Results 1 to 3 of 3
Thread: Transferring data from SD card on Teensy 3.6 without removing it from the SD port
    Sep 2017
    11
    I am working on a project where I will be writing data from analog pins to a micro SD card on the Teensy 3.6 and the Teensy will be powered by an external battery. In between tests I would like to remove the log file from the SD card without removing the card to plug it into my PC. This may be obvious, but is there any way to do this? Is it possible to transfer data by plugging in a laptop to the micro USB port or is this only for charging? Thanks in advance!
    Greg
    Senior Member pictographer's Avatar
    May 2013
    San Jose, CA
    633
    USB Serial is the simplest. Add a command line interface to your program (sketch). When a command is sent to the Teensy, it responds by printing the contents of the sd card. On the PC, either use a terminal program that does logging or write a program/script that writes to and reads from the USB serial port connected to the Teensy.
    Last edited by pictographer; 01-02-2018 at 10:17 PM. Reason: removed an extra word
    Sep 2017
    11
    Awesome, thanks pictographer!
