Results 1 to 9 of 9
Thread: prop board will not callibrate properly
    I have tried 2 versions of the windows calibrate utility. Supposedly continued data gathering will reduce errors and turn the graphic into a perfect? sphere but the opposite is happening and the save calibration button in inactive. The raw serial data looks as it should. What could be wrong? Here is the CalibrateSensors code-----Thanks for anyl help, Ralph.
    #include <NXPMotionSense.h>
    #include <EEPROM.h>
    #include <util/crc16.h>
    NXPMotionSense imu;
    const int ledPin = 13;
    int ledState = LOW;
    int ledFastblinks = 0;
    elapsedMillis ledMillis = 0;
    int loopcount = 0;
    void receiveCalibration();
    while (!Serial) ; // wait for serial port open
    imu.begin();
    pinMode(ledPin, OUTPUT);
    int ax, ay, az;
    int gx, gy, gz;
    int mx, my, mz;
    // get and print uncalibrated data
    if (imu.available()) {
    imu.readMotionSensor(ax, ay, az, gx, gy, gz, mx, my, mz);
    Serial.print("Raw:");
    Serial.print(ax);
    Serial.print(',');
    Serial.print(ay);
    Serial.print(',');
    Serial.print(az);
    Serial.print(',');
    Serial.print(gx);
    Serial.print(',');
    Serial.print(gy);
    Serial.print(',');
    Serial.print(gz);
    Serial.print(',');
    Serial.print(mx);
    Serial.print(',');
    Serial.print(my);
    Serial.print(',');
    Serial.print(mz);
    loopcount = loopcount + 1;
    // check for incoming calibration
    // occasionally print calibration
    if (loopcount == 50 || loopcount > 100) {
    Serial.print("Cal1:");
    float caloffsets[9], calmag;
    imu.getCalibration(caloffsets, NULL, &calmag);
    for (int i=0; i<9; i++) {
    Serial.print(caloffsets[i], 3);
    Serial.print(',');
    Serial.println(calmag, 3);
    if (loopcount >= 100) {
    Serial.print("Cal2:");
    float calsoftiron[9];
    imu.getCalibration(NULL, calsoftiron, NULL);
    Serial.print(calsoftiron[i], 4);
    if (i < 8) Serial.print(',');
    loopcount = 0;
    // blink LED, slow normally, fast when calibration written
    if (ledMillis >= 1000) {
    if (ledFastblinks > 0) {
    ledFastblinks = ledFastblinks - 1;
    ledMillis -= 125;
    ledMillis -= 1000;
    if (ledState == LOW) {
    ledState = HIGH;
    ledState = LOW;
    digitalWrite(ledPin, ledState);
    byte caldata[68]; // buffer to receive magnetic calibration data
    byte calcount=0;
    void receiveCalibration() {
    uint16_t crc;
    byte b, i;
    if (Serial.available()) {
    b = Serial.read();
    if (calcount == 0 && b != 117) {
    // first byte must be 117
    return;
    if (calcount == 1 && b != 84) {
    // second byte must be 84
    calcount = 0;
    return;
    // store this byte
    caldata[calcount++] = b;
    if (calcount < 68) {
    // full calibration message is 68 bytes
    return;
    // verify the crc16 check
    crc = 0xFFFF;
    for (i=0; i < 68; i++) {
    crc = _crc16_update(crc, caldata[i]);
    if (crc == 0) {
    // data looks good, use it
    imu.writeCalibration(caldata);
    calcount = 0;
    loopcount = 10000;
    ledFastblinks = 16; // Toggle LED faster the next 16 times
    return;
    // look for the 117,84 in the data, before discarding
    for (i=2; i < 67; i++) {
    if (caldata[i] == 117 && caldata[i+1] == 84) {
    // found possible start within data
    calcount = 68 - i;
    memmove(caldata, caldata + i, calcount);
    return;
    // look for 117 in last byte
    if (caldata[67] == 117) {
    caldata[0] = 117;
    calcount = 1;
    calcount = 0;
    raw readings: arbitrary sample
    Raw:-368,-7588,4484,-18,-10,0,-896,1051,1150
    Raw:-352,-7600,4472,-15,-9,2,-894,1043,1156
    Raw:-356,-7596,4460,-17,-9,-3,-886,1046,1166
    Raw:-352,-7600,4464,-9,-11,-2,-888,1041,1151
    Raw:-216,-4876,7328,-22,-9,4,367,26,-71
    Raw:-228,-4900,7312,-13,-9,0,360,14,-71
    Raw:-220,-4892,7324,-11,-8,1,360,16,-79
    Raw:-228,-4884,7332,-7,-7,0,365,26,-58
    Raw:-204,-4896,7316,-10,-7,1,383,-1,-89
    Raw:-228,-4888,7304,-16,-8,4,365,18,-81
    Raw:-212,-4896,7300,-19,-8,3,370,21,-87
    Raw:-224,-4888,7308,-11,-9,2,372,4,-49
    Cal1:0.000,0.000,0.000,0.000,0.000,0.000,0.000,0.0 00,0.000,50.000
    Raw:-212,-4904,7316,-10,-10,3,373,-4,-63
    Raw:-228,-4864,7312,-14,-7,4,382,21,-75
    Raw:-236,-4884,7332,-13,-10,4,361,18,-79
    Raw:-208,-4872,7320,-5,-8,4,361,21,-82
    Raw:-212,-4880,7332,-19,-9,1,375,20,-72
    Raw:-216,-4888,7312,-11,-9,2,364,32,-73
    Raw:-224,-4876,7328,-14,-8,4,351,19,-64
    Raw:-232,-4872,7292,-14,-8,-3,368,17,-83
    Raw:-228,-4900,7320,-16,-10,1,383,13,-65
    Raw:-204,-4872,7320,-9,-12,2,354,25,-72
    Raw:-232,-4888,7336,-10,-9,5,358,25,-67
    Raw:-216,-4880,7312,-15,-5,4,364,13,-70
    Raw:-216,-4888,7328,-18,-9,2,373,10,-71
    Raw:-220,-4896,7316,-18,-10,3,363,35,-73
    Raw:-228,-4896,7304,-10,-7,5,374,8,-59
    Raw:-228,-4892,7356,-9,-9,1,365,8,-68
    Raw:-216,-4868,7336,-11,-7,3,343,24,-57
    Raw:-228,-4884,7328,-13,-9,4,360,17,-79
    Raw:-212,-4896,7316,-17,-9,1,365,17,-60
    Raw:-208,-4896,7324,-14,-7,1,370,15,-84
    Raw:-212,-4884,7316,-8,-11,0,371,22,-77
    Raw:-220,-4888,7324,-11,-10,0,374,8,-80
    Last edited by Ralph Trimnell; 12-27-2017 at 06:08 PM. Reason: added screen shot raw
    1,386
    What version of WIndows? You selected the COM port on the MotionCal.exe? so do the red dots change position on the sphere as you twist and roll the propshield?
    Yes, the red dots do move around and seem to be trying to form a sphere. the fit error generally hovers around 10 . Lowest readings I've ever gotten are 16.7(gap), 6(var),1.8(wob),6(fit) so then I try to send calibration but buttondoes not respond. Actually I don't understand it's connection to the CalibrateSensor program which has no cin statement or similar. I notice in this program that the led is to blink rapidly when a good calibration is found but I've never seen it do this. Sorry to be such a worry, but I do appreciate help. Ralph. Oh, using Windows 10.
    1,386
    CalibrateSensor has a Serial.read() in receiveCalibration() to get the calibration data from MotionCal when you press the send button. the sketch then saves the calibration data in the teensy EEPROM, so other sketches can fetch it from the EEPROM
    (use the CODE tags when embedding code in your post, "#" button, to retain indentation)
    Thanks, but my send cal button is grayed out and will not respond. Why is this? Ralph Also the Motion Sensor Cal tool shows no input from accelerometer or gyro, only magnetic. ls this correct?
    1,386
    Quote Originally Posted by Ralph Trimnell View Post
    i think gray will go away when gaps < 10% (in my experience). then when you push send, you should see the fast LED blink. wiggle propshield in more orientations to fill gaps
    MotionCal source: when to enable send calibration
    if (gaps < 15.0f && variance < 4.5f && wobble < 4.0f && fiterror < 5.0f)
    I have spent hour after hour on this with no success. Gap (at one time) was down to 0 and error 9.5. Still not allowed to send cal. Don't know whether to say "board defect" and order another set, or scrap this and look for another solution. This endeavor is not a whlm but part of an important long term project and must be resolved one way or another. So frustrating!
    1,386
    Cold comfort: It works for me on windows 10, mac OS, and linux64. maybe download latest MotionCal from https://www.pjrc.com/store/prop_shield.html
    i'm out of ideas ...
    get a longer USB cable and move your prop shield away from any magnetic fields.
    Thank you, again and again. The solution: work on a laptop: take out of your office full of mechanisms into a neutral enviroment: use a 6 foot lead for the prop shield and everything works as designed. Perfect circle and calc send enabled, OK, Ralph
