New project code named: teensquitto
New additions & changes to the library for teensy:
* EEPROM support added
* WiFi, ESP, and SPIFFS classes are no longer called via constructor, they are preloaded by the library so you have access to them immediately in your sketch.
* AsyncUDP added, pre-constructed as above as "udp", user has the ability to create messages from AsyncUDPMessage class as well as receive callbacks using the original lambda library methods!
As an example, the AsyncUDP library by nomedev located at https://github.com/me-no-dev/ESPAsyncUDP/blob/master/examples/AsyncUDPServer/AsyncUDPServer.ino, everything BELOW the *AsyncUDP udp;* should compile on teensy now.
The library has both the "Udp" (WiFiUdp.H) and "udp" (AsyncUDP) classes and methods ready to use, so choose your poison :)
I also kept the AsyncUDP in a separate h/cpp file located in the library folder, and the teensquitto library and AsyncUDP talk to each other as needed over scope calls to access data as needed.
This video shows teensy as a sender only, not listening, which can be seen in Packet Sender app.
https://www.youtube.com/watch?v=tZa6ZK_ISHc
This video shows both MQTT working at sending & receiving, as well as sending & receiving UDP packets from teensy and Packet Sender
https://www.youtube.com/watch?v=jO6GUNfn8dY
This video shows a short log snippet of the packetsender window
https://www.youtube.com/watch?v=p4fcdjh8qqA
this is a demo sketch i ran using a AsyncUDP example modified just a little bit, works on teensy fine :)
#include <teensquitto.h>
teensquitto eep = teensquitto("EEPROM", &Serial1);
//#include <ESP8266WiFi.h>
//#include "ESPAsyncUDP.h"
const char * ssid = "Tony";
const char * password = "********";
//AsyncUDP udp;
  Serial1.begin(1000000);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
  if (WiFi.waitForConnectResult() != WL_CONNECTED) {
    Serial.println("WiFi Failed");
    while (1) {
  if (udp.listen(1234)) {
    Serial.print("UDP Listening on IP: ");
    Serial.println(WiFi.localIP());
    udp.onPacket([](AsyncUDPPacket packet) {
      Serial.print("UDP Packet Type: ");
      Serial.print(packet.isBroadcast() ? "Broadcast" : packet.isMulticast() ? "Multicast" : "Unicast");
      Serial.print(", From: ");
      Serial.print(packet.remoteIP());
      Serial.print(":");
      Serial.print(packet.remotePort());
      Serial.print(", To: ");
      Serial.print(packet.localIP());
      Serial.print(":");
      Serial.print(packet.localPort());
      Serial.print(", Length: ");
      Serial.print(packet.length());
      Serial.print(", Data: ");
      Serial.write(packet.data(), packet.length());
      //reply to the client
      packet.printf("Got %u bytes of data", packet.length());
  uint8_t moo[] = "Anyone here?";
  udp.writeTo(moo, sizeof(moo), IPAddress(192, 168, 2, 122), 64866);
Tony
Next up on the table is asynchronous websockets for teensy. according to their documentation, asynchronous support is only available on esp8266. yeah right!:) i already added transparent handlers to the library for async websocket library by Link2004, and teensy will soon have async websocket support for both server and client modes. both handlers are working on teensy ATM using original example sketch from Link2004’s repo, i just need to start adding the methods in this week
https://www.youtube.com/watch?v=5H4WNRGchdI
thats a video demonstrating the async server and client handlers working on teensy for websockets.
I also added WiFiMulti support as well.
Tony
Is that IOT coming to Teensy over Serial :)
That is much better than native "AT" command set on the ESP8266! How big is the ESP sketch?
Will be interesting to see it and samples published. Have you ever gotten a onehorse ESP unit - would be nice with its form fitted mounted Teensy footprint..
no hardware yet, im surprised i didnt burn out the flash on the huzzah reflashing it for every tests! :)
but yeah uart speeds are 1 megabaud rates with dynamic buffer and crc, the floods the other day went on overnight in the tests for mqtt on teensy, but the data doesnt seem to be lost over the protocol in all the tests, which is a plus!
i posted a few compiles a few posts ago, im around 45% storage with program and about same for memory on the esp, but on the teensy end, ~10% program & 4% memory, other than the ipaddress.h include on teensy side, it’s all just methods used to control the ESP, all the original libraries are on the ESP of course (esp core, async udp, asynctcp, async mqtt, async websockets, etc). also, since the websockets handlers are already implemented on teensy, they are triggered over uart and are non blocking as well, even if you care to sprinkle in a few delays(), none of the handlers should be affected as opposed to the originals. theres a very long list of methods in the library and they are shared and identified between classes to run different links on the esp, probably close to ~100 (im not home to check...), but i made it elegant to add functions as needed to link to the esp, in order to add more capability. but yeah AT is a joke right now when working on this, i havnt pushed more than 1 megabaud yet but is very stable, no flow control, no packet loss, no corruption, using Serial1 on the teensy 3.6.
even with the breakout board tho still need to mod it i think, the tx1 of the ESP is connected to teensy serial1, but rx0 is connected to teensy serial1, as i chose a dedicated uart for teensy so i could debug during my cross-mcu-code, looks like the one on tindie is “retired”
at the very least, the hope of this project will get people coding on the teensy side to take advantage of the ESP rather than keep running ESP-ONLY libraries over transparency, worst case is i could add defines in the ESP code that disables/enables the includes with their respective functions. a very good feature of the code is if the function doesnt exist, the packet is dropped, this prevents teensy from running unknown code locations on the ESP. at the moment this project has exceeded what i had anticipated it to be, and ive pushed the mqtt teensy controller aside for now as this project could be better benefit to that one later on. but the mqtt teensy controller will definately be a teensy side library, which will be hopefully one of many libraries to take advantage of the transparency in teensquitto
Tony
without a project in mind for it - but having worked with ESP a bit this seems like a good way to offload the net stuff to ESP to wait for and arrange - assuming those time taking tasks are the ones that come back async - but not have to write and run a second set of code for the ESP.
It looks like the only onehorse offering to fit Teensy today is this $17 ESP8285 variant that only has 1MB of internal flash [ and seems aimed for T_3.2's Serial2 and middle 3V3/GND for power - so not a direct T_3.6 fit.] - which limits OTA code size to < half of that and makes SPIFFS less useful - unless OTA is traded off to get a smaller SPIFFS space. With this code on the ESP OTA would be less important as it would be a 'static library' of function.
yeah, theres no second set of code running, think of it at a link-pointer if you will, where only original methods are called based on uart packet. the real bonus is having non blocking handlers in this type of setup, where the esp updates the teensy transparent handler and continues it’s tasks even if teensy is busy in its handler... i doubt i will use OTA anyways since the code onward would be written on teensy, not ESP, except if you would want to upgrade the ESP core in future (2.5?;) ), but that alone will give you additional patches, fixes, and wont affect this library in the process. the only way to break it is to change the way the methods are called, like i said, if they decide to change the methods in their libraries, it wont only affect this library, but everyone’s sketches using it. however, adapting it to new methods or adding new methods wont be an issue as long as you send the proper packet on teensy end and handle it in the switch statement on ESP end.
I also mention that all methods also return original values, whether you read them or not, i try to make it as transparent as possible, and the handler outputs on ESP end are only activated when you activate them on teensy end, this reduces extra stream that gets discarded if you didnt enable a handler. it even took me a week to figure out how to replicate the lambda function of asyncUDP library, that was a pain, but all the handlers done in the library run like the original on the ESP.
yeah, mostly its async except core functions and stock libraries, (WiFiUdp.h)
AsyncUDP (udp) by menodev
AsyncMQTT by marvin
Asyncwebsockets by Links2004
theyre all async, heck, i even added Async wifi scanning :) (asyncscannetworks?) im not sure what the command is im not home, but its the original call going to the async handler.
Async client & server websockets are done!
I setup 2 ESP's since the ESP can't do loopbacks of client&server
I setup a dummy ESP with ESP websocket server, then booted up teensy's ESP without handlers/websocketserver/client initialized, and started this on teensy:
      webSocketServer.begin(); webSocketServer.setAuthorization("tony", "teensy");
      webSocketClient.onEvent(webSocketEventClient);
      webSocketServer.onEvent(webSocketEventServer);
      webSocketClient.disconnect();
      webSocketClient.begin("192.168.2.55", 43110, "/");
      webSocketClient.setAuthorization("tony", "teensy");
      webSocketClient.setReconnectInterval(5000);
then in teensy loop i call this every few seconds:
webSocketClient.sendTXT("Hello Server!, from Tony!");
The dummy ESP responds from IP *.55 and replies back, which goes into the teensy client handler --> void webSocketEventClient(WStype_t type, uint8_t * payload, size_t length) {
[WSc] get text: SERVER: TEXT TO YOU
and from google chrome websocket client to teensy's websocket server IP *.168, i send:
teensy test
in the websocket handler (on teensy ) --> void webSocketEventServer(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
response:
[0] get Text: teensy test
clients & servers use authorization, which, as i mentioned, is set in teensy.
Tony
Demo Compile results for both ESP & Teensy:
Teensy:
Sketch uses 120920 bytes (11%) of program storage space. Maximum is 1048576 bytes.
Global variables use 9240 bytes (3%) of dynamic memory, leaving 252904 bytes for local variables. Maximum is 262144 bytes.
ESP:
Sketch uses 441592 bytes (42%) of program storage space. Maximum is 1044464 bytes.
Global variables use 42864 bytes (52%) of dynamic memory, leaving 39056 bytes for local variables. Maximum is 81920 bytes.
Note: max baud rate viewable for debug on teensy & esp is 2 megabaud, i bumped up the teensy and esp to 2megabaud rate and the communication so far is stable
ignore the byte packets, i have library debugging enabled while tweaking :)
2Megabaud uart teensy <->ESP communication
DEC:   AA 55 38 38 7 1
DEC:   AA 55 38 38 10 1
DEC:   AA 55 38 38 8 1
DEC:   AA 55 38 38 12 1
DEC:   AA 55 38 38 14 1
DEC:   AA 55 38 38 3 1
*** MQTT connected ***
DEC:   AA 55 38 38 0 0 1
Publish received.
 topic: teensquitto/ payload: hello world
 qos: 2 dup: 0
 retain: 1 len: 11 index: 0 total: 11
DEC:   AA 55 EA EA 11 0
DEC:   AA 55 CE CE 1 1
DEC:   AA 55 38 38 6 0 2
Packet ID: 2
Publish received.
 qos: 2 dup: 0
 retain: 0 len: 11 index: 0 total: 11
[WSc] Connected to url: /
[WSc] get text: SERVER: Connected
UDP Packet Type: Broadcast, From: 192.168.2.122:64866, To: 255.255.255.255:1234, Length: 22, Data: test from packetsender
DEC:   AA 55 CE CE 5 0 0 0 14
UDP Packet Type: Broadcast, From: 192.168.2.122:64866, To: 255.255.255.255:1234, Length: 6, Data: teensy
DEC:   AA 55 CE CE 5 0 0 0 13
UDP Packet Type: Unicast, From: 192.168.2.122:64866, To: 192.168.2.168:1234, Length: 22, Data: test from packetsender
DEC:   AA 55 EA EA 11 1
DEC:   AA 55 38 38 6 0 3
Packet ID: 3
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 4
Packet ID: 4
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 5
Packet ID: 5
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 6
Packet ID: 6
Publish received.
 qos: 2 dup: 0
[0] Disconnected!
connected server
DEC:   AA 55 38 38 6 0 7
Packet ID: 7
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 8
Packet ID: 8
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 9
Packet ID: 9
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 A
Packet ID: 10
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 B
Packet ID: 11
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 C
Packet ID: 12
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 D
Packet ID: 13
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 E
Packet ID: 14
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 F
Packet ID: 15
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 10
Packet ID: 16
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 11
Packet ID: 17
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 12
Packet ID: 18
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 13
Packet ID: 19
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 14
Packet ID: 20
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 15
Packet ID: 21
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 16
Packet ID: 22
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 17
Packet ID: 23
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 18
Packet ID: 24
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 19
Packet ID: 25
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 1A
Packet ID: 26
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 1B
Packet ID: 27
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 1C
Packet ID: 28
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 1D
Packet ID: 29
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 1E
Packet ID: 30
Publish received.
 qos: 2 dup: 0
tested 3 Megabaud working with mqtt and websockets
anything above 3 megabaud doesnt seem to register anything readable under putty/terminal
just letting you know 3 megabaud is working so far with client & server sockets and mqtt send/receiving
3Mbaud teensy monitor:
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 32
Packet ID: 50
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 33
Packet ID: 51
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 34
Packet ID: 52
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 35
Packet ID: 53
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 36
Packet ID: 54
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 37
Packet ID: 55
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 38
Packet ID: 56
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 39
Packet ID: 57
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 3A
Packet ID: 58
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 3B
Packet ID: 59
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 3C
Packet ID: 60
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 0 3D
Packet ID: 61
Publish received.
 qos: 2 dup: 0
mqtt and websockets ran since yesturday, still is! :) i took a break today
regarding the 3M baud rate i was reading some forums of esp8266 and fell onto this
Thanks for updating Kevin. The 74880 on esp8266 is an artifact of the crystal speed (if you use a 40MHz crystal the baud rate is 115200, but everyone uses 26MHz crystals so it's proportionally lower.)
if thats true that explains the 3M baud (115200x26==2,995,200). with an xtal of 40 a 4,608,000 could be achieved
i guess that makes sense :)
furthermore, if thats still true, according to frankB’s XLS baud rate calulations, that gives an error rate on teensy 3.6 @ 180mhz of %0.16. (for 3Mbaud)
Tony
New feature, automatic ESP firmware uploading without affecting Serial Monitor from user/his code... no additional GPIOs used.
https://www.youtube.com/watch?v=okO9KeWpYpQ
in the video above, teensy is COM46. if you open Serial Monitor, you can use teensy as normal. However, when you go to flash an ESP firmware, close serial monitor and point ESP sketch to the teensy com port COM46.
The first packet esptool sends after toggling the DTR is a 36 byte static array of bytes, once a match is found, teensy goes into ESP programming mode automatically and then switches the LED ON (led is for demonstration of ESP program mode)
every byte transfered to the ESP from teensy is counted, with an additonal timer counter as well. What happens is i count if theres more than 1K bytes transfered, technically it was streaming, once the data stops and the timeout expires (which was always updated during the transfer), teensy goes back to regular user tasks. The demo shows teensy automatically programming the ESP at 921600 baud rate using the arduino IDE, followed by returning to the user code right after, probably will have it call reset on teensy just so it can reconfigure the ESP functions... but yeah, function is 23 lines as it is, and will use 3 uart wires, (Serial1 RX1/TX1 of teensy, and ALT TX1 of teensy for the Uart0 of ESP since regular TX1 is used by esp's GPIO2 (Serial1) port.
Now we can just wire up an ESP to teensy (5 wires(power,gnd,uart0RX,uart0TX,uart1TX)) and program both without rewiring anything, as long, as the library is on teensy of course
Tony
This looks amazing! I've been wanting to make a board with a teensy 3.6, esp8266 and rfw95w. Not having to program both the teensy and the esp independently with separate connections would be perfect. Do you have any plans to share your library?
yup, im still working on the uploader portion however having issues with dtr toggling, so im still working on that, on the plus side, teensy can use the reset line gpio in user code to restart the esp when requested (you can still use ESP.reset() or ESP.restart(), but gpio is hard reset :) ) the rfw95w i presume you’ll run that on teensy side correct?
what is a rfw95w? :p
google searches informs me its an rfm95w radio
then yeah it should work fine, i added most of the transparent stuff including wificlient, not sure httpclient is needed yet or can just use wificlient as it is, still adding more esp code over to teensy end, but i need to finish off the auto uploading this week as its holding me back on more implementations, mqtt never crashed at all the last 2 weeks tho on teensy, publishing over esp link and receiving on teensy’s handler, using original functions transparently and a transparent non blocking handler :)
~ 4 hours ago i updated to latest git of the ESP, and it still compiles fine, because i dont port over the function’s code, i run the function directly while transferring the responses, its pretty hard to break this library code without changing the function overloads in the ESP code which would otherwise affect everyone else using it as well, but very easy to fix later on regardless :)
packet radio does sound nice, maybe in future ill make a teensy controller based on that
Posting this here for reference, ESP uploads can be quite....picky. What made the huzzah more stable at least for programming was to tie CH_EN and RST together when putting it into firmware update mode, it either has something to do with the way the breakout is designed or the type of ESP subversion used i guess. This auto uploader code will work at any supported speeds in the arduino IDE to upload to the ESP from teensy.
Teensy Pin Huzzah pin
D24 CH_EN & RST (tied)
D25 GPIO0
D0 (RX1) TX
D1 (TX1) RX
Sketch for Teensy 3.x
void serialEvent() {
  static bool _DTR = Serial.dtr();
  if ( _DTR != Serial.dtr() ) {
    uint8_t ESP_RESET = 24, ESP_GPIO0 = 25;
    static uint32_t _baud = 1;
    if ( !_DTR ) {
      delay(100); while ( Serial.available() > 0 ) Serial.read();
    else {
      if ( _baud != Serial.baud() ) {
        _baud = Serial.baud(); Serial1.begin(_baud);
      delay(40); if ( Serial.peek() != 0xC0 ) return;
      pinMode(ESP_RESET, OUTPUT); digitalWriteFast(ESP_RESET, 0);
      pinMode(ESP_GPIO0, OUTPUT); digitalWriteFast(ESP_GPIO0, 0);
      uint32_t _pulse = millis(), _count = 0, _program_timeout = millis();
      while (1) {
        digitalWriteFast(ESP_RESET, !Serial.dtr());
        if ( millis() - _program_timeout > 12000 ) {
          pinMode(ESP_GPIO0, INPUT_DISABLE); pinMode(ESP_RESET, INPUT_DISABLE); return;
        while ( Serial.available() > 0 ) {
          _pulse = millis(); _count++;
          if ( _count > 3500 ) {
            _program_timeout = millis(); pinMode(ESP_GPIO0, INPUT_DISABLE);
            if ( millis() - _pulse > 500 ) {
          Serial1.write(Serial.read());
        if ( Serial1.available() > 0 ) Serial.write(Serial1.read());
It took alot of "tweaking" to get it upload more often, i get alot of good success rates, but still bound to a "retry", which is not bad considering thats normal in the ESP world ;)
I havn't been able to make it work together with user input in serial monitor, so if you plan on using it with serial monitor, no can do sorry...
Video demonstration uploading a blank ESP sketch to the ESP starting with baud rate of 115200, and then another at 921600:
https://www.youtube.com/watch?v=DnbBjAX1hQo
Slight modification for use in teensquitto to reflash the ESP, (provided your using Serial1 pins 0,1 and ALT pin 27)
    if ( !_DTR ) {
    else {
        _baud = Serial.baud(); pinMode(0, INPUT_DISABLE); Serial1.setRX(27); Serial1.begin(_baud);
      while (1) {
          pinMode(ESP_GPIO0, INPUT_DISABLE); digitalWriteFast(ESP_RESET,0); delay(100); pinMode(ESP_RESET, INPUT_DISABLE);
          Serial1.setRX(0); pinMode(27, INPUT_DISABLE); Serial1.begin(2000000); return;
              pinMode(ESP_RESET, INPUT_DISABLE); ((*(volatile uint32_t *)0xE000ED0C) = (0x5FA0004));
This allows teensy to reboot after reprogramming the ESP, so setup() can run again your ESP configurations... Code Swaps to ALT RX1 pin 27 where ESP's uart0 TX is attached, because ESP's uart1 TX is attached to pin 0...
Video demonstrating mqtt & UDP running on teensy, closing the monitor before clicking on ESP code upload pointed to teensy's COM46 port, as soon as the data is transfered teensy resets, i reopen the serial monitor on COM46 to show teensy startup and UDP & mqtt running again..
https://www.youtube.com/watch?v=PC3GiiDSXFw
I'm working on the ESP detection code once again and it works quite well, 250ms pulses when ESP is offline to query the ESP uart, and timeout of 5 seconds when "online", timeout resets for every valid CRC packet that passes when a function is called. When the ESP is offline, 250ms pulses ping the ESP until its detected, at the same time, all functions are disabled giving the loop() full speed (non blocking).
Now a question for the packet already implemented for "ESP was reset" signal. This is an addition to the detected on/off signal used by the library, this notifies the library when an ESP reset was detected. When the ESP boots up it sends a uart packet to teensy telling it, "hey, i reset, you might want to reinitialize all your setup() or init data to configure me?".
Any suggestions on whether I should create an "init"() handler, or just have teensy "reboot" when that signal is detected?
in one scenario with the handler, the user can reconfigure his own set of setup parameters to run on a fresh boot (without the need to reset teensy), on the other end, simpler would be to reboot teensy, and that will obviously stop other things that teensy /could be doing/... if a handler is a good idea, what should we call it? obviously this wouldnt be part of the ESP transparency as it's a new function ( WiFi.onReset(handle) ? ) ;P
or should we do a fallback idea?
We create a handler for the ESP init code, if the user doesnt create the handler(NULL), should it fallback to a reset method automatically instead?
I think having an init call would make most sense. It's going to be very frustrating for a user who doesn't understand this functionality, if their application code on their teensy is constantly resetting because their ESP has a power issue or something! :)
the other problem is the user probably wont know also why the ESP is partially working when its not reconfigured from teensy :eek:
or we could do a “combined” handler just for “connected”/“disconnected”/“reset” states (WiFi.onEvent(xxx)) so a user can run other code if the ESP is disconnected, it’ll fireoff a callback so the user can handle his code accordingly
Hi all, I ended up using an anonymous function callback for teensquitto that can be ran in setup() as follows:
  Serial.begin(1);
  delay(2000);  // stabilize both uarts...
  ESP.onDetect([]() {
    IPAddress ip(192, 168, 2, 168);
    IPAddress gate(192, 168, 2, 1);
    IPAddress sub(255, 255, 255, 0);
    WiFi.begin("Tony", "*******");
    WiFi.waitForConnectResult();
    WiFi.config(ip, gate, sub);
    // setup MQTT handlers
    mqtt.onConnect(onMqttConnect);
    mqtt.onDisconnect(onMqttDisconnect);
    mqtt.onSubscribe(onMqttSubscribe);
    mqtt.onUnsubscribe(onMqttUnsubscribe);
    mqtt.onMessage(onMqttMessage);
    mqtt.onPublish(onMqttPublish);
    WiFi.onStationModeGotIP(onWifiConnect);
    WiFi.onStationModeDisconnected(onWifiDisconnect);
    // setup MQTT connection
    IPAddress _server = { 192, 168, 2, 122 };
    mqtt.setKeepAlive(8);
    mqtt.setMaxTopicLength(128);
    mqtt.setClientId("Tony");
    mqtt.setCredentials("ESP02", "tony");
    mqtt.setServer(_server, 1883);
    mqtt.connect();
    if (  udp.listen(1234) ) {
        Serial.print(":");
        Serial.print(":");
        // reply to the client
  }); // end of onDetect callback
As you can see from the code, UDP, MQTT, WEBSOCKETS, and other things are re-registered whenever the ESP is detected, or rebooted.
I uploaded a video of pushing reset on the huzzah, and teensy reconfiguring the chip automagically from the callback, and literally, that callback configuration is huge, but successful :)
https://www.youtube.com/watch?v=AEgg5LwGVh0
I haven't added a disconnect handler, dont think it's really needed. I could add a public bool function ESP.connected() in case a user needs to identify whether an ESP is connected or not (which can be rare but, if you put the ESP to sleep, your teensy becomes non blocking as the library disables all functions
WiFiClientSecure.h ported over.
In previous posts, I had SPIFFS object handle File functions remotely since it's driven on another MCU, which allowed read/writing to the SPIFFS filesystem from Teensy
The 3 last functions of WiFiClientSecure:
  bool loadCACert(Stream& stream, size_t size);
  bool loadCertificate(Stream& stream, size_t size);
  bool loadPrivateKey(Stream& stream, size_t size);
were ported over to teensy as:
  bool loadCACert();
  bool loadCertificate();
  bool loadPrivateKey();
calling it uses the File that was opened with SPIFFS. So by calling it in teensy as:
if ( SPIFFS.open("/ca.der", "r") ) sclient.loadCACert(); // if file opens, load it's certificate
It will technically run sclient.loadCACert(f); at the other end of the ESP link
since those functions return bool, you'll get a 0 if failed to load file, or 1 if successful
Sketch uses 129560 bytes (12%) of program storage space. Maximum is 1048576 bytes.
Global variables use 11448 bytes (4%) of dynamic memory, leaving 250696 bytes for local variables. Maximum is 262144 bytes.
T3.6 @ 180MHz
in this test demo sketch, we're flooding mqtt publishes at 25ms intervals while PacketSender(win32 app) sending UDP packets every few seconds to teensy.
Reason? testing out a new handler queueing system :)
The implementation of std::vectors with std::deque container, it's now possible to push sizeable handlers into queue to process when a function is not busy waiting for it's own response.
If a function, for example publishes, and the next data is handler data which is irrelevant to it, it will automatically be queued, and processed when WiFi.events() is called. I uploaded a demo to youtube to demonstrate the test:
https://www.youtube.com/watch?v=a1k1lWzBfTo
sample log posted below:
DEC:   AA 55 A2 A2 39 1
DEC:   AA 55 A2 A2 1 3
DEC:   AA 55 A2 A2 10 3
DEC:   AA 55 A2 A2 4 1
*** WiFi Status 6: WL_DISCONNECTED ***
*** MQTT disconnected ***
DEC:   AA 55 38 38 6 3F A8
Packet ID: 16296
DEC:   AA 55 38 38 6 3F A9
Publish received.
 qos: 2 dup: 0
Packet ID: 16297
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F AA
DEC:   AA 55 38 38 6 3F AB
*** WiFi Status 3: WL_CONNECTED ***
DEC:   AA 55 38 38 6 3F AC
Packet ID: 16298
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F AD
             DeQueing Handler!  Queue size: 4
PROCESS?: 175 175 4 63 171 144
Packet ID: 16299
             DeQueing Handler!  Queue size: 3
PROCESS?: 175 175 5 0 12 2 0 0 0 0 0 11 0 0 0 0 0 0 0 11 116 101 101 110 115 113 117 105 116 116 111 47 104 101 108 108 111 32 119 111 114 108 100 111
Publish received.
 qos: 2 dup: 0
             DeQueing Handler!  Queue size: 2
PROCESS?: 175 175 4 63 172 151
Packet ID: 16300
             DeQueing Handler!  Queue size: 1
Publish received.
 qos: 2 dup: 0
Packet ID: 16301
DEC:   AA 55 38 38 6 3F AE
Publish received.
 qos: 2 dup: 0
Packet ID: 16302
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F AF
Packet ID: 16303
DEC:   AA 55 38 38 6 3F B0
Publish received.
 qos: 2 dup: 0
Packet ID: 16304
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F B1
Packet ID: 16305
DEC:   AA 55 38 38 6 3F B2
Publish received.
 qos: 2 dup: 0
Packet ID: 16306
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F B3
DEC:   AA 55 38 38 6 3F B4
PROCESS?: 175 175 4 63 179 136
Packet ID: 16307
Publish received.
 qos: 2 dup: 0
Packet ID: 16308
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F B5
DEC:   AA 55 38 38 6 3F B6
DEC:   AA 55 38 38 6 3F B7
DEC:   AA 55 38 38 6 3F B8
DEC:   AA 55 38 38 6 3F B9
Packet ID: 16309
Publish received.
 qos: 2 dup: 0
Packet ID: 16310
Publish received.
 qos: 2 dup: 0
Packet ID: 16311
Publish received.
 qos: 2 dup: 0
Packet ID: 16312
Publish received.
 qos: 2 dup: 0
Packet ID: 16313
DEC:   AA 55 38 38 6 3F BA
Publish received.
 qos: 2 dup: 0
Packet ID: 16314
DEC:   AA 55 38 38 6 3F BB
Publish received.
 qos: 2 dup: 0
Packet ID: 16315
DEC:   AA 55 38 38 6 3F BC
Publish received.
 qos: 2 dup: 0
Packet ID: 16316
DEC:   AA 55 38 38 6 3F BD
Publish received.
 qos: 2 dup: 0
Packet ID: 16317
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F BE
Packet ID: 16318
DEC:   AA 55 38 38 6 3F BF
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F C0
PROCESS?: 175 175 4 63 191 132
Packet ID: 16319
Publish received.
 qos: 2 dup: 0
Packet ID: 16320
DEC:   AA 55 38 38 6 3F C1
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F C2
Packet ID: 16321
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F C3
Packet ID: 16322
Publish received.
 qos: 2 dup: 0
Packet ID: 16323
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F C4
Packet ID: 16324
DEC:   AA 55 38 38 6 3F C5
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F C6
Packet ID: 16325
Publish received.
 qos: 2 dup: 0
Packet ID: 16326
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F C7
DEC:   AA 55 38 38 6 3F C8
DEC:   AA 55 38 38 6 3F C9
DEC:   AA 55 38 38 6 3F CA
Packet ID: 16327
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F CB
Packet ID: 16328
Publish received.
 qos: 2 dup: 0
Packet ID: 16329
Publish received.
 qos: 2 dup: 0
Packet ID: 16330
Publish received.
 qos: 2 dup: 0
Packet ID: 16331
DEC:   AA 55 38 38 6 3F CC
Publish received.
 qos: 2 dup: 0
Packet ID: 16332
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F CD
DEC:   AA 55 38 38 6 3F CE
DEC:   AA 55 38 38 6 3F CF
Packet ID: 16333
Publish received.
 qos: 2 dup: 0
Packet ID: 16334
Publish received.
 qos: 2 dup: 0
Packet ID: 16335
DEC:   AA 55 38 38 6 3F D0
Publish received.
 qos: 2 dup: 0
Packet ID: 16336
DEC:   AA 55 38 38 6 3F D1
Publish received.
 qos: 2 dup: 0
Packet ID: 16337
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F D2
DEC:   AA 55 38 38 6 3F D3
DEC:   AA 55 38 38 6 3F D4
Packet ID: 16338
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F D5
Packet ID: 16339
Publish received.
 qos: 2 dup: 0
Packet ID: 16340
Publish received.
 qos: 2 dup: 0
Packet ID: 16341
DEC:   AA 55 38 38 6 3F D6
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F D7
Packet ID: 16342
Publish received.
 qos: 2 dup: 0
Packet ID: 16343
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F D8
DEC:   AA 55 38 38 6 3F D9
DEC:   AA 55 38 38 6 3F DA
DEC:   AA 55 38 38 6 3F DB
Packet ID: 16344
Publish received.
 qos: 2 dup: 0
Packet ID: 16345
Publish received.
 qos: 2 dup: 0
Packet ID: 16346
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F DC
Packet ID: 16347
Publish received.
 qos: 2 dup: 0
Packet ID: 16348
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F DD
DEC:   AA 55 38 38 6 3F DE
DEC:   AA 55 38 38 6 3F DF
Packet ID: 16349
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F E0
Packet ID: 16350
Publish received.
 qos: 2 dup: 0
Packet ID: 16351
Publish received.
 qos: 2 dup: 0
Packet ID: 16352
DEC:   AA 55 38 38 6 3F E1
Publish received.
 qos: 2 dup: 0
Packet ID: 16353
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F E2
Packet ID: 16354
DEC:   AA 55 38 38 6 3F E3
Publish received.
 qos: 2 dup: 0
Packet ID: 16355
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F E4
Packet ID: 16356
DEC:   AA 55 38 38 6 3F E5
Publish received.
 qos: 2 dup: 0
Packet ID: 16357
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F E6
Packet ID: 16358
DEC:   AA 55 38 38 6 3F E7
Publish received.
 qos: 2 dup: 0
Packet ID: 16359
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F E8
Packet ID: 16360
DEC:   AA 55 38 38 6 3F E9
Publish received.
 qos: 2 dup: 0
Packet ID: 16361
DEC:   AA 55 38 38 6 3F EA
Publish received.
 qos: 2 dup: 0
Packet ID: 16362
DEC:   AA 55 38 38 6 3F EB
Publish received.
 qos: 2 dup: 0
Packet ID: 16363
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F EC
Packet ID: 16364
DEC:   AA 55 38 38 6 3F ED
Publish received.
 qos: 2 dup: 0
Packet ID: 16365
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F EE
DEC:   AA 55 38 38 6 3F EF
DEC:   AA 55 38 38 6 3F F0
DEC:   AA 55 38 38 6 3F F1
Packet ID: 16366
Publish received.
 qos: 2 dup: 0
Packet ID: 16367
Publish received.
 qos: 2 dup: 0
Packet ID: 16368
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F F2
Packet ID: 16369
Publish received.
 qos: 2 dup: 0
Packet ID: 16370
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F F3
DEC:   AA 55 38 38 6 3F F4
DEC:   AA 55 38 38 6 3F F5
Packet ID: 16371
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F F6
Packet ID: 16372
Publish received.
 qos: 2 dup: 0
Packet ID: 16373
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F F7
Packet ID: 16374
Publish received.
 qos: 2 dup: 0
Packet ID: 16375
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F F8
DEC:   AA 55 38 38 6 3F F9
DEC:   AA 55 38 38 6 3F FA
Packet ID: 16376
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F FB
PROCESS?: 175 175 4 63 249 194
Packet ID: 16377
Publish received.
 qos: 2 dup: 0
PROCESS?: 175 175 4 63 250 193
Packet ID: 16378
Publish received.
 qos: 2 dup: 0
Packet ID: 16379
DEC:   AA 55 38 38 6 3F FC
Publish received.
 qos: 2 dup: 0
Packet ID: 16380
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F FD
Packet ID: 16381
DEC:   AA 55 38 38 6 3F FE
Publish received.
 qos: 2 dup: 0
Packet ID: 16382
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 3F FF
DEC:   AA 55 38 38 6 40 0
DEC:   AA 55 38 38 6 40 1
DEC:   AA 55 38 38 6 40 2
Packet ID: 16383
Publish received.
 qos: 2 dup: 0
Packet ID: 16384
Publish received.
 qos: 2 dup: 0
Packet ID: 16385
Publish received.
 qos: 2 dup: 0
Packet ID: 16386
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 3
Packet ID: 16387
DEC:   AA 55 38 38 6 40 4
Publish received.
 qos: 2 dup: 0
Packet ID: 16388
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 5
DEC:   AA 55 38 38 6 40 6
DEC:   AA 55 38 38 6 40 7
Packet ID: 16389
Publish received.
 qos: 2 dup: 0
Packet ID: 16390
Publish received.
 qos: 2 dup: 0
Packet ID: 16391
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 8
Packet ID: 16392
DEC:   AA 55 38 38 6 40 9
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 A
Packet ID: 16393
Publish received.
 qos: 2 dup: 0
Packet ID: 16394
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 B
DEC:   AA 55 38 38 6 40 C
DEC:   AA 55 38 38 6 40 D
PROCESS?: 207 207 0 1 0 192 168 2 122 237 53 255 255 255 255 4 210 0 6 116 101 101 110 115 121 9
UDP Packet Type: Broadcast, From: 192.168.2.122:60725, To: 255.255.255.255:1234, Length: 6, Data: teensy
Packet ID: 16395
Publish received.
 qos: 2 dup: 0
Packet ID: 16396
Publish received.
 qos: 2 dup: 0
Packet ID: 16397
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 E
DEC:   AA 55 38 38 6 40 F
Packet ID: 16398
Publish received.
 qos: 2 dup: 0
Packet ID: 16399
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 10
DEC:   AA 55 38 38 6 40 11
DEC:   AA 55 38 38 6 40 12
Packet ID: 16400
Publish received.
 qos: 2 dup: 0
Packet ID: 16401
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 13
PROCESS?: 175 175 4 64 18 86
Packet ID: 16402
Publish received.
 qos: 2 dup: 0
Packet ID: 16403
DEC:   AA 55 38 38 6 40 14
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 15
PROCESS?: 175 175 4 64 20 80
Packet ID: 16404
Publish received.
 qos: 2 dup: 0
Packet ID: 16405
DEC:   AA 55 38 38 6 40 16
Publish received.
 qos: 2 dup: 0
Packet ID: 16406
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 17
Packet ID: 16407
DEC:   AA 55 38 38 6 40 18
Publish received.
 qos: 2 dup: 0
Packet ID: 16408
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 19
DEC:   AA 55 38 38 6 40 1A
DEC:   AA 55 38 38 6 40 1B
Packet ID: 16409
Publish received.
 qos: 2 dup: 0
Packet ID: 16410
Publish received.
 qos: 2 dup: 0
Packet ID: 16411
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 1C
Packet ID: 16412
DEC:   AA 55 38 38 6 40 1D
Publish received.
 qos: 2 dup: 0
Packet ID: 16413
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 1E
DEC:   AA 55 38 38 6 40 1F
DEC:   AA 55 38 38 6 40 20
DEC:   AA 55 38 38 6 40 21
Packet ID: 16414
Publish received.
 qos: 2 dup: 0
Packet ID: 16415
Publish received.
 qos: 2 dup: 0
Packet ID: 16416
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 22
Packet ID: 16417
Publish received.
 qos: 2 dup: 0
Packet ID: 16418
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 23
DEC:   AA 55 38 38 6 40 24
DEC:   AA 55 38 38 6 40 25
DEC:   AA 55 38 38 6 40 26
Packet ID: 16419
Publish received.
 qos: 2 dup: 0
Packet ID: 16420
Publish received.
 qos: 2 dup: 0
Packet ID: 16421
Publish received.
 qos: 2 dup: 0
Packet ID: 16422
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 27
DEC:   AA 55 38 38 6 40 28
DEC:   AA 55 38 38 6 40 29
Packet ID: 16423
Publish received.
 qos: 2 dup: 0
Packet ID: 16424
Publish received.
 qos: 2 dup: 0
Packet ID: 16425
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 2A
Packet ID: 16426
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 2B
DEC:   AA 55 38 38 6 40 2C
DEC:   AA 55 38 38 6 40 2D
Packet ID: 16427
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 2E
Packet ID: 16428
Publish received.
 qos: 2 dup: 0
Packet ID: 16429
Publish received.
 qos: 2 dup: 0
Packet ID: 16430
DEC:   AA 55 38 38 6 40 2F
Publish received.
 qos: 2 dup: 0
Packet ID: 16431
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 30
DEC:   AA 55 38 38 6 40 31
DEC:   AA 55 38 38 6 40 32
DEC:   AA 55 38 38 6 40 33
PROCESS?: 175 175 4 64 48 116
Packet ID: 16432
Publish received.
 qos: 2 dup: 0
Packet ID: 16433
Publish received.
 qos: 2 dup: 0
Packet ID: 16434
Publish received.
 qos: 2 dup: 0
Packet ID: 16435
DEC:   AA 55 38 38 6 40 34
Publish received.
 qos: 2 dup: 0
Packet ID: 16436
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 35
DEC:   AA 55 38 38 6 40 36
DEC:   AA 55 38 38 6 40 37
Packet ID: 16437
Publish received.
 qos: 2 dup: 0
Packet ID: 16438
Publish received.
 qos: 2 dup: 0
Packet ID: 16439
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 38
Packet ID: 16440
DEC:   AA 55 38 38 6 40 39
Publish received.
 qos: 2 dup: 0
Packet ID: 16441
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 3A
Packet ID: 16442
DEC:   AA 55 38 38 6 40 3B
Publish received.
 qos: 2 dup: 0
Packet ID: 16443
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 3C
DEC:   AA 55 38 38 6 40 3D
DEC:   AA 55 38 38 6 40 3E
Packet ID: 16444
Publish received.
 qos: 2 dup: 0
Packet ID: 16445
Publish received.
 qos: 2 dup: 0
Packet ID: 16446
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 3F
Packet ID: 16447
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 40
Packet ID: 16448
DEC:   AA 55 38 38 6 40 41
Publish received.
 qos: 2 dup: 0
Packet ID: 16449
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 42
DEC:   AA 55 38 38 6 40 43
DEC:   AA 55 38 38 6 40 44
DEC:   AA 55 38 38 6 40 45
Packet ID: 16450
Publish received.
 qos: 2 dup: 0
Packet ID: 16451
Publish received.
 qos: 2 dup: 0
Packet ID: 16452
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 46
Packet ID: 16453
Publish received.
 qos: 2 dup: 0
Packet ID: 16454
DEC:   AA 55 38 38 6 40 47
Publish received.
 qos: 2 dup: 0
Packet ID: 16455
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 48
DEC:   AA 55 38 38 6 40 49
DEC:   AA 55 38 38 6 40 4A
Packet ID: 16456
Publish received.
 qos: 2 dup: 0
Packet ID: 16457
Publish received.
 qos: 2 dup: 0
Packet ID: 16458
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 4B
DEC:   AA 55 38 38 6 40 4C
DEC:   AA 55 38 38 6 40 4D
DEC:   AA 55 38 38 6 40 4E
Packet ID: 16459
Publish received.
 qos: 2 dup: 0
Packet ID: 16460
Publish received.
 qos: 2 dup: 0
Packet ID: 16461
Publish received.
 qos: 2 dup: 0
Packet ID: 16462
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 4F
DEC:   AA 55 38 38 6 40 50
DEC:   AA 55 38 38 6 40 51
Packet ID: 16463
Publish received.
 qos: 2 dup: 0
Packet ID: 16464
Publish received.
 qos: 2 dup: 0
Packet ID: 16465
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 52
DEC:   AA 55 38 38 6 40 53
DEC:   AA 55 38 38 6 40 54
DEC:   AA 55 38 38 6 40 55
Packet ID: 16466
Publish received.
 qos: 2 dup: 0
Packet ID: 16467
Publish received.
 qos: 2 dup: 0
Packet ID: 16468
Publish received.
 qos: 2 dup: 0
Packet ID: 16469
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 56
Packet ID: 16470
DEC:   AA 55 38 38 6 40 57
Publish received.
 qos: 2 dup: 0
PROCESS?: 175 175 4 64 87 19
Packet ID: 16471
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 58
DEC:   AA 55 38 38 6 40 59
DEC:   AA 55 38 38 6 40 5A
Packet ID: 16472
Publish received.
 qos: 2 dup: 0
Packet ID: 16473
Publish received.
 qos: 2 dup: 0
Packet ID: 16474
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 5B
DEC:   AA 55 38 38 6 40 5C
DEC:   AA 55 38 38 6 40 5D
Packet ID: 16475
Publish received.
 qos: 2 dup: 0
Packet ID: 16476
Publish received.
 qos: 2 dup: 0
Packet ID: 16477
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 5E
Packet ID: 16478
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 5F
Packet ID: 16479
DEC:   AA 55 38 38 6 40 60
Publish received.
 qos: 2 dup: 0
Packet ID: 16480
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 61
DEC:   AA 55 38 38 6 40 62
DEC:   AA 55 38 38 6 40 63
Packet ID: 16481
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 64
PROCESS?: 175 175 4 64 98 38
Packet ID: 16482
Publish received.
 qos: 2 dup: 0
PROCESS?: 175 175 4 64 99 39
Packet ID: 16483
Publish received.
 qos: 2 dup: 0
Packet ID: 16484
DEC:   AA 55 38 38 6 40 65
Publish received.
 qos: 2 dup: 0
Packet ID: 16485
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 66
DEC:   AA 55 38 38 6 40 67
DEC:   AA 55 38 38 6 40 68
DEC:   AA 55 38 38 6 40 69
DEC:   AA 55 38 38 6 40 6A
Packet ID: 16486
Publish received.
 qos: 2 dup: 0
Packet ID: 16487
Publish received.
 qos: 2 dup: 0
Packet ID: 16488
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 6B
DEC:   AA 55 38 38 6 40 6C
Packet ID: 16489
Publish received.
 qos: 2 dup: 0
Packet ID: 16490
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 6D
Packet ID: 16491
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 6E
Packet ID: 16492
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 6F
Packet ID: 16493
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 70
Packet ID: 16494
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 71
Packet ID: 16495
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 72
Packet ID: 16496
Publish received.
 qos: 2 dup: 0
Packet ID: 16497
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 73
DEC:   AA 55 38 38 6 40 74
Packet ID: 16498
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 75
Packet ID: 16499
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 76
Packet ID: 16500
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 77
Packet ID: 16501
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 78
Packet ID: 16502
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 79
Packet ID: 16503
Publish received.
 qos: 2 dup: 0
Packet ID: 16504
Publish received.
 qos: 2 dup: 0
Packet ID: 16505
DEC:   AA 55 38 38 6 40 7A
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 7B
DEC:   AA 55 38 38 6 40 7C
Packet ID: 16506
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 7D
Packet ID: 16507
Publish received.
 qos: 2 dup: 0
Packet ID: 16508
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 7E
DEC:   AA 55 38 38 6 40 7F
Packet ID: 16509
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 80
Packet ID: 16510
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 81
Packet ID: 16511
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 82
DEC:   AA 55 38 38 6 40 83
Packet ID: 16512
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 84
Packet ID: 16513
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 85
DEC:   AA 55 38 38 6 40 86
Packet ID: 16514
Publish received.
 qos: 2 dup: 0
Packet ID: 16515
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 87
DEC:   AA 55 38 38 6 40 88
Packet ID: 16516
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 89
Packet ID: 16517
Publish received.
 qos: 2 dup: 0
Packet ID: 16518
Publish received.
 qos: 2 dup: 0
Packet ID: 16519
Publish received.
 qos: 2 dup: 0
Packet ID: 16520
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 8A
DEC:   AA 55 38 38 6 40 8B
DEC:   AA 55 38 38 6 40 8C
Packet ID: 16521
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 8D
DEC:   AA 55 38 38 6 40 8E
Packet ID: 16522
Publish received.
 qos: 2 dup: 0
Packet ID: 16523
Publish received.
 qos: 2 dup: 0
Packet ID: 16524
Publish received.
 qos: 2 dup: 0
Packet ID: 16525
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 8F
DEC:   AA 55 38 38 6 40 90
Packet ID: 16526
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 91
Packet ID: 16527
Publish received.
 qos: 2 dup: 0
Packet ID: 16528
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 92
DEC:   AA 55 38 38 6 40 93
Packet ID: 16529
Publish received.
 qos: 2 dup: 0
Packet ID: 16530
Publish received.
 qos: 2 dup: 0
Packet ID: 16531
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 94
DEC:   AA 55 38 38 6 40 95
DEC:   AA 55 38 38 6 40 96
Packet ID: 16532
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 97
Packet ID: 16533
Publish received.
 qos: 2 dup: 0
Packet ID: 16534
Publish received.
 qos: 2 dup: 0
Packet ID: 16535
DEC:   AA 55 38 38 6 40 98
Publish received.
 qos: 2 dup: 0
Packet ID: 16536
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 99
DEC:   AA 55 38 38 6 40 9A
DEC:   AA 55 38 38 6 40 9B
Packet ID: 16537
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 9C
Packet ID: 16538
Publish received.
 qos: 2 dup: 0
Packet ID: 16539
Publish received.
 qos: 2 dup: 0
Packet ID: 16540
DEC:   AA 55 38 38 6 40 9D
Publish received.
 qos: 2 dup: 0
Packet ID: 16541
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 9E
DEC:   AA 55 38 38 6 40 9F
DEC:   AA 55 38 38 6 40 A0
Packet ID: 16542
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 A1
Packet ID: 16543
Publish received.
 qos: 2 dup: 0
Packet ID: 16544
Publish received.
 qos: 2 dup: 0
Packet ID: 16545
DEC:   AA 55 38 38 6 40 A2
Publish received.
 qos: 2 dup: 0
Packet ID: 16546
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 A3
DEC:   AA 55 38 38 6 40 A4
DEC:   AA 55 38 38 6 40 A5
Packet ID: 16547
Publish received.
 qos: 2 dup: 0
Packet ID: 16548
Publish received.
 qos: 2 dup: 0
Packet ID: 16549
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 A6
Packet ID: 16550
DEC:   AA 55 38 38 6 40 A7
Publish received.
 qos: 2 dup: 0
Packet ID: 16551
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 A8
DEC:   AA 55 38 38 6 40 A9
DEC:   AA 55 38 38 6 40 AA
Packet ID: 16552
Publish received.
 qos: 2 dup: 0
Packet ID: 16553
Publish received.
 qos: 2 dup: 0
Packet ID: 16554
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 AB
Packet ID: 16555
DEC:   AA 55 38 38 6 40 AC
Publish received.
 qos: 2 dup: 0
Packet ID: 16556
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 AD
DEC:   AA 55 38 38 6 40 AE
DEC:   AA 55 38 38 6 40 AF
Packet ID: 16557
Publish received.
 qos: 2 dup: 0
Packet ID: 16558
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 B0
PROCESS?: 175 175 4 64 175 235
Packet ID: 16559
Publish received.
 qos: 2 dup: 0
Packet ID: 16560
DEC:   AA 55 38 38 6 40 B1
Publish received.
 qos: 2 dup: 0
Packet ID: 16561
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 B2
DEC:   AA 55 38 38 6 40 B3
DEC:   AA 55 38 38 6 40 B4
Packet ID: 16562
Publish received.
 qos: 2 dup: 0
Packet ID: 16563
Publish received.
 qos: 2 dup: 0
Packet ID: 16564
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 B5
Packet ID: 16565
DEC:   AA 55 38 38 6 40 B6
Publish received.
 qos: 2 dup: 0
Packet ID: 16566
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 B7
DEC:   AA 55 38 38 6 40 B8
DEC:   AA 55 38 38 6 40 B9
Packet ID: 16567
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 BA
Packet ID: 16568
Publish received.
 qos: 2 dup: 0
Packet ID: 16569
Publish received.
 qos: 2 dup: 0
Packet ID: 16570
DEC:   AA 55 38 38 6 40 BB
Publish received.
 qos: 2 dup: 0
Packet ID: 16571
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 BC
DEC:   AA 55 38 38 6 40 BD
DEC:   AA 55 38 38 6 40 BE
Packet ID: 16572
Publish received.
 qos: 2 dup: 0
Packet ID: 16573
Publish received.
 qos: 2 dup: 0
Packet ID: 16574
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 BF
Packet ID: 16575
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 C0
Packet ID: 16576
DEC:   AA 55 38 38 6 40 C1
Publish received.
 qos: 2 dup: 0
Packet ID: 16577
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 C2
DEC:   AA 55 38 38 6 40 C3
DEC:   AA 55 38 38 6 40 C4
Packet ID: 16578
Publish received.
 qos: 2 dup: 0
Packet ID: 16579
Publish received.
 qos: 2 dup: 0
Packet ID: 16580
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 C5
DEC:   AA 55 38 38 6 40 C6
DEC:   AA 55 38 38 6 40 C7
Packet ID: 16581
Publish received.
 qos: 2 dup: 0
Packet ID: 16582
Publish received.
 qos: 2 dup: 0
Packet ID: 16583
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 C8
Packet ID: 16584
DEC:   AA 55 38 38 6 40 C9
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 CA
Packet ID: 16585
Publish received.
 qos: 2 dup: 0
Packet ID: 16586
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 CB
Packet ID: 16587
DEC:   AA 55 38 38 6 40 CC
Publish received.
 qos: 2 dup: 0
Packet ID: 16588
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 CD
DEC:   AA 55 38 38 6 40 CE
DEC:   AA 55 38 38 6 40 CF
Packet ID: 16589
Publish received.
 qos: 2 dup: 0
Packet ID: 16590
Publish received.
 qos: 2 dup: 0
Packet ID: 16591
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 D0
DEC:   AA 55 38 38 6 40 D1
DEC:   AA 55 38 38 6 40 D2
DEC:   AA 55 38 38 6 40 D3
Packet ID: 16592
Publish received.
 qos: 2 dup: 0
Packet ID: 16593
Publish received.
 qos: 2 dup: 0
Packet ID: 16594
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 D4
PROCESS?: 175 175 4 64 211 151
Packet ID: 16595
Publish received.
 qos: 2 dup: 0
Packet ID: 16596
DEC:   AA 55 38 38 6 40 D5
Publish received.
 qos: 2 dup: 0
Packet ID: 16597
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 D6
Packet ID: 16598
DEC:   AA 55 38 38 6 40 D7
Publish received.
 qos: 2 dup: 0
Packet ID: 16599
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 D8
DEC:   AA 55 38 38 6 40 D9
DEC:   AA 55 38 38 6 40 DA
Packet ID: 16600
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 DB
Packet ID: 16601
Publish received.
 qos: 2 dup: 0
Packet ID: 16602
Publish received.
 qos: 2 dup: 0
Packet ID: 16603
DEC:   AA 55 38 38 6 40 DC
Publish received.
 qos: 2 dup: 0
Packet ID: 16604
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 DD
DEC:   AA 55 38 38 6 40 DE
DEC:   AA 55 38 38 6 40 DF
Packet ID: 16605
Publish received.
 qos: 2 dup: 0
Packet ID: 16606
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 E0
PROCESS?: 175 175 4 64 223 155
Packet ID: 16607
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 E1
PROCESS?: 175 175 4 64 224 164
Packet ID: 16608
Publish received.
 qos: 2 dup: 0
Packet ID: 16609
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 E2
DEC:   AA 55 38 38 6 40 E3
DEC:   AA 55 38 38 6 40 E4
Packet ID: 16610
Publish received.
 qos: 2 dup: 0
Packet ID: 16611
Publish received.
 qos: 2 dup: 0
Packet ID: 16612
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 E5
Packet ID: 16613
DEC:   AA 55 38 38 6 40 E6
Publish received.
 qos: 2 dup: 0
Packet ID: 16614
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 E7
DEC:   AA 55 38 38 6 40 E8
DEC:   AA 55 38 38 6 40 E9
Packet ID: 16615
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 EA
PROCESS?: 175 175 4 64 232 172
Packet ID: 16616
Publish received.
 qos: 2 dup: 0
PROCESS?: 175 175 4 64 233 173
Packet ID: 16617
Publish received.
 qos: 2 dup: 0
Packet ID: 16618
DEC:   AA 55 38 38 6 40 EB
Publish received.
 qos: 2 dup: 0
Packet ID: 16619
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 EC
DEC:   AA 55 38 38 6 40 ED
DEC:   AA 55 38 38 6 40 EE
Packet ID: 16620
Publish received.
 qos: 2 dup: 0
Packet ID: 16621
Publish received.
 qos: 2 dup: 0
Packet ID: 16622
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 EF
DEC:   AA 55 38 38 6 40 F0
DEC:   AA 55 38 38 6 40 F1
Packet ID: 16623
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 F2
Packet ID: 16624
Publish received.
 qos: 2 dup: 0
Packet ID: 16625
Publish received.
 qos: 2 dup: 0
Packet ID: 16626
DEC:   AA 55 38 38 6 40 F3
Publish received.
 qos: 2 dup: 0
Packet ID: 16627
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 F4
DEC:   AA 55 38 38 6 40 F5
DEC:   AA 55 38 38 6 40 F6
Packet ID: 16628
Publish received.
 qos: 2 dup: 0
Packet ID: 16629
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 F7
Packet ID: 16630
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 F8
Packet ID: 16631
Publish received.
 qos: 2 dup: 0
Packet ID: 16632
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 F9
DEC:   AA 55 38 38 6 40 FA
DEC:   AA 55 38 38 6 40 FB
Packet ID: 16633
Publish received.
 qos: 2 dup: 0
Packet ID: 16634
Publish received.
 qos: 2 dup: 0
Packet ID: 16635
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 FC
DEC:   AA 55 38 38 6 40 FD
DEC:   AA 55 38 38 6 40 FE
Packet ID: 16636
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 40 FF
Packet ID: 16637
Publish received.
 qos: 2 dup: 0
Packet ID: 16638
Publish received.
 qos: 2 dup: 0
Packet ID: 16639
DEC:   AA 55 38 38 6 41 0
Publish received.
 qos: 2 dup: 0
Packet ID: 16640
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 1
DEC:   AA 55 38 38 6 41 2
DEC:   AA 55 38 38 6 41 3
DEC:   AA 55 38 38 6 41 4
Packet ID: 16641
Publish received.
 qos: 2 dup: 0
Packet ID: 16642
Publish received.
 qos: 2 dup: 0
Packet ID: 16643
Publish received.
 qos: 2 dup: 0
Packet ID: 16644
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 5
DEC:   AA 55 38 38 6 41 6
DEC:   AA 55 38 38 6 41 7
Packet ID: 16645
Publish received.
 qos: 2 dup: 0
Packet ID: 16646
Publish received.
 qos: 2 dup: 0
Packet ID: 16647
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 8
DEC:   AA 55 38 38 6 41 9
DEC:   AA 55 38 38 6 41 A
Packet ID: 16648
Publish received.
 qos: 2 dup: 0
Packet ID: 16649
Publish received.
 qos: 2 dup: 0
Packet ID: 16650
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 B
Packet ID: 16651
DEC:   AA 55 38 38 6 41 C
Publish received.
 qos: 2 dup: 0
Packet ID: 16652
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 D
DEC:   AA 55 38 38 6 41 E
DEC:   AA 55 38 38 6 41 F
Packet ID: 16653
Publish received.
 qos: 2 dup: 0
Packet ID: 16654
Publish received.
 qos: 2 dup: 0
Packet ID: 16655
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 10
Packet ID: 16656
DEC:   AA 55 38 38 6 41 11
Publish received.
 qos: 2 dup: 0
Packet ID: 16657
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 12
DEC:   AA 55 38 38 6 41 13
DEC:   AA 55 38 38 6 41 14
Packet ID: 16658
Publish received.
 qos: 2 dup: 0
Packet ID: 16659
Publish received.
 qos: 2 dup: 0
Packet ID: 16660
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 15
Packet ID: 16661
DEC:   AA 55 38 38 6 41 16
Publish received.
 qos: 2 dup: 0
Packet ID: 16662
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 17
DEC:   AA 55 38 38 6 41 18
DEC:   AA 55 38 38 6 41 19
Packet ID: 16663
Publish received.
 qos: 2 dup: 0
Packet ID: 16664
Publish received.
 qos: 2 dup: 0
Packet ID: 16665
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 1A
DEC:   AA 55 38 38 6 41 1B
DEC:   AA 55 38 38 6 41 1C
Packet ID: 16666
Publish received.
 qos: 2 dup: 0
Packet ID: 16667
Publish received.
 qos: 2 dup: 0
Packet ID: 16668
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 1D
Packet ID: 16669
DEC:   AA 55 38 38 6 41 1E
Publish received.
 qos: 2 dup: 0
Packet ID: 16670
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 1F
DEC:   AA 55 38 38 6 41 20
DEC:   AA 55 38 38 6 41 21
Packet ID: 16671
Publish received.
 qos: 2 dup: 0
Packet ID: 16672
Publish received.
 qos: 2 dup: 0
Packet ID: 16673
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 22
Packet ID: 16674
DEC:   AA 55 38 38 6 41 23
Publish received.
 qos: 2 dup: 0
Packet ID: 16675
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 24
DEC:   AA 55 38 38 6 41 25
DEC:   AA 55 38 38 6 41 26
Packet ID: 16676
Publish received.
 qos: 2 dup: 0
Packet ID: 16677
Publish received.
 qos: 2 dup: 0
Packet ID: 16678
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 27
Packet ID: 16679
DEC:   AA 55 38 38 6 41 28
Publish received.
 qos: 2 dup: 0
Packet ID: 16680
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 29
Packet ID: 16681
DEC:   AA 55 38 38 6 41 2A
Publish received.
 qos: 2 dup: 0
Packet ID: 16682
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 2B
DEC:   AA 55 38 38 6 41 2C
DEC:   AA 55 38 38 6 41 2D
Packet ID: 16683
Publish received.
 qos: 2 dup: 0
Packet ID: 16684
Publish received.
 qos: 2 dup: 0
Packet ID: 16685
DEC:   AA 55 38 38 6 41 2E
Publish received.
 qos: 2 dup: 0
Packet ID: 16686
DEC:   AA 55 38 38 6 41 2F
Publish received.
 qos: 2 dup: 0
Packet ID: 16687
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 30
DEC:   AA 55 38 38 6 41 31
DEC:   AA 55 38 38 6 41 32
Packet ID: 16688
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 33
Packet ID: 16689
Publish received.
 qos: 2 dup: 0
Packet ID: 16690
Publish received.
 qos: 2 dup: 0
Packet ID: 16691
DEC:   AA 55 38 38 6 41 34
Publish received.
 qos: 2 dup: 0
Packet ID: 16692
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 35
DEC:   AA 55 38 38 6 41 36
DEC:   AA 55 38 38 6 41 37
DEC:   AA 55 38 38 6 41 38
PROCESS?: 175 175 4 65 53 112
Packet ID: 16693
Publish received.
 qos: 2 dup: 0
Packet ID: 16694
Publish received.
 qos: 2 dup: 0
Packet ID: 16695
Publish received.
 qos: 2 dup: 0
Packet ID: 16696
DEC:   AA 55 38 38 6 41 39
Publish received.
 qos: 2 dup: 0
Packet ID: 16697
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 3A
DEC:   AA 55 38 38 6 41 3B
DEC:   AA 55 38 38 6 41 3C
DEC:   AA 55 38 38 6 41 3D
Packet ID: 16698
Publish received.
 qos: 2 dup: 0
Packet ID: 16699
Publish received.
 qos: 2 dup: 0
Packet ID: 16700
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 3E
PROCESS?: 175 175 4 65 61 120
Packet ID: 16701
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 3F
DEC:   AA 55 38 38 6 41 40
DEC:   AA 55 38 38 6 41 41
Packet ID: 16702
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 42
Packet ID: 16703
Publish received.
 qos: 2 dup: 0
Packet ID: 16704
Publish received.
 qos: 2 dup: 0
Packet ID: 16705
Publish received.
 qos: 2 dup: 0
Packet ID: 16706
DEC:   AA 55 38 38 6 41 43
Publish received.
 qos: 2 dup: 0
Packet ID: 16707
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 44
DEC:   AA 55 38 38 6 41 45
DEC:   AA 55 38 38 6 41 46
Packet ID: 16708
Publish received.
 qos: 2 dup: 0
Packet ID: 16709
Publish received.
 qos: 2 dup: 0
Packet ID: 16710
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 47
Packet ID: 16711
DEC:   AA 55 38 38 6 41 48
Publish received.
 qos: 2 dup: 0
Packet ID: 16712
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 49
DEC:   AA 55 38 38 6 41 4A
DEC:   AA 55 38 38 6 41 4B
Packet ID: 16713
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 4C
PROCESS?: 175 175 4 65 74 15
Packet ID: 16714
Publish received.
 qos: 2 dup: 0
PROCESS?: 175 175 4 65 75 14
Packet ID: 16715
Publish received.
 qos: 2 dup: 0
Packet ID: 16716
DEC:   AA 55 38 38 6 41 4D
Publish received.
 qos: 2 dup: 0
Packet ID: 16717
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 4E
Packet ID: 16718
DEC:   AA 55 38 38 6 41 4F
Publish received.
 qos: 2 dup: 0
Packet ID: 16719
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 50
DEC:   AA 55 38 38 6 41 51
DEC:   AA 55 38 38 6 41 52
DEC:   AA 55 38 38 6 41 53
DEC:   AA 55 38 38 6 41 54
DEC:   AA 55 38 38 6 41 55
Packet ID: 16720
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 56
Packet ID: 16721
Publish received.
 qos: 2 dup: 0
Packet ID: 16722
Publish received.
 qos: 2 dup: 0
Packet ID: 16723
Publish received.
 qos: 2 dup: 0
Packet ID: 16724
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 57
PROCESS?: 175 175 4 65 85 16
Packet ID: 16725
Publish received.
 qos: 2 dup: 0
Packet ID: 16726
Publish received.
 qos: 2 dup: 0
Packet ID: 16727
DEC:   AA 55 38 38 6 41 58
Publish received.
 qos: 2 dup: 0
Packet ID: 16728
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 59
DEC:   AA 55 38 38 6 41 5A
DEC:   AA 55 38 38 6 41 5B
Packet ID: 16729
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 5C
Packet ID: 16730
Publish received.
 qos: 2 dup: 0
Packet ID: 16731
Publish received.
 qos: 2 dup: 0
Packet ID: 16732
DEC:   AA 55 38 38 6 41 5D
Publish received.
 qos: 2 dup: 0
Packet ID: 16733
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 5E
DEC:   AA 55 38 38 6 41 5F
DEC:   AA 55 38 38 6 41 60
DEC:   AA 55 38 38 6 41 61
PROCESS?: 175 175 4 65 94 27
Packet ID: 16734
Publish received.
 qos: 2 dup: 0
Packet ID: 16735
Publish received.
 qos: 2 dup: 0
Packet ID: 16736
Publish received.
 qos: 2 dup: 0
Packet ID: 16737
DEC:   AA 55 38 38 6 41 62
Publish received.
 qos: 2 dup: 0
Packet ID: 16738
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 63
DEC:   AA 55 38 38 6 41 64
DEC:   AA 55 38 38 6 41 65
Packet ID: 16739
Publish received.
 qos: 2 dup: 0
Packet ID: 16740
Publish received.
 qos: 2 dup: 0
Packet ID: 16741
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 66
DEC:   AA 55 38 38 6 41 67
DEC:   AA 55 38 38 6 41 68
DEC:   AA 55 38 38 6 41 69
Packet ID: 16742
Publish received.
 qos: 2 dup: 0
Packet ID: 16743
Publish received.
 qos: 2 dup: 0
Packet ID: 16744
Publish received.
 qos: 2 dup: 0
Packet ID: 16745
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 6A
DEC:   AA 55 38 38 6 41 6B
DEC:   AA 55 38 38 6 41 6C
Packet ID: 16746
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 6D
Packet ID: 16747
Publish received.
 qos: 2 dup: 0
Packet ID: 16748
Publish received.
 qos: 2 dup: 0
Packet ID: 16749
DEC:   AA 55 38 38 6 41 6E
Publish received.
 qos: 2 dup: 0
Packet ID: 16750
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 6F
DEC:   AA 55 38 38 6 41 70
DEC:   AA 55 38 38 6 41 71
Packet ID: 16751
Publish received.
 qos: 2 dup: 0
Packet ID: 16752
Publish received.
 qos: 2 dup: 0
Packet ID: 16753
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 72
Packet ID: 16754
DEC:   AA 55 38 38 6 41 73
Publish received.
 qos: 2 dup: 0
Packet ID: 16755
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 74
DEC:   AA 55 38 38 6 41 75
DEC:   AA 55 38 38 6 41 76
Packet ID: 16756
Publish received.
 qos: 2 dup: 0
Packet ID: 16757
Publish received.
 qos: 2 dup: 0
Packet ID: 16758
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 77
Packet ID: 16759
DEC:   AA 55 38 38 6 41 78
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 79
Packet ID: 16760
Publish received.
 qos: 2 dup: 0
Packet ID: 16761
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 7A
Packet ID: 16762
DEC:   AA 55 38 38 6 41 7B
Publish received.
 qos: 2 dup: 0
Packet ID: 16763
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 7C
DEC:   AA 55 38 38 6 41 7D
DEC:   AA 55 38 38 6 41 7E
Packet ID: 16764
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 7F
Packet ID: 16765
Publish received.
 qos: 2 dup: 0
Packet ID: 16766
Publish received.
 qos: 2 dup: 0
Packet ID: 16767
DEC:   AA 55 38 38 6 41 80
Publish received.
 qos: 2 dup: 0
Packet ID: 16768
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 81
DEC:   AA 55 38 38 6 41 82
DEC:   AA 55 38 38 6 41 83
Packet ID: 16769
Publish received.
 qos: 2 dup: 0
Packet ID: 16770
Publish received.
 qos: 2 dup: 0
Packet ID: 16771
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 84
Packet ID: 16772
DEC:   AA 55 38 38 6 41 85
Publish received.
 qos: 2 dup: 0
Packet ID: 16773
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 86
DEC:   AA 55 38 38 6 41 87
DEC:   AA 55 38 38 6 41 88
Packet ID: 16774
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 89
PROCESS?: 175 175 4 65 135 194
Packet ID: 16775
Publish received.
 qos: 2 dup: 0
Packet ID: 16776
Publish received.
 qos: 2 dup: 0
Packet ID: 16777
DEC:   AA 55 38 38 6 41 8A
Publish received.
 qos: 2 dup: 0
Packet ID: 16778
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 8B
DEC:   AA 55 38 38 6 41 8C
DEC:   AA 55 38 38 6 41 8D
Packet ID: 16779
Publish received.
 qos: 2 dup: 0
Packet ID: 16780
Publish received.
 qos: 2 dup: 0
Packet ID: 16781
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 8E
Packet ID: 16782
DEC:   AA 55 38 38 6 41 8F
Publish received.
 qos: 2 dup: 0
Packet ID: 16783
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 90
DEC:   AA 55 38 38 6 41 91
DEC:   AA 55 38 38 6 41 92
Packet ID: 16784
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 93
PROCESS?: 175 175 4 65 145 212
Packet ID: 16785
Publish received.
 qos: 2 dup: 0
PROCESS?: 175 175 4 65 146 215
Packet ID: 16786
Publish received.
 qos: 2 dup: 0
Packet ID: 16787
DEC:   AA 55 38 38 6 41 94
Publish received.
 qos: 2 dup: 0
Packet ID: 16788
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 95
DEC:   AA 55 38 38 6 41 96
DEC:   AA 55 38 38 6 41 97
DEC:   AA 55 38 38 6 41 98
Packet ID: 16789
Publish received.
 qos: 2 dup: 0
Packet ID: 16790
Publish received.
 qos: 2 dup: 0
Packet ID: 16791
Publish received.
 qos: 2 dup: 0
Packet ID: 16792
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 99
DEC:   AA 55 38 38 6 41 9A
DEC:   AA 55 38 38 6 41 9B
Packet ID: 16793
Publish received.
 qos: 2 dup: 0
Packet ID: 16794
Publish received.
 qos: 2 dup: 0
Packet ID: 16795
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 9C
Packet ID: 16796
DEC:   AA 55 38 38 6 41 9D
Publish received.
 qos: 2 dup: 0
Packet ID: 16797
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 9E
Packet ID: 16798
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 9F
Packet ID: 16799
DEC:   AA 55 38 38 6 41 A0
Publish received.
 qos: 2 dup: 0
Packet ID: 16800
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 A1
DEC:   AA 55 38 38 6 41 A2
DEC:   AA 55 38 38 6 41 A3
Packet ID: 16801
Publish received.
 qos: 2 dup: 0
Packet ID: 16802
Publish received.
 qos: 2 dup: 0
Packet ID: 16803
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 A4
DEC:   AA 55 38 38 6 41 A5
DEC:   AA 55 38 38 6 41 A6
DEC:   AA 55 38 38 6 41 A7
PROCESS?: 175 175 4 65 164 225
Packet ID: 16804
Publish received.
 qos: 2 dup: 0
Packet ID: 16805
Publish received.
 qos: 2 dup: 0
Packet ID: 16806
Publish received.
 qos: 2 dup: 0
Packet ID: 16807
DEC:   AA 55 38 38 6 41 A8
Publish received.
 qos: 2 dup: 0
Packet ID: 16808
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 A9
DEC:   AA 55 38 38 6 41 AA
DEC:   AA 55 38 38 6 41 AB
Packet ID: 16809
Publish received.
 qos: 2 dup: 0
Packet ID: 16810
Publish received.
 qos: 2 dup: 0
Packet ID: 16811
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 AC
Packet ID: 16812
DEC:   AA 55 38 38 6 41 AD
Publish received.
 qos: 2 dup: 0
Packet ID: 16813
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 AE
DEC:   AA 55 38 38 6 41 AF
DEC:   AA 55 38 38 6 41 B0
Packet ID: 16814
Publish received.
 qos: 2 dup: 0
Packet ID: 16815
Publish received.
 qos: 2 dup: 0
Packet ID: 16816
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 B1
Packet ID: 16817
DEC:   AA 55 38 38 6 41 B2
Publish received.
 qos: 2 dup: 0
Packet ID: 16818
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 B3
DEC:   AA 55 38 38 6 41 B4
DEC:   AA 55 38 38 6 41 B5
Packet ID: 16819
Publish received.
 qos: 2 dup: 0
Packet ID: 16820
Publish received.
 qos: 2 dup: 0
Packet ID: 16821
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 B6
DEC:   AA 55 38 38 6 41 B7
DEC:   AA 55 38 38 6 41 B8
Packet ID: 16822
Publish received.
 qos: 2 dup: 0
Packet ID: 16823
Publish received.
 qos: 2 dup: 0
Packet ID: 16824
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 B9
DEC:   AA 55 38 38 6 41 BA
DEC:   AA 55 38 38 6 41 BB
DEC:   AA 55 38 38 6 41 BC
DEC:   AA 55 38 38 6 41 BD
DEC:   AA 55 38 38 6 41 BE
Packet ID: 16825
Publish received.
 qos: 2 dup: 0
Packet ID: 16826
Publish received.
 qos: 2 dup: 0
Packet ID: 16827
Publish received.
 qos: 2 dup: 0
Packet ID: 16828
Publish received.
 qos: 2 dup: 0
Packet ID: 16829
Publish received.
 qos: 2 dup: 0
Packet ID: 16830
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 BF
Packet ID: 16831
DEC:   AA 55 38 38 6 41 C0
Publish received.
 qos: 2 dup: 0
Packet ID: 16832
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 C1
DEC:   AA 55 38 38 6 41 C2
DEC:   AA 55 38 38 6 41 C3
Packet ID: 16833
Publish received.
 qos: 2 dup: 0
Packet ID: 16834
Publish received.
 qos: 2 dup: 0
Packet ID: 16835
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 C4
Packet ID: 16836
DEC:   AA 55 38 38 6 41 C5
Publish received.
 qos: 2 dup: 0
Packet ID: 16837
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 C6
DEC:   AA 55 38 38 6 41 C7
DEC:   AA 55 38 38 6 41 C8
Packet ID: 16838
Publish received.
 qos: 2 dup: 0
Packet ID: 16839
Publish received.
 qos: 2 dup: 0
Packet ID: 16840
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 C9
DEC:   AA 55 38 38 6 41 CA
DEC:   AA 55 38 38 6 41 CB
DEC:   AA 55 38 38 6 41 CC
Packet ID: 16841
Publish received.
 qos: 2 dup: 0
Packet ID: 16842
Publish received.
 qos: 2 dup: 0
Packet ID: 16843
Publish received.
 qos: 2 dup: 0
Packet ID: 16844
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 CD
DEC:   AA 55 38 38 6 41 CE
DEC:   AA 55 38 38 6 41 CF
Packet ID: 16845
Publish received.
 qos: 2 dup: 0
Packet ID: 16846
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 D0
PROCESS?: 175 175 4 65 207 138
Packet ID: 16847
Publish received.
 qos: 2 dup: 0
Packet ID: 16848
DEC:   AA 55 38 38 6 41 D1
Publish received.
 qos: 2 dup: 0
Packet ID: 16849
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 D2
DEC:   AA 55 38 38 6 41 D3
DEC:   AA 55 38 38 6 41 D4
Packet ID: 16850
Publish received.
 qos: 2 dup: 0
Packet ID: 16851
Publish received.
 qos: 2 dup: 0
Packet ID: 16852
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 D5
Packet ID: 16853
DEC:   AA 55 38 38 6 41 D6
Publish received.
 qos: 2 dup: 0
Packet ID: 16854
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 D7
DEC:   AA 55 38 38 6 41 D8
DEC:   AA 55 38 38 6 41 D9
Packet ID: 16855
Publish received.
 qos: 2 dup: 0
Packet ID: 16856
Publish received.
 qos: 2 dup: 0
Packet ID: 16857
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 DA
DEC:   AA 55 38 38 6 41 DB
DEC:   AA 55 38 38 6 41 DC
Packet ID: 16858
Publish received.
 qos: 2 dup: 0
Packet ID: 16859
Publish received.
 qos: 2 dup: 0
Packet ID: 16860
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 DD
DEC:   AA 55 38 38 6 41 DE
DEC:   AA 55 38 38 6 41 DF
Packet ID: 16861
Publish received.
 qos: 2 dup: 0
Packet ID: 16862
Publish received.
 qos: 2 dup: 0
Packet ID: 16863
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 E0
Packet ID: 16864
DEC:   AA 55 38 38 6 41 E1
Publish received.
 topic: teensquitto/ payload: hello world
 qos: 2 dup: 0
DEC:   AA 55 EA EA 11 0
DEC:   AA 55 38 38 6 41 E2
Packet ID: 16865
Publish received.
 qos: 2 dup: 0
Packet ID: 16866
DEC:   AA 55 38 38 6 41 E3
Publish received.
 qos: 2 dup: 0
 retain: 0 len: 11 index: 0 total: 11
Packet ID: 16867
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 E4
DEC:   AA 55 38 38 6 41 E5
DEC:   AA 55 38 38 6 41 E6
Packet ID: 16868
Publish received.
 qos: 2 dup: 0
Packet ID: 16869
Publish received.
 qos: 2 dup: 0
Packet ID: 16870
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 E7
Packet ID: 16871
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 E8
Packet ID: 16872
DEC:   AA 55 38 38 6 41 E9
Publish received.
 qos: 2 dup: 0
Packet ID: 16873
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 EA
DEC:   AA 55 38 38 6 41 EB
DEC:   AA 55 38 38 6 41 EC
Packet ID: 16874
Publish received.
 qos: 2 dup: 0
Packet ID: 16875
Publish received.
 qos: 2 dup: 0
Packet ID: 16876
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 ED
Packet ID: 16877
DEC:   AA 55 38 38 6 41 EE
Publish received.
 qos: 2 dup: 0
Packet ID: 16878
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 EF
Packet ID: 16879
DEC:   AA 55 38 38 6 41 F0
Publish received.
 qos: 2 dup: 0
Packet ID: 16880
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 F1
DEC:   AA 55 38 38 6 41 F2
DEC:   AA 55 38 38 6 41 F3
Packet ID: 16881
Publish received.
 qos: 2 dup: 0
Packet ID: 16882
Publish received.
 qos: 2 dup: 0
Packet ID: 16883
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 F4
Packet ID: 16884
DEC:   AA 55 38 38 6 41 F5
Publish received.
 qos: 2 dup: 0
Packet ID: 16885
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 F6
DEC:   AA 55 38 38 6 41 F7
Packet ID: 16886
Publish received.
 qos: 2 dup: 0
Packet ID: 16887
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 F8
Packet ID: 16888
DEC:   AA 55 38 38 6 41 F9
Publish received.
 qos: 2 dup: 0
Packet ID: 16889
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 FA
DEC:   AA 55 38 38 6 41 FB
DEC:   AA 55 38 38 6 41 FC
Packet ID: 16890
Publish received.
 qos: 2 dup: 0
Packet ID: 16891
Publish received.
 qos: 2 dup: 0
Packet ID: 16892
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 41 FD
DEC:   AA 55 38 38 6 41 FE
DEC:   AA 55 38 38 6 41 FF
Packet ID: 16893
Publish received.
 qos: 2 dup: 0
Packet ID: 16894
Publish received.
 qos: 2 dup: 0
Packet ID: 16895
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 0
DEC:   AA 55 38 38 6 42 1
DEC:   AA 55 38 38 6 42 2
Packet ID: 16896
Publish received.
 qos: 2 dup: 0
Packet ID: 16897
Publish received.
 qos: 2 dup: 0
Packet ID: 16898
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 3
Packet ID: 16899
DEC:   AA 55 38 38 6 42 4
Publish received.
 qos: 2 dup: 0
Packet ID: 16900
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 5
DEC:   AA 55 38 38 6 42 6
DEC:   AA 55 38 38 6 42 7
Packet ID: 16901
Publish received.
 qos: 2 dup: 0
Packet ID: 16902
Publish received.
 qos: 2 dup: 0
Packet ID: 16903
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 8
DEC:   AA 55 38 38 6 42 9
DEC:   AA 55 38 38 6 42 A
Packet ID: 16904
Publish received.
 qos: 2 dup: 0
Packet ID: 16905
Publish received.
 qos: 2 dup: 0
Packet ID: 16906
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 B
Packet ID: 16907
DEC:   AA 55 38 38 6 42 C
Publish received.
 qos: 2 dup: 0
Packet ID: 16908
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 D
DEC:   AA 55 38 38 6 42 E
DEC:   AA 55 38 38 6 42 F
Packet ID: 16909
Publish received.
 qos: 2 dup: 0
Packet ID: 16910
Publish received.
 qos: 2 dup: 0
Packet ID: 16911
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 10
DEC:   AA 55 38 38 6 42 11
DEC:   AA 55 38 38 6 42 12
Packet ID: 16912
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 13
Packet ID: 16913
Publish received.
 qos: 2 dup: 0
Packet ID: 16914
Publish received.
 qos: 2 dup: 0
Packet ID: 16915
DEC:   AA 55 38 38 6 42 14
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 15
Packet ID: 16916
Publish received.
 qos: 2 dup: 0
Packet ID: 16917
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 16
DEC:   AA 55 38 38 6 42 17
DEC:   AA 55 38 38 6 42 18
Packet ID: 16918
Publish received.
 qos: 2 dup: 0
Packet ID: 16919
Publish received.
 qos: 2 dup: 0
Packet ID: 16920
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 19
Packet ID: 16921
DEC:   AA 55 38 38 6 42 1A
Publish received.
 qos: 2 dup: 0
Packet ID: 16922
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 1B
DEC:   AA 55 38 38 6 42 1C
DEC:   AA 55 38 38 6 42 1D
Packet ID: 16923
Publish received.
 qos: 2 dup: 0
Packet ID: 16924
Publish received.
 qos: 2 dup: 0
Packet ID: 16925
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 1E
DEC:   AA 55 38 38 6 42 1F
DEC:   AA 55 38 38 6 42 20
Packet ID: 16926
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 21
Packet ID: 16927
Publish received.
 qos: 2 dup: 0
Packet ID: 16928
Publish received.
 qos: 2 dup: 0
Packet ID: 16929
DEC:   AA 55 38 38 6 42 22
Publish received.
 qos: 2 dup: 0
Packet ID: 16930
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 23
DEC:   AA 55 38 38 6 42 24
DEC:   AA 55 38 38 6 42 25
Packet ID: 16931
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 26
PROCESS?: 175 175 4 66 36 98
Packet ID: 16932
Publish received.
 qos: 2 dup: 0
PROCESS?: 175 175 4 66 37 99
Packet ID: 16933
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 27
DEC:   AA 55 38 38 6 42 28
Packet ID: 16934
Publish received.
 qos: 2 dup: 0
Packet ID: 16935
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 29
Packet ID: 16936
Publish received.
 qos: 2 dup: 0
Packet ID: 16937
DEC:   AA 55 38 38 6 42 2A
Publish received.
 qos: 2 dup: 0
Packet ID: 16938
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 2B
DEC:   AA 55 38 38 6 42 2C
Packet ID: 16939
DEC:   AA 55 38 38 6 42 2D
Publish received.
 qos: 2 dup: 0
Packet ID: 16940
Publish received.
 qos: 2 dup: 0
Packet ID: 16941
DEC:   AA 55 38 38 6 42 2E
Publish received.
 qos: 2 dup: 0
Packet ID: 16942
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 2F
DEC:   AA 55 38 38 6 42 30
DEC:   AA 55 38 38 6 42 31
DEC:   AA 55 38 38 6 42 32
Packet ID: 16943
Publish received.
 qos: 2 dup: 0
Packet ID: 16944
Publish received.
 qos: 2 dup: 0
Packet ID: 16945
Publish received.
 qos: 2 dup: 0
Packet ID: 16946
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 33
DEC:   AA 55 38 38 6 42 34
DEC:   AA 55 38 38 6 42 35
Packet ID: 16947
Publish received.
 qos: 2 dup: 0
Packet ID: 16948
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 36
Packet ID: 16949
Publish received.
 qos: 2 dup: 0
Packet ID: 16950
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 37
Packet ID: 16951
DEC:   AA 55 38 38 6 42 38
Publish received.
 qos: 2 dup: 0
Packet ID: 16952
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 39
DEC:   AA 55 38 38 6 42 3A
DEC:   AA 55 38 38 6 42 3B
Packet ID: 16953
Publish received.
 qos: 2 dup: 0
Packet ID: 16954
Publish received.
 qos: 2 dup: 0
Packet ID: 16955
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 3C
DEC:   AA 55 38 38 6 42 3D
DEC:   AA 55 38 38 6 42 3E
DEC:   AA 55 38 38 6 42 3F
PROCESS?: 175 175 4 66 60 122
Packet ID: 16956
Publish received.
 qos: 2 dup: 0
Packet ID: 16957
Publish received.
 qos: 2 dup: 0
Packet ID: 16958
Publish received.
 qos: 2 dup: 0
Packet ID: 16959
DEC:   AA 55 38 38 6 42 40
Publish received.
 qos: 2 dup: 0
Packet ID: 16960
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 41
DEC:   AA 55 38 38 6 42 42
DEC:   AA 55 38 38 6 42 43
Packet ID: 16961
Publish received.
 qos: 2 dup: 0
Packet ID: 16962
Publish received.
 qos: 2 dup: 0
Packet ID: 16963
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 44
DEC:   AA 55 CE CE 5 0 0 0 13
Packet ID: 16964
DEC:   AA 55 38 38 6 42 45
Publish received.
 qos: 2 dup: 0
Packet ID: 16965
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 46
Packet ID: 16966
DEC:   AA 55 38 38 6 42 47
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 48
DEC:   AA 55 38 38 6 42 49
DEC:   AA 55 38 38 6 42 4A
Packet ID: 16967
Publish received.
 qos: 2 dup: 0
Packet ID: 16968
Publish received.
 qos: 2 dup: 0
Packet ID: 16969
Publish received.
 qos: 2 dup: 0
Packet ID: 16970
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 4B
DEC:   AA 55 38 38 6 42 4C
DEC:   AA 55 38 38 6 42 4D
Packet ID: 16971
Publish received.
 qos: 2 dup: 0
Packet ID: 16972
Publish received.
 qos: 2 dup: 0
Packet ID: 16973
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 4E
Packet ID: 16974
DEC:   AA 55 38 38 6 42 4F
Publish received.
 qos: 2 dup: 0
Packet ID: 16975
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 50
DEC:   AA 55 38 38 6 42 51
DEC:   AA 55 38 38 6 42 52
Packet ID: 16976
Publish received.
 qos: 2 dup: 0
Packet ID: 16977
Publish received.
 qos: 2 dup: 0
Packet ID: 16978
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 53
DEC:   AA 55 38 38 6 42 54
DEC:   AA 55 38 38 6 42 55
Packet ID: 16979
Publish received.
 qos: 2 dup: 0
Packet ID: 16980
Publish received.
 qos: 2 dup: 0
Packet ID: 16981
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 56
Packet ID: 16982
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 57
DEC:   AA 55 38 38 6 42 58
DEC:   AA 55 38 38 6 42 59
DEC:   AA 55 38 38 6 42 5A
Packet ID: 16983
Publish received.
 qos: 2 dup: 0
Packet ID: 16984
Publish received.
 qos: 2 dup: 0
Packet ID: 16985
Publish received.
 qos: 2 dup: 0
Packet ID: 16986
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 5B
DEC:   AA 55 38 38 6 42 5C
Packet ID: 16987
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 5D
Packet ID: 16988
Publish received.
 qos: 2 dup: 0
Packet ID: 16989
DEC:   AA 55 38 38 6 42 5E
Publish received.
 qos: 2 dup: 0
Packet ID: 16990
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 5F
DEC:   AA 55 38 38 6 42 60
DEC:   AA 55 38 38 6 42 61
Packet ID: 16991
Publish received.
 qos: 2 dup: 0
Packet ID: 16992
Publish received.
 qos: 2 dup: 0
Packet ID: 16993
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 62
Packet ID: 16994
DEC:   AA 55 38 38 6 42 63
Publish received.
 qos: 2 dup: 0
Packet ID: 16995
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 64
DEC:   AA 55 38 38 6 42 65
DEC:   AA 55 38 38 6 42 66
Packet ID: 16996
Publish received.
 qos: 2 dup: 0
Packet ID: 16997
Publish received.
 qos: 2 dup: 0
Packet ID: 16998
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 67
Packet ID: 16999
DEC:   AA 55 38 38 6 42 68
Publish received.
 qos: 2 dup: 0
Packet ID: 17000
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 69
Packet ID: 17001
DEC:   AA 55 38 38 6 42 6A
Publish received.
 qos: 2 dup: 0
Packet ID: 17002
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 6B
DEC:   AA 55 38 38 6 42 6C
DEC:   AA 55 38 38 6 42 6D
Packet ID: 17003
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 6E
PROCESS?: 175 175 4 66 108 42
Packet ID: 17004
Publish received.
 qos: 2 dup: 0
PROCESS?: 175 175 4 66 109 43
Packet ID: 17005
Publish received.
 qos: 2 dup: 0
Packet ID: 17006
DEC:   AA 55 38 38 6 42 6F
Publish received.
 qos: 2 dup: 0
Packet ID: 17007
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 70
DEC:   AA 55 38 38 6 42 71
DEC:   AA 55 38 38 6 42 72
Packet ID: 17008
Publish received.
 qos: 2 dup: 0
Packet ID: 17009
Publish received.
 qos: 2 dup: 0
Packet ID: 17010
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 73
Packet ID: 17011
DEC:   AA 55 38 38 6 42 74
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 75
Packet ID: 17012
Publish received.
 qos: 2 dup: 0
Packet ID: 17013
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 76
DEC:   AA 55 38 38 6 42 77
DEC:   AA 55 38 38 6 42 78
Packet ID: 17014
Publish received.
 qos: 2 dup: 0
Packet ID: 17015
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 79
PROCESS?: 175 175 4 66 120 62
Packet ID: 17016
Publish received.
 qos: 2 dup: 0
Packet ID: 17017
DEC:   AA 55 38 38 6 42 7A
Publish received.
 qos: 2 dup: 0
Packet ID: 17018
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 7B
DEC:   AA 55 38 38 6 42 7C
DEC:   AA 55 38 38 6 42 7D
Packet ID: 17019
Publish received.
 qos: 2 dup: 0
Packet ID: 17020
Publish received.
 qos: 2 dup: 0
Packet ID: 17021
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 7E
DEC:   AA 55 38 38 6 42 7F
DEC:   AA 55 38 38 6 42 80
Packet ID: 17022
Publish received.
 qos: 2 dup: 0
Packet ID: 17023
Publish received.
 qos: 2 dup: 0
Packet ID: 17024
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 81
Packet ID: 17025
DEC:   AA 55 38 38 6 42 82
Publish received.
 qos: 2 dup: 0
Packet ID: 17026
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 83
DEC:   AA 55 38 38 6 42 84
DEC:   AA 55 38 38 6 42 85
Packet ID: 17027
Publish received.
 qos: 2 dup: 0
Packet ID: 17028
Publish received.
 qos: 2 dup: 0
Packet ID: 17029
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 86
DEC:   AA 55 38 38 6 42 87
DEC:   AA 55 38 38 6 42 88
DEC:   AA 55 38 38 6 42 89
Packet ID: 17030
Publish received.
 qos: 2 dup: 0
Packet ID: 17031
Publish received.
 qos: 2 dup: 0
Packet ID: 17032
Publish received.
 qos: 2 dup: 0
Packet ID: 17033
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 8A
DEC:   AA 55 38 38 6 42 8B
DEC:   AA 55 38 38 6 42 8C
Packet ID: 17034
Publish received.
 qos: 2 dup: 0
Packet ID: 17035
Publish received.
 qos: 2 dup: 0
Packet ID: 17036
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 8D
DEC:   AA 55 38 38 6 42 8E
DEC:   AA 55 38 38 6 42 8F
Packet ID: 17037
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 90
PROCESS?: 175 175 4 66 142 200
Packet ID: 17038
Publish received.
 qos: 2 dup: 0
PROCESS?: 175 175 4 66 143 201
Packet ID: 17039
Publish received.
 qos: 2 dup: 0
Packet ID: 17040
DEC:   AA 55 38 38 6 42 91
Publish received.
 qos: 2 dup: 0
Packet ID: 17041
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 92
DEC:   AA 55 38 38 6 42 93
DEC:   AA 55 38 38 6 42 94
Packet ID: 17042
Publish received.
 qos: 2 dup: 0
Packet ID: 17043
Publish received.
 qos: 2 dup: 0
Packet ID: 17044
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 95
Packet ID: 17045
DEC:   AA 55 38 38 6 42 96
Publish received.
 qos: 2 dup: 0
Packet ID: 17046
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 97
DEC:   AA 55 38 38 6 42 98
DEC:   AA 55 38 38 6 42 99
Packet ID: 17047
Publish received.
 qos: 2 dup: 0
Packet ID: 17048
Publish received.
 qos: 2 dup: 0
Packet ID: 17049
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 9A
Packet ID: 17050
DEC:   AA 55 38 38 6 42 9B
Publish received.
 qos: 2 dup: 0
Packet ID: 17051
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 9C
DEC:   AA 55 38 38 6 42 9D
DEC:   AA 55 38 38 6 42 9E
Packet ID: 17052
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 9F
DEC:   AA 55 38 38 6 42 A0
Packet ID: 17053
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 A1
DEC:   AA 55 38 38 6 42 A2
PROCESS?: 175 175 4 66 158 216
Packet ID: 17054
Publish received.
 qos: 2 dup: 0
Packet ID: 17055
Publish received.
 qos: 2 dup: 0
Packet ID: 17056
Publish received.
 qos: 2 dup: 0
Packet ID: 17057
Publish received.
 qos: 2 dup: 0
Packet ID: 17058
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 A3
Packet ID: 17059
DEC:   AA 55 38 38 6 42 A4
Publish received.
 qos: 2 dup: 0
Packet ID: 17060
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 A5
DEC:   AA 55 38 38 6 42 A6
DEC:   AA 55 38 38 6 42 A7
Packet ID: 17061
Publish received.
 qos: 2 dup: 0
Packet ID: 17062
Publish received.
 qos: 2 dup: 0
Packet ID: 17063
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 A8
Packet ID: 17064
DEC:   AA 55 38 38 6 42 A9
Publish received.
 qos: 2 dup: 0
Packet ID: 17065
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 AA
DEC:   AA 55 38 38 6 42 AB
DEC:   AA 55 38 38 6 42 AC
Packet ID: 17066
Publish received.
 qos: 2 dup: 0
Packet ID: 17067
Publish received.
 qos: 2 dup: 0
Packet ID: 17068
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 AD
DEC:   AA 55 38 38 6 42 AE
DEC:   AA 55 38 38 6 42 AF
DEC:   AA 55 38 38 6 42 B0
Packet ID: 17069
Publish received.
 qos: 2 dup: 0
Packet ID: 17070
Publish received.
 qos: 2 dup: 0
Packet ID: 17071
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 B1
Packet ID: 17072
Publish received.
 qos: 2 dup: 0
Packet ID: 17073
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 B2
DEC:   AA 55 38 38 6 42 B3
DEC:   AA 55 38 38 6 42 B4
Packet ID: 17074
Publish received.
 qos: 2 dup: 0
Packet ID: 17075
Publish received.
 qos: 2 dup: 0
Packet ID: 17076
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 B5
Packet ID: 17077
DEC:   AA 55 38 38 6 42 B6
Publish received.
 qos: 2 dup: 0
Packet ID: 17078
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 B7
DEC:   AA 55 38 38 6 42 B8
DEC:   AA 55 38 38 6 42 B9
Packet ID: 17079
Publish received.
 qos: 2 dup: 0
Packet ID: 17080
Publish received.
 qos: 2 dup: 0
Packet ID: 17081
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 BA
DEC:   AA 55 38 38 6 42 BB
DEC:   AA 55 38 38 6 42 BC
Packet ID: 17082
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 BD
PROCESS?: 175 175 4 66 187 253
Packet ID: 17083
Publish received.
 qos: 2 dup: 0
PROCESS?: 175 175 4 66 188 250
Packet ID: 17084
Publish received.
 qos: 2 dup: 0
Packet ID: 17085
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 BE
DEC:   AA 55 38 38 6 42 BF
DEC:   AA 55 38 38 6 42 C0
Packet ID: 17086
Publish received.
 qos: 2 dup: 0
Packet ID: 17087
Publish received.
 qos: 2 dup: 0
Packet ID: 17088
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 C1
DEC:   AA 55 38 38 6 42 C2
DEC:   AA 55 38 38 6 42 C3
DEC:   AA 55 38 38 6 42 C4
Packet ID: 17089
Publish received.
 qos: 2 dup: 0
Packet ID: 17090
Publish received.
 qos: 2 dup: 0
Packet ID: 17091
Publish received.
 qos: 2 dup: 0
Packet ID: 17092
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 C5
DEC:   AA 55 38 38 6 42 C6
DEC:   AA 55 38 38 6 42 C7
Packet ID: 17093
Publish received.
 qos: 2 dup: 0
Packet ID: 17094
Publish received.
 qos: 2 dup: 0
Packet ID: 17095
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 C8
Packet ID: 17096
DEC:   AA 55 38 38 6 42 C9
Publish received.
 qos: 2 dup: 0
Packet ID: 17097
Publish received.
 qos: 2 dup: 0
DEC:   AA 55 38 38 6 42 CA
DEC:   AA 55 38 38 6 42 CB
DEC:   AA 55 38 38 6 42 CC
Packet ID: 17098
the current test is running at 2megabaud speeds
queues are being popped from the front and pushed in the back :)
