Page 25 of 28 FirstFirst ... 15 23 24 25 26 27 ... LastLast
Results 601 to 625 of 679
Thread: uNav INS
  1. #601
    Oct 2017
    Houston
    414
    Mike, Tim,
    I'm going back and trying to document some of the versions/changes we had. I have them all saved, but didn't a great job of documenting what we did. Started a log book for my IMU projects, so lesson learned for next time!
    Attached are photos of the Perma-Board (from Adafruit) version I just soldered up this morning. Testing it with the cal routines now, looks like it's working. So will figure out how I want to plug in the GPS next (maybe second layer, i.e. GPS board on top). Then I'll start using it to start on some EKF testing again.
    Don
Name:	uNavINS Perma-Proto, Front.JPG
Name:	uNavINS Perma-Proto, Back.JPG
  2. #602
    Dec 2016
    Montreal, Canada
    3,002
    Don, i tested dual slaves and upped a video, its crazy stuff
    https://www.youtube.com/watch?v=xD9TTK5cL6g
    it was based on a 3.2 slave, 3.5 slave, and 3.6 master
  3. #603
    Senior Member+
    New York
    3,216
    Hey Don,
    Documentation is my biggest problem as well, so don't feel bad. I start then get side tracked. I have been testing with the new version of the GPS library from Chris O. and its pretty much a drop in replacement for Brian's library. Except it allows you to change the GPS rate and NAV5 as well plus. I also tested with a 10hz update rate with the current version which basically gives updates about as fast as the IMU does.
    Mike
  4. #604
    Oct 2017
    Houston
    414
    Mike,
    Sounds like I need to catch up on Chris O's library!
    tonton81 - that is crazy stuff. thinking there could be some interesting applications for this!
    Don
  5. #605
    Senior Member+
    New York
    3,216
    Hi Tim - Don
    Found the source of the issue with the erratic YPR that I described a few posts ago. It is not the timing. The timing changes are fine. The issue is with the readSensorPMD function. Can't pin it down why since only the magnetometer should be affected or it may be in how I am using the data - have to do a double check of that. How did I find out - I changed back to the just using the readSensors call as opposed to the PMD call and it behaved nicely. The other thing I noticed is that it would just hang the data flow - loose imu data?
    Mike
  6. #606
    Oct 2017
    Houston
    414
    Here's my final hard-soldered config. GPS (M8N) mounted on top, JST-GH connector to main board. Did a quick test and it seems to be processing both IMU and GPS data. So solders look good. Can get back to looking at EKF now that this and cal routine done...
    Don
  7. #607
    Senior Member+
    New York
    3,216
    Don
    First - nice job. I have just one question where are the connections for spi to the slave?
    Mike
  8. #608
    Oct 2017
    Houston
    414
    Mike,
    My plan is to add another 4-wire JST-GH connector, like I did for the GPS. But I'm waiting for my JST cables to arrive from mRobotics. So in the meantime, I'm doing some experiments without the slave, and cataloging those earlier versions of uNavINS that we posted.
    The JST connectors will allow me to easily plug-in/remove either the Slave T36 or the GPS.
    Don
  9. #609
    Senior Member+
    New York
    3,216
    Don.
    You got me worried for a minute I didn't see anyplace for them so....
    Don and Tim
    I made some headway with the PMD function. I figured out how to use the magnetometers data ready bit to determine when the mag is actually updated - I am also now testing for when there is an overflow condition on the magnetometer. Unfortunately, for some reason the GPS is not updating like it should so the filter gets stuck. Anyway if you are interested here is the code for the PMD function:
    // Added to \libraries\MPU9250\MPU9250.cpp
    int MPU9250::readSensorPMD(float* ax, float* ay, float* az, float* gx, float* gy, float* gz, float* hx, float* hy, float* hz, bool* MagD)
      _useSPIHS = false; // use the high speed SPI for data readout
      bool newMagData = 0;
      uint8_t rawData[7];  // x/y/z gyro register data, ST2 register stored here, must read ST2 at end of data acquisition
      uint8_t dest[1];
      readAK8963Registers(AK8963_ST1,1,dest);
      newMagData = (dest[0] & 0x01);
        readAK8963Registers(AK8963_HXL,7,rawData);
        //readRegisters(EXT_SENS_DATA_00,7,&_buffer[0]);
        readAK8963Registers(AK8963_ST2,1, dest); // End data read by reading ST2 register
      if(newMagData == 1 && rawData[6] == 0x10) { // wait for magnetometer data ready bit to be set
        _hxcounts = ((int16_t)rawData[1] << 8) | rawData[0];
        _hycounts = ((int16_t)rawData[3] << 8) | rawData[2];
        _hzcounts = ((int16_t)rawData[5] << 8) | rawData[4];
        *MagD = true;
        *MagD = false;
        //_hxcounts = 0;
        //_hycounts = 0;
        //_hzcounts = 0;
      // grab the data from the MPU9250
      if (readRegisters(ACCEL_OUT, 14, _buffer) < 0) {
        return -1;
      // combine into 16 bit values
      _axcounts = (((int16_t)_buffer[0]) << 8) | _buffer[1];
      _aycounts = (((int16_t)_buffer[2]) << 8) | _buffer[3];
      _azcounts = (((int16_t)_buffer[4]) << 8) | _buffer[5];
      _tcounts = (((int16_t)_buffer[6]) << 8) | _buffer[7];
      _gxcounts = (((int16_t)_buffer[8]) << 8) | _buffer[9];
      _gycounts = (((int16_t)_buffer[10]) << 8) | _buffer[11];
      _gzcounts = (((int16_t)_buffer[12]) << 8) | _buffer[13];
      // transform and convert to float values
      *ax = (((float)(tX[0] * _axcounts + tX[1] * _aycounts + tX[2] * _azcounts) * _accelScale) - _axb) * _axs;
      *ay = (((float)(tY[0] * _axcounts + tY[1] * _aycounts + tY[2] * _azcounts) * _accelScale) - _ayb) * _ays;
      *az = (((float)(tZ[0] * _axcounts + tZ[1] * _aycounts + tZ[2] * _azcounts) * _accelScale) - _azb) * _azs;
      *gx = ((float)(tX[0] * _gxcounts + tX[1] * _gycounts + tX[2] * _gzcounts) * _gyroScale) - _gxb;
      *gy = ((float)(tY[0] * _gxcounts + tY[1] * _gycounts + tY[2] * _gzcounts) * _gyroScale) - _gyb;
      *gz = ((float)(tZ[0] * _gxcounts + tZ[1] * _gycounts + tZ[2] * _gzcounts) * _gyroScale) - _gzb;
      *hx = (((float)(_hxcounts) * _magScaleX) - _hxb)*_hxs;
      *hy = (((float)(_hycounts) * _magScaleY) - _hyb)*_hys;
      *hz = (((float)(_hzcounts) * _magScaleZ) - _hzb)*_hzs;
      return 1;
  10. #610
    Oct 2017
    Houston
    414
    Mike,
    I also still have the old breadboard setup still, with Master and Slave T36s. Would just need to move the GPS back over.
    Don
  11. #611
    Dec 2016
    Montreal, Canada
    3,002
    Just wire the GPS TX to both setups, with common ground, and both setups can use it
  12. #612
    Oct 2017
    Houston
    414
    Mike,
    Looks like that code would make it easy for just doing a mag-only update (w/o GPS). Nice!
    Don
  13. #613
    Senior Member+
    New York
    3,216
    Thanks Don. Took me a while to break the code on to get it to read the data ready bit. But it seems to work. Now if I can figure out why the GPS is not updating
    Mike
  14. #614
    Dec 2016
    Montreal, Canada
    3,002
    Quote Originally Posted by Don Kelly View Post
    Don
    im sure someone might find 18 uarts and 3 usberials, 7spi busses, 12 wire busses, and ~180 gpio control useful lol
    Just think what would happen if we could, instead of using the 12Mbps USBSerial, if the 480 ever worked out working on the T3.6...... :O
  15. #615
    Senior Member+
    New York
    3,216
    Don-Tim
    Just as an update = I tried the code change with the library, but had to put the GPS in its own thread, seems like the method eats up too much time I guess. Unfortunately I still get the same as before. Has to be something with the way mag update is handled? Interesting thing, is that when I bring it back to rest it continues to oscillate in YPR.
    Mike
  16. #616
    Oct 2017
    Houston
    414
    Mike,
    hmmm... weird...
    i'm still studying calibrations, as I'm still seeing some unusual behaviors with the heading at times. Want to work on this a bit more before I get back to the 15-state. Have had house guests, so not much accomplished last couple days, but will get back to work on things tomorrow.
    Don
  17. #617
    Senior Member+
    New York
    3,216
    Don
    Thanks for getting back. I noticed heading follow yaw pretty closely. In other words, whatever, yaw does heading follows. So if heading in weird so is yaw. What you might be seeing may not be an issue with the calibration but an issue with yaw?
    Mike
  18. #618
    Oct 2017
    Houston
    414
    Mike,
    In the calibration code, I'm calculating heading directly from the calibrated magnetometer readings, so not really even calculating yaw.
    But if I'm understanding it, the EKF is continually tweaking heading (via the calibrated magnetometer readings) and yaw is just an offset from heading. But I'd need to go back and dig in to make sure that's correct.
    Don
  19. #619
    Senior Member+
    New York
    3,216
    Don,
    Got it. Thanks - thought you were doing it from the library.
    By the way I just posted something you and Tim may interested on the UBLOX thread by Chris O (https://forum.pjrc.com/threads/46058...l=1#post177067) I used his setup (screen and all) to change the pps frequency and then measured it with a T3.5. Good stuff. You want accurate time
    Mike
    EDIT:
    Yaw from heading, yep
    float uNavINS::getYaw_rad() {
      return constrainAngle180(psi-psi_initial);
  20. #620
    8,366
    Saw that - not sure how that would help having 1000 or 1000000 processor interrupts each second - if they are triggering the inbuilt timer it is hardware and not bad - but that give freq. With more information comes more effort to make sense of it?
    Seems enough overhead once a second to get a baseline average to the elapsed cyclecounts that seem to be stable.
  21. #621
    Oct 2017
    Houston
    414
    Mike,
    I need to check out Chris O's GPS lib, have been spread thin lately with my data analytics project and other stuff.
    Prob a dumb question, but assume Chris O's lib requires PPS pin access (which unfortunately my mRobotics Dual M8N doesn't have). Think I need to find another board that does, maybe even move up to the M8P (or similar) so I can eventually pass in RTK correction too.
    Don
  22. #622
    Senior Member+
    New York
    3,216
    Don
    Actually, no it does not require access to the pin. Everything is done through software and set via TP5 messages. I attached the pps pin to a 3.5 to check the pps pin output since the unit I picked up off ebay had one. Think Chris O. has one on order though.
    Just started back up this morning on using the RTKLIB since I have not used it for a while
    Mike
  23. #623
    Oct 2017
    Houston
    414
    Mike,
    Thx. I ordered the same one via ebay as well. So I'll finally have one with PPS pin...
    I've been experimenting still with the cal routine. Am able to get what I think is really good cal now, and I can use the sigma values it calculates for the mag R values. I'm running the 1st mag version (before we added the slave capability), which is uNavINS_MPU9250_I2C_MAGV1. I want to keep testing this version a bit, making sure the PRY and Heading stay stable. Then I think I'll add that JST-GH connector to my setup so I can plug the Slave T36 in to see the 77 parameters too.
    Don
  24. #624
    Senior Member+
    New York
    3,216
    Hi Don,
    I have been using it and its actually not a bad little unit. I just got a Drotek M8T to play around with RTKLib again. Getting interesting.
    Mike
  25. #625
    Oct 2017
    Houston
    414
    Mike,
    Which Drotek M8T did you get, the plain one without the compass? Think I'll do the same! Would like to think about incorporating RTK into what we've been doing here. Maybe kick off an RTK-Teensy thread???
    Will be out-of-pocket for 5-6 days here, but might try to go ahead and get the M8T ordered...
    Don
