Teensy 3.1 on Linux
I have an older board, 3.1, that I want to use as an I2C device for a project. All of the project is in Linux so I figured I would see if I could use the arduino and teensy IDE on linux.
I can't find the board to set in the IDE, all of the boards are Arduino with Teensy? The web page mentions an install but all I did was extract the files from the archive. Is there something I didn't see to find the right board files?
After you install Arduino, the easiest approach is to run the Teensyduino installer. See instructions here.
Sorry, I must be tired. I know I had to install the teensyduino on my windows machine. When I did the search it took me to a place that only dealt with the loader. I went back and installed it correctly and it all works great now. Thanks.
Glad it's working for you now!
- You may not post replies
- You may not edit your posts
Forum Rules
