Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 76 to 100 of 142
Thread: T3.6 USB Host - Joysticks
  1. #76
    New York
    5,466
    Did not get as far today as I was hoping for. But did another trace of windows starting a paring.
    Figured out windows is using extended inquiry mode, which I want to try, as the extended response includes the name, which was trying to get earlier for ps4...
    Glad you got your windows working again along with multiboot.
    Didn't get very far either today, i.e., flexcan or Linux bt sniffing. Have to do more reading on Linux I guess. Only good thing I am learning some basic stuff with Linux. Going to post the flexcan issue again over on the T$ thread. Just can't seem to get it working for some reason.
  2. #77
    7,133
    @mjs513 and @defragster,
    Right now trying to enable the extended information to be returned, I am making some progress, to do this, I first need to set the inquiry mode, then found out that the event generated for extended was not enabled by default so now set it... And now I am getting some results. Note: Sometimes the controller sends the full data and few times not.
    Not sure if I maybe also need to set the extended_inquiry_length setting to non zero...
    But here is sort of the start of the inquire process:
    HCI_WRITE_INQUIRY_MODE called (45 0c 01 02 )
        Control callback (bluetooth): 6 : 45 c 1 2
    BT rx_data(6): e 4 1 45 c 0
        Command Completed!
    HCI_Set_Event_Mask called (01 0c 08 ff ff ff ff ff 5f 00 00 )
        Control callback (bluetooth): 7 : 1 c 8 ff ff ff ff ff 5f 0 0
    BT rx_data(6): e 4 1 1 c 0
        Command Completed!
    HCI_INQUIRY called (01 04 05 33 8b 9e 30 0a )
        Control callback (bluetooth): 8 : 1 4 5 33 8b 9e 30 a
    BT rx_data(6): f 4 0 1 1 4
        Command 401 Status 0
    BT rx_data(16): 2f ff 1 dc 13 d6 1b aa 9c 1 2 8 5 0 92 16
    BT rx_data(16): c9 19 9 58 62 6f 78 20 57 69 72 65 6c 65 73 73
    BT rx_data(16): 20 43 6f 6e 74 72 6f 6c 6c 65 72 3 3 24 11 0
    BT rx_data(16): 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    BT rx_data(1): 0
        Extended Inquiry Result - Count: 1
          BD:dc:13:d6:1b:aa:9c, PS:1, class: 508
          Local Name: Xbox Wireless Controller
          Peripheral device
            Gamepad
    BluetoothController::find_driver  driver 20005678
    JoystickController::claim_bluetooth TRUE
        *** Claimed ***
    Notice how I am now getting a more full response, where you see the first line of several that starts of as 2f ff
    The 2f is the extended result, ff says the length of data... As we are only getting in 16 bytes at a time, that is all of the other Reads after tha which ends with the one byte 1 of 00.
    But as you can see from my pringint below it included local name ...
  3. #78
    New York
    5,466
    @KurtE and @defragster
    You really are making progress.
    Its a whole heck a lot more that I am.
  4. #79
    7,133
    @mjs513 - I feel like I am making some progress. Although pretty slow, as have many distractions (Annie, Age, ...)
    If I get a chance I will now change the code that processes that extended inquiry result and pass it the name of the object, and keep a copy of it.
    Not sure yet what other pieces of information in it, might come in handy.
    The data in the last 240 is extended inquiry data, where, it is made up of small fields, first byte is count of bytes, send byte is indicator of what the data is and the remaining N bytes is the data.
    The data types are in the documeent: https://www.bluetooth.com/specificat...access-profile
    Document talking about this stuff: https://www.bluetooth.org/docman/han...?doc_id=245130
    So the data above:
    So we have first field of 19 hex bytes type 9 which is complete local name.
    The next field: 3 bytes field is list of service list UUIDS
    Now back to the distractions
  5. #80
    7,133
    @mjs513 and @defragster - I still don't have XBox one working, but pushed up my WIP for Bluetooth changes.
    In particular I am using the extended inquiry now for trying to setup binding: BluetoothController bluet(myusb, true, "0000");
    So for example in my last test I was able to bind to PS4 and I think it was properly knowing it was PS4 and so even in the pairing case was getting the full messages.
    Mike I also tried to remove compiler warnings and the like, but still have one: Serial.printf("Battery Status: %d\n", ((psAxis[30] & (1 << 4) - 1)*10));
    It suggests () as it is unclear unless you really know C++ operator ordering, that this is the same as: Serial.printf("Battery Status: %d\n", ((psAxis[30] & 0xf)*10));
  6. #81
    New York
    5,466
    @KurtE
    Cool I pull down the new stuff later have to go do doctor visits today. Progress is still progress. Entertained my self by getting flexcan working on the T$. Something that's been on the todo list for a long while. I will fix the warning as well.
  7. #82
    New York
    5,466
    @KurtE and @defragster and others
    Just hooked up the throttle unit of the Logitech G Pro Flight X56 Rhino HOTAS which has all kinds of buttons, sliders, hats and switches as a test for the USB.
    First thing that I noticed is that it is also backlight (on the base) which is interesting and yes it is light up.
    But I did have to comment out the PS3/PS4/XBOX case switch statement - on compile it gives the error message that "joysticks[joystick_index].joystickType" is not of type integer and then a couple of other errors "JoystickController::PS4" etc. Once that was commented out it compiled and loaded onto the T3.6 not problem.
    The toggle switches are spdt so that was interesting but both directions did register as well as the dual throttle and the knobs. So that was good.
    The other thing that did not register was the three position mode switch on the unit. Haven't did any debugging on this yet but just wanted to give you all an update.
    <EDIT> Also just noticed the slider on the right throttle isn't registering either
  8. #83
    7,133
    @mjs513 Sorry, I thought I caught most of those... I made it a functions instead of member variable the user code could muck with:
    So:
    Should now be:
    joysticks[joystick_index].joystickType()
  9. #84
    New York
    5,466
    @KurtE
    Not a problem - didn't look at the changes you made this time - usually I do but of course not this time.
    BTW I cant seem to get a usage report that shows for the joystick - all I see printed is UP: … pages = 21, 22, 23, 24
  10. #85
    New York
    5,466
    @KurtE:
    Ok - uncommented the right dbgprint statement. Think the problem is that the missing data falls under additional axis which is not captured:
    Joystick: usage=90021, value=0      Mode Switch position S1
    UP: usage_page=9 usage=21 add: 0 0 0
    Joystick: usage=90022, value=0      Mode Switch position S2
    UP: usage_page=9 usage=22 add: 0 0 0
    Joystick: usage=90023, value=0      Mode Switch position M1
    UP: usage_page=9 usage=23 add: 0 0 0
    Joystick: usage=90024, value=1      Slider switch - on/off
    UP: usage_page=9 usage=24 add: 0 0 0
    not sure how to handle this one. Any suggestiongs?
    <EDIT> Got a fix that works but not sure if its the right one. In joystick:claim_collection I changed the default additional pages to:
    		default:
    			additional_axis_usage_page_ = 0x9;
    			additional_axis_usage_start_ = 0x21;
    			additional_axis_usage_count_ = 5;
    			axis_change_notify_mask_ = 0x3ff;	// Start off assume only the 10 bits...
    It now picks up the additional switches but not sure this is the right approach.
  11. #86
    7,133
    @mjs513 and if looking @Paul (and others) - Good question,
    Paul did the main parsing code for the HID data. If I remember correctly, I started it and had some specific stuff decoded, and then he rewrote it in a much more general way...
    Mike, I am trying to remember where you posted the linux HID dump for this one... If I remember correctly it was sort of interesting, and I was wondering how the system would handle it... Again short handing it, it was something like:
    10 bits X, 10 bits Y, 4 bits of buttons, <more stuff>, More bits of buttons,
    I was wondering how the code would handle that the bits for the buttons were split into multiple pieces. Maybe there was no problem, but was goint to be interesting to see how the callbacks into Joystick was handling that. Was it hopefully just continuing to use the next set of bits in our 32 bit button mask, or did it reset to reuse the bits? ...
    As for other Axis stuff coming through, as you have already done, probably need to see if or where that data comes through...
    Sorry I know that is not much help
  12. #87
    New York
    5,466
    Actually this is a brand new joystick - just got it the other day as a test unit for the USBHost_t36 library. What I tested was the throttle unit. Guess it was a good choice. So I never posted the HID dump (actually think I did from the lib). What I posted was for my other Logitech joystick. I will reattach it and post the full dump for your reading pleasure
    To be honest, those extra switches show up as additional axes as opposed to buttons - will post that too. Just in the middle of a Kicad session I want to finish up. Frank B got me started again on my breakout board, never ends does it
    EDIT
    Here is the dump with my changes:
    Joystick: usage=10030, value=4
    Joystick: usage=10031, value=4
    Joystick: usage=90001, value=0
    Joystick: usage=90002, value=0
    Joystick: usage=90003, value=0
    Joystick: usage=90004, value=0
    Joystick: usage=90005, value=0
    Joystick: usage=90006, value=0
    Joystick: usage=90007, value=0
    Joystick: usage=90008, value=0
    Joystick: usage=90009, value=0
    Joystick: usage=9000A, value=0
    Joystick: usage=9000B, value=0
    Joystick: usage=9000C, value=0
    Joystick: usage=9000D, value=0
    Joystick: usage=9000E, value=0
    Joystick: usage=9000F, value=0
    Joystick: usage=90010, value=0
    Joystick: usage=90011, value=0
    Joystick: usage=90012, value=0
    Joystick: usage=90013, value=0
    Joystick: usage=90014, value=0
    Joystick: usage=90015, value=0
    Joystick: usage=90016, value=0
    Joystick: usage=90017, value=0
    Joystick: usage=90018, value=0
    Joystick: usage=90019, value=0
    Joystick: usage=9001A, value=0
    Joystick: usage=9001B, value=0
    Joystick: usage=9001C, value=0
    Joystick: usage=9001D, value=0
    Joystick: usage=9001E, value=0
    Joystick: usage=9001F, value=0
    Joystick: usage=90020, value=0
    Joystick: usage=90021, value=1
    Joystick: usage=90022, value=1
    Joystick: usage=90024, value=0
    Joystick: usage=10032, value=126
    Joystick: usage=10033, value=128
    Joystick: usage=10035, value=126
    Joystick: usage=10034, value=128
    Joystick: usage=10036, value=63
    Joystick: usage=10037, value=0
    e=0
    And the associated output:
    Joystick(0): buttons = 0 0:4 1:4 2:126 3:128 4:128 5:126 6:63 7:0 10:1 11:0 12:0 13:1
    The added axes were 10-13
    Without:
    �JoystickController::claim_collection joystickType_=0
    Claim Additional axis: 0 0 0
    Joystick: usage=10030, value=1023
    Joystick: usage=10031, value=1023
    Joystick: usage=10034, value=127
    Joystick: usage=90023, value=1
    and output
    Joystick(0): buttons = 0 0:1023 1:1023 2:126 3:128 4:127 5:126 6:63 7:0
  13. #88
    New York
    5,466
    @KurtE
    Don't know if you noticed or not - I updated the prior post with the HID reports for the throttle joystick I am using.
  14. #89
    7,133
    Thanks @mjs513 - Oops was distracted. As far as I can tell, that looks reasonable . Sometimes we probably just have to wing it.... So unless you see that it is breaking something else, then I would say check it in
  15. #90
    New York
    5,466
    @KurtE
    You and me both for being distracted - I blame Frank for that for asking that question on pin positions - troublemaker.
    Yeah - not worried about winging it - do it all the time. Just didn't know if there was a better way I will do some regression testing with the PS4 and my other joystick. If nothing breaks then I will push it up
  16. #91
    Germany NRW
    6,919
    :-) my next screen name will be distracter
  17. #92
    New York
    5,466
    Well at least it got me off my you know what to finish off the board design. So I guess you are a good distractor.
  18. #93
    7,133
    I agree, it also got some of us to look into some more interesting things like, what else can those SD card pins be used for
    On my trying to capture the XBox One being claimed (paired) with PC, using logic analyzer and then try to reduce the 3 million lines output in report
    down to more useful extract as discussed in: https://forum.pjrc.com/threads/55457...-in-large-file
    I found unix grep worked the best to get rid of the big bulk, then I was able to do some sublime edits, no including a regreplace setup/command which tries to insert the names of several of the events and commands in to make it easier to read:
    Current output is:
    SETUP	0x00	0x05		0x00 0x01 0x01 0x00 0x00 0x00 0x00 0x00
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x04 0x00
    OUT	0x00	0x05		0x59 0x0C 0x01 0x00
    IN	0x01	0x13		0x0E 0x04 0x01 0x59 0x0C 0x00
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x08 0x00
    OUT	0x00	0x05	HCI_INQUIRY	0x01 0x04 0x05 0x33 0x8B 0x9E 0x05 0x00
    IN	0x01	0x13		0x0F 0x04 0x00 0x01 0x01 0x04
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x0A 0x00
    OUT	0x00	0x05		0x0B 0x20 0x07 0x01 0x12 0x00 0x12 0x00 0x00 0x00
    IN	0x01	0x13		0x0E 0x04 0x01 0x0B 0x20 0x00
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x05 0x00
    OUT	0x00	0x05		0x0C 0x20 0x02 0x01 0x00
    IN	0x01	0x13		0x0E 0x04 0x01 0x0C 0x20 0x00
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x1A 0x02 0x01 0x00 0x01 0xA4 0x66 0x77 0xC3 0x69 0x7B 0x0E 0x02 0x01 0x1A
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x01 0x1C 0x33 0x40 0xB3 0xC2
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x2B 0x02 0x01 0x03 0x01 0x03 0xC3 0x57 0x1F 0x0A 0x45 0x1F 0x1E 0xFF 0x06
    IN	0x01	0x13		0x00 0x01 0x09 0x20 0x02 0x75 0x42 0xB2 0x9D 0x7E 0xD9 0x74 0x95 0x66 0x12 0x0B
    IN	0x01	0x13		0xA1 0x80 0x6D 0x2F 0x28 0x71 0xC9 0x9B 0xA3 0x98 0xED 0xB2 0xD6
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x1A 0x02 0x01 0x00 0x01 0x70 0xA1 0xD0 0x2B 0x7E 0x71 0x0E 0x02 0x01 0x1A
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x1C 0x6E 0xEA 0xF2 0xBC
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0x70 0xA1 0xD0 0x2B 0x7E 0x71 0x00 0xBC
    IN	0x01	0x13		0xA1 0x80 0x6D 0x2F 0x28 0x71 0xC9 0x9B 0xA3 0x98 0xED 0xB2 0xD8
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x01 0x1C 0x33 0x40 0xB3 0xC1
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0xA4 0x66 0x77 0xC3 0x69 0x7B 0x00 0xC1
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x28 0x02 0x01 0x03 0x00 0x7D 0x2B 0x22 0x27 0x97 0xC0 0x1C 0x1B 0xFF 0x75
    IN	0x01	0x13		0x00 0x42 0x04 0x01 0x80 0x60 0xC0 0x97 0x27 0x22 0x2B 0x7D 0xC2 0x97 0x27 0x22
    IN	0x01	0x13		0x2B 0x7C 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0xC6
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x1C 0x6E 0xEA 0xF2 0xBF
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0x70 0xA1 0xD0 0x2B 0x7E 0x71 0x00 0xBF
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x1A 0x02 0x01 0x00 0x01 0xA2 0x96 0x4B 0x65 0x85 0x5C 0x0E 0x02 0x01 0x1A
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x18 0xA1 0x98 0x48 0xBE
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0xA2 0x96 0x4B 0x65 0x85 0x5C 0x00 0xBE
    IN	0x01	0x13		0xA1 0x80 0x6D 0x2F 0x28 0x71 0xC9 0x9B 0xA3 0x98 0xED 0xB2 0xD7
    IN	0x01	0x13		0x2B 0x7C 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0xC5
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x01 0x1C 0x33 0x40 0xB3 0xC3
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x1C 0x6E 0xEA 0xF2 0xBE
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0x70 0xA1 0xD0 0x2B 0x7E 0x71 0x00 0xBE
    IN	0x01	0x13		0x2B 0x7C 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0xC7
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x18 0x02 0x01 0x00 0x00 0x18 0x0D 0xA1 0x82 0x91 0x14 0x0C 0x02 0x01 0x06
    IN	0x01	0x13		0x08 0x09 0x4C 0x69 0x6E 0x6B 0x73 0x79 0x73 0xB1
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x24 0x02 0x01 0x04 0x00 0x18 0x0D 0xA1 0x82 0x91 0x14 0x18 0x05 0xFF 0x5C
    IN	0x01	0x13		0x00 0x01 0x01 0x11 0x07 0xD1 0x6F 0x01 0x40 0x94 0x0E 0x88 0xB7 0xC2 0x46 0xAB
    IN	0x01	0x13		0x8E 0x80 0x20 0x00 0x00 0xB1
    IN	0x01	0x13		0xA1 0x80 0x6D 0x2F 0x28 0x71 0xC9 0x9B 0xA3 0x98 0xED 0xB2 0xD4
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x18 0xA1 0x98 0x48 0xBB
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0xA2 0x96 0x4B 0x65 0x85 0x5C 0x00 0xBB
    IN	0x01	0x13		0x2B 0x7C 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0xC8
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x18 0x02 0x01 0x00 0x00 0xBA 0x0D 0xA1 0x82 0x91 0x14 0x0C 0x02 0x01 0x06
    IN	0x01	0x13		0x08 0x09 0x4C 0x69 0x6E 0x6B 0x73 0x79 0x73 0xC0
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x24 0x02 0x01 0x04 0x00 0xBA 0x0D 0xA1 0x82 0x91 0x14 0x18 0x05 0xFF 0x5C
    IN	0x01	0x13		0x8E 0x80 0x20 0x00 0x00 0xBF
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x1A 0x02 0x01 0x00 0x01 0xFE 0x7D 0x4E 0xE8 0xCA 0x6B 0x0E 0x02 0x01 0x1A
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x01 0x1C 0xF0 0x32 0x9E 0xAE
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0xFE 0x7D 0x4E 0xE8 0xCA 0x6B 0x00 0xAC
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x1A 0x02 0x01 0x00 0x01 0x8F 0x2F 0x00 0x03 0xE1 0x62 0x0E 0x02 0x01 0x1A
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x18 0xEA 0x4C 0xD3 0xB9
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0x8F 0x2F 0x00 0x03 0xE1 0x62 0x00 0xB8
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x1C 0x6E 0xEA 0xF2 0xC3
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0x70 0xA1 0xD0 0x2B 0x7E 0x71 0x00 0xC3
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x18 0xEA 0x4C 0xD3 0xB7
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0x8F 0x2F 0x00 0x03 0xE1 0x62 0x00 0xB7
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x01 0x1C 0x33 0x40 0xB3 0xC0
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0xA4 0x66 0x77 0xC3 0x69 0x7B 0x00 0xC0
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x1C 0x6E 0xEA 0xF2 0xC0
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0x70 0xA1 0xD0 0x2B 0x7E 0x71 0x00 0xC0
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x18 0xA1 0x98 0x48 0xBA
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0xA2 0x96 0x4B 0x65 0x85 0x5C 0x00 0xBA
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x18 0xEA 0x4C 0xD3 0xB8
    IN	0x01	0x13	EV_Extended_Inquiry_Result	0x2F 0xFF 0x01 0xCB 0x5D 0x3A 0xBD 0x3D 0x20 0x01 0x02 0x28 0x04 0x24 0xB9 0x71
    IN	0x01	0x13		0xB8 0x02 0x0A 0x04 0x05 0x03 0x0B 0x11 0x0C 0x11 0x0F 0x09 0x4C 0x47 0x20 0x53
    IN	0x01	0x13		0x4B 0x39 0x59 0x28 0x35 0x44 0x3A 0x43 0x42 0x29 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x01	0x13		0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x01	0x13		0x00
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x01 0x1C 0xF0 0x32 0x9E 0xAC
    IN	0x01	0x13		0x2B 0x7C 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0xC4
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x18 0xEA 0x4C 0xD3 0xB2
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0x8F 0x2F 0x00 0x03 0xE1 0x62 0x00 0xB2
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x01 0x1C 0x33 0x40 0xB3 0xBC
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0xA4 0x66 0x77 0xC3 0x69 0x7B 0x00 0xBB
    IN	0x01	0x13		0xA0 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x01	0x13		0x00
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x1C 0x6E 0xEA 0xF2 0xC2
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0x70 0xA1 0xD0 0x2B 0x7E 0x71 0x00 0xC2
    IN	0x01	0x13		0xA1 0x80 0x6D 0x2F 0x28 0x71 0xC9 0x9B 0xA3 0x98 0xED 0xB2 0xD5
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x18 0xA1 0x98 0x48 0xBC
    IN	0x01	0x13	HCI_LE_Connection_Complete	0x3E 0x0C 0x02 0x01 0x04 0x01 0xA2 0x96 0x4B 0x65 0x85 0x5C 0x00 0xBC
    IN	0x01	0x13		0x0A 0xFF 0x4C 0x00 0x10 0x05 0x03 0x18 0xEA 0x4C 0xD3 0xB5
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x03 0x00
    OUT	0x00	0x05		0x02 0x04 0x00
    IN	0x01	0x13		0x0E 0x04 0x01 0x02 0x04 0x00
    OUT	0x00	0x05		0x0C 0x20 0x02 0x00 0x00
    OUT	0x00	0x05		0x0B 0x20 0x07 0x00 0xBD 0x00 0x1D 0x00 0x00 0x01
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x10 0x00
    OUT	0x00	0x05	HCI_CREATE_CONNECTION	0x05 0x04 0x0D 0xDC 0x13 0xD6 0x1B 0xAA 0x9C 0x18 0xCC 0x01 0x00 0xDE 0x00 0x01
    IN	0x01	0x13		0x0F 0x04 0x00 0x01 0x05 0x04
    IN	0x01	0x13	EV_CONNECT_COMPLETE	0x03 0x0B 0x00 0x47 0x00 0xDC 0x13 0xD6 0x1B 0xAA 0x9C 0x01 0x00
    OUT	0x00	0x05	HCI_OP_READ_REMOTE_FEATURES	0x1B 0x04 0x02 0x47 0x00
    IN	0x01	0x13		0x0F 0x04 0x00 0x00 0x1B 0x04
    IN	0x02	0x00		0x47 0x20 0x0C 0x00 0x08 0x00 0x01 0x00 0x02 0x01 0x04 0x00 0x01 0x00 0x40 0x00
    IN	0x01	0x13		0x1B 0x03 0x47 0x00 0x05
    IN	0x01	0x13		0x0F 0x04 0x00 0x01 0x00 0x00
    IN	0x01	0x13		0x0B 0x0B 0x00 0x47 0x00 0xBF 0x3E 0x8D 0xFE 0xDB 0xFD 0x7B 0x87
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x06 0x00
    OUT	0x00	0x05		0x1C 0x04 0x03 0x47 0x00 0x01
    IN	0x01	0x13		0x0F 0x04 0x00 0x01 0x1C 0x04
    IN	0x01	0x13		0x23 0x0D 0x00 0x47 0x00 0x01 0x03 0x01 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    OUT	0x00	0x05	HCI_OP_READ_REMOTE_VERSION_INFORMATION	0x1D 0x04 0x02 0x47 0x00
    IN	0x01	0x13		0x0F 0x04 0x00 0x01 0x1D 0x04
    IN	0x01	0x13		0x0C 0x08 0x00 0x47 0x00 0x08 0x46 0x00 0x00 0x00
    OUT	0x00	0x05		0x05 0x14 0x02 0x47 0x00
    IN	0x01	0x13		0x0E 0x07 0x01 0x05 0x14 0x00 0x47 0x00 0x00
    OUT	0x02	0x00		0x47 0x00 0x0C 0x00 0x08 0x00 0x01 0x00 0x02 0x01 0x04 0x00 0x01 0x00 0x40 0x00
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x07 0x00
    OUT	0x02	0x00		0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x01 0x08 0x00 0x41 0x00 0x40 0x00 0x01 0x00 0x00 0x00
    OUT	0x02	0x00		0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x01 0x08 0x00 0x41 0x00 0x40 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00		0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x02 0x08 0x00 0x40 0x00 0x00 0x00 0x01 0x02 0x00 0x04
    OUT	0x00	0x05		0x0D 0x08 0x04 0x47 0x00 0x0F 0x00
    IN	0x01	0x13		0x13 0x05 0x01 0x47 0x00 0x01 0x00
    IN	0x01	0x13		0x0E 0x06 0x01 0x0D 0x08 0x00 0x47 0x00
    IN	0x02	0x00		0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x01 0x08 0x00 0x41 0x00 0x40 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00		0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x03 0x08 0x00 0x41 0x00 0x00 0x00 0x01 0x02 0x00 0x04
    OUT	0x00	0x05		0x09 0x08 0x02 0x47 0x00
    IN	0x02	0x00		0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x02 0x08 0x00 0x40 0x00 0x00 0x00 0x01 0x02 0xC8 0x05
    OUT	0x02	0x00		0x47 0x00 0x12 0x00 0x0E 0x00 0x01 0x00 0x05 0x02 0x0A 0x00 0x41 0x00 0x00 0x00 0x00 0x00 0x01 0x02 0x00 0x04
    IN	0x02	0x00		0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x03 0x08 0x00 0x41 0x00 0x00 0x00 0x01 0x02 0xC8 0x05
    OUT	0x02	0x00		0x47 0x00 0x12 0x00 0x0E 0x00 0x01 0x00 0x05 0x03 0x0A 0x00 0x40 0x00 0x00 0x00 0x00 0x00 0x01 0x02 0x00 0x04
    IN	0x02	0x00		0x47 0x20 0x0E 0x00 0x0A 0x00 0x01 0x00 0x05 0x02 0x06 0x00 0x41 0x00 0x00 0x00 0x00 0x00
    IN	0x01	0x13		0x0E 0x07 0x01 0x09 0x08 0x00 0x47 0x00 0x00
    OUT	0x00	0x05		0x28 0x0C 0x04 0x47 0x00 0x00 0x00
    IN	0x01	0x13		0x0E 0x06 0x01 0x28 0x0C 0x00 0x47 0x00
    OUT	0x00	0x05		0x1F 0x04 0x02 0x47 0x00
    IN	0x01	0x13		0x0F 0x04 0x00 0x01 0x1F 0x04
    OUT	0x00	0x05		0x2D 0x0C 0x03 0x47 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x0E 0x00 0x0A 0x00 0x01 0x00 0x05 0x03 0x06 0x00 0x40 0x00 0x00 0x00 0x00 0x00
    IN	0x01	0x13		0x1C 0x05 0x00 0x47 0x00 0x21 0x17
    IN	0x01	0x13		0x0E 0x07 0x01 0x2D 0x0C 0x00 0x47 0x00 0x04
    OUT	0x00	0x05		0x03 0x14 0x02 0x47 0x00
    IN	0x01	0x13		0x0E 0x07 0x01 0x03 0x14 0x00 0x47 0x00 0xFF
    OUT	0x00	0x05		0x36 0x0C 0x02 0x47 0x00
    IN	0x01	0x13		0x0E 0x08 0x01 0x36 0x0C 0x00 0x47 0x00 0x00 0x7D
    OUT	0x00	0x05		0x2D 0x0C 0x03 0x47 0x00 0x01
    IN	0x01	0x13		0x0E 0x07 0x01 0x2D 0x0C 0x00 0x47 0x00 0x08
    OUT	0x00	0x05	HCI_AUTH_REQUESTED	0x11 0x04 0x02 0x47 0x00
    IN	0x02	0x00		0x47 0x20 0x16 0x00 0x12 0x00 0x41 0x00 0x06 0x00 0x00 0x00 0x0D 0x35 0x03 0x19 0x12 0x00 0x00 0x64 0x35 0x03 0x09 0x00 0x01 0x00
    OUT	0x02	0x00		0x47 0x00 0x18 0x00 0x14 0x00 0x40 0x00 0x07 0x00 0x00 0x00 0x0F 0x00 0x0C 0x35 0x0A 0x35 0x08 0x09 0x00 0x01 0x35 0x03 0x19 0x12 0x00 0x00
    IN	0x01	0x13		0x0F 0x04 0x00 0x01 0x11 0x04
    IN	0x01	0x13	EV_LINK_KEY_REQUEST	0x17 0x06 0xDC 0x13 0xD6 0x1B 0xAA 0x9C
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x09 0x00
    OUT	0x00	0x05	HCI_LINK_KEY_NEG_REPLY	0x0C 0x04 0x06 0xDC 0x13 0xD6 0x1B 0xAA 0x9C
    IN	0x02	0x00		0x47 0x20 0x11 0x00 0x0D 0x00 0x41 0x00 0x02 0x00 0x01 0x00 0x08 0x35 0x03 0x19 0x12 0x00 0x00 0x01 0x00
    OUT	0x02	0x00		0x47 0x00 0x12 0x00 0x0E 0x00 0x40 0x00 0x03 0x00 0x01 0x00 0x09 0x00 0x01 0x00 0x01 0x00 0x01 0x00 0x00 0x00
    IN	0x01	0x13		0x0E 0x0A 0x01 0x0C 0x04 0x00 0xDC 0x13 0xD6 0x1B 0xAA 0x9C
    IN	0x02	0x00		0x47 0x20 0x17 0x00 0x13 0x00 0x41 0x00 0x04 0x00 0x02 0x00 0x0E 0x00 0x01 0x00 0x00 0x00 0x64 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x00
    OUT	0x02	0x00		0x47 0x00 0x78 0x00 0x74 0x00 0x40 0x00 0x05 0x00 0x02 0x00 0x6F 0x00 0x64 0x35 0x95 0x09 0x00 0x00 0x0A 0x00 0x01 0x00 0x00 0x09 0x00 0x01 0x35 0x03 0x19 0x12 0x00 0x09 0x00 0x04 0x35 0x0D 0x35 0x06 0x19 0x01 0x00 0x09 0x00 0x01 0x35 0x03 0x19 0x00 0x01 0x09 0x00 0x05 0x35 0x03 0x19 0x10 0x02 0x09 0x00 0x06 0x35 0x09
    OUT	0x02	0x00		0x09 0x65 0x6E 0x09 0x00 0x6A 0x09 0x01 0x00 0x09 0x01 0x00 0x25 0x18 0x44 0x65 0x76 0x69 0x63 0x65 0x20 0x49 0x44 0x20 0x53 0x65 0x72 0x76 0x69 0x63 0x65 0x20 0x52 0x65 0x63 0x6F 0x72 0x64 0x09 0x01 0x01 0x25 0x18 0x44 0x65 0x76 0x69 0x63 0x65 0x20 0x49 0x08 0x60 0xEB 0x65 0x62 0x81 0xD4 0xFF 0xFF
    IN	0x01	0x13		0x31 0x06 0xDC 0x13 0xD6 0x1B 0xAA 0x9C
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x0C 0x00
    OUT	0x00	0x05		0x2B 0x04 0x09 0xDC 0x13 0xD6 0x1B 0xAA 0x9C 0x01 0x00 0x05
    IN	0x02	0x00		0x47 0x20 0x1F 0x00 0x1B 0x00 0x41 0x00 0x04 0x00 0x03 0x00 0x16 0x00 0x01 0x00 0x00 0x00 0x64 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x08 0x60 0xEB 0x65 0x62 0x81 0xD4 0xFF 0xFF
    OUT	0x02	0x00		0x47 0x00 0x3F 0x00 0x3B 0x00 0x40 0x00 0x05 0x00 0x03 0x00 0x36 0x00 0x33 0x44 0x20 0x53 0x65 0x72 0x76 0x69 0x63 0x65 0x20 0x52 0x65 0x63 0x6F 0x72 0x64 0x09 0x02 0x00 0x09 0x01 0x03 0x09 0x02 0x01 0x09 0x00 0x06 0x09 0x02 0x02 0x09 0x00 0x01 0x09 0x02 0x03 0x09 0x0A 0x00 0x09 0x02 0x04 0x28 0x01 0x09 0x02 0x05 0x09
    OUT	0x02	0x00		0x00 0x01 0x00
    IN	0x01	0x13		0x0E 0x0A 0x01 0x2B 0x04 0x00 0xDC 0x13 0xD6 0x1B 0xAA 0x9C
    IN	0x01	0x13		0x32 0x09 0xDC 0x13 0xD6 0x1B 0xAA 0x9C 0x03 0x00 0x04
    IN	0x02	0x00		0x47 0x20 0x0C 0x00 0x08 0x00 0x01 0x00 0x06 0x04 0x04 0x00 0x41 0x00 0x40 0x00
    OUT	0x02	0x00		0x47 0x00 0x0C 0x00 0x08 0x00 0x01 0x00 0x07 0x04 0x04 0x00 0x41 0x00 0x40 0x00
    IN	0x01	0x13		0x33 0x0A 0xDC 0x13 0xD6 0x1B 0xAA 0x9C 0x67 0x2F 0x0D 0x00
    OUT	0x00	0x05		0x2C 0x04 0x06 0xDC 0x13 0xD6 0x1B 0xAA 0x9C
    IN	0x01	0x13		0x0E 0x0A 0x01 0x2C 0x04 0x00 0xDC 0x13 0xD6 0x1B 0xAA 0x9C
    IN	0x01	0x13		0x36 0x07 0x00 0xDC 0x13 0xD6 0x1B 0xAA 0x9C
    IN	0x01	0x13	EV_LINK_KEY_NOTIFICATION	0x18 0x17 0xDC 0x13 0xD6 0x1B 0xAA 0x9C 0xB1 0x98 0x8F 0xB2 0xFF 0xA5 0x29 0x75
    IN	0x01	0x13		0x56 0x64 0x4E 0x72 0x66 0xF9 0x79 0x66 0x04
    IN	0x01	0x13	EV_AUTHENTICATION_COMPLETE	0x06 0x03 0x00 0x47 0x00
    OUT	0x00	0x05		0x13 0x04 0x03 0x47 0x00 0x01
    IN	0x01	0x13		0x0F 0x04 0x00 0x01 0x13 0x04
    OUT	0x02	0x00		0x47 0x00 0x18 0x00 0x14 0x00 0x41 0x00 0x06 0x00 0x00 0x00 0x0F 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x00
    IN	0x01	0x13		0x08 0x04 0x00 0x47 0x00 0x01
    IN	0x02	0x00		0x47 0x20 0x84 0x00 0x80 0x00 0x40 0x00 0x07 0x00 0x00 0x00 0x7B 0x00 0x77 0x36 0x02 0xBE 0x35 0x82 0x09 0x00 0x00 0x0A 0x00 0x01 0x00 0x00 0x09 0x00 0x01 0x35 0x03 0x19 0x12 0x00 0x09 0x00 0x02 0x0A 0x00 0x00 0x03 0x04 0x09 0x00 0x04 0x35 0x0D 0x35 0x06 0x19 0x01 0x00 0x09 0x00 0x01 0x35 0x03 0x19 0x00 0x01 0x09 0x00
    IN	0x02	0x00		0x05 0x35 0x03 0x19 0x10 0x02 0x09 0x00 0x06 0x35 0x09 0x09 0x65 0x6E 0x09 0x00 0x6A 0x09 0x01 0x00 0x09 0x00 0x09 0x35 0x08 0x35 0x06 0x19 0x12 0x00 0x09 0x01 0x00 0x09 0x01 0x00 0x25 0x01 0x00 0x09 0x01 0x01 0x25 0x01 0x00 0x09 0x01 0x02 0x25 0x01 0x00 0x09 0x02 0x00 0x09 0x01 0x03 0x09 0x02 0x01 0x09 0x04 0x5E 0x09
    IN	0x02	0x00	EV_INQUIRY_RESULT	0x02 0x02 0x09 0x02 0xE0 0x09 0x01 0x01
    OUT	0x02	0x00		0x47 0x00 0x19 0x00 0x15 0x00 0x41 0x00 0x06 0x00 0x01 0x00 0x10 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x01 0x01
    IN	0x02	0x00		0x47 0x20 0x84 0x00 0x80 0x00 0x40 0x00 0x07 0x00 0x01 0x00 0x7B 0x00 0x77 0x02 0x03 0x09 0x09 0x03 0x09 0x02 0x04 0x28 0x01 0x09 0x02 0x05 0x09 0x00 0x02 0x36 0x02 0x37 0x09 0x00 0x00 0x0A 0x00 0x01 0x00 0x01 0x09 0x00 0x01 0x35 0x03 0x19 0x11 0x24 0x09 0x00 0x02 0x0A 0x00 0x00 0x03 0x12 0x09 0x00 0x04 0x35 0x0D 0x35
    IN	0x02	0x00	EV_AUTHENTICATION_COMPLETE	0x06 0x19 0x01 0x00 0x09 0x00 0x11 0x35 0x03 0x19 0x00 0x11 0x09 0x00 0x05 0x35 0x03 0x19 0x10 0x02 0x09 0x00 0x06 0x35 0x09 0x09 0x65 0x6E 0x09 0x00 0x6A 0x09 0x01 0x00 0x09 0x00 0x09 0x35 0x08 0x35 0x06 0x19 0x11 0x24 0x09 0x01 0x00 0x09 0x00 0x0D 0x35 0x0F 0x35 0x0D 0x35 0x06 0x19 0x01 0x00 0x09 0x00 0x13 0x35 0x03
    IN	0x02	0x00		0x19 0x00 0x11 0x09 0x01 0x00 0x01 0x02
    OUT	0x02	0x00		0x47 0x00 0x19 0x00 0x15 0x00 0x41 0x00 0x06 0x00 0x02 0x00 0x10 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x01 0x02
    IN	0x02	0x00		0x47 0x20 0x84 0x00 0x80 0x00 0x40 0x00 0x07 0x00 0x02 0x00 0x7B 0x00 0x77 0x25 0x17 0x58 0x62 0x6F 0x78 0x20 0x42 0x6C 0x75 0x65 0x74 0x6F 0x6F 0x74 0x68 0x20 0x47 0x61 0x6D 0x65 0x70 0x61 0x64 0x00 0x09 0x01 0x01 0x25 0x08 0x47 0x61 0x6D 0x65 0x70 0x61 0x64 0x00 0x09 0x01 0x02 0x25 0x16 0x4D 0x69 0x63 0x72 0x6F 0x73
    IN	0x02	0x00		0x6F 0x66 0x74 0x20 0x43 0x6F 0x72 0x70 0x6F 0x72 0x61 0x74 0x69 0x6F 0x6E 0x00 0x09 0x02 0x00 0x09 0x01 0x00 0x09 0x02 0x01 0x09 0x01 0x11 0x09 0x02 0x02 0x08 0x40 0x09 0x02 0x03 0x08 0x21 0x09 0x02 0x04 0x28 0x01 0x09 0x02 0x05 0x28 0x01 0x09 0x02 0x06 0x36 0x01 0x3A 0x36 0x01 0x37 0x08 0x22 0x26 0x01 0x32 0x05 0x01
    IN	0x02	0x00		0x09 0x05 0xA1 0x01 0x85 0x01 0x01 0x03
    OUT	0x02	0x00		0x47 0x00 0x19 0x00 0x15 0x00 0x41 0x00 0x06 0x00 0x03 0x00 0x10 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x01 0x03
    IN	0x02	0x00		0x47 0x20 0x84 0x00 0x80 0x00 0x40 0x00 0x07 0x00 0x03 0x00 0x7B 0x00 0x77 0x09 0x01 0xA1 0x00 0x09 0x30 0x09 0x31 0x15 0x00 0x27 0xFF 0xFF 0x00 0x00 0x95 0x02 0x75 0x10 0x81 0x02 0xC0 0x09 0x01 0xA1 0x00 0x09 0x33 0x09 0x34 0x15 0x00 0x27 0xFF 0xFF 0x00 0x00 0x95 0x02 0x75 0x10 0x81 0x02 0xC0 0x05 0x01 0x09 0x32 0x15
    IN	0x02	0x00		0x00 0x26 0xFF 0x03 0x95 0x01 0x75 0x0A 0x81 0x02 0x15 0x00 0x25 0x00 0x75 0x06 0x95 0x01 0x81 0x03 0x05 0x01 0x09 0x35 0x15 0x00 0x26 0xFF 0x03 0x95 0x01 0x75 0x0A 0x81 0x02 0x15 0x00 0x25 0x00 0x75 0x06 0x95 0x01 0x81 0x03 0x05 0x01 0x09 0x39 0x15 0x01 0x25 0x08 0x35 0x00 0x46 0x3B 0x01 0x66 0x14 0x00 0x75 0x04 0x95
    IN	0x02	0x00		0x01 0x81 0x42 0x75 0x04 0x95 0x01 0x04
    OUT	0x02	0x00		0x47 0x00 0x19 0x00 0x15 0x00 0x41 0x00 0x06 0x00 0x04 0x00 0x10 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x01 0x04
    IN	0x02	0x00		0x47 0x20 0x84 0x00 0x80 0x00 0x40 0x00 0x07 0x00 0x04 0x00 0x7B 0x00 0x77 0x01 0x15 0x00 0x25 0x00 0x35 0x00 0x45 0x00 0x65 0x00 0x81 0x03 0x05 0x09 0x19 0x01 0x29 0x0A 0x15 0x00 0x25 0x01 0x75 0x01 0x95 0x0A 0x81 0x02 0x15 0x00 0x25 0x00 0x75 0x06 0x95 0x01 0x81 0x03 0x05 0x01 0x09 0x80 0x85 0x02 0xA1 0x00 0x09 0x85
    IN	0x02	0x00		0x15 0x00 0x25 0x01 0x95 0x01 0x75 0x01 0x81 0x02 0x15 0x00 0x25 0x00 0x75 0x07 0x95 0x01 0x81 0x03 0xC0 0x05 0x0F 0x09 0x21 0x85 0x03 0xA1 0x02 0x09 0x97 0x15 0x00 0x25 0x01 0x75 0x04 0x95 0x01 0x91 0x02 0x15 0x00 0x25 0x00 0x75 0x04 0x95 0x01 0x91 0x03 0x09 0x70 0x15 0x00 0x25 0x64 0x75 0x08 0x95 0x04 0x91 0x02 0x09
    IN	0x02	0x00		0x50 0x66 0x01 0x10 0x55 0x0E 0x01 0x05
    OUT	0x02	0x00		0x47 0x00 0x19 0x00 0x15 0x00 0x41 0x00 0x06 0x00 0x05 0x00 0x10 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x01 0x05
    IN	0x02	0x00		0x47 0x20 0x7A 0x00 0x76 0x00 0x40 0x00 0x07 0x00 0x05 0x00 0x71 0x00 0x6E 0x15 0x00 0x26 0xFF 0x00 0x75 0x08 0x95 0x01 0x91 0x02 0x09 0xA7 0x15 0x00 0x26 0xFF 0x00 0x75 0x08 0x95 0x01 0x91 0x02 0x65 0x00 0x55 0x00 0x09 0x7C 0x15 0x00 0x26 0xFF 0x00 0x75 0x08 0x95 0x01 0x91 0x02 0xC0 0x85 0x04 0x05 0x06 0x09 0x20 0x15
    IN	0x02	0x00		0x00 0x26 0xFF 0x00 0x75 0x08 0x95 0x01 0x81 0x02 0xC0 0x09 0x02 0x07 0x35 0x08 0x35 0x06 0x09 0x04 0x09 0x09 0x01 0x00 0x09 0x02 0x08 0x28 0x00 0x09 0x02 0x09 0x28 0x01 0x09 0x02 0x0A 0x28 0x00 0x09 0x02 0x0B 0x09 0x01 0x00 0x09 0x02 0x0C 0x09 0x0C 0x80 0x09 0x02 0x0D 0x28 0x01 0x09 0x02 0x0E 0x28 0x00 0x00
    OUT	0x02	0x00		0x47 0x00 0x0C 0x00 0x08 0x00 0x01 0x00 0x06 0x04 0x04 0x00 0x41 0x00 0x40 0x00
    IN	0x02	0x00		0x47 0x20 0x0C 0x00 0x08 0x00 0x01 0x00 0x07 0x04 0x04 0x00 0x41 0x00 0x40 0x00
    OUT	0x02	0x00		0x47 0x00 0x0C 0x00 0x08 0x00 0x01 0x00 0x02 0x05 0x04 0x00 0x11 0x00 0x42 0x00
    IN	0x02	0x00		0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x05 0x08 0x00 0x40 0x00 0x42 0x00 0x01 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x05 0x08 0x00 0x40 0x00 0x42 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00		0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x06 0x08 0x00 0x40 0x00 0x00 0x00 0x01 0x02 0xA0 0x02
    IN	0x02	0x00		0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x05 0x08 0x00 0x42 0x00 0x00 0x00 0x01 0x02 0xC8 0x05
    OUT	0x02	0x00		0x47 0x00 0x12 0x00 0x0E 0x00 0x01 0x00 0x05 0x05 0x0A 0x00 0x40 0x00 0x00 0x00 0x00 0x00 0x01 0x02 0xA0 0x02
    IN	0x02	0x00		0x47 0x20 0x0E 0x00 0x0A 0x00 0x01 0x00 0x05 0x06 0x06 0x00 0x42 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00		0x47 0x00 0x0C 0x00 0x08 0x00 0x01 0x00 0x02 0x07 0x04 0x00 0x13 0x00 0x43 0x00
    OUT	0x00	0x05		0x37 0x0C 0x04 0x47 0x00 0x80 0x0C
    IN	0x01	0x13		0x0E 0x06 0x01 0x37 0x0C 0x00 0x47 0x00
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x17 0x00
    OUT	0x00	0x05		0x07 0x08 0x14 0x47 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x10 0x27 0x00 0x00 0xFF 0xFF 0xFF 0xFF
    IN	0x02	0x00		0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x07 0x08 0x00 0x41 0x00 0x43 0x00 0x01 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x07 0x08 0x00 0x41 0x00 0x43 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00		0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x08 0x08 0x00 0x41 0x00 0x00 0x00 0x01 0x02 0xA0 0x02
    IN	0x02	0x00		0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x06 0x08 0x00 0x43 0x00 0x00 0x00 0x01 0x02 0xC8 0x05
    OUT	0x02	0x00		0x47 0x00 0x12 0x00 0x0E 0x00 0x01 0x00 0x05 0x06 0x0A 0x00 0x41 0x00 0x00 0x00 0x00 0x00 0x01 0x02 0xA0 0x02
    IN	0x01	0x13		0x0F 0x04 0x00 0x01 0x07 0x08
    IN	0x02	0x00		0x47 0x20 0x0E 0x00 0x0A 0x00 0x01 0x00 0x05 0x08 0x06 0x00 0x43 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00		0x47 0x00 0x06 0x00 0x02 0x00 0x40 0x00 0x90 0x00
    IN	0x01	0x13		0x0D 0x15 0x00 0x47 0x00 0x00 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x10
    IN	0x01	0x13		0x27 0x00 0x00 0xFF 0xFF 0xFF 0xFF
    IN	0x01	0x13		0x1B 0x03 0x47 0x00 0x01
    IN	0x02	0x00		0x47 0x20 0x05 0x00 0x01 0x00 0x42 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0x9A 0x85 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x01	0x13		0x14 0x06 0x00 0x47 0x00 0x02 0x0C 0x00
    IN	0x02	0x00		0x47 0x20 0x07 0x00 0x03 0x00 0x43 0x00 0xA1 0x04 0x87
    SETUP	0x00	0x05		0x00 0x03 0x01 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00		0x47 0x00 0x0E 0x00 0x0A 0x00 0x41 0x00 0xA2 0x03 0x0F 0x00 0x00 0x00 0x00 0xFF 0x00 0xEB
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0x07 0x85 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0x93 0x84 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0x06 0x84 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0x82 0x83 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0xB6 0x82 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0x9A 0x81 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0x67 0x80 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0x1B 0x7F 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0x13 0x7D 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x13 0x88 0x90 0x7A 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x69 0x87 0xA8 0x73 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x99 0x86 0x87 0x70 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xCE 0x85 0x9E 0x6D 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x08 0x85 0x1F 0x6B 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x69 0x84 0x20 0x69 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xEB 0x83 0x93 0x67 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x8A 0x83 0x81 0x66 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x37 0x83 0xE8 0x65 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xF5 0x82 0xE8 0x65 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xF5 0x82 0xE2 0x66 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x52 0x83 0xFB 0x6A 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xF0 0x83 0x30 0x6F 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x74 0x84 0xEF 0x72 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xEB 0x84 0x07 0x76 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x4F 0x85 0x86 0x78 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x4F 0x85 0x8C 0x7A 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD5 0x85 0x2A 0x7C 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD5 0x85 0x7B 0x7D 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD5 0x85 0x90 0x7E 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x43 0x86 0x7E 0x7F 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x43 0x86 0x5C 0x80 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xB1 0x85 0x63 0x81 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x09 0x85 0x7F 0x82 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xDF 0x83 0x1E 0x84 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD5 0x81 0x59 0x86 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xF3 0x7E 0x16 0x89 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x66 0x7B 0x54 0x8C 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xA2 0x77 0x17 0x90 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xDE 0x73 0xF4 0x93 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x49 0x70 0x6F 0x98 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x4E 0x6D 0x1C 0x9D 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xAF 0x6A 0xFF 0xA1 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xE2 0x67 0xC3 0xA6 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x1E 0x65 0x3D 0xAB 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x9B 0x62 0x41 0xAF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x74 0x60 0x1B 0xB3 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x91 0x5E 0x2A 0xB7 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xCC 0x5C 0x9B 0xBB 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x18 0x5B 0x1C 0xC0 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xF5 0x58 0x93 0xC4 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x5F 0x56 0xAB 0xC9 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xBE 0x53 0x32 0xCE 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xCF 0x50 0xCE 0xE7 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x0F 0x4E 0x31 0xE9 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x88 0x4B 0xF7 0xEA 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x47 0x49 0xB2 0xED 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x73 0x47 0xB7 0xF0 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFB 0x45 0x28 0xF3 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xCF 0x44 0x1C 0xF5 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xDA 0x43 0xAC 0xF6 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x21 0x43 0xF2 0xF7 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x88 0x42 0xF7 0xF8 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x08 0x42 0xC7 0xF9 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xA0 0x41 0x6D 0xFA 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x4D 0x41 0xF3 0xFA 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x4D 0x41 0x5D 0xFB 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xDA 0x40 0xB3 0xFB 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xDA 0x40 0xF8 0xFB 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x8D 0x40 0xA4 0xFC 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x4E 0x40 0xA4 0xFC 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x4E 0x40 0xEE 0xFC 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0x42 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x8C 0x46 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x7E 0x4B 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0x65 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xBA 0x66 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x08 0x69 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x44 0x6C 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x8D 0x70 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x40 0x75 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x26 0x8F 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xB4 0x90 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x7B 0x93 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x96 0x97 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x08 0x9C 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD6 0xA0 0xFF 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xAA 0xBC 0x48 0xFF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x9B 0xBD 0xE7 0xFE 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xC6 0xBF 0x38 0xFE 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x64 0xC3 0x37 0xFC 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xA9 0xC7 0xCD 0xF9 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x40 0xCC 0x95 0xF6 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x6A 0xEA 0x5D 0xF3 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x3E 0xEB 0x63 0xEF 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xA8 0xEC 0xAE 0xEB 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x5A 0xEE 0x3D 0xE7 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xA1 0xF0 0xB6 0xE2 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x49 0xF5 0xA3 0xD9 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x03 0xD5 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xB1 0xD0 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xD5 0xCC 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x70 0xC9 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x25 0xC6 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xE5 0xC0 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x36 0xBE 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xB5 0xBB 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x6C 0xB9 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x6D 0xB7 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xB6 0xB5 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xEF 0xB3 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x16 0xB2 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x7C 0xB0 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xEB 0xAE 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x37 0xAD 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x7E 0xAB 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xA3 0xA9 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xBF 0xA7 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x42 0xA5 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xB8 0xA2 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0x7E 0x9F 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0xFF 0xAC 0x9A 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xE9 0xF4 0xF3 0x7B 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xCB 0xF1 0xCD 0x79 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x9B 0xD6 0xA2 0x75 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xBF 0xD3 0xB9 0x70 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x35 0xD0 0xBF 0x6B 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x56 0xCD 0x93 0x67 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x09 0xCB 0x37 0x64 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x2C 0xC9 0x6E 0x61 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x44 0xC6 0xFD 0x5E 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x26 0xC2 0x02 0x5C 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x44 0xA8 0x88 0x58 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x0C 0xA6 0xCC 0x54 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x40 0xA1 0x24 0x50 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x88 0x82 0x59 0x36 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xE8 0x7F 0xAA 0x35 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x08 0x5B 0xA4 0x30 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x8E 0x58 0x3B 0x2C 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xB0 0x53 0x45 0x27 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xB5 0x34 0xD9 0x0A 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x4B 0x34 0x1C 0x0B 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD7 0x31 0x61 0x0D 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFC 0x2F 0xCF 0x0E 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFA 0x2D 0xE1 0x10 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xAA 0x2B 0x2F 0x13 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x03 0x29 0xC2 0x15 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x65 0x26 0x0F 0x19 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x44 0x21 0x60 0x20 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xFF 0x1E 0x21 0x24 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD4 0x1C 0x82 0x27 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x44 0x1A 0x01 0x2B 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xBE 0x17 0xA1 0x2E 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x90 0x15 0xF8 0x31 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x89 0x13 0x1C 0x35 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD7 0x11 0x82 0x38 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x63 0x10 0x88 0x3B 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x10 0x0F 0x37 0x3E 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xEA 0x0D 0xC5 0x40 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xE5 0x0C 0x0C 0x43 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x0E 0x0C 0xFE 0x44 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x68 0x0B 0xAB 0x46 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD9 0x0A 0x13 0x48 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x66 0x0A 0x35 0x49 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x09 0x0A 0x29 0x4A 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xC0 0x09 0xEC 0x4A 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xC0 0x09 0x80 0x4B 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x50 0x09 0xE6 0x4B 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x50 0x09 0x30 0x4C 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xF7 0x0A 0xA2 0x4C 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xE2 0x0D 0x48 0x4D 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x0A 0x12 0xA9 0x4E 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x65 0x2D 0x30 0x50 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xA4 0x4A 0x2C 0x54 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD3 0x81 0xCA 0x81 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xB7 0x82 0x2D 0x82 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x98 0x83 0x88 0x82 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x45 0x84 0xD1 0x82 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xD1 0x84 0xD1 0x82 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x46 0x85 0x38 0x83 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xEC 0x85 0x38 0x83 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xEC 0x85 0x8E 0x83 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0x54 0x86 0x8E 0x83 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00		0x47 0x20 0x15 0x00 0x11 0x00 0x43 0x00 0xA1 0x01 0xC7 0x86 0xD0 0x83 0x32 0x85 0x3D 0x86 0x00 0x00 0x00 0x00 0x00 0x00 0x00
    Still lots to dig through but starting to get to a point where I can start to find some of the trees in the forest
  19. #94
    New York
    5,466
    @KurtE that's a lot of stuff to go through but looks like you are beginning to get a better handle on whats going on. Did a little more poking around and found this article that talks about xbox controller bt on a rpi: https://pimylifeup.com/xbox-controllers-raspberry-pi/. If you can get a hold of the joystick api maybe that will help
  20. #95
    New York
    5,466
    Just as a test I ran 3 tests. The first using a hub and connecting the 2 Logitech joysticks that I have and second using the PS4 in Bluetooth mode using the T$ as the test bed. The third test was a wired PS4. In all 3 cases everything worked the same as if on the T3.6.
    Just thought you all would like to know.
  21. #96
    7,133
    Sounds great!
    @mjs513 - taking a look at the link you gave for getting the XBox one to work on RPI...
    Wondering what: Enhanced Re-Transmission Mode (ERTM) is and where to set it...
    There is a section 8.6 in Vol 3 Part A...
  22. #97
    11,963
    Am I still here ...
    Good report @mjs513 - I should get around to making a pass with what I have to see ...
    Need to get back and finish my Touch effort - I found it 2 years back looking for an answer to a Frank[ Distraction ]B question . . . then at the end of the thread in Jan 2019 I pointed to my map[] code and somebody grabbed it and said it worked great … Grrr … guess I should go fix that ...
  23. #98
    New York
    5,466
    @KurtE - you might want to check this out - maybe it will give you a few ideas: https://github.com/bluekitchen/btsta...1ddf2c9c1ec975
    @defragster - I kind of remember your map function when I was playing around with the ili9341 for the GPS PPS
  24. #99
    7,133
    @mjs513 - Thanks, it will be interesting to see how that relates to our code. I don't remember any thing mentioning any of this in either our code or HS2 code...
    But it might be part of the L2CAP commands... I edited the SublimeText regreplace script/rules to give me more data... There is probably an easier/better way, but it is getting the job done
    But to give you an idea:
    	"format": "3.0",
    	"replacements":
        "L2CAP_IN_COMMAND_REJECT":
          "case": false,
          "greedy": true,
          "find": "(IN,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x01)",
          "replace": "\\1L2CAP_IN_COMMAND_REJECT\\2"
        "L2CAP_IN_CONNECTION_REQUEST":
          "case": false,
          "greedy": true,
          "find": "(IN,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x02)",
          "replace": "\\1L2CAP_IN_CONNECTION_REQUEST\\2"
        "L2CAP_IN_CONNECTION_RESPONSE":
          "case": false,
          "greedy": true,
          "find": "(IN,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x03)",
          "replace": "\\1L2CAP_IN_CONNECTION_RESPONSE\\2"
        "L2CAP_IN_CONFIG_REQUEST":
          "case": false,
          "greedy": true,
          "find": "(IN,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x04)",
          "replace": "\\1L2CAP_IN_CONFIG_REQUEST\\2"
        "L2CAP_IN_CONFIG_RESPONSE":
          "case": false,
          "greedy": true,
          "find": "(IN,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x05)",
        "L2CAP_IN_DISCONNECT_REQUEST":
          "case": false,
          "greedy": true,
          "find": "(IN,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x06)",
          "replace": "\\1L2CAP_IN_DISCONNECT_REQUEST\\2"
        "L2CAP_IN_INFORMATION_REQUEST":
          "case": false,
          "greedy": true,
          "find": "(IN,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x0A)",
        "L2CAP_IN_INFORMATION_RESPONSE":
          "case": false,
          "greedy": true,
          "find": "(IN,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x0B)",
          "replace": "\\1L2CAP_IN_INFORMATION_REQUEST\\2"
        "L2CAP_OUT_COMMAND_REJECT":
          "case": false,
          "greedy": true,
          "find": "(OUT,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x01)",
          "replace": "\\1L2CAP_OUT_COMMAND_REJECT\\2"
        "L2CAP_OUT_CONNECTION_REQUEST":
          "case": false,
          "greedy": true,
          "find": "(OUT,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x02)",
          "replace": "\\1L2CAP_OUT_CONNECTION_REQUEST\\2"
        "L2CAP_OUT_CONNECTION_RESPONSE":
          "case": false,
          "greedy": true,
          "find": "(OUT,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x03)",
          "replace": "\\1L2CAP_OUT_CONNECTION_RESPONSE\\2"
        "L2CAP_OUT_CONFIG_REQUEST":
          "case": false,
          "greedy": true,
          "find": "(OUT,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x04)",
          "replace": "\\1L2CAP_OUT_CONFIG_REQUEST\\2"
        "L2CAP_OUT_CONFIG_RESPONSE":
          "case": false,
          "greedy": true,
          "find": "(OUT,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x05)",
        "L2CAP_OUT_DISCONNECT_REQUEST":
          "case": false,
          "greedy": true,
          "find": "(OUT,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x06)",
          "replace": "\\1L2CAP_OUT_DISCONNECT_REQUEST\\2"
        "L2CAP_OUT_INFORMATION_REQUEST":
          "case": false,
          "greedy": true,
          "find": "(OUT,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x0A)",
        "L2CAP_OUT_INFORMATION_RESPONSE":
          "case": false,
          "greedy": true,
          "find": "(OUT,0x02,0x00,)(,0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x[0-9A-F][0-9A-F] 0x0B)",
          "replace": "\\1L2CAP_OUT_INFORMATION_REQUEST\\2"
        "EV_INQUIRY_RESULT":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x02)",
          "replace": "\\1EV_INQUIRY_RESULT,0x02"
        "EV_CONNECT_COMPLETE":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x03)",
          "replace": "\\1EV_CONNECT_COMPLETE,0x03",
        "EV_INCOMING_CONNECT":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x04)",
          "replace": "\\1EV_INCOMING_CONNECT,0x04",
        "EV_AUTHENTICATION_COMPLETE":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x06)",
          "replace": "\\1EV_AUTHENTICATION_COMPLETE,0x06",
        "EV_REMOTE_NAME_COMPLETE":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x07)",
          "replace": "\\1EV_REMOTE_NAME_COMPLETE,0x07",
        "EV_ENCRYPTION_CHANGE":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x08)",
          "replace": "\\1EV_ENCRYPTION_CHANGE,0x08",
        "EV_COMMAND_STATUS":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x0F)",
          "replace": "\\1EV_COMMAND_STATUS,0x0F",
        "EV_ROLE_CHANGED":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x12)",
          "replace": "\\1EV_ROLE_CHANGED,0x12",
        "EV_NUM_COMPLETE_PKT":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x13)",
          "replace": "\\1EV_NUM_COMPLETE_PKT,0x13",
        "EV_PIN_CODE_REQUEST":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x16)",
          "replace": "\\1EV_PIN_CODE_REQUEST,0x16",
        "EV_LINK_KEY_REQUEST":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x17)",
          "replace": "\\1EV_LINK_KEY_REQUEST,0x17",
        "EV_LINK_KEY_NOTIFICATION":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x18)",
          "replace": "\\1EV_LINK_KEY_NOTIFICATION,0x18",
        "EV_Extended_Inquiry_Result":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x2F)",
          "replace": "\\1EV_Extended_Inquiry_Result,0x2F",
        "EV_LE_Connection_Complete":
          "case": false,
          "greedy": true,
          "find": "(IN,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x3E)",
          "replace": "\\1HCI_LE_Connection_Complete,0x3E",
        "HCI_INQUIRY":
          "case": false,
          "find": "^.*,IN,.*\\n.*,NAK.*\\n",
          "find": "(OUT,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x01 0x04)",
          "replace": "\\1HCI_INQUIRY,0x01 0x04",
        "HCI_CREATE_CONNECTION":
          "case": false,
          "find": "(OUT,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x05 0x04)",
          "replace": "\\1HCI_CREATE_CONNECTION,0x05 0x04",
        "HCI_LINK_KEY_NEG_REPLY":
          "case": false,
          "find": "(OUT,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x0C 0x04)",
          "replace": "\\1HCI_LINK_KEY_NEG_REPLY,0x0C 0x04",
        "HCI_PIN_CODE_REPLY":
          "case": false,
          "find": "(OUT,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x0D 0x04)",
          "replace": "\\1HCI_PIN_CODE_REPLY,0x0D 0x04",
        "HCI_AUTH_REQUESTED":
          "case": false,
          "find": "(OUT,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x11 0x04)",
          "replace": "\\1HCI_AUTH_REQUESTED,0x11 0x04",
        "HCI_OP_REMOTE_NAME_REQ":
          "case": false,
          "find": "(OUT,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x19 0x04)",
          "replace": "\\1HCI_OP_REMOTE_NAME_REQ,0x19 0x04",
        "HCI_OP_READ_REMOTE_VERSION_INFORMATION":
          "case": false,
          "find": "(OUT,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x1D 0x04)",
          "replace": "\\1HCI_OP_READ_REMOTE_VERSION_INFORMATION,0x1D 0x04",
        "HCI_OP_READ_REMOTE_FEATURES":
          "case": false,
          "find": "(OUT,0x[0-9][0-9],0x[0-9A-F][0-9A-F],)(,0x1B 0x04)",
          "replace": "\\1HCI_OP_READ_REMOTE_FEATURES,0x1B 0x04",
    		"remove_usb_packets_ACK":
    			"case": false,
    			"find": "^.*,ACK,.*\\n",
    			"greedy": true,
    			"replace": ""
    		"remove_usb_packets_IN_NAK":
    			"case": false,
    			"greedy": true,
    			"replace": ""
    		"remove_usb_packets_SOF":
    			"case": false,
    			"find": "^.*,SOF,.*\\n",
    			"greedy": true,
    			"replace": ""
    And the Commands file:
        "caption": "USB Logic Packet format",
        "command": "reg_replace",
        "args": {
          "replacements": [
            "L2CAP_IN_COMMAND_REJECT",
            "L2CAP_IN_CONNECTION_REQUEST",
            "L2CAP_IN_CONNECTION_RESPONSE",
            "L2CAP_IN_CONFIG_REQUEST",
            "L2CAP_IN_CONFIG_RESPONSE",
            "L2CAP_IN_DISCONNECT_REQUEST",
            "L2CAP_IN_INFORMATION_REQUEST",
            "L2CAP_IN_INFORMATION_RESPONSE",
            "L2CAP_OUT_COMMAND_REJECT",
            "L2CAP_OUT_CONNECTION_REQUEST",
            "L2CAP_OUT_CONNECTION_RESPONSE",
            "L2CAP_OUT_CONFIG_REQUEST",
            "L2CAP_OUT_CONFIG_RESPONSE",
            "L2CAP_OUT_DISCONNECT_REQUEST",
            "L2CAP_OUT_INFORMATION_REQUEST",
            "L2CAP_OUT_INFORMATION_RESPONSE",
            "EV_INQUIRY_RESULT",
            "EV_CONNECT_COMPLETE",
            "EV_INCOMING_CONNECT",
            "EV_AUTHENTICATION_COMPLETE",
            "EV_REMOTE_NAME_COMPLETE",
            "EV_ENCRYPTION_CHANGE",
            "EV_COMMAND_STATUS",
            "EV_ROLE_CHANGED",
            "EV_NUM_COMPLETE_PKT",
            "EV_PIN_CODE_REQUEST",
            "EV_LINK_KEY_REQUEST",
            "EV_LINK_KEY_NOTIFICATION",
            "EV_Extended_Inquiry_Result",
            "EV_LE_Connection_Complete",
            "HCI_INQUIRY",
            "HCI_CREATE_CONNECTION",
            "HCI_LINK_KEY_NEG_REPLY",
            "HCI_PIN_CODE_REPLY",
            "HCI_AUTH_REQUESTED",
            "HCI_OP_REMOTE_NAME_REQ",
            "HCI_OP_READ_REMOTE_FEATURES",
    But with it and the previous edits, I am getting data like: (Partial extract)
    IN	0x01	0x13		0x00
    IN	0x01	0x13		0x00
    IN	0x01	0x13	EV_COMMAND_STATUS	0x0F 0x04 0x00 0x01 0x05 0x04
    IN	0x01	0x13	EV_COMMAND_STATUS	0x0F 0x04 0x00 0x00 0x1B 0x04
    IN	0x02	0x00	L2CAP_IN_CONNECTION_REQUEST	0x47 0x20 0x0C 0x00 0x08 0x00 0x01 0x00 0x02 0x01 0x04 0x00 0x01 0x00 0x40 0x00
    IN	0x01	0x13	EV_COMMAND_STATUS	0x0F 0x04 0x00 0x01 0x00 0x00
    IN	0x01	0x13	EV_COMMAND_STATUS	0x0F 0x04 0x00 0x01 0x1C 0x04
    IN	0x01	0x13	EV_COMMAND_STATUS	0x0F 0x04 0x00 0x01 0x1D 0x04
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_REQUEST	0x47 0x00 0x0C 0x00 0x08 0x00 0x01 0x00 0x02 0x01 0x04 0x00 0x01 0x00 0x40 0x00
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_RESPONSE	0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x01 0x08 0x00 0x41 0x00 0x40 0x00 0x01 0x00 0x00 0x00
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_RESPONSE	0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x01 0x08 0x00 0x41 0x00 0x40 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00	L2CAP_OUT_CONFIG_REQUEST	0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x02 0x08 0x00 0x40 0x00 0x00 0x00 0x01 0x02 0x00 0x04
    IN	0x01	0x13	EV_NUM_COMPLETE_PKT	0x13 0x05 0x01 0x47 0x00 0x01 0x00
    IN	0x02	0x00	L2CAP_IN_CONNECTION_RESPONSE	0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x01 0x08 0x00 0x41 0x00 0x40 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00	L2CAP_OUT_CONFIG_REQUEST	0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x03 0x08 0x00 0x41 0x00 0x00 0x00 0x01 0x02 0x00 0x04
    SETUP	0x00	0x05		0x20 0x00 0x00 0x00 0x00 0x00 0x05 0x00
    IN	0x02	0x00	L2CAP_IN_CONFIG_REQUEST	0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x02 0x08 0x00 0x40 0x00 0x00 0x00 0x01 0x02 0xC8 0x05
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_REQUEST	0x47 0x00 0x12 0x00 0x0E 0x00 0x01 0x00 0x05 0x02 0x0A 0x00 0x41 0x00 0x00 0x00 0x00 0x00 0x01 0x02 0x00 0x04
    IN	0x02	0x00	L2CAP_IN_CONFIG_REQUEST	0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x03 0x08 0x00 0x41 0x00 0x00 0x00 0x01 0x02 0xC8 0x05
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_REQUEST	0x47 0x00 0x12 0x00 0x0E 0x00 0x01 0x00 0x05 0x03 0x0A 0x00 0x40 0x00 0x00 0x00 0x00 0x00 0x01 0x02 0x00 0x04
    IN	0x02	0x00	L2CAP_IN_CONNECTION_REQUEST	0x47 0x20 0x0E 0x00 0x0A 0x00 0x01 0x00 0x05 0x02 0x06 0x00 0x41 0x00 0x00 0x00 0x00 0x00
    IN	0x01	0x13	EV_COMMAND_STATUS	0x0F 0x04 0x00 0x01 0x1F 0x04
    IN	0x02	0x00	L2CAP_IN_CONNECTION_REQUEST	0x47 0x20 0x0E 0x00 0x0A 0x00 0x01 0x00 0x05 0x03 0x06 0x00 0x40 0x00 0x00 0x00 0x00 0x00
    IN	0x02	0x00	L2CAP_IN_DISCONNECT_REQUEST	0x47 0x20 0x16 0x00 0x12 0x00 0x41 0x00 0x06 0x00 0x00 0x00 0x0D 0x35 0x03 0x19 0x12 0x00 0x00 0x64 0x35 0x03 0x09 0x00 0x01 0x00
    IN	0x01	0x13	EV_COMMAND_STATUS	0x0F 0x04 0x00 0x01 0x11 0x04
    IN	0x02	0x00	L2CAP_IN_CONNECTION_REQUEST	0x47 0x20 0x11 0x00 0x0D 0x00 0x41 0x00 0x02 0x00 0x01 0x00 0x08 0x35 0x03 0x19 0x12 0x00 0x00 0x01 0x00
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_RESPONSE	0x47 0x00 0x12 0x00 0x0E 0x00 0x40 0x00 0x03 0x00 0x01 0x00 0x09 0x00 0x01 0x00 0x01 0x00 0x01 0x00 0x00 0x00
    IN	0x02	0x00	L2CAP_IN_CONFIG_REQUEST	0x47 0x20 0x17 0x00 0x13 0x00 0x41 0x00 0x04 0x00 0x02 0x00 0x0E 0x00 0x01 0x00 0x00 0x00 0x64 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x00
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_REQUEST	0x47 0x00 0x78 0x00 0x74 0x00 0x40 0x00 0x05 0x00 0x02 0x00 0x6F 0x00 0x64 0x35 0x95 0x09 0x00 0x00 0x0A 0x00 0x01 0x00 0x00 0x09 0x00 0x01 0x35 0x03 0x19 0x12 0x00 0x09 0x00 0x04 0x35 0x0D 0x35 0x06 0x19 0x01 0x00 0x09 0x00 0x01 0x35 0x03 0x19 0x00 0x01 0x09 0x00 0x05 0x35 0x03 0x19 0x10 0x02 0x09 0x00 0x06 0x35 0x09
    IN	0x02	0x00	L2CAP_IN_CONFIG_REQUEST	0x47 0x20 0x1F 0x00 0x1B 0x00 0x41 0x00 0x04 0x00 0x03 0x00 0x16 0x00 0x01 0x00 0x00 0x00 0x64 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x08 0x60 0xEB 0x65 0x62 0x81 0xD4 0xFF 0xFF
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_REQUEST	0x47 0x00 0x3F 0x00 0x3B 0x00 0x40 0x00 0x05 0x00 0x03 0x00 0x36 0x00 0x33 0x44 0x20 0x53 0x65 0x72 0x76 0x69 0x63 0x65 0x20 0x52 0x65 0x63 0x6F 0x72 0x64 0x09 0x02 0x00 0x09 0x01 0x03 0x09 0x02 0x01 0x09 0x00 0x06 0x09 0x02 0x02 0x09 0x00 0x01 0x09 0x02 0x03 0x09 0x0A 0x00 0x09 0x02 0x04 0x28 0x01 0x09 0x02 0x05 0x09
    IN	0x02	0x00	L2CAP_IN_DISCONNECT_REQUEST	0x47 0x20 0x0C 0x00 0x08 0x00 0x01 0x00 0x06 0x04 0x04 0x00 0x41 0x00 0x40 0x00
    IN	0x01	0x13	EV_COMMAND_STATUS	0x0F 0x04 0x00 0x01 0x13 0x04
    OUT	0x02	0x00	L2CAP_OUT_DISCONNECT_REQUEST	0x47 0x00 0x18 0x00 0x14 0x00 0x41 0x00 0x06 0x00 0x00 0x00 0x0F 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x00
    IN	0x01	0x13	EV_ENCRYPTION_CHANGE	0x08 0x04 0x00 0x47 0x00 0x01
    IN	0x02	0x00	L2CAP_IN_DISCONNECT_REQUEST	0x05 0x35 0x03 0x19 0x10 0x02 0x09 0x00 0x06 0x35 0x09 0x09 0x65 0x6E 0x09 0x00 0x6A 0x09 0x01 0x00 0x09 0x00 0x09 0x35 0x08 0x35 0x06 0x19 0x12 0x00 0x09 0x01 0x00 0x09 0x01 0x00 0x25 0x01 0x00 0x09 0x01 0x01 0x25 0x01 0x00 0x09 0x01 0x02 0x25 0x01 0x00 0x09 0x02 0x00 0x09 0x01 0x03 0x09 0x02 0x01 0x09 0x04 0x5E 0x09
    OUT	0x02	0x00	L2CAP_OUT_DISCONNECT_REQUEST	0x47 0x00 0x19 0x00 0x15 0x00 0x41 0x00 0x06 0x00 0x01 0x00 0x10 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x01 0x01
    OUT	0x02	0x00	L2CAP_OUT_DISCONNECT_REQUEST	0x47 0x00 0x19 0x00 0x15 0x00 0x41 0x00 0x06 0x00 0x02 0x00 0x10 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x01 0x02
    OUT	0x02	0x00	L2CAP_OUT_DISCONNECT_REQUEST	0x47 0x00 0x19 0x00 0x15 0x00 0x41 0x00 0x06 0x00 0x03 0x00 0x10 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x01 0x03
    OUT	0x02	0x00	L2CAP_OUT_DISCONNECT_REQUEST	0x47 0x00 0x19 0x00 0x15 0x00 0x41 0x00 0x06 0x00 0x04 0x00 0x10 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x01 0x04
    OUT	0x02	0x00	L2CAP_OUT_DISCONNECT_REQUEST	0x47 0x00 0x19 0x00 0x15 0x00 0x41 0x00 0x06 0x00 0x05 0x00 0x10 0x35 0x03 0x19 0x01 0x00 0x03 0xF8 0x35 0x05 0x0A 0x00 0x00 0xFF 0xFF 0x01 0x05
    OUT	0x02	0x00	L2CAP_OUT_DISCONNECT_REQUEST	0x47 0x00 0x0C 0x00 0x08 0x00 0x01 0x00 0x06 0x04 0x04 0x00 0x41 0x00 0x40 0x00
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_REQUEST	0x47 0x00 0x0C 0x00 0x08 0x00 0x01 0x00 0x02 0x05 0x04 0x00 0x11 0x00 0x42 0x00
    IN	0x02	0x00	L2CAP_IN_CONNECTION_RESPONSE	0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x05 0x08 0x00 0x40 0x00 0x42 0x00 0x01 0x00 0x00 0x00
    IN	0x02	0x00	L2CAP_IN_CONNECTION_RESPONSE	0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x05 0x08 0x00 0x40 0x00 0x42 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00	L2CAP_OUT_CONFIG_REQUEST	0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x06 0x08 0x00 0x40 0x00 0x00 0x00 0x01 0x02 0xA0 0x02
    IN	0x02	0x00	L2CAP_IN_CONFIG_REQUEST	0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x05 0x08 0x00 0x42 0x00 0x00 0x00 0x01 0x02 0xC8 0x05
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_REQUEST	0x47 0x00 0x12 0x00 0x0E 0x00 0x01 0x00 0x05 0x05 0x0A 0x00 0x40 0x00 0x00 0x00 0x00 0x00 0x01 0x02 0xA0 0x02
    IN	0x02	0x00	L2CAP_IN_CONNECTION_REQUEST	0x47 0x20 0x0E 0x00 0x0A 0x00 0x01 0x00 0x05 0x06 0x06 0x00 0x42 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_REQUEST	0x47 0x00 0x0C 0x00 0x08 0x00 0x01 0x00 0x02 0x07 0x04 0x00 0x13 0x00 0x43 0x00
    IN	0x02	0x00	L2CAP_IN_CONNECTION_RESPONSE	0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x07 0x08 0x00 0x41 0x00 0x43 0x00 0x01 0x00 0x00 0x00
    IN	0x02	0x00	L2CAP_IN_CONNECTION_RESPONSE	0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x03 0x07 0x08 0x00 0x41 0x00 0x43 0x00 0x00 0x00 0x00 0x00
    OUT	0x02	0x00	L2CAP_OUT_CONFIG_REQUEST	0x47 0x00 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x08 0x08 0x00 0x41 0x00 0x00 0x00 0x01 0x02 0xA0 0x02
    IN	0x02	0x00	L2CAP_IN_CONFIG_REQUEST	0x47 0x20 0x10 0x00 0x0C 0x00 0x01 0x00 0x04 0x06 0x08 0x00 0x43 0x00 0x00 0x00 0x01 0x02 0xC8 0x05
    OUT	0x02	0x00	L2CAP_OUT_CONNECTION_REQUEST	0x47 0x00 0x12 0x00 0x0E 0x00 0x01 0x00 0x05 0x06 0x0A 0x00 0x41 0x00 0x00 0x00 0x00 0x00 0x01 0x02 0xA0 0x02
    IN	0x01	0x13	EV_COMMAND_STATUS	0x0F 0x04 0x00 0x01 0x07 0x08
    IN	0x02	0x00	L2CAP_IN_CONNECTION_REQUEST	0x47 0x20 0x0E 0x00 0x0A 0x00 0x01 0x00 0x05 0x08 0x06 0x00 0x43 0x00 0x00 0x00 0x00 0x00
    Now to again try it on our code base and see about the different things/responses...
  25. #100
    New York
    5,466
    @KurtE
    You really filled in a lot of the missing pieces. That XBOX controller seems to be a lot different than the PlayStation controllers. Think I read somewhere that XBOX BT is kind of unique to the xbox controllers and doesn't follow the norm. Think we are seeing that now.
