I built a board with 8 buttons and three sliders on it.
I wrote some code to get input on the pins and Serial.printed to the monitor verifying that everything was working.
I then copied in some code from a midi control project called "teensy_MIDI_control_v2" (see attachment 1). Imodified it. None of the buttons worked. I then noticed that I had to select MIDI as my USB type. It still didin't work.
So then I tried the "simple_teensy_midi_controller" code from a different project. I modified it. It sort of ran with 7 out of 8 buttons working. I modified the code and when I went to write it I could no longer see a "Port" for my teensy in the IDE.
I uninstalled the Arduio IDE and reinstalled it and then installed the Teensyduino code again.
I am still having the same problem... No Port.
I have another Teensy LC but hesitate to hook it up, just in case I've done something that damaged the first one.
Any ideas or suggestions on what I should try next?
