Teensy3.6 clock frequency
Jacob.Schultz
I found a mismatch in the 180 Mhz clock configuration in Tensyduino
The only way to hit a 180 Mhz clock in HS mode exactly with a 16 Mhz crystal with Kinetis own online clock tools is the following parameters:
MCG.VDIV.scale, value: '45'
MCG.PRDIV.scale, value: '2'
SIM.OUTDIV2.scale, value: '3' - gives 60 Mhz bus clock
and it looks like Teensyduino is running a 116 Mhz core and 58 Mz bus in 180 Mhz mode. The OUTDIV2 must be 3 anyway since 180/3 = 60
VDIV = 29
PRDIV = 1
OUTDIV2 = 2
is it correct assumed? I have verified that the clock frequency according to Kinetis configuration is working correct.
how do your paper arguments compare with what your scope says?
look at k66 ref pg 262 (SIM_CLKDIV1) SIM_CLKDIV1_OUTDIV2(2) ( 2 means divisor of 3) RTFM
from mk20dx128.c
#elif F_CPU == 180000000
    // config divisors: 180 MHz core, 60 MHz bus, 25.7 MHz flash, USB = IRC48M
    #if F_BUS == 60000000
    SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIV1(0) | SIM_CLKDIV1_OUTDIV2(2) | SIM_CLKDIV1_OUTDIV4(6);
https://www.pjrc.com/teensy/datasheets.html
Sorry, your right nothing is wrong, i was cheatet by some macro translations Teensyduino code is using the raw register values not human readable.
VDIV 11101 45
