Results 1 to 8 of 8
Thread: Teensy 3.5 Can + FreqMesure Problem
    Jan 2018
    4
    I'm working on a digital dashboard project for Mega Squirt. I'm using Pins 3 and 4 for Communicating with Megasquit. I also want to read a frequency but ıt defines the FreqMesure pin as 3. Is there any chance for me to use another pin for measuring frequency? FreqCount pin is 13 can I use it for Freqmesure?
    Regards
    18,687
    Yes, you can use other pins. Just edit util/FreqMeasureCapture.h. Comment out the config for pin 3 and uncomment one of the others you'd prefer to use. Read the comments in that file for info.
    Jan 2018
    4
    Thank you for your response. Can I measure multiple frequencies at the same time?
    Sorry I can't answer your question, but I'm doing exactly the same thing at the moment as well :-) I don't suppose you have any updates or pics on what you are doing? (Check my recent post here for the latest update on mine)
    Cheers - N
    Sorry, my mistake - I posted the update on the MSextra forums - http://www.msextra.com/forums/viewto...?f=101&t=68046
    Cheers - N
    18,687
    Quote Originally Posted by 35cmd35 View Post
    https://github.com/PaulStoffregen/FreqMeasureMulti
    Jan 2018
    4
    Thank you very much Paul
    Jan 2018
    4
    I'm just tinkering now I will share it when I have some progress...
