Arduino: 1.8.7 (Windows 7), TD: 1.44-beta2, Board: "Adafruit Feather HUZZAH ESP8266, 80 MHz, Flash, 4M (1M SPIFFS), v2 Lower Memory, Disabled, None, Only Sketch, 921600"
Teensquitto:75:1: error: 'uint8_t' does not name a type
uint8_t events() {
Teensquitto:118:22: error: variable or field 'processing_data' declared void
void processing_data(uint8_t *data, uint16_t len) {
Teensquitto:118:22: error: 'uint8_t' was not declared in this scope
Teensquitto:118:31: error: 'data' was not declared in this scope
Teensquitto:118:37: error: 'uint16_t' was not declared in this scope
MQTT_HANDLERS:16:23: error: variable or field 'onMqttDisconnect' declared void
void onMqttDisconnect(AsyncMqttClientDisconnectReason reason) {
MQTT_HANDLERS:16:23: error: 'AsyncMqttClientDisconnectReason' was not declared in this scope
MQTT_HANDLERS:26:22: error: variable or field 'onMqttSubscribe' declared void
void onMqttSubscribe(uint16_t packetId, uint8_t qos) {
MQTT_HANDLERS:26:22: error: 'uint16_t' was not declared in this scope
MQTT_HANDLERS:26:41: error: 'uint8_t' was not declared in this scope
MQTT_HANDLERS:37:24: error: variable or field 'onMqttUnsubscribe' declared void
void onMqttUnsubscribe(uint16_t packetId) {
MQTT_HANDLERS:37:24: error: 'uint16_t' was not declared in this scope
MQTT_HANDLERS:47:20: error: variable or field 'onMqttPublish' declared void
void onMqttPublish(uint16_t packetId) {
MQTT_HANDLERS:47:20: error: 'uint16_t' was not declared in this scope
MQTT_HANDLERS:57:48: error: 'AsyncMqttClientMessageProperties' has not been declared
void onMqttMessage(char* topic, char* payload, AsyncMqttClientMessageProperties properties, size_t len, size_t index, size_t total) {
MQTT_HANDLERS:57:93: error: 'size_t' has not been declared
MQTT_HANDLERS:57:105: error: 'size_t' has not been declared
MQTT_HANDLERS:57:119: error: 'size_t' has not been declared
WEBSOCKET_HANDLERS:1:27: error: variable or field 'webSocketEventServer' declared void
void webSocketEventServer(uint8_t num, WStype_t type, uint8_t * payload, size_t length) {
WEBSOCKET_HANDLERS:1:27: error: 'uint8_t' was not declared in this scope
WEBSOCKET_HANDLERS:1:40: error: 'WStype_t' was not declared in this scope
WEBSOCKET_HANDLERS:1:55: error: 'uint8_t' was not declared in this scope
WEBSOCKET_HANDLERS:1:65: error: 'payload' was not declared in this scope
WEBSOCKET_HANDLERS:1:74: error: 'size_t' was not declared in this scope
WEBSOCKET_HANDLERS:17:27: error: variable or field 'webSocketEventClient' declared void
void webSocketEventClient(WStype_t type, uint8_t * payload, size_t length) {
WEBSOCKET_HANDLERS:17:27: error: 'WStype_t' was not declared in this scope
WEBSOCKET_HANDLERS:17:42: error: 'uint8_t' was not declared in this scope
WEBSOCKET_HANDLERS:17:52: error: 'payload' was not declared in this scope
WEBSOCKET_HANDLERS:17:61: error: 'size_t' was not declared in this scope
WIFI_HANDLERS:11:33: error: 'WiFiEventStationModeGotIP' does not name a type
void onStationModeGotIPCB(const WiFiEventStationModeGotIP& event) {
WIFI_HANDLERS:11:60: error: ISO C++ forbids declaration of 'event' with no type [-fpermissive]
WIFI_HANDLERS:31:40: error: 'WiFiEventStationModeDisconnected' does not name a type
void onStationModeDisconnectedCB(const WiFiEventStationModeDisconnected& event) {
WIFI_HANDLERS:31:74: error: ISO C++ forbids declaration of 'event' with no type [-fpermissive]
WIFI_HANDLERS:52:37: error: 'WiFiEventStationModeConnected' does not name a type
void onStationModeConnectedCB(const WiFiEventStationModeConnected& event) {
WIFI_HANDLERS:52:68: error: ISO C++ forbids declaration of 'event' with no type [-fpermissive]
WIFI_HANDLERS:76:43: error: 'WiFiEventStationModeAuthModeChanged' does not name a type
void onStationModeAuthModeChangedCB(const WiFiEventStationModeAuthModeChanged& event) {
WIFI_HANDLERS:76:80: error: ISO C++ forbids declaration of 'event' with no type [-fpermissive]
WIFI_HANDLERS:94:43: error: 'WiFiEventSoftAPModeStationConnected' does not name a type
void onSoftAPModeStationConnectedCB(const WiFiEventSoftAPModeStationConnected& event) {
WIFI_HANDLERS:94:80: error: ISO C++ forbids declaration of 'event' with no type [-fpermissive]
WIFI_HANDLERS:109:46: error: 'WiFiEventSoftAPModeStationDisconnected' does not name a type
void onSoftAPModeStationDisconnectedCB(const WiFiEventSoftAPModeStationDisconnected& event) {
WIFI_HANDLERS:109:86: error: ISO C++ forbids declaration of 'event' with no type [-fpermissive]
WIFI_HANDLERS:124:47: error: 'WiFiEventSoftAPModeProbeRequestReceived' does not name a type
void onSoftAPModeProbeRequestReceivedCB(const WiFiEventSoftAPModeProbeRequestReceived& event) {
WIFI_HANDLERS:124:88: error: ISO C++ forbids declaration of 'event' with no type [-fpermissive]
WIFI_HANDLERS:143:25: error: variable or field '_wifi_state_notify' declared void
void _wifi_state_notify(int8_t status) {
WIFI_HANDLERS:143:25: error: 'int8_t' was not declared in this scope
Teensquitto:56:6: error: previous declaration of 'void setup()' with 'C++' linkage
In file included from G:\Dropbox (Personal)\Arduino\libraries\async-mqtt-client\src/AsyncMqttClient.hpp:6:0,
from G:\Dropbox (Personal)\Arduino\libraries\async-mqtt-client\src/AsyncMqttClient.h:4,
from C:\Users\Simi\AppData\Local\Temp\arduino_modified_sketch_56491\Teensquitto.ino:1:
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Arduino.h:221:16: error: conflicts with new declaration with 'C' linkage
void setup(void);
Teensquitto:66:6: error: previous declaration of 'void loop()' with 'C++' linkage
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Arduino.h:222:15: error: conflicts with new declaration with 'C' linkage
void loop(void);
In file included from C:\Users\Simi\AppData\Local\Temp\arduino_modified_sketch_56491\Teensquitto.ino:24:0:
G:\Dropbox (Personal)\Arduino\libraries\FastLED-master/FastLED.h:14:21: note: #pragma message: FastLED version 3.002.001
# pragma message "FastLED version 3.002.001"
In file included from G:\Dropbox (Personal)\Arduino\libraries\FastLED-master/FastLED.h:65:0,
G:\Dropbox (Personal)\Arduino\libraries\FastLED-master/fastspi.h:110:23: note: #pragma message: No hardware SPI pins defined. All SPI access will default to bitbanged output
# pragma message "No hardware SPI pins defined. All SPI access will default to bitbanged output"
In file included from G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/ESPAsyncUDP.h:7:0,
from C:\Users\Simi\AppData\Local\Temp\arduino_modified_sketch_56491\Teensquitto.ino:32:
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:43:15: error: redeclaration of 'FM_QIO'
FM_QIO = 0x00,
In file included from C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Arduino.h:262:0,
from G:\Dropbox (Personal)\Arduino\libraries\async-mqtt-client\src/AsyncMqttClient.hpp:6,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:78:6: note: previous declaration 'FlashMode_t FM_QIO'
FM_QIO = 0x00,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:44:16: error: redeclaration of 'FM_QOUT'
FM_QOUT = 0x01,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:79:6: note: previous declaration 'FlashMode_t FM_QOUT'
FM_QOUT = 0x01,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:45:15: error: redeclaration of 'FM_DIO'
FM_DIO = 0x02,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:80:6: note: previous declaration 'FlashMode_t FM_DIO'
FM_DIO = 0x02,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:46:16: error: redeclaration of 'FM_DOUT'
FM_DOUT = 0x03,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:81:6: note: previous declaration 'FlashMode_t FM_DOUT'
FM_DOUT = 0x03,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:47:19: error: redeclaration of 'FM_UNKNOWN'
FM_UNKNOWN = 0xff
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:82:6: note: previous declaration 'FlashMode_t FM_UNKNOWN'
FM_UNKNOWN = 0xff
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:48:3: error: conflicting declaration 'typedef enum FlashMode_t FlashMode_t'
} FlashMode_t;
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:83:3: error: 'FlashMode_t' has a previous declaration as 'typedef enum FlashMode_t FlashMode_t'
} FlashMode_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:49:6: error: multiple definition of 'enum RFMode'
enum RFMode {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:51:6: error: previous definition here
enum RFMode {
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:56:19: error: redeclaration of 'WDTO_0MS'
WDTO_0MS = 0, //!< WDTO_0MS
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:30:5: note: previous declaration 'WDTO_t WDTO_0MS'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:57:19: error: redeclaration of 'WDTO_15MS'
WDTO_15MS = 15, //!< WDTO_15MS
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:31:5: note: previous declaration 'WDTO_t WDTO_15MS'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:58:19: error: redeclaration of 'WDTO_30MS'
WDTO_30MS = 30, //!< WDTO_30MS
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:32:5: note: previous declaration 'WDTO_t WDTO_30MS'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:59:19: error: redeclaration of 'WDTO_60MS'
WDTO_60MS = 60, //!< WDTO_60MS
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:33:5: note: previous declaration 'WDTO_t WDTO_60MS'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:60:19: error: redeclaration of 'WDTO_120MS'
WDTO_120MS = 120, //!< WDTO_120MS
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:34:5: note: previous declaration 'WDTO_t WDTO_120MS'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:61:19: error: redeclaration of 'WDTO_250MS'
WDTO_250MS = 250, //!< WDTO_250MS
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:35:5: note: previous declaration 'WDTO_t WDTO_250MS'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:62:19: error: redeclaration of 'WDTO_500MS'
WDTO_500MS = 500, //!< WDTO_500MS
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:36:5: note: previous declaration 'WDTO_t WDTO_500MS'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:63:19: error: redeclaration of 'WDTO_1S'
WDTO_1S = 1000,//!< WDTO_1S
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:37:5: note: previous declaration 'WDTO_t WDTO_1S'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:64:19: error: redeclaration of 'WDTO_2S'
WDTO_2S = 2000,//!< WDTO_2S
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:38:5: note: previous declaration 'WDTO_t WDTO_2S'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:65:19: error: redeclaration of 'WDTO_4S'
WDTO_4S = 4000,//!< WDTO_4S
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:39:5: note: previous declaration 'WDTO_t WDTO_4S'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:66:19: error: redeclaration of 'WDTO_8S'
WDTO_8S = 8000 //!< WDTO_8S
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:40:5: note: previous declaration 'WDTO_t WDTO_8S'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:67:3: error: conflicting declaration 'typedef enum WDTO_t WDTO_t'
} WDTO_t;
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Esp.h:41:3: error: 'WDTO_t' has a previous declaration as 'typedef enum WDTO_t WDTO_t'
} WDTO_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:70:27: error: redeclaration of 'WL_NO_SHIELD'
WL_NO_SHIELD = 255, // for compatibility with WiFi Shield library
In file included from C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFi.h:28:0,
from C:\Users\Simi\AppData\Local\Temp\arduino_modified_sketch_56491\Teensquitto.ino:3:
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/include/wl_definitions.h:51:5: note: previous declaration 'wl_status_t WL_NO_SHIELD'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:71:27: error: redeclaration of 'WL_IDLE_STATUS'
WL_IDLE_STATUS = 0,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/include/wl_definitions.h:52:5: note: previous declaration 'wl_status_t WL_IDLE_STATUS'
WL_IDLE_STATUS = 0,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:72:27: error: redeclaration of 'WL_NO_SSID_AVAIL'
WL_NO_SSID_AVAIL = 1,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/include/wl_definitions.h:53:5: note: previous declaration 'wl_status_t WL_NO_SSID_AVAIL'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:73:27: error: redeclaration of 'WL_SCAN_COMPLETED'
WL_SCAN_COMPLETED = 2,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/include/wl_definitions.h:54:5: note: previous declaration 'wl_status_t WL_SCAN_COMPLETED'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:74:27: error: redeclaration of 'WL_CONNECTED'
WL_CONNECTED = 3,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/include/wl_definitions.h:55:5: note: previous declaration 'wl_status_t WL_CONNECTED'
WL_CONNECTED = 3,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:75:27: error: redeclaration of 'WL_CONNECT_FAILED'
WL_CONNECT_FAILED = 4,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/include/wl_definitions.h:56:5: note: previous declaration 'wl_status_t WL_CONNECT_FAILED'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:76:27: error: redeclaration of 'WL_CONNECTION_LOST'
WL_CONNECTION_LOST = 5,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/include/wl_definitions.h:57:5: note: previous declaration 'wl_status_t WL_CONNECTION_LOST'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:77:27: error: redeclaration of 'WL_DISCONNECTED'
WL_DISCONNECTED = 6
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/include/wl_definitions.h:58:5: note: previous declaration 'wl_status_t WL_DISCONNECTED'
WL_DISCONNECTED = 6
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:78:3: error: conflicting declaration 'typedef enum wl_status_t wl_status_t'
} wl_status_t;
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/include/wl_definitions.h:59:3: error: 'wl_status_t' has a previous declaration as 'typedef enum wl_status_t wl_status_t'
} wl_status_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:93:14: error: multiple definition of 'enum WiFiMode'
typedef enum WiFiMode {
In file included from C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFi.h:33:0,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:35:14: error: previous definition here
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:98:13: error: invalid type in declaration before ';' token
} WiFiMode_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:98:13: error: conflicting declaration 'typedef int WiFiMode_t'
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:38:3: error: 'WiFiMode_t' has a previous declaration as 'typedef enum WiFiMode WiFiMode_t'
} WiFiMode_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:100:14: error: multiple definition of 'enum WiFiPhyMode'
typedef enum WiFiPhyMode {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:40:14: error: previous definition here
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:104:16: error: invalid type in declaration before ';' token
} WiFiPhyMode_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:104:16: error: conflicting declaration 'typedef int WiFiPhyMode_t'
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:43:3: error: 'WiFiPhyMode_t' has a previous declaration as 'typedef enum WiFiPhyMode WiFiPhyMode_t'
} WiFiPhyMode_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:106:14: error: multiple definition of 'enum WiFiSleepType'
typedef enum WiFiSleepType {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:45:14: error: previous definition here
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:110:18: error: invalid type in declaration before ';' token
} WiFiSleepType_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:110:18: error: conflicting declaration 'typedef int WiFiSleepType_t'
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:48:3: error: 'WiFiSleepType_t' has a previous declaration as 'typedef enum WiFiSleepType WiFiSleepType_t'
} WiFiSleepType_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:112:6: error: multiple definition of 'enum wl_enc_type'
enum wl_enc_type {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/include/wl_definitions.h:62:6: error: previous definition here
enum wl_enc_type { /* Values map to 802.11 encryption suites... */
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:120:6: error: multiple definition of 'enum fs::SeekMode'
enum SeekMode {
In file included from C:\Users\Simi\AppData\Local\Temp\arduino_modified_sketch_56491\Teensquitto.ino:29:0:
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/FS.h:42:6: error: previous definition here
enum SeekMode {
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:126:8: error: redefinition of 'struct fs::FSInfo'
struct FSInfo {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/FS.h:93:8: error: previous definition of 'struct fs::FSInfo'
struct FSInfo {
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:135:12: error: multiple definition of 'enum class AsyncMqttClientDisconnectReason'
enum class AsyncMqttClientDisconnectReason : int8_t {
In file included from G:\Dropbox (Personal)\Arduino\libraries\async-mqtt-client\src/AsyncMqttClient/Callbacks.hpp:5:0,
from G:\Dropbox (Personal)\Arduino\libraries\async-mqtt-client\src/AsyncMqttClient.hpp:25,
G:\Dropbox (Personal)\Arduino\libraries\async-mqtt-client\src/AsyncMqttClient/DisconnectReasons.hpp:3:12: error: previous definition here
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:145:14: error: multiple definition of 'enum WiFiEvent'
typedef enum WiFiEvent {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:51:14: error: previous definition here
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:157:14: error: invalid type in declaration before ';' token
} WiFiEvent_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:157:14: error: conflicting declaration 'typedef int WiFiEvent_t'
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:64:3: error: 'WiFiEvent_t' has a previous declaration as 'typedef enum WiFiEvent WiFiEvent_t'
} WiFiEvent_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:159:6: error: multiple definition of 'enum WiFiDisconnectReason'
enum WiFiDisconnectReason {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:66:6: error: previous definition here
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:190:8: error: redefinition of 'struct WiFiEventModeChange'
struct WiFiEventModeChange {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:99:8: error: previous definition of 'struct WiFiEventModeChange'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:194:8: error: redefinition of 'struct WiFiEventStationModeConnected'
struct WiFiEventStationModeConnected {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:105:8: error: previous definition of 'struct WiFiEventStationModeConnected'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:198:8: error: redefinition of 'struct WiFiEventStationModeDisconnected'
struct WiFiEventStationModeDisconnected {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:112:8: error: previous definition of 'struct WiFiEventStationModeDisconnected'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:202:8: error: redefinition of 'struct WiFiEventStationModeAuthModeChanged'
struct WiFiEventStationModeAuthModeChanged {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:119:8: error: previous definition of 'struct WiFiEventStationModeAuthModeChanged'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:206:8: error: redefinition of 'struct WiFiEventStationModeGotIP'
struct WiFiEventStationModeGotIP {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:125:8: error: previous definition of 'struct WiFiEventStationModeGotIP'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:210:8: error: redefinition of 'struct WiFiEventSoftAPModeStationConnected'
struct WiFiEventSoftAPModeStationConnected {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:132:8: error: previous definition of 'struct WiFiEventSoftAPModeStationConnected'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:214:8: error: redefinition of 'struct WiFiEventSoftAPModeStationDisconnected'
struct WiFiEventSoftAPModeStationDisconnected {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:138:8: error: previous definition of 'struct WiFiEventSoftAPModeStationDisconnected'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:218:8: error: redefinition of 'struct WiFiEventSoftAPModeProbeRequestReceived'
struct WiFiEventSoftAPModeProbeRequestReceived {
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\libraries\ESP8266WiFi\src/ESP8266WiFiType.h:144:8: error: previous definition of 'struct WiFiEventSoftAPModeProbeRequestReceived'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:222:8: error: redefinition of 'struct AsyncMqttClientMessageProperties'
struct AsyncMqttClientMessageProperties {
In file included from G:\Dropbox (Personal)\Arduino\libraries\async-mqtt-client\src/AsyncMqttClient.hpp:23:0,
G:\Dropbox (Personal)\Arduino\libraries\async-mqtt-client\src/AsyncMqttClient/MessageProperties.hpp:3:8: error: previous definition of 'struct AsyncMqttClientMessageProperties'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:229:5: error: redeclaration of 'WStype_ERROR'
WStype_ERROR,
In file included from G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSocketsServer.h:28:0,
from C:\Users\Simi\AppData\Local\Temp\arduino_modified_sketch_56491\Teensquitto.ino:16:
G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSockets.h:190:5: note: previous declaration 'WStype_t WStype_ERROR'
WStype_ERROR,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:230:5: error: redeclaration of 'WStype_DISCONNECTED'
WStype_DISCONNECTED,
G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSockets.h:191:5: note: previous declaration 'WStype_t WStype_DISCONNECTED'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:231:5: error: redeclaration of 'WStype_CONNECTED'
WStype_CONNECTED,
G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSockets.h:192:5: note: previous declaration 'WStype_t WStype_CONNECTED'
WStype_CONNECTED,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:232:5: error: redeclaration of 'WStype_TEXT'
WStype_TEXT,
G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSockets.h:193:5: note: previous declaration 'WStype_t WStype_TEXT'
WStype_TEXT,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:233:5: error: redeclaration of 'WStype_BIN'
WStype_BIN,
G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSockets.h:194:5: note: previous declaration 'WStype_t WStype_BIN'
WStype_BIN,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:234:2: error: redeclaration of 'WStype_FRAGMENT_TEXT_START'
WStype_FRAGMENT_TEXT_START,
G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSockets.h:195:2: note: previous declaration 'WStype_t WStype_FRAGMENT_TEXT_START'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:235:2: error: redeclaration of 'WStype_FRAGMENT_BIN_START'
WStype_FRAGMENT_BIN_START,
G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSockets.h:196:2: note: previous declaration 'WStype_t WStype_FRAGMENT_BIN_START'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:236:2: error: redeclaration of 'WStype_FRAGMENT'
WStype_FRAGMENT,
G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSockets.h:197:2: note: previous declaration 'WStype_t WStype_FRAGMENT'
WStype_FRAGMENT,
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:237:2: error: redeclaration of 'WStype_FRAGMENT_FIN'
WStype_FRAGMENT_FIN,
G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSockets.h:198:2: note: previous declaration 'WStype_t WStype_FRAGMENT_FIN'
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:238:3: error: conflicting declaration 'typedef enum WStype_t WStype_t'
} WStype_t;
G:\Dropbox (Personal)\Arduino\libraries\arduinoWebSockets-master\src/WebSockets.h:199:3: error: 'WStype_t' has a previous declaration as 'typedef enum WStype_t WStype_t'
} WStype_t;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:613:8: error: 'teensquitto' does not name a type
extern teensquitto WiFi;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:614:8: error: 'teensquitto' does not name a type
extern teensquitto SPIFFS;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:615:8: error: 'teensquitto' does not name a type
extern teensquitto ESP;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:616:8: error: 'teensquitto' does not name a type
extern teensquitto AsyncUDPPlugin;
G:\Dropbox (Personal)\Arduino\libraries\Teensquitto-master/teensquitto.h:617:8: error: 'teensquitto' does not name a type
extern teensquitto WiFiMulti;
C:\Users\Simi\AppData\Local\Temp\arduino_modified_sketch_56491\Teensquitto.ino: In function 'void loop()':
Teensquitto:73:10: error: 'events' was not declared in this scope
events();
C:\Users\Simi\AppData\Local\Temp\arduino_modified_sketch_56491\Teensquitto.ino: In function 'uint8_t events()':
Teensquitto:78:58: error: '_wifi_state_notify' was not declared in this scope
_status = _current_status; _wifi_state_notify(_status);
Teensquitto:96:57: error: 'processing_data' was not declared in this scope
processing_data(uartBuffer, uartBufferSize); return '$';
C:\Users\Simi\AppData\Local\Temp\arduino_modified_sketch_56491\Teensquitto.ino: In function 'void processing_data(uint8_t*, uint16_t)':
Teensquitto:142:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Serial1.write(datar, sizeof(datar)); return; // don't send ACK, response given instead.
In file included from C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/Arduino.h:261:0,
C:\Users\Simi\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.4.2\cores\esp8266/HardwareSerial.h:156:12: error: initializing argument 1 of 'virtual size_t HardwareSerial::write(const uint8_t*, size_t)' [-fpermissive]
size_t write(const uint8_t *buffer, size_t size)
Teensquitto:152:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:164:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:174:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:186:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:199:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:215:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:225:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:238:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:251:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:264:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:282:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:293:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:304:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:317:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:328:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:347:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:358:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:368:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:384:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:397:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:408:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:443:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:461:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
Teensquitto:474:49: error: invalid conversion from 'char*' to 'const uint8_t* {aka const unsigned char*}' [-fpermissive]
