uNav INS
tonton81,
I wouldn't recommend naming the intermediate steps. So maybe just something like
cb.average() and cb.stdev()
Sorry about my short replies, am off to meetings this morning then will re-engage this afternoon. Tough to keep up with you guys!!
P.S. I've ordered one of Brian's Marmot (hardwired MPU9250 and T36) boards. Looking forward to loading this all on it. No more loose wires issues with it I hope! and the SPI connections will be via cable with plus too I think...
Don
ill be home in 1 hr or so to add the queue features for Don, this is gonna be an awesome addition
indeed i wont make steps, i just figured now ill just keep average() and deviation(), and maybe if you want the variance() as well, :) lemme know im en route
tonton81 = might as well add variance. Easier to add now than later. This way it will be complete :)
Don: nice board that Brian has - wish he had a version without the beagle connectors soldered on :)
According to: http://www.calculator.net/standard-deviation-calculator.html
Thats where I'm using it's calculator to test if the variance is correct in my library, I paste this on the website:
3.14159,12.3456,78.91234
Website says: Variance (Population Standard), σ2 1139.6723588745
However, serial monitor reports:
am i doing something wrong or thats just how the floats work on microcontrollers vs computers?
This is the current method:
template<typename T, uint16_t _size, uint16_t multi>
T Circular_Buffer<T,_size,multi>::variance() {
  T _mean = average();
  T value = 0;
  for ( uint16_t i = 0; i < _available; i++ ) {
    value += ((_cbuf[(head+i)&(_size-1)] - _mean) * (_cbuf[(head+i)&(_size-1)] - _mean));
  value /= _available;
  Serial.println(_mean,11); // [COLOR="#006400"]debug[/COLOR]
  Serial.println(value,11); // [COLOR="#006400"]debug[/COLOR]
  return value;
tonton81,
you want the general form for standard deviation, the "population" version, where you divide by n,
not the "sample" form for standard deviation where they calculate it a bit different and divide by n-1
The link I sent on my post from last night has a nice example with real numbers that we can test with, using a population size of 20 samples. for his example of 20 samples, mean comes out to 7, and standard deviation comes out to 2.983.
Don
Yeah im just need to fix the variation to make sure its okay before i use it for deviation calculation afterwards, i just wanna make sure the numbers match
the calculater from the site you linked showed this:
(Add up the Squared Differences)
Variance:
[COLOR="#FF8C00"]1139.672359[/COLOR]
(Sum of Differences2 / Count)
and teensy got this:
1139.67236328125
tonton81,
this will be really nice to have. This will allow us to dig into the inner workings of the EKF and attempt to optimize the tuning parameters (Q and R). Brian has some code in his uNavAHRS that uses a particular method for calculating the mean and variance of the gyro, accel, and mag when you kick off the IMU, but your circular buffer is much better suited (as best I can tell) for continually getting an updated mean and deviation in real time. Very slick.
Time for me to download Mike's latest version of uNavINS and give it a whirl...
Don
  Serial.println(myFloats.deviation(),8); // print last 8 decimal places
Output:
Lastly, take the square root of the Variance:
Standard Deviation:
33.75903374
(The square root of the Variance)
Thats pretty close! But yeah, ready for action :)
deviation function was easier:
T Circular_Buffer<T,_size,multi>::deviation() {
  if ( multi || !_available ) return 0;
  return sqrt(variance());
I also added mean() method, its same as average()
Circular_Buffer will have a commit soon, with these new features
        T variance();
        T deviation();
        T average();
        T mean() { return average(); }
EDIT: commit complete: https://github.com/tonton81/Circular_Buffer/commit/a438494278cfe0899972a68bb84d4ea95d5ff68f
tonton81,
Cool! I'll try it out in a few hours!
Mike,
Am running your latest uNavINS version, so far so good. My pitch and roll values are starting high (like 8-10 deg), so I will re-calibrate my IMU later today to see if that helps. Pretty cool.
Once I make sure angles are looking steady again, my thought is to do a little test routine to make sure I see what tonton81 is doing with his mean/deviation functions. then i'll pick a particular EKF state (like "pitch" maybe) and then develop the analysis plots via SPI and TViewer...
Don
tonton81: :)
Don: Glad its finally working the way its suppose to. The only value starting high for me was roll at 25 degrees. Same here on recalibration eventually. Good luck.
tonton81 - may not be useful here - but since you are crunching stats - MIN and MAX might be nice to have?
Having coffee now so in an hour or so i will be awake again.
I am now running the Master at 168Mhz and the Slave at 144Mhz. Yeah. I didn't update to the latest yet - probably will this morning now that this is working.
Glad you found that Assert too. Have a few more compiler things I can add to my list - wish there was one spot that had what you could use.:)
For the test ran it for about 5000secs no issues. :)
Now guess Don can continue the KF debug effort and expand on it.
Not sure what to do next - slave I2C or play circular buffer. Oh well....
Didn't make it to 5,000 here ... I came to find a failed assert for NaN found at 4281.916992!
Master:
-----Loop#:281139 IMU#:502
	 #21403  @11:46.6_479937 [fix:3 #:16
	 #21404  @11:46.6_200480011 [fix:3 #:15
	 #21405  @11:46.6_400480086 [fix:3 #:16
	 #21406  @11:46.6_600480160 [fix:3 #:16
	 #21407  @11:46.6_800480235 [fix:3 #:16
-----Loop#:281385 IMU#:501
	 #21408  @11:46.7_480310 [fix:3 #:16
	 #21409  @11:46.7_200480384 [fix:3 #:16
	 #21410  @11:46.7_400480459 [fix:3 #:16
ASSERT: NaN Fail index = 26
 ___ ASSERT FAILED ___ FILE, LINE#, Expression
T:\tCode\_GPSimuDK\1Apr18\uNavINS_MPU9250_I2C_MAGV3\C_serialPrint.ino
64
!std::isnan( MST_PrintVals[jj] )
 ___ ASSERT FAILED ___ STOPPING !!!!
Slave - At END of TyComm buffer:
4281.838867, 51.198551,154.976212,-148.012558, 63.657646, 48.214287,-122.450485, 24.315233,  0.000311, -0.000629,  0.018962, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.560522,  0.560557,  0.721608,  0.541436,  0.542839,  0.531820,  0.050322,  0.031611,  0.043818,  0.089853,  0.093999,  0.095019,  0.006747,  0.005976,  0.006443,  0.388454,  0.698663,  0.543849, -0.255346,
4281.841309, 51.198593,154.976074,-148.012619, 63.657585, 48.214287,-122.450485, 24.315195,  0.000327, -0.000660,  0.018958, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.560747,  0.560783,  0.721781,  0.543380,  0.544798,  0.533661,  0.050326,  0.031615,  0.043822,  0.089854,  0.094000,  0.095019,  0.006747,  0.005976,  0.006443,  0.388455,  0.698663,  0.543849, -0.255346,
4281.843262, 51.198643,154.975998,-148.012650, 63.657551, 48.214287,-122.450485, 24.315159,  0.000336, -0.000712,  0.018936, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.560973,  0.561010,  0.721955,  0.545319,  0.546752,  0.535495,  0.050330,  0.031618,  0.043825,  0.089854,  0.094000,  0.095019,  0.006747,  0.005976,  0.006444,  0.388456,  0.698663,  0.543849, -0.255346,
4281.845215, 51.198753,154.975906,-148.012726, 63.657475, 48.214287,-122.450485, 24.315113,  0.000353, -0.000755,  0.018896, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.561259,  0.561298,  0.722176,  0.547734,  0.549186,  0.537779,  0.050335,  0.031623,  0.043830,  0.089855,  0.094000,  0.095020,  0.006748,  0.005977,  0.006444,  0.388456,  0.698662,  0.543848, -0.255346,
4281.847168, 51.198830,154.975754,-148.012863, 63.657337, 48.214287,-122.450485, 24.315084,  0.000365, -0.000771,  0.018871, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.561432,  0.561471,  0.722309,  0.549179,  0.550642,  0.539145,  0.050338,  0.031625,  0.043832,  0.089855,  0.094000,  0.095020,  0.006748,  0.005977,  0.006444,  0.388457,  0.698662,  0.543848, -0.255347,
4281.849121, 51.198837,154.975494,-148.013138, 63.657066, 48.214287,-122.450485, 24.315048,  0.000375, -0.000794,  0.018822, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.561665,  0.561705,  0.722488,  0.551101,  0.552579,  0.540961,  0.050342,  0.031629,  0.043836,  0.089855,  0.094001,  0.095020,  0.006748,  0.005978,  0.006445,  0.388458,  0.698662,  0.543847, -0.255346,
4281.851074, 51.198818,154.975113,-148.013428, 63.656773, 48.214287,-122.450485, 24.315002,  0.000379, -0.000817,  0.018793, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.561958,  0.561999,  0.722715,  0.553495,  0.554991,  0.543223,  0.050347,  0.031633,  0.043841,  0.089856,  0.094001,  0.095020,  0.006749,  0.005978,  0.006445,  0.388460,  0.698663,  0.543846, -0.255345,
4281.853027, 51.198895,154.974915,-148.013596, 63.656609, 48.214287,-122.450485, 24.314966,  0.000376, -0.000829,  0.018760, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.562195,  0.562237,  0.722897,  0.555404,  0.556915,  0.545025,  0.050351,  0.031637,  0.043844,  0.089856,  0.094001,  0.095020,  0.006749,  0.005979,  0.006445,  0.388461,  0.698662,  0.543845, -0.255345,
4281.854980, 51.198975,154.974823,-148.013657, 63.656540, 48.214287,-122.450485, 24.314928,  0.000390, -0.000835,  0.018737, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.562435,  0.562477,  0.723081,  0.557307,  0.558834,  0.546822,  0.050355,  0.031641,  0.043848,  0.089857,  0.094001,  0.095020,  0.006749,  0.005979,  0.006446,  0.388462,  0.698662,  0.543845, -0.255346,
4281.857422, 51.199085,154.974777,-148.013763, 63.656445, 48.214287,-122.450485, 24.314892,  0.000404, -0.000833,  0.018719, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.562676,  0.562719,  0.723267,  0.559205,  0.560747,  0.548612,  0.050359,  0.031644,  0.043851,  0.089857,  0.094002,  0.095021,  0.006750,  0.005979,  0.006446,  0.388462,  0.698662,  0.543844, -0.255347,
4281.858887, 51.199203,154.974823,-148.013840, 63.656361, 48.214287,-122.450485, 24.314856,  0.000414, -0.000822,  0.018719, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.562919,  0.562964,  0.723454,  0.561098,  0.562654,  0.550397,  0.050363,  0.031647,  0.043855,  0.089858,  0.094002,  0.095021,  0.006750,  0.005980,  0.006447,  0.388462,  0.698662,  0.543844, -0.255348,
4281.869141, 51.199051,154.974365,-148.014343, 63.655849, 48.214287,-122.450485, 24.314672,  0.000464, -0.000840,  0.018762, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.564166,  0.564216,  0.724413,  0.570480,  0.572113,  0.559238,  0.050382,  0.031665,  0.043874,  0.089860,  0.094003,  0.095022,  0.006752,  0.005982,  0.006448,  0.388463,  0.698664,  0.543842, -0.255347,
4281.871094, 51.199028,154.974274,-148.014435, 63.655762, 48.214287,-122.450485, 24.314627,  0.000472, -0.000867,  0.018760, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.564486,  0.564537,  0.724659,  0.572806,  0.574458,  0.561426,  0.050387,  0.031670,  0.043878,  0.089860,  0.094003,  0.095022,  0.006752,  0.005982,  0.006449,  0.388463,  0.698664,  0.543841, -0.255346,
4281.873047, 51.199051,154.974274,-148.014465, 63.655735, 48.214287,-122.450485, 24.314590,  0.000479, -0.000897,  0.018754, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.564744,  0.564797,  0.724858,  0.574661,  0.576328,  0.563171,  0.050391,  0.031673,  0.043882,  0.089861,  0.094004,  0.095022,  0.006752,  0.005983,  0.006449,  0.388463,  0.698664,  0.543841, -0.255347,
4281.875000, 51.199059,154.974274,-148.014481, 63.655712, 48.214287,-122.450485, 24.314554,  0.000497, -0.000943,  0.018739, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.565005,  0.565059,  0.725058,  0.576510,  0.578194,  0.564910,  0.050395,  0.031677,  0.043886,  0.089861,  0.094004,  0.095022,  0.006753,  0.005983,  0.006449,  0.388463,  0.698664,  0.543841, -0.255347,
4281.877441, 51.199001,154.974258,-148.014542, 63.655651, 48.214287,-122.450485, 24.314518,  0.000509, -0.000991,  0.018710, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.565268,  0.565323,  0.725260,  0.578355,  0.580054,  0.566644,  0.050399,  0.031680,  0.043889,  0.089861,  0.094004,  0.095023,  0.006753,  0.005984,  0.006450,  0.388463,  0.698664,  0.543841, -0.255346,
4281.878906, 51.198986,154.974197,-148.014648, 63.655556, 48.214287,-122.450485, 24.314480,  0.000500, -0.001049,  0.018677, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.565533,  0.565589,  0.725463,  0.580195,  0.581910,  0.568373,  0.050403,  0.031684,  0.043893,  0.089862,  0.094004,  0.095023,  0.006753,  0.005984,  0.006450,  0.388463,  0.698665,  0.543840, -0.255346,
4281.880859, 51.199074,154.974121,-148.014725, 63.655476, 48.214287,-122.450485, 24.314444,  0.000492, -0.001100,  0.018650, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.565800,  0.565857,  0.725668,  0.582031,  0.583761,  0.570097,  0.050407,  0.031687,  0.043897,  0.089862,  0.094005,  0.095023,  0.006754,  0.005985,  0.006450,  0.388464,  0.698664,  0.543840, -0.255347,
4281.883301, 51.199150,154.973999,-148.014893, 63.655319, 48.214287,-122.450485, 24.314407,  0.000492, -0.001152,  0.018625, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.566069,  0.566128,  0.725875,  0.583861,  0.585607,  0.571815,  0.050411,  0.031691,  0.043900,  0.089863,  0.094005,  0.095023,  0.006754,  0.005985,  0.006451,  0.388465,  0.698664,  0.543839, -0.255347,
4281.885254, 51.199158,154.973892,-148.014938, 63.655270, 48.214287,-122.450485, 24.314371,  0.000501, -0.001197,  0.018608, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.566341,  0.566400,  0.726084,  0.585687,  0.587449,  0.573529,  0.050415,  0.031694,  0.043904,  0.089863,  0.094005,  0.095023,  0.006754,  0.005985,  0.006451,  0.388465,  0.698664,  0.543839, -0.255347,
4281.887207, 51.199169,154.973816,-148.014832, 63.655357, 48.214287,-122.450485, 24.314335,  0.000505, -0.001225,  0.018614, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.566615,  0.566675,  0.726294,  0.587508,  0.589285,  0.575237,  0.050419,  0.031698,  0.043908,  0.089864,  0.094005,  0.095024,  0.006755,  0.005986,  0.006452,  0.388466,  0.698664,  0.543840, -0.255347,
4281.889160, 51.199177,154.973648,-148.014908, 63.655296, 48.214287,-122.450485, 24.314299,  0.000505, -0.001278,  0.018624, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.566891,  0.566953,  0.726505,  0.589324,  0.591118,  0.576941,  0.050423,  0.031701,  0.043911,  0.089864,  0.094006,  0.095024,  0.006755,  0.005986,  0.006452,  0.388467,  0.698663,  0.543840, -0.255346,
4281.891113, 51.199162,154.973572,-148.015015, 63.655186, 48.214287,-122.450485, 24.314262,  0.000509, -0.001341,  0.018616, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.567169,  0.567232,  0.726719,  0.591135,  0.592945,  0.578639,  0.050427,  0.031705,  0.043915,  0.089864,  0.094006,  0.095024,  0.006755,  0.005987,  0.006452,  0.388467,  0.698664,  0.543839, -0.255346,
4281.893066, 51.199223,154.973557,-148.014999, 63.655209, 48.214287,-122.450485, 24.314217,  0.000531, -0.001399,  0.018598, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.567520,  0.567585,  0.726988,  0.593393,  0.595223,  0.580755,  0.050432,  0.031709,  0.043920,  0.089865,  0.094006,  0.095024,  0.006756,  0.005987,  0.006453,  0.388467,  0.698663,  0.543840, -0.255346,
4281.895020, 51.199322,154.973541,-148.014938, 63.655254, 48.214287,-122.450485, 24.314180,  0.000554, -0.001444,  0.018598, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.567803,  0.567870,  0.727206,  0.595195,  0.597041,  0.582442,  0.050436,  0.031713,  0.043923,  0.089865,  0.094006,  0.095024,  0.006756,  0.005988,  0.006453,  0.388468,  0.698663,  0.543840, -0.255347,
4281.896973, 51.199348,154.973511,-148.014908, 63.655296, 48.214287,-122.450485, 24.314154,  0.000558, -0.001476,  0.018595, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.568017,  0.568085,  0.727370,  0.596543,  0.598401,  0.583705,  0.050439,  0.031715,  0.043926,  0.089866,  0.094006,  0.095025,  0.006756,  0.005988,  0.006453,  0.388468,  0.698662,  0.543840, -0.255347,
4281.898926, 51.199276,154.973480,-148.014801, 63.655399, 48.214287,-122.450485, 24.314108,  0.000561, -0.001527,  0.018605, -0.000355, -0.000007, -0.000172, -1.642543,  2.729327,  1.959170,  0.568377,  0.568446,  0.727645,  0.598784,  0.600663,  0.585803,  0.050444,  0.031720,  0.043931,  0.089866,  0.094007,  0.095025,  0.006757,  0.005988,  0.006454,  0.388468,  0.698662,  0.543841, -0.255346,
4281.900879, 51.244141,154.969254,-148.046585, 63.623619, 48.214287,-122.450485, 24.315016, -0.034192, -0.049254,  0.025625, -0.000365,  0.000062, -0.000151, -1.642408,  2.729473,  1.959144,  0.548783,  0.548788,  0.712479,  0.384042,  0.384560,  0.380700,  0.050034,  0.031371,  0.043547,  0.089824,  0.093982,  0.095005,  0.006724,  0.005946,  0.006417,  0.388574,  0.698618,  0.543634, -0.255745,
4281.903809, 51.243999,154.969025,-148.046707, 63.623497, 48.214287,-122.450485, 24.314939, -0.034184, -0.049337,  0.025641, -0.000365,  0.000062, -0.000151, -1.642408,  2.729473,  1.959144,  0.548963,  0.548969,  0.712621,  0.387989,  0.388522,  0.384537,  0.050040,  0.031376,  0.043553,  0.089825,  0.093983,  0.095006,  0.006724,  0.005947,  0.006418,  0.388574,  0.698618,  0.543634, -0.255744,
4281.905273, 51.243984,154.968933,-148.046768, 63.623428, 48.214287,-122.450485, 24.314915, -0.034181, -0.049354,  0.025631, -0.000365,  0.000062, -0.000151, -1.642408,  2.729473,  1.959144,  0.549024,  0.549029,  0.712668,  0.389296,  0.389835,  0.385807,  0.050042,  0.031378,  0.043555,  0.089825,  0.093983,  0.095006,  0.006725,  0.005947,  0.006418,  0.388575,  0.698618,  0.543634, -0.255743,
4281.907227, 51.243965,154.968689,-148.046951, 63.623249, 48.214287,-122.450485, 24.314865, -0.034172, -0.049382,  0.025603, -0.000365,  0.000062, -0.000151, -1.642408,  2.729473,  1.959144,  0.549146,  0.549151,  0.712764,  0.391899,  0.392449,  0.388336,  0.050046,  0.031381,  0.043558,  0.089825,  0.093983,  0.095006,  0.006725,  0.005947,  0.006418,  0.388576,  0.698618,  0.543633, -0.255743,
4281.909180, 51.243935,154.968430,-148.047134, 63.623074, 48.214287,-122.450485, 24.314816, -0.034185, -0.049426,  0.025579, -0.000365,  0.000062, -0.000151, -1.642408,  2.729473,  1.959144,  0.549269,  0.549275,  0.712861,  0.394487,  0.395047,  0.390848,  0.050049,  0.031385,  0.043562,  0.089826,  0.093983,  0.095006,  0.006725,  0.005948,  0.006419,  0.388577,  0.698618,  0.543633, -0.255742,
4281.911133, 51.243912,154.968185,-148.047318, 63.622879, 48.214287,-122.450485, 24.314764, -0.034200, -0.049448,  0.025571, -0.000365,  0.000062, -0.000151, -1.642408,  2.729473,  1.959144,  0.549393,  0.549399,  0.712958,  0.397058,  0.397630,  0.393344,  0.050053,  0.031389,  0.043566,  0.089826,  0.093983,  0.095006,  0.006726,  0.005948,  0.006419,  0.388578,  0.698618,  0.543632, -0.255741,
4281.913086, 51.243900,154.968033,-148.047516, 63.622696, 48.214287,-122.450485, 24.314714, -0.034222, -0.049463,  0.025553, -0.000365,  0.000062, -0.000151, -1.642408,  2.729473,  1.959144,  0.549519,  0.549525,  0.713057,  0.399615,  0.400197,  0.395825,  0.050057,  0.031392,  0.043569,  0.089826,  0.093984,  0.095006,  0.006726,  0.005949,  0.006420,  0.388578,  0.698619,  0.543632, -0.255741,
4281.915039, 51.243893,154.967743,-148.047867, 63.622326, 48.214287,-122.450485, 24.314653, -0.034260, -0.049480,  0.025528, -0.000365,  0.000062, -0.000151, -1.642408,  2.729473,  1.959144,  0.549677,  0.549683,  0.713181,  0.402790,  0.403386,  0.398904,  0.050062,  0.031397,  0.043574,  0.089827,  0.093984,  0.095007,  0.006726,  0.005949,  0.006420,  0.388579,  0.698620,  0.543630, -0.255741,
4281.916992, 51.243881,154.967484,-148.048172, 63.622028, 48.214287,-122.450485, 24.314602, -0.034281, -0.049503,  0.025505, -0.000365,  0.000062, -0.000151, -1.642408,  2.729473,  1.959144,  0.549804,  0.549811,  0.713281,  0.405313,  0.405920,  0.401350,  0.050066,  0.031400,  0.043577,  0.089827,  0.093984,  0.095007,  0.006727,  0.005950,  0.006420,  0.388580,  0.698620,  0.543629, -0.255741,
Slave at START of TyComm buffer:
3818.854492, 50.908184,154.948166,-147.808014, 63.862183, 48.214344,-122.450348, 38.209553, -0.027077,  0.012324,  0.028511, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.561699,  0.561739,  0.722489,  0.551630,  0.553113,  0.541443,  0.050278,  0.031663,  0.043886,  0.089855,  0.093997,  0.095026,  0.006753,  0.005975,  0.006444,  0.388100,  0.698763,  0.545300, -0.252499,
3818.856445, 50.908062,154.948029,-147.808121, 63.862076, 48.214344,-122.450348, 38.209503, -0.027046,  0.012394,  0.028514, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.561904,  0.561945,  0.722647,  0.553306,  0.554801,  0.543025,  0.050281,  0.031667,  0.043889,  0.089855,  0.093997,  0.095026,  0.006753,  0.005975,  0.006444,  0.388101,  0.698764,  0.545300, -0.252498,
3818.858154, 50.907978,154.947769,-147.808273, 63.861923, 48.214344,-122.450348, 38.209450, -0.027011,  0.012474,  0.028517, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.562141,  0.562183,  0.722830,  0.555215,  0.556725,  0.544828,  0.050285,  0.031670,  0.043893,  0.089855,  0.093997,  0.095026,  0.006753,  0.005976,  0.006445,  0.388102,  0.698764,  0.545300, -0.252497,
3818.860352, 50.907860,154.947617,-147.808380, 63.861828, 48.214344,-122.450348, 38.209385, -0.026983,  0.012591,  0.028536, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.562410,  0.562453,  0.723037,  0.557357,  0.558883,  0.546850,  0.050289,  0.031674,  0.043897,  0.089856,  0.093997,  0.095026,  0.006754,  0.005976,  0.006445,  0.388102,  0.698764,  0.545299, -0.252495,
3818.862305, 50.907806,154.947449,-147.808502, 63.861683, 48.214344,-122.450348, 38.209332, -0.026961,  0.012690,  0.028560, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.562651,  0.562695,  0.723223,  0.559255,  0.560795,  0.548640,  0.050293,  0.031678,  0.043901,  0.089856,  0.093998,  0.095026,  0.006754,  0.005977,  0.006445,  0.388102,  0.698765,  0.545299, -0.252495,
3818.864258, 50.907745,154.947266,-147.808670, 63.861519, 48.214344,-122.450348, 38.209274, -0.026944,  0.012787,  0.028569, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.562895,  0.562940,  0.723410,  0.561147,  0.562702,  0.550425,  0.050297,  0.031681,  0.043904,  0.089857,  0.093998,  0.095027,  0.006754,  0.005977,  0.006446,  0.388103,  0.698765,  0.545298, -0.252494,
3818.866455, 50.907692,154.947083,-147.808762, 63.861454, 48.214344,-122.450348, 38.209217, -0.026922,  0.012859,  0.028549, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.563140,  0.563186,  0.723598,  0.563035,  0.564604,  0.552204,  0.050301,  0.031685,  0.043908,  0.089857,  0.093998,  0.095027,  0.006755,  0.005978,  0.006446,  0.388104,  0.698765,  0.545298, -0.252493,
3818.868164, 50.907616,154.946884,-147.808884, 63.861324, 48.214344,-122.450348, 38.209164, -0.026900,  0.012924,  0.028524, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.563387,  0.563434,  0.723789,  0.564917,  0.566501,  0.553978,  0.050305,  0.031689,  0.043912,  0.089858,  0.093998,  0.095027,  0.006755,  0.005978,  0.006446,  0.388104,  0.698765,  0.545298, -0.252492,
3818.870361, 50.907574,154.946716,-147.809052, 63.861145, 48.214344,-122.450348, 38.209099, -0.026863,  0.012978,  0.028486, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.563668,  0.563716,  0.724005,  0.567028,  0.568629,  0.555967,  0.050309,  0.031693,  0.043916,  0.089858,  0.093999,  0.095027,  0.006755,  0.005978,  0.006447,  0.388105,  0.698766,  0.545297, -0.252491,
3818.880127, 50.907673,154.945770,-147.809601, 63.860600, 48.214344,-122.450348, 38.208824, -0.026637,  0.013120,  0.028306, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.564949,  0.565003,  0.724989,  0.576331,  0.578011,  0.564720,  0.050329,  0.031710,  0.043934,  0.089860,  0.094000,  0.095028,  0.006757,  0.005981,  0.006449,  0.388110,  0.698765,  0.545296, -0.252489,
3818.882324, 50.907593,154.945618,-147.809616, 63.860584, 48.214344,-122.450348, 38.208759, -0.026569,  0.013202,  0.028287, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.565244,  0.565299,  0.725216,  0.578407,  0.580104,  0.566672,  0.050333,  0.031714,  0.043938,  0.089861,  0.094000,  0.095028,  0.006757,  0.005981,  0.006449,  0.388110,  0.698765,  0.545296, -0.252488,
3818.884277, 50.907555,154.945557,-147.809631, 63.860573, 48.214344,-122.450348, 38.208706, -0.026521,  0.013279,  0.028280, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.565509,  0.565566,  0.725420,  0.580247,  0.581960,  0.568400,  0.050337,  0.031718,  0.043942,  0.089861,  0.094000,  0.095029,  0.006758,  0.005981,  0.006449,  0.388111,  0.698765,  0.545296, -0.252488,
3818.886475, 50.907459,154.945465,-147.809769, 63.860428, 48.214344,-122.450348, 38.208649, -0.026481,  0.013357,  0.028270, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.565776,  0.565834,  0.725625,  0.582083,  0.583811,  0.570124,  0.050341,  0.031722,  0.043946,  0.089861,  0.094001,  0.095029,  0.006758,  0.005982,  0.006450,  0.388111,  0.698765,  0.545296, -0.252487,
3818.888184, 50.907349,154.945358,-147.809967, 63.860229, 48.214344,-122.450348, 38.208595, -0.026457,  0.013432,  0.028278, -0.000266, -0.000464, -0.000517, -1.643200,  2.729435,  1.958753,  0.566046,  0.566105,  0.725832,  0.583913,  0.585657,  0.571842,  0.050345,  0.031725,  0.043950,  0.089862,  0.094001,  0.095029,  0.006758,  0.005982,  0.006450,  0.388110,  0.698766,  0.545295, -0.252486,
sure thing, you mean MINimum value in entire array and MAXimum value?
Why stop there, how about Median? :O
Don, please don't use 30, it must be a power of 2 the buffer or else undefined behaviour will occur with library
Use 32 instead if you want 30 items...
Hi Tim. Busy shoveling more snow this morning. Anyway I don't see the NaN. Which means it failed at the rollover? Probably my eyes.
Anyway, around 4282 or so was where the rollover occurred for me and I had the problem - once fixed rtcTime should start recounting. I don't see that occurring. Did you load the v3 Master?
Tim, how's this?
 Circular_Buffer<float, 16> myFloats;
  myFloats.push_back(3.14159);
  myFloats.push_back(12.3456);
  myFloats.push_back(78.91234);
  myFloats.push_back(7.91234);
  myFloats.push_back(11.91234);
  myFloats.push_back(58.91234);
  myFloats.push_back(18.91234);
  Serial.print("MIN: "); Serial.println(myFloats.min(), 5);
  Serial.print("MAX: "); Serial.println(myFloats.max(), 5);
Output:
MIN: 3.14159
MAX: 78.91234
https://github.com/tonton81/Circular_Buffer/commit/a62f2858c17d227e386363608c55d13cfff58904
tonton81 - MIN & MAX looks good.
Running the last ZIP post that has this sketch name: ...\1Apr18\uNavINS_MPU9250_I2C_MAGV3\uNavINS_MPU9250_I2C_MAGV3.ino
Not sure where the rollover recounting code is actualized? This is the only place I see it being set.
  //Define RTC time for this iterationrt
  rtcTime = (float) micros() / 1000000.0 - rtcOffset;
Ok. I have something weird going on. I just looked in the v3 file and code for rollover correction is not there and I know I saved the file. Anyway, here's the fix:
In the uNAVINS.h tab delete (its about line 26)
    // timing
    float tnow, tprev, dt;
and add the following:
    // timing
    elapsedMicros _t;
    float dt;
In the .cpp delete (about line 188):
    // get the change in time
    tnow = (float) micros()/1000000.0f;
    dt = tnow - tprev;
    tprev = tnow;
and substitute this:
      dt = (float)_t /1000000.0;
      _t = 0;
That was the whole fix that was extracted from Brian's EKF code.
Really don't know what happened. All the other changes are there.
Mike
uNavINS_MPU9250_I2C_MAGV4
Here's the updated sketch with those corrections. Hopefully I did it right :)
  • uNavINS_MPU9250_I2C_MAGV4.zip
T:\TEMP\arduino_build_439128\sketch\uNavINS.cpp: In member function 'void uNavINS::update(long unsigned int, double, double, double, double, double, double, float, float, float, float, float, float, float, float, float)':
uNavINS.cpp:51: error: 'tprev' was not declared in this scope
tprev = (float) micros()/1000000.0f;
edit:
// timing
elapsedMicros _t;
float dt, tprev;
Mike,
I'm getting this error with V4 now:
IMU initialization unsuccessful
Check IMU wiring or try cycling power
Status: -1
I tried recycling power, so that's not it. Do I need to back off the IMU speed or something like that?
Don
Tim, I added "float tprev" to the h file and that fixed the compile error...
Don
Mike,
I set IMU_SPD back to 1000000 and got to this now:
Setup Complete
-----Loop#:1 IMU#:0
#1 @18:8.34_800338219 [fix:3 #:18
ASSERT: NaN Fail index = 28
C:\Users\User\Desktop\uNavINS_MPU9250_I2C_MAGV4\uNavINS_MPU9250_I2C_MAGV4\C_serialPrint.ino
64
Me Too:
Gyro Calibration Underway
Gyro Calibration Complete
Setup Complete
T:\tCode\_GPSimuDK\1Apr18\uNavINS_MPU9250_I2C_MAGV4\C_serialPrint.ino
64
  0.339668, 72.472931, 49.413803, 53.493053,265.491638, 48.214333,-122.450325, 42.571877,  1.386992,  1.362751,  4.127507, -0.003696, -0.002071,  0.002641,  8.298505,  0.977089, 14.375739,  2.944455,  2.948416,  4.763172,  0.905949,  0.880890,  1.001549,  0.167624,  0.109688,  0.222566,  0.684927,  0.816811,  0.112641,  0.012540,  0.013869,  0.013555,  0.315907,  0.623191,  0.116911, -0.705810,
  0.365640, 72.479248, 49.412224, 53.487080,265.485657, 48.214336,-122.450325, 42.461033,  1.511060,  1.485580,  4.434150, -0.003696, -0.002071,  0.002641,  8.298505,  0.977089, 14.375739,  2.945716,  2.949865,  4.765454,  0.940240,  0.912364,  1.047434,  0.167710,  0.109847,  0.222593,  0.684753,  0.816603,  0.112635,  0.012538,  0.013865,  0.013552,  0.315844,  0.623213,  0.116925, -0.705816,
Got it, something really dumb on my part - forgot to set _t=0 at the end of the initialization loop. Also, Don - you don't need Tprev at all. Here is the updated v4.
Just copied all but config.h over the prior - it compiled and it running - coming up on a minute.
I wondered about tprev when tnow was gone ...
<edit>: Had to set coutD to Serial ...
It shows :: -----Loop#:359573 IMU#:500
on T_3.6 @ 180 MHz
This means after the 500 IMU updates are caught and processed loop() is passed through another 359,000 times per second every 2.8 uS looking for something to do.
New code ran 363 seconds no trouble - I just stopped it for another restart with SRD at 3 for 250 Hz IMU
It shows :: -----Loop#:528144 IMU#:250
Mike - can you show that Loop# on your T_3.5 for reference
