A couple of days ago the SD card initialization was successful and I could log data with the code below. Today I couldn't make it work again. I tried also to use SD card data logging example but it seems that the sd card can not be initialized. Am I missing something??
#include <TeensyThreads.h> // https://github.com/ftrias/TeensyThreads
#include <SPI.h>  // include the SPI library to initiate the clock signal for absolute encoders and IMU
//-----------------------------------------------Define pins needed for wheel and pedal cadence encoders------------------------------------------------------------------------------------------------------
#define rearencoderA 0 // define pin where rear wheel encoder chanel A is connected
#define pedalencoderA 2 // define pin where the pedal encoder chanel A is connected
//--------------------------------------------SD Card logging-----------------------------------------------------------------------------------------------------------------------------------
File myFile; // create a file object
const int CS =BUILTIN_SDCARD; // define CS pin of SD card
//-----------------------------------------------Define pins needed for absolude encoders------------------------------------------------------------------------------------------------------------------
const int ssimu = 10; // slave selection enable is low
const int sshand = 24;
const int ssfork = 25;
const int pwrencoders = 26; // making high enable power to encoders
float handlebaranglelast; // check estimation of angular velocity section
//-----------------------------------------------Define time as a variable for SD card----------------------------------------------------------------------------------------------------------------
unsigned long time;
//-----------------------------------------------Define variables needed for calculation of forward velocity and pedal cadence--------------------------------------------------------------------------------
unsigned long duration;
unsigned long duration1;
unsigned long freq;
unsigned long freq1;
unsigned long rpm;
unsigned long rpm1;
unsigned long U;
unsigned long rear;
void run_motor() { // name thread function
// set the slaveSelectpins and power pin of absolute encoders and IMU as outputs:
  pinMode (ssimu, OUTPUT);
  pinMode (sshand, OUTPUT);
  pinMode (ssfork, OUTPUT);
  pinMode (pwrencoders, OUTPUT);
  while(1) { // this  is basically the control loop of the two motors
    // enable slave device
    digitalWrite(ssimu,HIGH); // setting HIGH slave selection pin to disable IMU
    digitalWrite(sshand,LOW);  // setting LOW slave selection pin to enable handlebar encoder
    digitalWrite(pwrencoders,HIGH); // setting HIGH PA10 pin of external pcb connected to pin 26 of teensie to enable power to my encoders
    digitalWrite(ssfork,HIGH); // setting HIGH slave selection pin to disable fork encoder
    // set clock signal characteristics
    SPI.beginTransaction(SPISettings(125000, MSBFIRST, SPI_MODE3));  // set frequency to 125 Khz-4 Mhz, encoder transmit first the MSB, Clock Idles High Latch on the initial clock edge, sample on the subsequent edge
    uint16_t mybyte; // declaring variable to unsigned 16-bit integer
    uint16_t mybyte1; //declaring variable to unsigned 16-bit integer
    mybyte= SPI.transfer16(0); // transfering 16 bits to MOSI and reading what comes back to MISO
    //From my byte1 you need to mask out 3 bits the first MSB and the two LSB;
    mybyte1 = (mybyte &= 0x7fff)>>2; // First AND bit operator is used bit mask 0111 1111 1111 1111 the 16bit is set to zero.
    //afterwards the bits are shifted two positions to the left. mybyte is now a 14bit with the MSB=0 and the upcoming 13 bit coming from the encoder signal.
    digitalWrite(sshand,HIGH); // disable handlebar encoder
    SPI.endTransaction(); // ending transaction
    delayMicroseconds(20); // delay between 12.5 μs ≤ tm ≤ 20.5 μs for SSI timeout
    //---------------------------------------------------Reading data from fork encoder----------------------------------------------------------------------------------------
    digitalWrite(ssfork,LOW); // enable fork encoder
    uint16_t mybytefork; // declaring variable to unsigned 16-bit integer
    mybytefork= SPI.transfer16(0); // transfering 16 bits to MOSI and reading what comes back to MISO
    uint16_t mybyte1fork; //declaring variable to unsigned 16-bit integer
    mybyte1fork = (mybytefork &= 0x7fff)>>2; // First AND bit operator is used bit mask 0111 1111 1111 1111 the 16bit is set to zero.
    digitalWrite(ssfork,HIGH); // disable fork encoder
    // -----------------------------------------------Processing data output of encoders------------------------------------------------------------------------
    //Note: The two encoders are mounted oppose to each other for this reason we have different counts directions.
    // More specific, Anticlockwise rotation of handlebar encoder gives 360 deg-> 310 deg whereas, anticlockwise rotation gives 0-55 degrees.
    // The rotational direction must be the same for both encoders, the encoders must give an output 0+- 180 degrees. Two if statements are used for these reasons.
    float handlebarangle;
    handlebarangle=(float)mybyte1*360.0/8191.0; // encoder counts to deg
    if (handlebarangle >180) // Anticlockwise rotation of handlebar encoder gives 360 deg-> 310 deg.
    handlebarangle = handlebarangle -360; //substracting -360 we get 0-180 deg anticlockwise.
    // ---------------------------------------------Set software limits------------------------------------------------------------------------------------------
    // The fork mechanical range is +- 38 degrees since handlebars do bot have a mechanical limit software limits are set below if you do not set this limits the motor foldsback.
    if (handlebarangle >38)
    handlebarangle = 38;
    if (handlebarangle <-38) // seting angle limit
    handlebarangle = -38;
    // end of software limits
    float forkangle;
    forkangle=-(float)mybyte1fork*360.0/8191.0-41.5; //// encoder counts to deg, substracting 8 deg to align fork with handlebars and - to get minus values from fork encoder
    if (forkangle <-180) // Clockwise rotation of fork encoder gives -360 deg-> -310 deg
    forkangle = forkangle+360; //by adding +360 we get 0-180 deg anticlockwise
    // -----------------------------------------------Fork feedback tracking controller------------------------------------------------------------------------
    //declare pin alocation on teensie 3.6 board
    const int forkmotordrive = 30; // making High enables fork motor drive
    const int pwmforkmotor = 9;
    //declare pin as outputs
    pinMode (forkmotordrive, OUTPUT);
    pinMode (pwmforkmotor, OUTPUT);
    // define variables
    float Kp= 0.5;//0.139626 ; // Nick recommends 8 Nm/rad=0.139626 Nm/deg
    float Kd=0.010472;// Nick recommends 0.6 Nm/rad=0.010472 Nm/deg
    float Tc= 0.0369;// Torque constant  36.9 mNm/A = 0.0369 Nm/A
    const int Tdac=1;
    float Torque;
    signed int Torquedac;
    //----------------------------------------Estimation of angular velocity---------------------------------------------------------------------------------
    float velocity;
    velocity=(handlebaranglelast-handlebarangle)/0.000352; // where dt=352 (us)// it is two fast i need to add a counter and a while loop and print at lower frequencies
    if (handlebarangle!=handlebaranglelast)
    handlebaranglelast=handlebarangle;
    //--------------------------------------------------------------------calculation of Torque fork motor--------------------------------------------------------
    Torque=Kp*(-handlebarangle+forkangle);
    Torquedac=(Torque*1334+32768)+412; // divide with reduction ratio* torque constant to give a command in Amperes
    // Scale torque amp with a constant to obtain a dac number
    if (Torquedac>65536) // Clockwise rotation of fork encoder gives -360 deg-> -310 deg
    Torquedac=65536; //by adding +360 we get 0-180 deg anticlockwise
    if (Torquedac<-65536) // Clockwise rotation of fork encoder gives -360 deg-> -310 deg
    Torquedac=-65536; //by adding +360 we get 0-180 deg anticlockwise
    analogWriteResolution(16);
    analogWrite(pwmforkmotor,abs(Torquedac));
    digitalWrite(forkmotordrive,LOW);
    // -----------------------------------------------Handlebar feedback tracking controller------------------------------------------------------------------------
    const int handmotordrive = 29; // making high enables handlebar motor drive
    const int pwmhandmotor = 8;
    pinMode (handmotordrive, OUTPUT);
    pinMode (pwmhandmotor, OUTPUT);
    // define variables
    float Kp1= 0.3;//0.139626 ; // Nick recommends 8 Nm/rad=0.139626 Nm/deg
    float Kd1=0.010472;// Nick recommends 0.6 Nm/rad=0.010472 Nm/deg
    float Tc1= 0.0369;// Torque constant  36.9 mNm/A = 0.0369 Nm/A
    const int Tdac1=1;
    float Torque1;
    signed int Torquedac1;
    //--------------------------------------------------------------------calculation of Torque handlebar motor--------------------------------------------------------
    Torque1=Kp1*(-handlebarangle+forkangle);
    Torquedac1=(Torque1*1334+32768)+412; // divide with reduction ratio* torque constant to give a command in Amperes
    if (Torquedac1>65536) // Clockwise rotation of fork encoder gives -360 deg-> -310 deg
    Torquedac1=65536; //by adding +360 we get 0-180 deg anticlockwise
    if (Torquedac1<-65536) // Clockwise rotation of fork encoder gives -360 deg-> -310 deg
    Torquedac1=-65536; //by adding +360 we get 0-180 deg anticlockwise
    analogWrite(pwmhandmotor,abs(Torquedac1));
    digitalWrite(handmotordrive,LOW);
    // -----------------------------------------------Printing encoder counts&deg handlebar------------------------------------------------------------------------
//     Serial.print("Hand(deg)=");
//    Serial.print(handlebarangle);
//    // Serial.print(",Hand(Counts)= ");
//    // Serial.print(mybyte1);
//    // Printing encoder counts&deg Fork
//   Serial.print(",Fork(deg)=");
//    Serial.print(forkangle);
//    // Serial.print(",Fork(Counts)= ");
//    // Serial.print(mybyte1fork);
//    // Serial.println();
//   Serial.print(",Torque(Nm)=");
//    Serial.print(Torque);
//   //Serial.print(",Torque(dac)=");
//   // Serial.print(Torquedac);
void read_data() {
  pinMode (rearencoderA,INPUT);
  pinMode (pedalencoderA,INPUT);
  //----------------------------------------------------------------SD CARD initialization-----------------------------------------------------------------------------------------------
  if  (SD.begin(CS))
    Serial.println("SD card is ready to use.");
  }  else
    Serial.println("SD card initialization failed");
    return;
  while (1) {
    // This program calculates the bicycle forward velocity in km/h
    duration = pulseIn(rearencoderA,HIGH,250000); //  Returns the length of the pulse in microseconds when signal output A is high
    freq=1200000/(duration*2); // The period of the is 2 times the duration of the pulse of output A https://tushev.org/articles/arduino/9/measuring-frequency-with-arduino
    rpm = (freq*60)/96; // 96 are the line counts of the encoder http://www.quantumdev.com/finding-the-rpm-of-an-optical-encoder-using-an-oscilloscope/
    U=6.28*0.3355*rpm*60/1000; // http://answers.tutorvista.com/489133/what-is-the-formula-for-converting-rpm-to-kph.html#
    // This program calculates the pedal cadence speed in rpm
    duration1 = pulseIn(pedalencoderA, HIGH,250000); //  Returns the length of the pulse in microseconds when signal output A is high
    freq1=1200000/(duration1*2); // The period is 2 times the duration of the pulse of output A. 12e6 is set based on speedometer output comparison https://tushev.org/articles/arduino/9/measuring-frequency-with-arduino
    rpm1 = (freq1*60)/96; // 96 are the line counts of the encoder http://www.quantumdev.com/finding-the-rpm-of-an-optical-encoder-using-an-oscilloscope/
  // -----------------------------------------------Data logging forward velocity U and pedal cadence rpm1------------------------------------------------------------------------------
    // Create/Open file
    myFile = SD.open("out.csv", FILE_WRITE);
    // if the file opened okay, write to it:
    if (myFile) {
      time = millis();
Serial.print("Time = "); // printing variables when needed for debugging
    Serial.print(time);
     Serial.print(", Speed(km/h) = ");
     Serial.print(U);
     Serial.print(",Pedal(rpm)= ");
      Serial.println(rpm1);
      myFile.print(time);
      myFile.print(',');
      myFile.print(U);
      myFile.print(',');
      myFile.println(rpm1);
      // Write to file
     myFile.close(); // close the file
    // if the file didn't open, print an error:
    else {
      Serial.println("error opening file");
  SPI.begin(); // intializing SPI
  Serial.begin(500000); // begin serial communication;
  pinMode(CS, OUTPUT);
  threads.addThread(run_motor); // creating a thread call run motor fuction
  threads.addThread(read_data);// creating a thread call read data fuction
  threads.delay(10);
SD data logging example from arduino library gives "SD card initialization failed"
File myFile;
const int CS =BUILTIN_SDCARD ;
// SD Card Initialization
if  (SD.begin(CS))
  } else
    return;
  // Create/Open file
  myFile = SD.open("test.txt", FILE_WRITE);
  if (myFile) {
    Serial.println("Writing to file...");
    // Write to file
    myFile.println("Testing text 1, 2 ,3...");
    Serial.println("Done.");
  else {
    Serial.println("error opening test.txt");
  // Reading the file
  myFile = SD.open("test.txt");
  if (myFile) {
    Serial.println("Read:");
    // Reading the whole file
    while (myFile.available()) {
      Serial.write(myFile.read());
    myFile.close();
  else {
