TonyParakka
New member
My Teensy 3.1 (T3.1) loses serial connection and also non-functional (but recoverable); Could use help tot figure out why.
In this un-responsive mode, it no longer appears connected (under Port) and devices attached to it (2.2" TFT ILI9341) goes blank.
Recovery : (Thanks Paul, picked this up from a previous "Teensy dead thread") Disconnect USB cable, hold Reset button, reconnect USB cable, wait 15sec release USB button; then load "Blinky"; then upload program again (code below)
After recovery, the code works; but would feel much better knowing why the T3.1 went un.responsive.
This behaviour is a recent thing, since I moved the T3.1 from the breadboard to a prototype board.
On the breadboard, the program was stable, and operated indefinitely.
On the breadboard mu connections were: CS=D10, DC=D9; MOSI=D11, MISO=D12, SCK=D13, RESET=Vdd(3.3v), RLED=100ohm from 3.3v
In going to the porto board, I did make a few small change,
CS=D15, DC=D10, others remained the same MOSI=D11, MISO=D12, SCK=D13 RESET=Vdd, RLED=82ohm from 3.3v
HW wise, I have double-checked connections; all seem fine (evidenced by the board working after recovery)
I do not see any component on the T3.1 board, or the 82ohm resistor, or anything on the TFT board getting hot.
Grateful for any thoughts and suggestions..
thanks..
-Tony
PS. I am relatively new to the Teensy devices, and still learning..
Full Code:#include "ILI9341_t3.h" //TFT library with Teensy3+
#include "font_Arial.h"
#define TFT_CS 15 //<<<<<<====NOTE: FOR INTEGRATED BOARD WITH T3 AND 2.2TFT
#define TFT_DC 10 //<<<<<<====NOTE: FOR INTEGRATED BOARD WITH T3 AND 2.2TFT
#define TFT_MOSI 11 //defaulat MOSI
#define TFT_MISO 12 //default MISO
#define TFT_SCK 13 //default SCK
#define TFT_RST 255 //tied to 3.3v
#define TFT_GREY 0x5AEB
ILI9341_t3 tft=ILI9341_t3(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCK, TFT_MISO);
#define CMPS11_ADDRESS 0x60 // Address of CMPS11 shifted right one bit for arduino wire library
#define ANGLE_8 1 // Register to read 8bit angle from
#define aXneutral 160 //aircraft Xneutral = center of box
#define aYneutral 150 //aircrat Yneutral = cener of box
#define aYoffset 0 //aircraft Yoffset to compensate for installation
#define aXrange 90 //box is 180 wide
#define aYrange 90 //box is 180 tall
#define aRadius 8 //aircraft fuselage size
#define tLen 30 //aircraft tail size
#define wLen 50 //aircraft wing size
#define maxPitch 45 //LIMIT MAX PITCH FOR PITCH DISPLAY SENSITIVITY
#define maxUPpitch 45
#define maxDNpitch -45
#define screenColor ILI9341_BLACK
#define headingTxtColor ILI9341_YELLOW
#define headingBakColor ILI9341_BLACK
#define headingBoxColor ILI9341_YELLOW
#define headingFont 6
#define headingTxtSize 1
#define boxFillColor ILI9341_NAVY
#define boxBoxColor ILI9341_WHITE
#define boxXhairColor ILI9341_DARKGREEN
#define boxBankMarkerColor ILI9341_WHITE
#define boxPitchMarkerColor ILI9341_WHITE
#define boxPitchLineColor ILI9341_DARKGREEN
#define boxAircraftColor ILI9341_WHITE
int pitch, roll;//pitch and roll: valid range are +/-85degrees
int newHeading, oldHeading;//heading
int fontValue=6;//heading text font
// screen positions and increments for heading value display
int hYpos=10, hXpos=115, hXinc=30;//heading text position and increment
// aircraft display box start and end values
int aXstart=aXneutral-aXrange, aXend=aXneutral+aXrange;
int aYstart=aYneutral-aYrange, aYend=aYneutral+aYrange;
int oldAYpos= 150; //=(71+239)/2 aircraft dot position
int WX1=0, WX2=0, WY1=0, WY2=0;//wing line position
int TX1=0, TX2=0, TY1=0, TY2=0;//tail line position
//roll angle marker coord -inside, outside for R1=62, R2=70/80: angles 0->180deg, 15deg increments
int mX1[]={62,60,54,44,31,16,0,-16,-31,-44,-54,-60,-62}, mX2[]={80,68,69,49,40,18,0,-18,-40,-49,-69,-68,-80};//marker xcoord for 15, 30, 45, 60deg, R=45, 60
int mY1[]={0,16,31,44,54,60,62,60,54,44,31,16,0}, mY2[]={0,18,40,49,69, 68,80,68,69,49,40,19,0};//marker ycoord for 15, 30, 45, 60deg, R=45, 60
//pitch angle marker coordinates outside the Attitude box
int pMx[]={10,5,10,5,10}, pMy[]={0,18,36,54, 72, 90};
// marker coordinates from MarkerCoordinates Spreadhseet
//tft.init();
tft.begin();
tft.setRotation(1);
tft.fillScreen(screenColor);
//tft.fillRect(aXstart,aYstart, aXrange*2,aYrange*2, boxFillColor); //attitude box
//Attutude Box
tft.fillRect(aXstart, aYstart, aXrange*2, aYrange, ILI9341_BLUE); //sky half
tft.fillRect(aXstart, aYneutral, aXrange*2, aYrange, ILI9341_MAROON); //ground half
tft.drawRect(aXstart, aYstart, aXrange*2, aYrange*2, boxBoxColor); //draw Outline
for(int i=0; i<6; i++){ //draw pitch angle markers
tft.drawLine(aXstart-pMx,aYneutral+pMy,aXstart, aYneutral+pMy, boxPitchMarkerColor);
tft.drawLine(aXstart-pMx,aYneutral-pMy,aXstart, aYneutral-pMy, boxPitchMarkerColor);
tft.drawLine(aXend+pMx,aYneutral+pMy,aXend, aYneutral+pMy, boxPitchMarkerColor);
tft.drawLine(aXend+pMx,aYneutral-pMy,aXend, aYneutral-pMy, boxPitchMarkerColor);
tft.setFont(Arial_24);
tft.setTextColor(headingTxtColor, headingBakColor); //heading text color
tft.drawRect(100, 5, 120, 53, headingBoxColor); //box over heading
for(int i=0; i<13; i++){
mX1=aXneutral-mX1;
mX2=aXneutral-mX2;
mY1=aYneutral-mY1;
mY2=aYneutral-mY2;
Wire.begin();
//Serial.begin(9600); //Debug only
Wire.beginTransmission(CMPS11_ADDRESS); //starts communication with CMPS11
Wire.write(ANGLE_8); //Sends the register we wish to start reading from
Wire.endTransmission();
// Request 5 bytes from the CMPS11: byteHeading, wordHeading, bytePitch, byteRoll
Wire.requestFrom(CMPS11_ADDRESS, 5);
while(Wire.available() < 5);// Wait for all bytes to come back
newHeading = Wire.read();//read byteHeading heading value and discard
newHeading = Wire.read();//read high byte of wordHeading value
newHeading = (newHeading<<=8)+Wire.read();//shift high byte by 8bits, then read and add lower byte
pitch = Wire.read();//read bytePitch
roll = Wire.read();//read byteRoll
newHeading/=10; //Remove decimal value
//reverse heading direction for board header at aircraft tail end---------
newHeading-=180;
if(newHeading<0) newHeading+=360;
if(pitch>127) pitch-=256;
if(roll>127) roll-=256;
//limit pitch value to maxPitch for better pitch display sensitivity
if(pitch>maxUPpitch) pitch=maxUPpitch;
else if(pitch<maxDNpitch) pitch=maxDNpitch;
//Serial.print("Pitch="); Serial.print(pitch); //Debug only
//Serial.print(" : Roll="); Serial.print(roll); //Debug only
//Serial.print(" : Heading="); Serial.println(newHeading); //Debug only
printHeading();//update heading display value
drawAircraft(roll, pitch);//update pitch/roll display
delay(100); // update approx 10 times per second
void drawAircraft(int rValue, int pValue){ //For T3, changed to int from char; fixed ISSUE in _000
int newYneutral=aYoffset+map(pValue, maxDNpitch, maxUPpitch, aYend, aYstart);
int aYdip= (int)((float)aXrange*sin((float)rValue*0.0174));
int aY1=newYneutral-aYdip, aY2=newYneutral+aYdip;
if(aY1>aY2){ //aY1 is left side, aY2 is right side
tft.fillRect(aXstart, aYstart, aXrange*2, (aY2-aYstart), ILI9341_BLUE);//fill sky to higherY on screen
tft.fillRect(aXstart, aY1, aXrange*2, (aYend-aY1), ILI9341_MAROON);//fill ground from lower Y to bottom
tft.fillTriangle(aXstart, aY1, aXend, aY1, aXend, aY2, ILI9341_MAROON);//fill lower triangle with ground
tft.fillTriangle(aXstart, aY2, aXstart, aY1, aXend,aY2, ILI9341_BLUE);//fill upper triangle with sky
else{ //roll Left -works well
tft.fillRect(aXstart, aYstart, aXrange*2, (aY1-aYstart), ILI9341_BLUE);//fill sky to higher Y on screen
tft.fillRect(aXstart, aY2, aXrange*2, (aYend-aY2), ILI9341_MAROON);//fill ground from lower Y to bottom
tft.fillTriangle(aXstart, aY1, aXend, aY1, aXend, aY2, ILI9341_BLUE);//fill upper triangle with Sky
tft.fillTriangle(aXstart, aY1, aXstart, aY2, aXend, aY2, ILI9341_MAROON);//fill lower triangle with Ground
//Draw Aircraft
tft.fillRoundRect(aXneutral-wLen, aYneutral, wLen*2, 4, 2, ILI9341_WHITE); //draw Wings
tft.fillRoundRect(aXneutral-2, (aYneutral-tLen), 4, tLen, 2, ILI9341_WHITE); //draw Tail
tft.fillCircle(aXneutral, aYneutral, aRadius, ILI9341_WHITE); //draw Fuselage
//Draw Bank Markers
tft.drawLine(mX1, mY1, mX2, mY2, ILI9341_WHITE);//Flickers jsut redrawing! Why?
void printHeading(){
int i, decade, nHvalue=newHeading, oHvalue=oldHeading, x=hXpos, y=hYpos;
tft.setFont(Arial_40);
// Check individual digits; only if changed then erase old/print new; eliminates flicker
for(i=0, decade=100; i<3; i++){
if((nHvalue/decade) != (oHvalue/decade)){
tft.setCursor(x, y);
tft.setTextColor(headingBakColor);
tft.print(oHvalue/decade);
tft.setTextColor(headingTxtColor);
tft.print(nHvalue/decade);
nHvalue%=decade; oHvalue%=decade;
decade/=10; x+=hXinc;
oldHeading=newHeading;
thanks..
-Tony
//tft.init();
tft.begin();
tft.setRotation(1);
//Attutude Box
mX1=aXneutral-mX1;
mX2=aXneutral-mX2;
mY1=aYneutral-mY1;
mY2=aYneutral-mY2;
Wire.begin();
newHeading-=180;
//Draw Aircraft
//Draw Bank Markers
