Results 1 to 3 of 3
Thread: Teensy 3.2 Tesla Coil Winder
    Mar 2017
    11
    I am rewriting Jeff Rosowski's Arduino code to run on the Teensy. This version works on the Teensy 3.2 but I am sure much can be done to clean up the code.
    If there is a better way to post or attach the code, please let me know.
    Jeff
    /*  v1.0 Tesla Coil Winder Firmware                 */
    /*  29 Jan 2014 - Jeff Rosowski                     */
    /*  https://github.com/krux702/tesla_coil_winder    */
    /*  v 1.1 for Teensy 3.2   (20ms step pulse)        */
    /*  12 Dec 2017 - Jeff Parisse                      */
    #include <Adafruit_LiquidCrystal.h>
    #include <avr/eeprom.h>
    #include <MenuSystem.h>
    #include <stdlib.h>
    #define BAUDRATE 19200
    #define MENU_TITLE  "Tesla Winder v1.1  "
    #define MANUAL      "Manual Control     "
    #define ENABLE      "Stepper Enable     "
    #define JOG_COIL    "Jog coil           "
    #define JOG_GUIDE   "Jog guide          "
    #define SETTINGS    "Settings           "
    #define COIL_STEPS  "Coil steps/rot     "
    #define COIL_INV    "Coil invert        "
    #define GUIDE_STEPS "Guide steps/mm     "
    #define GUIDE_INV   "Guide invert       "
    #define HOME        "Home guide         "
    #define SETUP_JOB   "Setup Job          "
    #define SETUP_HELP  "Size in micrometers"
    #define WIRE_SIZE   "Wire size          "
    #define COIL_DIAM   "Coil diam          "
    #define COIL_HOME   "Home offset        "
    #define COIL_CALC   "Calc coil size     "
    #define COIL_RATIO  "Coil ratio         "
    #define COIL_LEN    "Coil len           "
    #define COIL_TURNS  "Coil turns         "
    #define COIL_SPEED  "Speed mm/sec       "
    #define START       "Start              "
    MenuSystem ms;
    Menu mm(MENU_TITLE);
    Menu manual(MANUAL);
    MenuItem manual_stepper(ENABLE);
    MenuItem manual_jogcoil(JOG_COIL);
    MenuItem manual_jogguide(JOG_GUIDE);
    Menu settings(SETTINGS);
    MenuItem settings_coilsteps(COIL_STEPS);
    MenuItem settings_coilinvert(COIL_INV);
    MenuItem settings_guidesteps(GUIDE_STEPS);
    MenuItem settings_guideinvert(GUIDE_INV);
    MenuItem settings_coilhome(COIL_HOME);
    MenuItem settings_home(HOME);
    Menu job(SETUP_JOB);
    MenuItem job_help(SETUP_HELP);
    MenuItem job_wiredia(WIRE_SIZE);
    MenuItem job_coildia(COIL_DIAM);
    MenuItem job_coilhome(COIL_HOME);
    MenuItem job_coilcalc(COIL_CALC);
    MenuItem job_coilratio(COIL_RATIO);
    MenuItem job_length(COIL_LEN);
    MenuItem job_turns(COIL_TURNS);
    MenuItem job_speed(COIL_SPEED);
    MenuItem job_home(HOME);
    MenuItem job_start(START);
    const int min_stop = 17;
    const int max_stop = 16;
    const int led = 13;
    byte line = 0;
    byte cursor_line = 0;
    // stepper a - guide
    const int stepper_a_enable = 12;
    const int stepper_a_direction = 11;
    const int stepper_a_step = 10;
    long stepper_a_steps = 0;
    byte stepper_a_run = 0;
    byte stepper_a_dir = 0;
    byte stepper_a_ena = 0;
    // stepper b - coil
    const int stepper_b_enable = 7;
    const int stepper_b_direction = 8;
    const int stepper_b_step = 9;
    long stepper_b_steps = 0;
    byte stepper_b_run = 0;
    byte stepper_b_dir = 0;
    byte stepper_b_ena = 0;
    // input buttons
    const int button_a = 2;  // ENTER
    const int button_b = 3;  // DOWN
    const int button_c = 4;  // UP
    const int button_d = 5;  // LEFT
    const int button_e = 6;  // RIGHT
    const int invert_buttons = 1;    // invert buttons
    // switch debounce
    #define DEBOUNCE_TIME 10    // Default 20
    #define LONG_TIME 250       // Default 500
    long a_wait_timer;
    long b_wait_timer;
    long c_wait_timer;
    long d_wait_timer;
    long e_wait_timer;
    long a_wait_timer2;
    long b_wait_timer2;
    long c_wait_timer2;
    long d_wait_timer2;
    long e_wait_timer2;
    byte min_state;
    byte max_state;
    byte a_state;
    byte b_state;
    byte c_state;
    byte d_state;
    byte e_state;
    byte a_state2;
    byte b_state2;
    byte c_state2;
    byte d_state2;
    byte e_state2;
    bool a_state_ack;
    bool b_state_ack;
    bool c_state_ack;
    bool d_state_ack;
    bool e_state_ack;
    bool a_state_ack2;
    bool b_state_ack2;
    bool c_state_ack2;
    bool d_state_ack2;
    bool e_state_ack2;
    // stepper acceleration
    long current_delay = 2000;
    long current_step = 0;
    // configuration values
    struct config_t
      unsigned long coilSteps;
      bool coilInvert;
      unsigned long guideSteps;
      bool guideInvert;
      unsigned long wireSize;   // micrometers
      unsigned long coilDiam;   // micrometers
      unsigned long coilLength; // micrometers
      unsigned long coilTurns;
      unsigned long coilSpeed;
      bool coilCalc;
      float coilRatio;
      unsigned long coilHome;   // micrometers
    } conf;
    // Connect via i2c, default address #0 (A0-A2 not jumpered)
    Adafruit_LiquidCrystal lcd(0);
      Serial.begin(BAUDRATE);
      pinMode(min_stop, INPUT);           // set pin to input
      digitalWrite(min_stop, HIGH);       // turn on pullup resistors
      pinMode(max_stop, INPUT);           // set pin to input
      digitalWrite(max_stop, HIGH);       // turn on pullup resistors
      pinMode(led, OUTPUT);               // set pin to output
      pinMode(button_a, INPUT);           // set pin to input
      digitalWrite(button_a, HIGH);       // turn on pullup resistors
      pinMode(button_b, INPUT);           // set pin to input
      digitalWrite(button_b, HIGH);       // turn on pullup resistors
      pinMode(button_c, INPUT);           // set pin to input
      digitalWrite(button_c, HIGH);       // turn on pullup resistors
      pinMode(button_d, INPUT);           // set pin to input
      digitalWrite(button_d, HIGH);       // turn on pullup resistors
      pinMode(button_e, INPUT);           // set pin to input
      digitalWrite(button_e, HIGH);       // turn on pullup resistors
      pinMode(stepper_a_enable, OUTPUT);
      pinMode(stepper_a_direction, OUTPUT);
      pinMode(stepper_a_step, OUTPUT);
      pinMode(stepper_b_enable, OUTPUT);
      pinMode(stepper_b_direction, OUTPUT);
      pinMode(stepper_b_step, OUTPUT);
      digitalWrite(stepper_a_enable, HIGH);      // HIGH = disabled
      digitalWrite(stepper_a_direction, HIGH);  // HIGH = forward
      digitalWrite(stepper_a_step, LOW);
      digitalWrite(stepper_b_enable, HIGH);      // HIGH = disabled
      digitalWrite(stepper_b_direction, HIGH);  // HIGH = forward
      digitalWrite(stepper_b_step, LOW);
      // set up the LCD's number of rows and columns:
      lcd.begin(20, 4);
      // define menu structure
      mm.add_menu(&manual);
      manual.add_item(&manual_stepper, &menu_stepper_enable);
      manual.add_item(&manual_jogcoil, &menu_jog_coil);
      manual.add_item(&manual_jogguide, &menu_jog_guide);
      mm.add_menu(&settings);
      settings.add_item(&settings_coilsteps, &menu_settings_coilsteps);
      settings.add_item(&settings_coilinvert, &menu_settings_coilinvert);
      settings.add_item(&settings_guidesteps, &menu_settings_guidesteps);
      settings.add_item(&settings_guideinvert, &menu_settings_guideinvert);
      settings.add_item(&settings_coilhome, &menu_job_coilhome);
      settings.add_item(&settings_home, &menu_home_guide);
      mm.add_menu(&job);
      job.add_item(&job_help, &menu_job_help);
      job.add_item(&job_wiredia, &menu_job_wiredia);
      job.add_item(&job_coildia, &menu_job_coildia);
      job.add_item(&job_coilhome, &menu_job_coilhome);
      job.add_item(&job_coilcalc, &menu_job_calc);
      job.add_item(&job_coilratio, &menu_job_ratio);
      job.add_item(&job_length, &menu_job_length);
      job.add_item(&job_turns, &menu_job_turns);
      job.add_item(&job_speed, &menu_job_speed);
      job.add_item(&job_home, &menu_home_guide);
      job.add_item(&job_start, &menu_job_start);
      mm.add_item(&job_start, &menu_job_start);
      ms.set_root_menu(&mm);
      lcd.setBacklight(LOW);
      lcd.setBacklight(HIGH);
      // Print a message to the lcd.
      lcd.clear();
      String LCDScroll = "                   Project Icarus      ";
      for (int i = 0 ; i < 20 ; i++)
        lcd.setCursor(0, 0);
        lcd.print(LCDScroll.substring(i, i + 20));
        delay(75);
      // read eeprom settings
      eeprom_read_block((void*)&conf, (void*)0, sizeof(conf));
      // set to initial sane values and save
      conf.coilSteps = 6400;    // 400 steps/rev * 16th steps
      conf.coilInvert = 1;
      conf.guideSteps = 800;    // 400 steps/rev * 16th steps
      conf.guideInvert = 1;
      conf.wireSize = 141;      // micrometers
      conf.coilDiam = 108712;   // micrometers
      conf.coilLength = 228600; // micrometers
      conf.coilTurns = 814;
      conf.coilSpeed = 100;
      conf.coilCalc = 1;
      conf.coilRatio = 5.00;
      conf.coilHome = 7000;    // micrometers
      eeprom_write_block((const void*)&conf, (void*)0, sizeof(conf));
      delay(1500);
      lcd.clear();
      delay(160);
      displayMenu();
      check_buttons();
      if (a_state && !a_state_ack)
        // center
        a_state_ack = 1;
        ms.select(0);
        displayMenu();
      if (b_state && !b_state_ack)
        // down
        b_state_ack = 1;
        ms.next();
        displayMenu();
      if (c_state && !c_state_ack)
        // up
        c_state_ack = 1;
        ms.prev();
        displayMenu();
      if (d_state && !d_state_ack)
        // left
        d_state_ack = 1;
        ms.back();
        displayMenu();
      delay(10);               // wait Default 1000
    void check_buttons()
      // end stop code
      min_state = digitalRead(min_stop);
      max_state = digitalRead(max_stop);
      // button debounce code
      int a_read = invert_buttons ^ digitalRead(button_a);
      if (a_read == a_state)
        a_wait_timer = millis();
      else if (a_read != a_state and (millis() - a_wait_timer) > DEBOUNCE_TIME)
        a_state = a_read;
        a_state_ack = 0;
      if (a_read == a_state2)
        a_wait_timer2 = millis();
      else if (a_read != a_state2 and (millis() - a_wait_timer2) > LONG_TIME)
        a_state2 = a_read;
        a_state_ack2 = 0;
      int b_read = invert_buttons ^ digitalRead(button_b);
      if (b_read == b_state)
        b_wait_timer = millis();
      else if (b_read != b_state and (millis() - b_wait_timer) > DEBOUNCE_TIME)
        b_state = b_read;
        b_state_ack = 0;
      if (b_read == b_state2)
        b_wait_timer2 = millis();
      else if (b_read != b_state2 and (millis() - b_wait_timer2) > LONG_TIME)
        b_state2 = b_read;
        b_state_ack2 = 0;
      int c_read = invert_buttons ^ digitalRead(button_c);
      if (c_read == c_state)
        c_wait_timer = millis();
      else if (c_read != c_state and (millis() - c_wait_timer) > DEBOUNCE_TIME)
        c_state = c_read;
        c_state_ack = 0;
      if (c_read == c_state2)
        c_wait_timer2 = millis();
      else if (c_read != c_state2 and (millis() - c_wait_timer2) > LONG_TIME)
        c_state2 = c_read;
        c_state_ack2 = 0;
      int d_read = invert_buttons ^ digitalRead(button_d);
      if (d_read == d_state)
        d_wait_timer = millis();
      else if (d_read != d_state and (millis() - d_wait_timer) > DEBOUNCE_TIME)
        d_state = d_read;
        d_state_ack = 0;
      int e_read = invert_buttons ^ digitalRead(button_e);
      if (e_read == e_state)
        e_wait_timer = millis();
      else if (e_read != e_state and (millis() - e_wait_timer) > DEBOUNCE_TIME)
        e_state = e_read;
        e_state_ack = 0;
    void menu_stepper_enable(MenuItem* p_menu_item)
      stepper_enable(1 ^ (stepper_a_ena & 1));
    void stepper_enable(byte enable)
        options
        0 = turn off and save
        1 = turn on and save
        3 = turn off
        4 = turn on
        5 = revert to saved
        bits
        1 = operating state
        2 = saved state
        Set bit
        number |= 1 << x;
        Clear bit
        number &= ~(1 << x);
        Toggle bit
        number ^= 1 << x;
        Check bit
        bit = number & (1 << x);
      if (enable == 0)
        // set and save bit 1 and 2
        stepper_a_ena = 0;
      else if (enable == 1)
        stepper_a_ena = 3;
      else if (enable == 3)
        // turn off 1 bit
        stepper_a_ena &= ~(1 << 0);
      else if (enable == 4)
        // turn on 1 bit
        stepper_a_ena |= 1 << 0;
      else if (enable == 5)
        byte stepper_saved = stepper_a_ena & 2;
        if (stepper_saved)
      if (stepper_a_ena & 1)
        // enable steppers
        digitalWrite(led, HIGH);
        digitalWrite(stepper_a_enable, LOW);      // HIGH = disabled
        digitalWrite(stepper_b_enable, LOW);      // HIGH = disabled
      else if (!stepper_a_ena & 1)
        // disable steppers
        digitalWrite(led, LOW);
    void displayMenu()
      // Display the menu
      Menu const* cp_menu = ms.get_current_menu();
      //lcd.print("Current menu name: ");
      lcd.print(cp_menu->get_name());
      lcd.setCursor(0, 1);
      MenuComponent const* cp_menu_sel = cp_menu->get_selected();
      int menu_components = cp_menu->get_num_menu_components();
      int current_item = cp_menu->get_cur_menu_component_num();
      // calculate start and end items
      int start = current_item - 1;
      if (start < 0)
        start = 0;
      if (start + 3 > menu_components)
        start = menu_components - 3;
      int max_item = start + 3;
      if (max_item > menu_components)
        max_item = menu_components;
      line = 1;
      for (int i = start; i < max_item; ++i)
        lcd.setCursor(0, line);
        MenuComponent const* cp_m_comp = cp_menu->get_menu_component(i);
        if (cp_menu_sel == cp_m_comp)
          lcd.print(">");
          cursor_line = line;
          lcd.print(" ");
        lcd.print(cp_m_comp->get_name());
        // display setting information
        if (cp_m_comp->get_name() == ENABLE)
          print_bool(stepper_a_ena & 1);
        else if (cp_m_comp->get_name() == COIL_STEPS)
          print_long(conf.coilSteps);
        else if (cp_m_comp->get_name() == COIL_INV)
          print_bool(conf.coilInvert);
        else if (cp_m_comp->get_name() == GUIDE_INV)
          print_bool(conf.guideInvert);
        else if (cp_m_comp->get_name() == GUIDE_STEPS)
          print_long(conf.guideSteps);
        else if (cp_m_comp->get_name() == WIRE_SIZE)
          print_long(conf.wireSize);
        else if (cp_m_comp->get_name() == COIL_DIAM)
          print_long(conf.coilDiam);
        else if (cp_m_comp->get_name() == COIL_HOME)
          print_long(conf.coilHome);
        else if (cp_m_comp->get_name() == COIL_CALC)
          print_bool(conf.coilCalc);
        else if (cp_m_comp->get_name() == COIL_RATIO)
          print_float(conf.coilRatio);
        else if (cp_m_comp->get_name() == COIL_LEN)
          print_long(conf.coilLength);
        else if (cp_m_comp->get_name() == COIL_TURNS)
          print_long(conf.coilTurns);
        else if (cp_m_comp->get_name() == COIL_SPEED)
          print_long(conf.coilSpeed);
        line++;
    void print_bool(bool bool_val)
      lcd.setCursor(17, line);
      if (bool_val)
        lcd.print("Yes");
        lcd.print(" No");
    void print_long(long long_val)
      char buf[16];
      ltoa(long_val, buf, 10);  // 10 is the base value not the size - look up ltoa for avr
      lcd.setCursor(20 - strlen(buf), line);
      lcd.print(buf);
    void print_float(float float_val)
      char buf[16];
      //ltoa(float_val, buf, 10);  // 10 is the base value not the size - look up ltoa for avr
      dtostrf(float_val, 4, 2, buf);
      lcd.print(buf);
    long edit_long(long long_val)
      long incr = 1;
      byte incr_count = 0;
      long saved_long_val = long_val;
      char buf[16];
      line = cursor_line;
      lcd.print(" ");
      lcd.setCursor(18 - strlen(buf), cursor_line);
      lcd.print(" >");
      while (1)
        check_buttons();
          // center
          a_state_ack = 1;
        if (b_state2 && !b_state_ack2)
          incr_count++;
          if (incr_count > 8)
            incr = incr * 10;
            incr_count = 0;
          if (long_val > incr)
            long_val = long_val - incr;
            lcd.setCursor(19 - strlen(buf), cursor_line);
            for (int i = 0; i <= strlen(buf); i++)
              lcd.print(" ");
            long_val = 0;
          b_state2 = 0;
          b_state_ack2 = 1;
          lcd.print(" >");
          print_long(long_val);
        if (b_state == 2 && !b_state_ack)
          if (long_val > 10)
            long_val = long_val - 10;
              lcd.print(" ");
            long_val = 0;
          b_state_ack = 1;
          lcd.print(" >");
          // down
          if (long_val > 0)
            long_val--;
          b_state_ack = 1;
          incr = 1;
          incr_count = 0;
          lcd.print(" >");
        if (c_state2 && !c_state_ack2)
          incr_count++;
          if (incr_count > 8)
            incr = incr * 10;
            incr_count = 0;
          long_val = long_val + incr;
          c_state2 = 0;
          c_state_ack2 = 1;
          lcd.print(" >");
          // up
          long_val++;
          c_state_ack = 1;
          incr = 1;
          incr_count = 0;
          lcd.print(" >");
          // left
          d_state_ack = 1;
          long_val = saved_long_val;
      return long_val;
    float edit_float(float float_val)
      float incr = .01;
      float saved_float_val = float_val;
      char buf[16];
      line = cursor_line;
      // ltoa(float_val, buf, 10);  // 10 is the base value not the size - look up ltoa for avr
      lcd.print(" ");
      lcd.print(" >");
      while (1)
        check_buttons();
          // center
          a_state_ack = 1;
          incr_count++;
          if (incr_count > 8)
            incr = incr * 10;
            incr_count = 0;
          if (float_val > incr)
            float_val = float_val - incr;
              lcd.print(" ");
            float_val = 0;
          b_state2 = 0;
          b_state_ack2 = 1;
          lcd.print(" >");
          print_float(float_val);
          if (float_val > 10)
            float_val = float_val - 10;
              lcd.print(" ");
            float_val = 0;
          b_state_ack = 1;
          lcd.print(" >");
          // down
          incr = .01;
          incr_count = 0;
          if (float_val > 0)
          b_state_ack = 1;
          lcd.print(" >");
          incr_count++;
          if (incr_count > 8)
            incr = incr * 10;
            incr_count = 0;
          float_val = float_val + incr;
          c_state2 = 0;
          c_state_ack2 = 1;
          lcd.print(" >");
          // up
          c_state_ack = 1;
          incr = .01;
          incr_count = 0;
          lcd.print(" >");
          // left
          d_state_ack = 1;
          float_val = saved_float_val;
      return float_val;
    void delay_step(long steps, int max_delay_time, int delay_time, int step_amount, byte accel_mode)
      long accel_steps = (max_delay_time - delay_time) / step_amount;
      accel_steps = abs(accel_steps);
      if (current_step == 0)
        current_delay = max_delay_time;
      else if (current_step > (steps - accel_steps) and accel_mode & 1)
        // decel
        if (current_delay < max_delay_time)
          current_delay = current_delay + step_amount;
      else if (current_delay > delay_time and accel_mode & 2)
        current_delay = current_delay - step_amount;
      else if (current_delay < delay_time)
      delayMicroseconds(current_delay);
      current_step++;
    void menu_jog_coil(MenuItem* p_menu_item)
      byte jog_mode = 0;
      byte jog_dir = 0;
      byte jog_run = 0;
      long jog_speed = conf.coilSpeed;
      lcd.clear();
      lcd.print("Jog coil");
      line = 0;
      print_long(jog_speed);
      lcd.setCursor(10, 0);
      lcd.print("  Man");
      lcd.setCursor(7, 1);
      lcd.print("^");
      lcd.print(" Fwd");
      lcd.setCursor(0, 2);
      lcd.print("Back < ");
      lcd.write(219);
      lcd.print(" Mode  >");
      lcd.setCursor(7, 3);
      lcd.print("v Rev   Stop");
      while (1)
        check_buttons();
          // left
          d_state_ack = 1;
          lcd.clear();
        else if (a_state && !a_state_ack)
          // center
          a_state_ack = 1;
          jog_mode++;
          if (jog_mode > 2)
            jog_mode = 0;
          lcd.setCursor(12, 0);
          if (jog_mode == 0)
            lcd.print("Man ");
          else if (jog_mode == 1)
            lcd.print("Cont");
          else if (jog_mode == 2)
            lcd.print("Fixd");
        else if (e_state && !e_state_ack)
          // left
          e_state_ack = 1;
          lcd.print(" ");
          jog_run = 0;
        if (jog_mode == 0)
          jog_run = 0;
          // Manual
          if (c_state)
            stepper_enable(4);
            c_state_ack = 1;
            lcd.print("F");
            jog_dir = 1;
            digitalWrite(stepper_b_direction, conf.coilInvert ^ jog_dir);  // HIGH = forward
            current_step = 0;
            while (c_state)
              check_buttons();
              delayMicroseconds(20);      // Set delay to match motor driver specs
              digitalWrite(stepper_b_step, HIGH);
              delay_step(conf.guideSteps, 2005, 385, 10, 2);
            current_step = 1;
            while (current_delay < 2000)
              delay_step(82, 2005, 385, 20, 1);
            lcd.print(" ");
            stepper_enable(5);
          if (b_state)
            stepper_enable(4);
            b_state_ack = 1;
            lcd.print("R");
            jog_dir = 0;
            current_step = 0;
            while (b_state)
              check_buttons();
              delay_step(conf.coilSteps, 2005, 385, 10, 2);
            current_step = 1;
            lcd.print(" ");
            stepper_enable(5);
          // Continuous
          if (!c_state_ack and c_state and (!jog_run or (jog_run and !jog_dir)))
            c_state_ack = 1;
            lcd.print("F");
            jog_dir = 1;
            jog_run = 1;
            current_step = 0;
            stepper_enable(4);
          else if (!c_state_ack and c_state and jog_run)
            c_state_ack = 1;
            lcd.print(" ");
            jog_run = 0;
          if (!b_state_ack and b_state and (!jog_run or (jog_run and jog_dir)))
            b_state_ack = 1;
            lcd.print("R");
            jog_dir = 0;
            jog_run = 1;
            current_step = 0;
            stepper_enable(4);
          else if (!b_state_ack and b_state and jog_run)
            b_state_ack = 1;
            lcd.print(" ");
            jog_run = 0;
          if (jog_run)
            current_step = 1;
            stepper_enable(5);
          // Fixed
          jog_run = 0;
            c_state_ack = 1;
            lcd.print("F");
            jog_dir = 1;
            jog_run = 1;
            stepper_enable(4);
            c_state_ack = 1;
            lcd.print(" ");
            jog_run = 0;
            b_state_ack = 1;
            lcd.print("R");
            jog_dir = 0;
            jog_run = 1;
            stepper_enable(4);
            b_state_ack = 1;
            lcd.print(" ");
            jog_run = 0;
          if (jog_run)
            current_step = 0;
            for (long i = 0 ; i < conf.coilSteps ; i++)
              check_buttons();
                // left
                e_state_ack = 1;
                lcd.print(" ");
                jog_run = 0;
              delay_step(conf.coilSteps, 2000, 385, 5, 3);
            jog_run = 0;
            lcd.print(" ");
            stepper_enable(5);
    void menu_jog_guide(MenuItem* p_menu_item)
      byte jog_mode = 0;
      byte jog_dir = 0;
      byte jog_run = 0;
      lcd.clear();
      lcd.print("Jog guide");
      line = 0;
      lcd.print("  Man");
      lcd.print("^");
      lcd.print(" Fwd");
      lcd.write(219);
      while (1)
        check_buttons();
          // left
          d_state_ack = 1;
          lcd.clear();
          // center
          a_state_ack = 1;
          jog_mode++;
          if (jog_mode > 2)
            jog_mode = 0;
          if (jog_mode == 0)
            lcd.print("Man ");
            lcd.print("Cont");
            lcd.print("Fixd");
          // left
          e_state_ack = 1;
          lcd.print(" ");
          jog_run = 0;
        if (jog_mode == 0)
          jog_run = 0;
          // Manual
          if (c_state && max_state)
            c_state_ack = 1;
            lcd.print("F");
            jog_dir = 1;
            stepper_enable(4);
            digitalWrite(stepper_a_direction, conf.guideInvert ^ jog_dir);  // HIGH = forward
            current_step = 0;
            while (c_state && max_state)
              check_buttons();
              digitalWrite(stepper_a_step, HIGH);
            if (max_state)
              current_step = 1;
              stepper_enable(5);
              jog_run = 0;
            lcd.print(" ");
          if (b_state && min_state)
            b_state_ack = 1;
            lcd.print("R");
            jog_dir = 0;
            stepper_enable(4);
            current_step = 0;
            while (b_state && min_state)
              check_buttons();
            if (min_state)
              current_step = 1;
              stepper_enable(5);
              jog_run = 0;
            lcd.print(" ");
          // Continuous
            c_state_ack = 1;
            lcd.print("F");
            jog_dir = 1;
            jog_run = 1;
            current_step = 0;
            stepper_enable(4);
            c_state_ack = 1;
            lcd.print(" ");
            jog_run = 0;
            b_state_ack = 1;
            lcd.print("R");
            jog_dir = 0;
            jog_run = 1;
            current_step = 0;
            stepper_enable(4);
            b_state_ack = 1;
            lcd.print(" ");
            jog_run = 0;
          if (jog_run && min_state && max_state)
          else if (!min_state || !max_state)
            // stop immediately
            jog_run = 0;
            current_step = 1;
            stepper_enable(5);
          // Fixed
          jog_run = 0;
            c_state_ack = 1;
            lcd.print("F");
            jog_dir = 1;
            jog_run = 1;
            stepper_enable(4);
            c_state_ack = 1;
            lcd.print(" ");
            jog_run = 0;
            b_state_ack = 1;
            lcd.print("R");
            jog_dir = 0;
            jog_run = 1;
            stepper_enable(4);
            b_state_ack = 1;
            lcd.print(" ");
            jog_run = 0;
          if (jog_run && ((!jog_dir && min_state) || (jog_dir && max_state)))
            current_step = 0;
            for (long i = 0 ; i < conf.guideSteps ; i++)
              check_buttons();
              if ((e_state && !e_state_ack) || (!jog_dir && !min_state) || (jog_dir && !max_state))
                // left
                e_state_ack = 1;
                lcd.print(" ");
                jog_run = 0;
              delay_step(conf.guideSteps, 1000, 385, 5, 3);
            jog_run = 0;
            lcd.print(" ");
            stepper_enable(5);
    void menu_settings_coilsteps(MenuItem* p_menu_item)
      conf.coilSteps = edit_long(conf.coilSteps);
    void menu_settings_coilinvert(MenuItem* p_menu_item)
      conf.coilInvert = conf.coilInvert ^ 1;
    void menu_settings_guidesteps(MenuItem* p_menu_item)
      conf.guideSteps = edit_long(conf.guideSteps);
    void menu_settings_guideinvert(MenuItem* p_menu_item)
      conf.guideInvert = conf.guideInvert ^ 1;
    void menu_home_guide(MenuItem* p_menu_item)
      // home guide
      lcd.setCursor(0, 3);
      lcd.print("Homing Guide        ");
      current_step = 0;
      stepper_enable(4);
      digitalWrite(stepper_a_direction, conf.guideInvert ^ 0);  // HIGH = forward
      while (min_state)
        check_buttons();
        if ((e_state && !e_state_ack) || (!min_state) || (!max_state))
          // left
          e_state_ack = 1;
      digitalWrite(stepper_a_direction, conf.guideInvert ^ 1);  // HIGH = forward
      unsigned long total_steps = conf.coilHome * conf.guideSteps / 1000;
      current_step = 0;
      for (unsigned long i = 0 ; i < total_steps ; i++)
        check_buttons();
        if ((e_state && !e_state_ack) || !max_state)
          // left
          e_state_ack = 1;
        delay_step(total_steps, 1000, 385, 5, 3);
      stepper_enable(5);
      lcd.print("              ");
    void menu_job_wiredia(MenuItem* p_menu_item)
      conf.wireSize = edit_long(conf.wireSize);
      calc_coil(0);
    void menu_job_help(MenuItem* p_menu_item)
    void menu_job_coildia(MenuItem* p_menu_item)
      conf.coilDiam = edit_long(conf.coilDiam);
      calc_coil(0);
    void menu_job_coilhome(MenuItem* p_menu_item)
      conf.coilHome = edit_long(conf.coilHome);
    void menu_job_length(MenuItem* p_menu_item)
      conf.coilLength = edit_long(conf.coilLength);
      calc_coil(1);
    void menu_job_turns(MenuItem* p_menu_item)
      conf.coilTurns = edit_long(conf.coilTurns);
      calc_coil(2);
    void menu_job_speed(MenuItem* p_menu_item)
      conf.coilSpeed = edit_long(conf.coilSpeed);
    void menu_job_calc(MenuItem* p_menu_item)
      conf.coilCalc = conf.coilCalc ^ 1;
      calc_coil(0);
    void menu_job_ratio(MenuItem* p_menu_item)
      conf.coilRatio = edit_float(conf.coilRatio);
      calc_coil(0);
    void calc_coil(byte calc_type)
      // calculate the coil size based on secondary diameter, ratio, and wire size
      if (conf.coilCalc)
        if (calc_type == 0)
          // using wire diam, coil diam, and ratio
          conf.coilLength = conf.coilDiam * conf.coilRatio;
          conf.coilTurns = conf.coilLength / conf.wireSize;
        else if (calc_type == 1)
          // using wire diam, coil diam, and lenght
          float i = (float) (conf.coilLength / conf.coilDiam) * 100 + 0.5;
          conf.coilRatio = i / 100;
        else if (calc_type == 2)
          // using wire diam, coil diam, and turns
          conf.coilLength = conf.coilTurns * conf.wireSize;
    void menu_job_start(MenuItem* p_menu_item)
      // Coil Winding Subroutine
      int max_speed = 200;   // Fast
      int min_speed = 800;  // Slow
      int set_speed = 800;   // Current Speed
      int saved_set_speed = set_speed;
      byte pause = 0;
      long guide_steps = 0;
      char buf[16];
      ltoa(conf.coilTurns, buf, 10);  // 10 is the base value not the size - look up ltoa for avr
      int len_buf = strlen(buf);
      char buf2[16];
      lcd.clear();
      lcd.print("Winding");
      lcd.print("Total Turns:");
      lcd.print("[] Pause  > Stop");
      byte end_job = 0;
      current_step = 0;
      ltoa(0, buf2, 10);  // 10 is the base value not the size - look up ltoa for avr
      lcd.setCursor(13, 1);
      //  lcd.print(buf2);
      //  lcd.setCursor(11 + len_buf, 1);
      //  lcd.print("/");
      lcd.print(buf);
      if (!stepper_a_ena)
        stepper_enable(1);
      digitalWrite(stepper_b_direction, conf.coilInvert ^ 1);  // HIGH = forward
      // calculate our loop value
      unsigned long coil_steps = (conf.wireSize * conf.guideSteps) / 1000; // use guide steps for coil
      unsigned long total_coil_steps = conf.coilSteps * conf.coilTurns; // use guide steps for coil
      unsigned long loop_steps = conf.coilSteps * guide_steps;
      unsigned long loop_counter = 0;
      unsigned long guide_counter = 0;
      unsigned long coil_counter = 0;
      unsigned long foo_counter = 0;
      unsigned long winding_counter = 0;
      unsigned long intersections = 0;
      for (long x = 0 ; x < total_coil_steps ; x = x + conf.coilSteps)
        if (x % coil_steps)
          intersections++;
      total_coil_steps = total_coil_steps + (conf.coilTurns * conf.wireSize / 1000 * conf.guideSteps) - intersections - conf.coilSteps;
      while (winding_counter < conf.coilTurns)
        loop_counter++;
        guide_counter++;
        coil_counter++;
        int delaynow = 0;
        if (guide_counter >= conf.coilSteps)
          delaynow = 1;
        if (coil_counter >= coil_steps)
          delaynow = 1;
        if (delaynow)
          delayMicroseconds(max_speed);
          guide_counter = 0;
          // check input
          check_buttons();
            // left - stop
            e_state_ack = 1;
            // left - pause
            a_state_ack = 1;
            // Timing is very crucial when you are running stepper and want a smooth speed,
            // so much of the informational LCD information is disabled while winding to prevent
            // undesired micro-stops
            //        lcd.setCursor(0,3);
            if (!pause)
              //          lcd.print("Paused");
              pause = 1;
              set_speed = min_speed;
              //          lcd.print("      ");
              pause = 0;
              set_speed = saved_set_speed;
          if (pause && current_delay == set_speed)
            while (1)
              check_buttons();
                // left - pause
                a_state_ack = 1;
                pause = 0;
              // left - stop
              e_state_ack = 1;
            // down
            b_state_ack = 1;
            set_speed = set_speed * 2;
            if (set_speed > min_speed)
            lcd.print(set_speed);
            // up
            c_state_ack = 1;
            set_speed = set_speed / 2;
            if (set_speed < max_speed)
              set_speed = max_speed;
          coil_counter = 0;
          foo_counter++;
          if (foo_counter >= conf.coilSteps)
            foo_counter = 0;
            winding_counter++;
        if (delaynow)
          delay_step(total_coil_steps, min_speed, set_speed, 5, 3);
      lcd.clear();
      lcd.print("     Complete");
      lcd.print("< Return");
      while (1)
        check_buttons();
          // left - stop
          d_state_ack = 1;
      stepper_enable(0);
    void print_status(long turn_number)
         this function largely abandoned due to it taking too
        much time.  I'm sure the code could be rewritten to be
        a bit more efficient about things, but we're not there
        just yet.
          12345678901234567890
         [Winding         65% ]
         [     Turn:   345/814]
         [ Position:    234234]
         [   Meters:     12345]
      char buf[16];
      char buf2[16];
    Attached Files Attached Files
    Feb 2014
    Colmar, France
    1,592
    Oh hell, please edit your post and put code tags around your code. (Select the code from beginning to the end with the mouse and then click the # in the editor toolbar.
    Mar 2017
    11
    Thank you very much!
