Page 27 of 28 FirstFirst ... 17 25 26 27 28 LastLast
Results 651 to 675 of 677
Thread: uNav INS
  1. #651
    Senior Member+
    2,960
    Ok. Just tried something else - just assume if there is no motion yaw stays constant from the last updated position but the filter update still runs - seems to work pretty good. as well.
  2. #652
    8,013
    just lurking … Seems like a useful observation Mike. I recall working with the Prop Shield and coloring the R | G | B on my light strip positions - and the YAW would drift when stationary with regularity. The others would generally return when moved and of course not move when stationary.
  3. #653
    Senior Member+
    2,960
    Hi Tim
    Happy Holidays and at the risk of being politically incorrect Merry Christmas. Yeah, I think that the yaw drift when it is stationary is something that is inherent with Kalman filters. If you look at the BNO055 IMU, it doesn't update values unless the IMU is moving. That is probably why.
    Mike
  4. #654
    Mar 2016
    Portland, OR
    495
    Maybe it would make sense if motion is low (i.e. below some threshold), switch to a tilt compass?
  5. #655
    Senior Member+
    2,960
    Was actually thinking about that one, that was why I was trying it out yesterday. Especially after I saw the charts in that link I posted
    From what I saw there is a lot of variation in the tilt compass data that was why I switched to using MahoneyAHRS. In just a quick look, since I was just trying things out (have to go back and try it out more carefully) there seems be several degrees of differences between what get calculated by the KF and the Mahoney filter and compass. Need to run a few more focused tests after the holidays - doing this between getting ready for the holiday
    Will keep you posted.
    EDIT: BTW here is my function for determining zero motion:
    #include "MovingAvarageFilter.h"
    //Setup Motion Detect Averages
    MovingAvarageFilter accnorm_avg(5);
    MovingAvarageFilter accnorm_test_avg(7);
    MovingAvarageFilter accnorm_var(7);
    MovingAvarageFilter motion_detect_ma(10);
    bool MotionDetect() {
       float gyro[3];
       float accnorm;
       int accnorm_test, accnorm_var_test, omegax, omegay, omegaz, omega_test, motionDetect;
       gyro[0] = gx;
       gyro[1] = gy;
       gyro[2] = gz;
       float ax_n = ax/9.807;
       float ay_n = ay/9.807;
       float az_n = az/9.807;
       #   acceleration squared euclidean norm analysis
       #   some test values previously used:
       #       if((accnorm >=0.96) && (accnorm <= 0.99)){
       #                   <= 0.995
        //accnorm = (ax*ax+ay*ay+az*az);
        accnorm = (ax_n*ax_n+ay_n*ay_n+az_n*az_n);
        if((accnorm >=0.9) && (accnorm <= 1.3)){  //was 1.07 and .9
            accnorm_test = 0;
            accnorm_test = 1; }
        /** take average of 5 to 10 points  **/
        float accnormavg = accnorm_avg.process(accnorm);
        float accnormtestavg = accnorm_test_avg.process(accnorm_test);
        #   squared norm analysis to determine suddenly changes signal
        //accnorm_var.process(sq(accnorm-accnorm_avg.getAvg()));
        // was 0.0005
        if(accnorm_var.process(sq(accnorm-accnormavg)) < 0.0005) {
            accnorm_var_test = 0;
            accnorm_var_test = 1; }
    //Serial.print("ACCEL TEST:  ");
    //Serial.print(accnorm); Serial.print(", "); Serial.print(accnorm_test);
    //Serial.print(", "); Serial.println(accnorm_var_test);
        #   angular rate analysis in order to disregard linear acceleration
        #   other test values used: 0, 0.00215, 0.00215
        if ((gyro[0] >=-0.02) && (gyro[0] <= 0.02)) {
            omegax = 0;
            omegax = 1; }
        if((gyro[1] >= -0.02) && (gyro[1] <= 0.02)) {
            omegay = 0;
            omegay = 1; }
        //if((gyro[2] >= -0.005) && (gyro[2] <= 0.005)) {
            omegaz = 0;
            omegaz = 1; }
        if ((omegax+omegay+omegaz) > 0) {
            omega_test = 1;
            omega_test = 0; }
    //Serial.print("GYRO TEST:"); Serial.print(gyro[2]);Serial.print(", ");
    //Serial.print(omegax); Serial.print(", "); Serial.print(omegay);
    //Serial.print(", "); Serial.print(omegaz);
    //Serial.print(", "); Serial.println(omega_test);
        # combined movement detector
        if ((accnormtestavg + omega_test + accnorm_var_test) > 0) {
          motionDetect = 1;
            motionDetect = 0; }
        //motion_detect_ma.process(motionDetect);
        if(motion_detect_ma.process(motionDetect) > 0.5) {
          return true;
          return false;
  6. #656
    8,013
    Hi Tim
    Mike
    Thanks Mike and Merry Christmas and Happy New Year - and Brian and Don … been a while since we saw the SPI_MSTransfer working and then new distractions.
            omega_test = omegax | omegay | omegaz;
    Cool if that improves reliability/results - so that is not adding Kalman - but just deciding to exclude yaw math creeping when there isn't motion?
  7. #657
    Senior Member+
    2,960
    Well, there is actually 2 parts to that algorithm. The first does some magic to test acceleration (that's the accnorm stuff) and then it looks at the gyros to determine if there is rotation (that's the omega terms). At the end it puts it all together:
    and if the test is greater than zero then you have motion.
    From just initial tests looks like excluding yaw it will work - just have to figure out the best way to handle it - looking at the KF now to see how ref handles it with in the filter itself. Here is the presentation that I was referring to earlier. Here is the extract of the pertinent pages. Just have to figure out how to apply it to Brian's model.
    Pages from foot_mounted_zero_velocity.pdf
  8. #658
    8,013
    I saw other parts - I just dropped that if free sample version of the one to keep my post 'on topic'
              motionDetect = accnormtestavg | omega_test | accnorm_var_test;
    Was wondering what happens when movement starts - if the Yaw is saved unchanged when motion stops - or if it will creep and show up way off when motion starts.
  9. #659
    Senior Member+
    2,960
    I ran a simple test using Brian's Teensy Backpack (T3.2 plus MPU9250). I aligned to x-axis pointer to close to magnetic North and let the filters run for awhile and then started movement up to about 90degs and then brought it back to North. This way zero degrees should be close for both filters. Going to run another test Brian's compass sketch and do a comparison.
    UPDATE: I added in the TiltCompass code and did a quick comparison of the yaw. Essential the yaw from the tiltcompass code matches the yaw output from the Mahoney filter. This is when its flat of course.
  10. #660
    Oct 2017
    Houston
    414
    Hi Mike, Brain, Tim,
    Happy Holidays! Am following along with your testing Mike, looks interesting.
    I'm still refining my M8P RTK work using the SparkFun M8P-02 boards. The M8P-02 requires RTCM3 base inputs, so I've switched my base station from UBX binary now to RTCM3 and it's working great. I posted over on Brian's UBLOX thread earlier today as I'm trying to parse UBX binary via I2C using the M8P's Qwiic cables (which are kinda cool). My thinking is to have my RTK base stations output RTCM3 via UART (for input into the Rover's M8P) and concurrently output UBX-NAV-PVT via I2C for base station status display (I2C LCD).
    I'd eventually like to start pulling in this super-accurate RTK solution into the uNav INS algorithm. With the 20Hz F9P chip coming soon, will be fun to try some different Kalman configs out!
    Don
  11. #661
    Mar 2016
    Portland, OR
    495
    Mike is the KF the 15 state INS or the Euler AHRS?
  12. #662
    Senior Member+
    2,960
    Should be the Euler AHRS. There were so many versions I had not sure which one is which any more
    uNavAHRSv1_MPU9250.zip
    Wanted to focus on a version without GPS first.
  13. #663
    Any plans on using the BME280 in the motion backpack for the INS or AHRS libraries? Typically baro, GPS, and vertical acceleration are fused to determined altitude.
    Bruce
  14. #664
    Mar 2016
    Portland, OR
    495
    Long term, yes, I would like to incorporate air data into the INS estimate when available. I'm not sure what the effect would be on output accuracy, but, it would help arrest drift in cases where GPS is unavailable for extended periods and provide an estimate of wind speed and direction when all sensors are available and working.
  15. #665
    My application will never have air speed as it will be in a vehicle so some implementation like this is required:https://github.com/juangallostra/AltitudeEstimation
    But this would not fuse the GPS.
  16. #666
    Just wondering why the update statement has negation and swapping of axis for the accel and the gyro?
    Filter.update(uBloxData.iTOW,uBloxData.velN,uBloxData.velE,uBloxData.velD,uBloxData.lat*PI/180.0f,uBloxData.lon*PI/180.0f,uBloxData.hMSL,Imu.getGyroY_rads(),-1*Imu.getGyroX_rads(),Imu.getGyroZ_rads(),Imu.getAccelY_mss(),-1*Imu.getAccelX_mss(),Imu.getAccelZ_mss(),Imu.getMagX_uT(),Imu.getMagY_uT(),Imu.getMagZ_uT());
    The axis system for the motion back pack is NED.
    The axis system for the uNavINS is missing from the wikki.
    Why are the axis swapped around?
    Bruce
  17. #667
    Mar 2016
    Portland, OR
    495
    Mike asked a similar question and the honest answer is I don't remember, but should be working with it again soonish and find out why:
    https://github.com/bolderflight/uNavINS/issues/3
    I would guess that you should not switch them around and that I was doing some testing that got committed...
    Brian
  18. #668
    Feb 2018
    13
    About UNAV-INS‘s paper or thesis who have?can you give me
  19. #669
    Calibration Issue with 9250
    Hi Don,
    I tried your calibration routine, CalAnalysisMPU9250Ver2, and I'm getting a static IMU bias calibration that doesn't look correct. The parameter, azb, magnitude looks too large. I'm thinking there is one of two possibilities, 1) either there's a code issue or, 2) I have a bad breakout card. Here are the results that I obtain:
    Wait... Conducting IMU static calibration...
    Static Calibration Bias Values:
    axb: -0.647463
    ayb: -0.115094
    azb: -4.477447
    gxb: 0.000910
    gyb: 0.001690
    gzb: 0.000004
    hxb: -13.498309
    hyb: 41.154903
    hzb: -26.354893
    I looked at your code and don't see any issues but I started getting lost in the circular buffer area. I appears the large bias is preventing me from calculating the accelerometer Z-axis calibration. Any thoughts?
    Thanks,
    Willie
    UPDATE:
    Just thought to try another experiment. I have a second 3.6 and 9250 that I was using for prototyping and here is the result that I obtain from the static calibration:
    axb: 0.157945
    ayb: -0.456676
    azb: -3.711194
    gxb: -0.000832
    gyb: 0.000367
    gzb: 0.000229
    hxb: -31.889704
    hyb: 10.246424
    hzb: -47.167191
    It looks about the same.
    Thanks,
    -W
  20. #670
    Update On Inverted ?
    Any update on why some of the IMU input are inverted within the update statement?
    Bruce
  21. #671
    I believe the reason is so that the magnetometer, accelerometer and the gyro axes are aligned.
  22. #672
    Mar 2016
    Portland, OR
    495
    Hi Bruce, sorry I've been down with an upper respiratory bug for the past few weeks. And now I'm playing catch up.
    I haven't had a chance to track down exactly what I was experimenting with. The MPU9250 library I wrote puts everything in the correct orientation first, so there shouldn't need to be that transformation. BUT, maybe I was testing with a different IMU and experimental code accidentally got committed to github. My best guess - the axis system shouldn't be swapped, I don't think you'll need the negative signs with the MPU-9250.
  23. #673
    So the library expects the IMU input in the NED convention?
    Also, is the any available paper/presentation/literature concerning the EKF in this library?
    I ask because I am very interest in adding baro as an altitude input to fuse of the GPS and IMU.
    Bruce
  24. #674
    Mar 2016
    Portland, OR
    495
    Quote Originally Posted by bvernham View Post
    Bruce
    Yes, NED. I can recommend Dan Simon's book for EKF. There are a few papers that mention the EKF presented here at a high level, but none (to my knowledge) go into the specifics. It's a very straightforward filter, however.
  25. #675
    I have reference for EKF implementation.
    The question I am asking is about this specific EKF implementation as the code is not really documented with comments and such.
    So anything that would help with variable meanings, what is being calculated where and so on would be very helpful.
    Bruce
