Results 1 to 2 of 2
Thread: SerialFlash.begin always returns true, even when no SPI flash is connected
    Senior Member Ben's Avatar
    Jul 2013
    Germany
    401
    I today tried to determine if an SPI flash IC is connected by checking the SerialFlash.begin return value. Turns out the function returns true unconditionally.
    I reproduced this with a Teensy 3.2 with nothing attached and the ListFiles example. This error message:
    if (!SerialFlash.begin(FlashChipSelect)) {
        error("Unable to access SPI Flash chip");
    is never printed over Serial.
    Ben
    2,094
    Hmmm, looks like the library's begin() should check some of the readID() bytes and if all 0 or all 0xff return false. capacity() already does such a check, so maybe in begin() one would add
           readID(id);
           if ((id[0]==0 && id[1]==0 && id[2]==0) ||
    		(id[0]==255 && id[1]==255 && id[2]==255)) {
    		return false;
           f = 0;
