Results 1 to 2 of 2
Thread: unwanted solder bridge, Serial3 to ground
    Oct 2016
    11
    I had an unwanted solder bridge, Serial3 (RX3 / TX3) to ground.
    Now Serial3 is not working anymore, Serial1 and Serial2 are working (for testing I have changed the code). Can it be that the Teensy 3.2 is sensitive to the serial ports?s sensitive?
    Feb 2014
    Colmar, France
    2,598
    Be happy that “only” Serial3 is broken. With a bit of luck, you might use these pins still as GPIO pins (check with an oscilloscope or a multimeter). Shorts to ground can theoretically kill the whole Teensy, thus you had still luck. But to prevent unwanted long term effects, I’d considering ordering a new one, or better two or three. It is always good to have a few spares in the drawer in case such “ooops” situations happen.
