Results 1 to 6 of 6
Thread: Encoder direction problem
    Jan 2018
    1
    I'm trying to use the Encoder.h library with Teensy. The program compiles without any errors and sort of works but not very reliably. I am using a standard rotary encoder and connecting the output of the encoder directly to pins 7 and 8.
    My code monitors the encoder in a loop and does a serial print on whether it is turned clockwise or counter clockwise. So, when I turn the encoder in one direction, it reports the wrong direction about 25% of the time. Has anyone here encountered a similar problem?
    Feb 2014
    Colmar, France
    1,153
    Difficult to say since there are tons of different Encoder.h libraries out there in the wild... one common problem with wrong readings is with cheap mechanical rotary encoders where mechanical contact bouncing may lead to extra-pulses. Some libraries do handle that, others don’t and expect you to debounce your encoder in hardware, i.e. with 2 RC low-pass filters and optionally 2 Schmitt-Triggers.
    Apr 2013
    1,574
    How far does the encoder move in one click? Some will jump a fair number of steps per detente which can make life interesting. Posting your code and possibly a photo of your wiring would help here.
    Feb 2014
    Colmar, France
    1,153
    The problem (as usual) is that the OP did neither share his code, nor schematics, nor details about the used components (i.e. encoder data sheet)...
    Knowing that there are many encoder libraries and an infinite number of encoder hardware, the OP did just not provide enough information to give qualified support. He also did not reply for more that 12 hours. I'm not sure if this is serious.
    16,236
    Quote Originally Posted by brakecane View Post
    Yes, they have. It's usually improperly connected hardware. Noisy mechanical chatter sometimes does this too. Adding the RC filters Theremingenieur mentioned can help.
    Feb 2014
    Colmar, France
    1,153
    If it was about these cheap rotary encoder knobs which have lots of mechanical chatter, this could be helpful, too.
