I'm trying to use snooze to put a teensy 3.2 to sleep for 30 seconds. It will wake up and take some measurements and then go back to sleep. However I have a digital input that I need to track each time it changes in between the sleep events. The digital will toggle at a maximum interval of 500 milliseconds. Am I implementing the snooze library (v6.3.2) correctly for this scenario?
#include <Snooze.h>
// Load drivers
SnoozeDigital digital;
SnoozeTimer timer;
SnoozeUSBSerial usb;
SnoozeBlock sleep_config(usb, digital, timer);
int counter = 0;
unsigned long lastTrigger = 0;
const unsigned long debounceDelay = 500;
while (!Serial);
Serial.println("Staring...");
pinMode(LED_BUILTIN, OUTPUT);
digital.pinMode(0, INPUT_PULLUP, CHANGE); //pin, mode, type
//pinMode(0, INPUT_PULLUP); //Setup 0 Pin as input for counter
//attachInterrupt(0, counterISR, CHANGE);
timer.setTimer(5000);// milliseconds
int who;
feed the sleep function its wakeup parameters. Then go
to deepSleep.
who = Snooze.deepSleep(sleep_config);// return module that woke processor
if (who == 36) { // lptmr wakeup value
for (int i = 0; i < 2; i++) {
delay(200);
delay(200);
else if (who == 0) {
if ((millis() - lastTrigger) > debounceDelay) {
lastTrigger = millis();
++counter;
while (!Serial) {
delay(30);
Serial.print("Counts: ");
Serial.println(counter);
// * ******* Interrupt Service Routines (ISR) *******
// Interrupt handler
//void counterISR ()
// if ((millis() - lastTrigger) > debounceDelay) {
// lastTrigger = millis();
// ++counter;
//} // ******** end of isr *******
