop to read each bit value from the serial out line of the SN74HC165N.
            // Set the corresponding bit in bytesVal.
            // Pulse the Clock (rising edge shifts the next bit).
        return(bytesVal);
    Kind regards,
    Gerrit
    Feb 2014
    Colmar, France
    1,457
    What you are doing looks basically like a bit-banging emulation of a slow ancestor of the SPI bus. Great to see that it works!
    Jan 2017
    Maastricht
    84
    I had a look at the SPI library documentation, it seems this is intended for more specialised applications. Using shift registers this way is really easy as there is no protocol overhead and all buttons can be debounced simultaneously.
    While browsing the libraries I found a similar case of clock ringing mentioned in the OctoWS2811 documentation so I thought I'd try a putting a series resistor in the clock line. I started with 220Ω and and then tried 100Ω. The resistor is mounted on the cable connector at the Teensy side.
    220Ω is a bit too much, the corners are rounded off and the rise time increases, 100Ω is just fine. The little blips in front of the first pulse are the result of crosstalk from the parallel load line, adding a series resistor cleans it up a little. Here's a before-after comparison of the clock signal without any series resistors and with 100Ω series resistors in the clock an parallel load lines:
    I'm quite satisfied with this result. A nice, clean clock signal and 32 buttons scanned in about 15Ás.
    Kind regards,
    Gerrit
    Jan 2017
    Maastricht
    84
    The finished button panel:
    Real old school wiring, it looks a little messy but remember that with shift registers the high frequency clock and data signals are confined to the ICs so there's no risk of RF interference. This is about as far as I'd go without designing a PCB but at least when using strip board like this it is easy to get exact dimensions for a front panel design by counting holes. Mounted on the front panel it look like this:
    The board is mounted on 8 M3 threaded standoffs on the back of the frontpanel, fortunately the measurements were correct so all the buttons are perfectly aligned In case you're wondering, this is part of a DAW (Digital Audio Workstation) plugin controller project I'm working on.
    Kind regards,
    Gerrit
    3,432
    Looks good!
    Wonder if you could use the Arduino function shiftin (https://www.arduino.cc/reference/en/...ed-io/shiftin/)
    To do each byte... But since you already have it working...
    Jan 2017
    Maastricht
    84
    Looks good!
    Thanks.
    I thought about using shiftIn() but, as you said, it's working now and there's still a lot to do. When my project is finished I'll take another look at this, it could well be that shiftIn() is faster.
    In the meantime I've got to the point where all the buttons and leds are operational with the DAW software (Logic Pro X).
    Kind regards,
    Gerrit
    Nov 2017
    4
    I would like to know where you got the switches with leds in them? Part number and supplier?
    Thanks.
    Jan 2017
    Maastricht
    84
    Quote Originally Posted by mark.winger View Post
    Thanks.
    The switches are from the C&K Digitast series. I can't make heads or tails of the pricing which varies a lot per supplier and type. I got them from RS Components and Mouser, here's a link to the black ones with the green leds
    Here's the datasheet: DIGITAST.pdf
    These switches have a very nice feel and precise pressure point, I selected the wide version because they're almost exactly the width of a finger. I also have some no name imitations but they're definitely not as refined as the C&K.
    Kind regards,
    Gerrit
    Sep 2014
    South Dundas, Ontario, Canada
    17
    I'm interested in how you made/cut the panel for the switches and the labelling. I often don't get past doing "a proof of concept" because of a lack finishing details and equipment. Thanks.
    Peter.
    Jan 2017
    Maastricht
    84
    Quote Originally Posted by KOC62 View Post
    Peter.
    The panel was made by Schaeffer using their free front panel designer software. It's not cheap but the result looks great and you can check the price at anytime in the design software, when finished the panel can be ordered from within the application.
    Kind regards,
    Gerrit
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    879
    It really is a beautiful build.
    But why a shift-register instead of a mux or GIPO expander? Seems like a lot of effort was expended to get this working, presumably not to save a few cents on the chips.
    Also, what's with the TRS connectors? Is this thing going to be an audio interface too?
    I hope you'll do a write up of the full project when complete.
    Jan 2017
    Maastricht
    84
    Quote Originally Posted by oddson View Post
    Here's a picture with the display and rotary encoder panel:
    For study I once took apart a Behringer controller and the thing is full of them (and the 595) so I figured I'll do it like this too. I also like the fact that there no multiplexing of the buttons, i.e. high frequency switching all over the pcb.
    Here's the rear view of the display and rotary panel:
    Level shifters for the encoders and two more shift registers for the encoder buttons.
    The trs jacks are for future expansion with foot pedals and other stuff, I thought I'd put them in now so I don't need to drill holes in the chassis later on. No audio functionality is planned, this is purely a (Mackie control compatible) controller.
    As soon as I find the time to create a little video demonstrating the controller I'll start a thread on the subject.
    Kind regards,
    Gerrit
