Results 1 to 6 of 6
Thread: No COM port
    Dec 2017
    Ohio
    12
    No COM port
    I've just installed the Beta version of Teensyduino 1.41 with the Teensy 3.5. I'm using Win 7 and Rel. 1.8.5 of the Arduino IDE. It appears that the installation of the Teensyduino software was successful, as I can see them listed in the Boards section of the IDE. My problem is that there is no COM port list and that menu Option is greyed out. I am also getting this error message:
    Archiving built core (caching) in: C:\Users\econjack\AppData\Local\Temp\arduino_cache _769301\core\core_teensy_avr_teensy35_usb_serial,s peed_120,opt_o2std,keys_en-us_3e0515dfaad153553690f968527624f2.a
    exec: "E:\\Arduino1.8.5\\hardware\\teensy/../tools/teensy_post_compile": file does not exist
    Error compiling for board Teensy 3.5.
    The IDE is installed on my E drive in a root directory named Arduino1.8.5. If I switch away from the Teensy and connect a Mega 2560 Pro Mini and select it from the Board menu option, the Port option allows me to select, compile, upload, and run a program. I've read a number of posts on this subject, but none seem to have made any difference.
    Feb 2014
    Colmar, France
    1,461
    First, wasn’t there an additional serial driver to install to fix a problem in Win7? Second, the compiler complains about a missing file. Thus, something went obviously wrong with your Teensyduino installation (which could also explain the missing serial patch). Do you run antivirus software? If yes, my guess is that is has quarantined some Teensyduino files by mistake. Deactivate the antivirus and do again a Teensyduino install over the existing one to add the missing stuff.
    Dec 2017
    Ohio
    12
    I'm not sure about the serial driver, but my Driver Manager says the driver is up to date. I do have antivirus software running, so I turn that off, reinstall and see what happens.
    Merci! Thanks for pointing in the right direction!
    Dec 2017
    Ohio
    12
    I did as you suggested and a COM port was available. I wrote a short program:
      Serial.println("Hello World");
    and it compiled and ran it, but with no output! I moved the println() call to loop(), and it works as expected. It this because the Teensy is so much faster than the stock Arduinos that the Serial port isn't available until after the call is processed?
    3,432
    note: the teensy is a lot faster than most old boards like Arduino UNO and the USB serial is handled differently than an UNO. The Uno has a different chip that does the USB stuff which then talks to a hardware serial port on the AVR processor. On the Teensy (like the Arduino Leonardo) the USB is handled by the processor chip...
    So your host board will take awhile to initialize it's serial port for when a new device arrives. So you typically either need to wait a bit before you output text or see if the Serial port is valid.
    So for programs like this, I will often do the code something like:
      while (!Serial && (millis() < 2000)) ;
    The while loop I put at the start will wait up to 2 seconds for the Serial port to be created and detected before it tries to output to the USB
    Dec 2017
    Ohio
    12
    I have seen code similar to that for the Due.
    Thanks, Kurt.
