Results 1 to 4 of 4
Thread: How to stop analyzing notefrequency
    Dec 2017
    12
    I'm using a Teensy 3.2 with the audio library and speaker and a microphone.
    For testing, if the speaker works, I send a special frequency (e.g. 1000 Hz) to the speaker and analayze the note frequency with the microphone.
    This works well.
    Now, if the speaker test is succussfully, I want to stop analyzing note frequency.
    Is there a function (e.g. notefreq.stop()) to stop or suspend AudioAnalyzeNoteFrequency?
    Feb 2017
    279
    Far from an expert here, but you could route the signal that you're sending to the AudioAnalyzeNoteFrequency through a mixer first. If you set the gain of that mixer channel to zero, the input to the AudioAnalyzeNoteFrequency will be all zeros. I believe that stops the block from processing its input data.
    Nov 2017
    Belgium
    33
    That was my initial thought too, so I had a look at the code. If I'm not mistaken, it only stops processing when it stops receiving audio blocks. If that's the case, I can think of 2 more options.
    Use the new AudioConnections disconnect() member in upcoming teensyduino 1.41.
    patchCord2notefreq.disconnect();
    Quote Originally Posted by walpre View Post
    No there isn't but if you feel adventurous, add it yourself by adding this line to the public section in analyze_notefreq.h
        void stop( void ) { enabled = false; }
    2,161
    Quote Originally Posted by neurofun View Post
    Or even creating a dedicated audioSwitch object as demonstrated here
    class AudioSwitch : public AudioStream {
    public:
        AudioSwitch( void ) : AudioStream( 1, inputQueueArray ), enabled( true ) { }
        void setSwitch(bool state) { enabled = state;}
        virtual void update( void ) {
          audio_block_t *block;
          block = receiveReadOnly();
          if (block)
          { if (enabled ) transmit(block);
            release(block);
    private:
        bool enabled;
        audio_block_t *inputQueueArray[1];
    } audioSwitch;
    AudioSynthWaveformSine   sine1;          //xy=157,501
    AudioOutputAnalog        dac1;           //xy=406,499
    AudioConnection          patchCord1(sine1, audioSwitch);
    AudioConnection          patchCord2(audioSwitch, dac1);
      AudioMemory(4);
      dac1.analogReference(INTERNAL);
      sine1.amplitude(0.5);
      sine1.frequency(1000.0);
      pinMode(13,OUTPUT);
      static uint32_t t0;
      if(millis()>t0+5000) // select tone or led
      { audioSwitch.setSwitch((bool) digitalReadFast(13));
        digitalWriteFast(13, !digitalReadFast(13));
        t0=millis();
