Page 6 of 7 FirstFirst ... 4 5 6 7 LastLast
Results 126 to 150 of 152
Thread: T3.6 USB Host - Joysticks
  1. #126
    7,865
    @mjs513 - Wondering. I know it is probably my screw up... But I was wondering about the PS4 and my mapping of Button bits and was thinking maybe they are screwed up?
    		 * [1] LX, [2] = LY, [3] = RX, [4] = RY
    		 * [5] combo, tri, cir, x, sqr, D-PAD (4bits, 0-3
    		 * [6] R3,L3, opt, share, R2, L2, R1, L1
    		 * [7] Counter (bit7-2), T-PAD, PS
    		 * [8] Left Trigger, [9] Right Trigger
    		 * [10-11] Timestamp
    		 * [12] Battery (0 to 0xff)
    		 * [13-14] acceleration x
    		 * [15-16] acceleration y
    		 * [17-18] acceleration z
    		 * [19-20] gyro x
    		 * [21-22] gyro y
    		 * [23-24] gyro z
    		 * [25-29] unknown
    		 * [30] 0x00,phone,mic, usb, battery level (4bits)
    		 * rest is trackpad?  to do implement?
    		//PS Bit
    		tmp_data[7] = (tmp_data[7] >> 0) & 1;
    		//set arrow buttons to axis[0]
    		tmp_data[10] = tmp_data[5] & ((1 << 4) - 1);
    		//set buttons for last 4bits in the axis[5]
    		tmp_data[5] = tmp_data[5] >> 4;
    		// Quick and dirty hack to match PS4 HID data
    		uint32_t cur_buttons = tmp_data[7] | (tmp_data[10]) | ((tmp_data[6]*10)) | ((uint16_t)tmp_data[5] << 16) ;
    		if (cur_buttons != buttons) {
    			buttons = cur_buttons;
    			joystickEvent = true;	// something changed.
    Did I/we think the 10 is correct? I can see maybe 0x10, but this sets two multiple bits, which I was noticing and the values just feel wrong...
    And if I fix was wondering if I should hack up the bits for D-PAD instead of 8 value for nothing pressed maybe quick map to bits like PS3?
    Thoughts?
  2. #127
    5,872
    		 * [10-11] Timestamp
    		 * [19-20] gyro x
    		 * [21-22] gyro y
    		 * [23-24] gyro z
    		 * [25-29] unknown
    		//PS Bit
    Thoughts?
    Been awhile since I/we played with this - but I was never good with the button mapping. If i remember we originally had them mapped out to more array elements but then we combined buttons.
    Be honest, i will leave to your discretion as long as it doesn't get too confusing
  3. #128
    Ok, not sure what's going on, but when I try the USBHost_viewer sketch, I get the following error:
    USBHost_viewer:28: error: 'ILI9341_TFTWIDTH' was not declared in this scope
    DMAMEM uint16_t frame_buffer[ILI9341_TFTWIDTH * ILI9341_TFTHEIGHT];
    USBHost_viewer:28: error: 'ILI9341_TFTHEIGHT' was not declared in this scope
    USBHost_viewer:50: error: 'ILI9341_t3n' does not name a type
    ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCK, TFT_MISO);
    USBHost_viewer: In function 'void setup()':
    USBHost_viewer:153: error: 'tft' was not declared in this scope
    tft.begin();
    USBHost_viewer:155: error: 'frame_buffer' was not declared in this scope
    tft.setFrameBuffer(frame_buffer);
    USBHost_viewer:160: error: 'ILI9341_BLACK' was not declared in this scope
    USBHost_viewer:161: error: 'ILI9341_YELLOW' was not declared in this scope
    tft.setTextColor(ILI9341_YELLOW);
    USBHost_viewer: In function 'void UpdateActiveDeviceInfo()':
    USBHost_viewer:206: error: 'tft' was not declared in this scope
    tft.fillScreen(ILI9341_BLACK); // clear the screen.
    USBHost_viewer:206: error: 'ILI9341_BLACK' was not declared in this scope
    USBHost_viewer:208: error: 'ILI9341_YELLOW' was not declared in this scope
    USBHost_viewer:232: error: 'tft' was not declared in this scope
    USBHost_viewer:232: error: 'ILI9341_BLACK' was not declared in this scope
    USBHost_viewer:234: error: 'ILI9341_YELLOW' was not declared in this scope
    USBHost_viewer:259: error: 'tft' was not declared in this scope
    USBHost_viewer:259: error: 'ILI9341_BLACK' was not declared in this scope
    USBHost_viewer:261: error: 'ILI9341_YELLOW' was not declared in this scope
    USBHost_viewer: In function 'void ProcessTabletData()':
    USBHost_viewer:285: error: 'tft' was not declared in this scope
    tft.getCursor(&x, &y_position_after_device_info);
    USBHost_viewer:286: error: 'ILI9341_YELLOW' was not declared in this scope
    USBHost_viewer:324: error: 'tft' was not declared in this scope
    tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK);
    USBHost_viewer:324: error: 'ILI9341_WHITE' was not declared in this scope
    USBHost_viewer:324: error: 'ILI9341_BLACK' was not declared in this scope
    USBHost_viewer: In function 'void OutputNumberField(int16_t, int16_t, int, int16_t)':
    USBHost_viewer:355: error: 'tft' was not declared in this scope
    tft.setCursor(x, y);
    USBHost_viewer:357: error: 'ILI9341_BLACK' was not declared in this scope
    tft.fillRect(x2, y, field_width - (x2 - x), Arial_12.line_space, ILI9341_BLACK);
    USBHost_viewer: In function 'void ProcessMouseData()':
    USBHost_viewer:368: error: 'tft' was not declared in this scope
    USBHost_viewer:369: error: 'ILI9341_YELLOW' was not declared in this scope
    USBHost_viewer:399: error: 'tft' was not declared in this scope
    USBHost_viewer:399: error: 'ILI9341_WHITE' was not declared in this scope
    USBHost_viewer:399: error: 'ILI9341_BLACK' was not declared in this scope
    USBHost_viewer: In function 'void ProcessJoystickData()':
    USBHost_viewer:483: warning: comparison between signed and unsigned integer expressions
    if (buttons != buttons_cur) {
    USBHost_viewer: In function 'void tft_JoystickData()':
    USBHost_viewer:508: error: 'tft' was not declared in this scope
    USBHost_viewer:509: error: 'ILI9341_YELLOW' was not declared in this scope
    USBHost_viewer:540: warning: enumeration value 'UNKNOWN' not handled in switch
    switch (joystick.joystickType()) {
    USBHost_viewer:540: warning: enumeration value 'PS3_MOTION' not handled in switch
    USBHost_viewer:540: warning: enumeration value 'SpaceNav' not handled in switch
    USBHost_viewer:568: error: 'tft' was not declared in this scope
    USBHost_viewer:568: error: 'ILI9341_WHITE' was not declared in this scope
    USBHost_viewer:568: error: 'ILI9341_BLACK' was not declared in this scope
    USBHost_viewer: In function 'bool OnReceiveHidData(uint32_t, const uint8_t*, uint32_t)':
    USBHost_viewer:634: error: 'tft' was not declared in this scope
    tft.fillRect(45, 197, 240, 20, ILI9341_RED);
    USBHost_viewer:634: error: 'ILI9341_RED' was not declared in this scope
    USBHost_viewer: In function 'void MaybeSetupTextScrollArea()':
    USBHost_viewer:662: error: 'tft' was not declared in this scope
    tft.enableScroll();
    USBHost_viewer:664: error: 'ILI9341_GREEN' was not declared in this scope
    tft.setScrollBackgroundColor(ILI9341_GREEN);
    USBHost_viewer:666: error: 'ILI9341_BLACK' was not declared in this scope
    tft.setTextColor(ILI9341_BLACK);
    USBHost_viewer: In function 'void OnPress(int)':
    USBHost_viewer:675: error: 'tft' was not declared in this scope
    tft.print("key: ");
    USBHost_viewer: In function 'void OnHIDExtrasPress(uint32_t, uint16_t)':
    USBHost_viewer:729: error: 'tft' was not declared in this scope
    tft.print("HID (");
    USBHost_viewer: In function 'void OnHIDExtrasRelease(uint32_t, uint16_t)':
    USBHost_viewer:966: error: 'tft' was not declared in this scope
    tft.print("HID (");
    Multiple libraries were found for "USBHost_t36.h"
    Used: C:\Users\-\Documents\Arduino\libraries\USBHost_t36
    Not used: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\USBHos t_t36
    I directly cloned the following libs to my Arduino IDE "libraries" folder:
    https://github.com/KurtE/USBHost_t36
    https://github.com/KurtE/ILI9341_t3n
    @KurtE - Any idea what's going on? I figured I downloaded the proper libraries, am I missing one?
  4. #129
    7,865
    Sounds like it did not find the header files for those libraries.
    Might help to see the full set of output, which might include things like what the compiler options were. Example for T4? 4.1 or 3.6? Also what version of Teensyduino.
    Also if you downloaded from my github, did you use the default branch (master?) Probably should be in sync with the master one that shipped with the current released teensyduino.
  5. #130
    I installed the libraries in the correct place, so finding the installed headers is not the problem. Also, I'm compiling for T3.6 with the current Teensyduino version.
    I'd really appreciate if you can figure out why it's broken.
  6. #131
    12,648
    Problem is missing DISPLAY library info ...ILI9341_TFTWIDTH' was not declared in this scope
    Library info not shown as if one was found
  7. #132
    Ok, I actually figured it out - you need to add
    #include "ILI9341_t3n.h"
    to either ili9341_t3n_font_Arial.h or to the example sketch in order for things to work. I think that should be updated in the repository. I can do a PR if you want.
  8. #133
    Now when I plug my XBox One controller into my T3.6 and run the test sketch, the only thing that shows up in the serial monitor is "USB Host Testing". My controller on lights do not turn on and none of the buttons cause any printouts.
    You mentioned something about uncommenting a #define with "debug" in it, but I've searched the sketch and several lib headers and can't for the life of me find what you're talking about.
    Any suggestions?
  9. #134
    12,648
    Quote Originally Posted by Power_Broker View Post
    Any suggestions?
    It is there as #define USBHOST_PRINT_DEBUG in : ...\hardware\teensy\avr\libraries\USBHost_t36\USBH ost_t36.h
  10. #135
    7,865
    XBox One controller: I believe we have some of it working for USB connections. However we still have not been able to make it work using Bluetooth. It requires more pieces of the Bluetooth system than we have implemented.
    As @defragster mentioned, if you uncomment the line: #define USBHOST_PRINT_DEBUG
    in USBHost_t36.h, which is a library file, and rebuild it should print out a lot more debug information.
  11. #136
    Ok, cool - can't believe ctrl+f "debug" didn't find that statement, lol.
    I ran it with my (hardwired) XBox One controller attached and got the following:
    USB Host Testing
    sizeof Device = 36
    sizeof Pipe = 96
    sizeof Transfer = 64
    power up USBHS PHY
    reset waited 5
    USBHS_ASYNCLISTADDR = 0
    USBHS_PERIODICLISTBASE = 2001B000
    periodictable = 2001B000
    port change: 10001803
    connect
    begin reset
    port change: 10001005
    port enabled
    end recovery
    new_Device: 12 Mbit/sec
    new_Pipe
    enumeration:
    enumeration:
    enumeration:
    Device Descriptor:
    12 01 00 02 FF FF FF 40 C6 24 1A 58 01 01 01 02 03 01
    VendorID = 24C6, ProductID = 581A, Version = 0101
    Class/Subclass/Protocol = 255 / 255 / 255
    Number of Configurations = 1
    enumeration:
    enumeration:
    Manufacturer: BDA
    enumeration:
    Product: XB1 Classic Controller
    enumeration:
    Serial Number: 00001AE88AC3F082
    enumeration:
    Config data length = 96
    enumeration:
    Configuration Descriptor:
    09 02 60 00 03 01 00 A0 FA
    NumInterfaces = 3
    ConfigurationValue = 1
    09 04 00 00 02 FF 47 D0 00
    Interface = 0
    Number of endpoints = 2
    Class/Subclass/Protocol = 255 / 71 / 208
    07 05 02 03 40 00 04
    Endpoint = 2 OUT
    Type = Interrupt
    Max Size = 64
    Polling Interval = 4
    07 05 81 03 40 00 04
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 64
    09 04 01 00 00 FF 47 D0 00
    Interface = 1
    Number of endpoints = 0
    09 04 01 01 02 FF 47 D0 00
    Interface = 1
    07 05 08 01 E4 00 01
    Endpoint = 8 OUT
    Type = Isochronous
    Max Size = 228
    Polling Interval = 1
    07 05 87 01 E4 00 01
    Endpoint = 7 IN
    Type = Isochronous
    Max Size = 228
    09 04 02 00 00 FF 47 D0 00
    Interface = 2
    09 04 02 01 02 FF 47 D0 00
    Interface = 2
    07 05 04 02 40 00 00
    Endpoint = 4 OUT
    Type = Bulk
    Max Size = 64
    Polling Interval = 0
    07 05 83 02 40 00 00
    Endpoint = 3 IN
    Type = Bulk
    Max Size = 64
    enumeration:
    USBHub memory usage = 960
    USBHub claim_device this=20019140
    USBHub claim_device this=20019500
    KeyboardController claim this=20017260
    KeyboardController claim this=20017500
    HIDParser claim this=200177A0
    HIDParser claim this=20017DC0
    HIDParser claim this=20018B00
    HIDParser claim this=20019980
    HIDParser claim this=20018400
    JoystickController claim this=20019FC0
    BluetoothController claim this=2001A520
    Descriptor 4 = INTERFACE
    09 04 00 00 02 FF 47 D0 00 07 05 02 03 40 00 04 07 05 81 03 40 00 04 09 04 01 00 00 FF 47 D0 00 09 04 01 01 02 FF 47 D0 00 07 05 08 01 E4 00 01 07 05 87 01 E4 00 01 09 04 02 00 00 FF 47 D0 00 09 04 02 01 02 FF 47 D0 00 07 05 04 02 40 00 00 07 05 83 02 40 00 00
    Jtype=0
    Descriptor 5 = ENDPOINT
    Jtype=0
    Jtype=0
    Jtype=0
    Jtype=0
    I'm not experienced with HID or USB enough to know what the printouts mean - is my device connecting correctly?
  12. #137
    Any updates? I tried printing "joystick" class attributes in the "XBOXONE" case to see if I can get button press info, but the library doesn't recognize/initialize the controller correctly. Can you look into this?
  13. #138
    7,865
    Sorry, I have been (and mostly still am) distracted with other things.
    But some of the information I see, in your output:
    enumeration:
    enumeration:
    Manufacturer: BDA
    enumeration:
    enumeration:
    Shows this is NOT a Microsoft XBox One controller, and as such our special casing code for the XBox One is not being run...
    Don't know anything about your controller or the like, but the current code knows it is an XBox one IF the Vendor ID and Product ID match to some known values.
    In particular at the start of joystick.cpp, is a static mapping table that maps a Vendor ID, Product ID, to what we think this joystick is....
    JoystickController::product_vendor_mapping_t JoystickController::pid_vid_mapping[] = {
    	{ 0x045e, 0x02ea, XBOXONE, false },{ 0x045e, 0x02dd, XBOXONE, false },
    	{ 0x045e, 0x0719, XBOX360, false},
    	{ 0x045e, 0x028E, SWITCH, false},  // Switch?
    	{ 0x054C, 0x0268, PS3, true},
    	{ 0x054C, 0x042F, PS3, true},	// PS3 Navigation controller
    	{ 0x054C, 0x03D5, PS3_MOTION, true},	// PS3 Motion controller
    	{ 0x054C, 0x05C4, PS4, true}, 	{0x054C, 0x09CC, PS4, true },
    	{ 0x046D, 0xC626, SpaceNav, true},  // 3d Connextion Space Navigator, 0x10008
    	{ 0x046D, 0xC628, SpaceNav, true}  // 3d Connextion Space Navigator, 0x10008
    Right now we show 2 different Product IDs under the one Vendor ID (0x45e for Microsoft)...
    It might work for you if you simply add a new entry for your unit and see what happens.
    Something like:
    	{ 0x24C6, 0x581A, XBOXONE, false },
    If it does work let us, and we can hopefully officially add it this list. Note: The red line I added, would be good to have comment of brand, model of your unit
  14. #139
    Apr 2020
    DFW area in Texas
    140
    Don't know if it's related or not, but that VID:PID (24c6:581a) seems to be reported <here> as having problems working with xboxdrv. Curiously, according to <this> reference, that VID belongs to ThrustMaster, Inc. & according to <this> reference, it belongs to "Xbox 3rd Party Partners".
    Mark J Culross
    KD5RXT
  15. #140
    7,865
    Note: Off and On, I look at seeing what it will take to support the XBox One in Bluetooth mode.
    The question at some point may be, do we continue to make things work as needed or does someone try to take the whole beast on and try to fully understand and implement whole sub-systems, state machines... Not sure if better to discuss the XBox stuff here or in the Bluetooth thread (fits both categories)
    But example in hand:
    In my debug output when trying to bind to XBox One, includes:
    BT rx_data(1): 0
        Extended Inquiry Result - Count: 1
          BD:dc:13:d6:1b:aa:9c, PS:1, class: 508
          Local Name: Xbox Wireless Controller
          Peripheral device
            Gamepad
    BluetoothController::find_driver  driver 200070f8
    JoystickController::claim_bluetooth TRUE
      JoystickController::mapNameToJoystickType 200070e0 Xbox Wireless Controller - set to XBOXONE
      Joystick Type: 3
        *** Claimed ***
    HCI_INQUIRY_CANCEL called (02 04 00 )
        control callback (bluetooth) 64
        Control callback (bluetooth): 100 : 2 4 0
    0E 04 01 02 04 00
    BT rx_data(6): e 4 1 2 4 0
        Command Completed!
    HCI_CREATE_CONNECTION called (05 04 0d dc 13 d6 1b aa 9c 18 cc 01 00 00 00 00 )
        control callback (bluetooth) 65
        Control callback (bluetooth): 101 : 5 4 d dc 13 d6 1b aa 9c 18 cc 1 0 0 0 0
    0F 04 00 01 05 04
    BT rx_data(6): f 4 0 1 5 4
        Command 405 Status 0
    03 0B 00 48 00 DC 13 D6 1B AA 9C 01 00
    BT rx_data(13): 3 b 0 48 0 dc 13 d6 1b aa 9c 1 0
        Connection Complete - ST:0 LH:48
    HCI_AUTH_REQUESTED called (11 04 02 48 00 )
        control callback (bluetooth) 6E
        Control callback (bluetooth): 110 : 11 4 2 48 0
    0F 04 00 00 11 04
    BT rx_data(6): f 4 0 0 11 4
        Command 411 Status 0
    BT rx2_data(16): 48 20 c 0 8 0 1 0 2 1 4 0 1 0 40 0
        L2CAP Connection Request: ID: 1, PSM: 1, SCID: 40
    1B 03 48 00 05
    BT rx_data(5): 1b 3 48 0 5
    17 06 DC 13 D6 1B AA 9C
    You see the connection request has PSM: 1
    Which we have not handled before:
    If you look at the assigned numbers for this in: https://www.bluetooth.com/specificat...-link-control/
    You see: 1 = SDP
    We currently only try to handle: 0x11 - HID_Control and 0x13 - HID_Interrupt
    So looks like, we need to learn more about SDP.
    Note: As far as I know there have not gotten the XBOX One to work in BT mode with the USB Host Shield 2 code either. There is a WIP branch of it from a year ago, which was not working... But it looks like they have implemented some of SDP... But again I will probably first go down the rabbit hole of seeing of we can make sense of each new message we receive and fake it
  16. #141
    5,872
    Morning @KurtE
    There is a bunch of stuff i posted on the other thread regarding the XBOXONE BT driver starting around post #730 from the results of BT sniffing on the Android and USBHost shield2.0. But you are absolutely correct about SDP. It looks like it uses SDP for authenication and initization and everything else seems to be our normal stuff the log can be read using Wireshark and it may help.
    Not sure where it is better to post the XBOX One?
    EDIT: You might be able to fake it so that when certain PSM=1 requests hit you just send the expected respons?
  17. #142
    7,865
    Morning again,
    As I mentioned it was unclear to do it here or in Bluetooth, will probably go back to BT thread. But probably BT so off to the other thread...
  18. #143
    Aug 2020
    4
    Hi
    Thanks you guys for the amazing work on this topic.
    I would like to read out a 3d Connexion Spacemouse, but struggling with some compiler error.
    My setup:
    - Teensy 4.0, USB cable soldered to board (red +5V, green -D, white +D, black GND)
    - Arduino IDE with Teensy Addon (Teensy 4.0 works fine with other sketches)
    - Plugin 3DConnexion SpaceMouse Vendor ID / Product ID 0x46D, 0xC628
    - Load Libraries from KurtE via Arduino IDE -> Sketches -> Include Library -> Add .Zip-File
    Following Libraries are loaded:
    USBHost_t36
    ILI9341_t3n
    SPIN
    - Open Sketch Example USBHost_viewer.ino
    - Compiling... and the error underneath occures
    Could you give me a hint, how to get the SpaceNavigator work with Teensy 4.0?
    USBHost_viewer:42: error: 'ILI9341_t3n' does not name a type
     ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST);
       tft.begin();
         tft.enableScroll();
       tft.print("key: ");
       tft.print("HID (");
       tft.print("HID (");
  19. #144
    7,865
    @teensyJoe It might help to know which version of Arduino and Teensyduino you have installed.
    I assume if you loaded up USBHost_veiewer code that you commented out the USE_ST77XX comment to have it load up the ILI9341_t3n code.
    Note: ILI9341_t3n should not need SPIN anymore..
    I don't see any of the comments here that shows which libraries were loaded and from where... To give a better indication of what is going wrong.
    As for the Space Mouse hard to say, I know nothing about it. For example does it output standard mouse HID data, in which case it should hopefully just work.
    If not, may need to capture more data on it. A lot of the debug data can be captured by turning on the debug output from the USBHost library.
    There is a #define in the header file not far down which turns this on... You just need to uncomment it.
  20. #145
    Jul 2020
    459
    Quote Originally Posted by TeensyJoe View Post
    Hi
    Those suggest the ILI9341_tfn library isn't #included.
  21. #146
    5,872
    @TeensyJoe - depends on which navigator mouse that you have. The latest version included with Teensyduino should support the spacenavigator like this one - https://www.amazon.com/3Dconnexion-3.../dp/B000LB7G00). But it is a bit finicky.
  22. #147
    Aug 2020
    4
    Thanks for fast response.
    @KurtE: Arduino IDE 1.8.13, TeensyAddon 1.53.
    Libraries are loaded from (window 10):
    1st trial: "C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries"
    2nd trial: "C:\Users\muej\Documents\Arduino\libraries" (path of 1st trial disabled by rename it in windows explorer to "...librearies_old"
    ...both trials behave the same way (Error message)
    @MarkT your hint brought me one step further. I've #include "ILI9341_t3n.h" and the errors are gone. I just have some warnings:
    USBHost_viewer:484: warning: comparison between signed and unsigned integer expressions
    USBHost_viewer:541: warning: enumeration value 'UNKNOWN' not handled in switch
    USBHost_viewer:541: warning: enumeration value 'PS3_MOTION' not handled in switch
    USBHost_viewer:541: warning: enumeration value 'SpaceNav' not handled in switch
    Opening Teensy Loader...
    Sketch uses 106528 bytes (5%) of program storage space. Maximum is 2031616 bytes.
    Global variables use 139956 bytes (26%) of dynamic memory, leaving 384332 bytes for local variables. Maximum is 524288 bytes.
    @myj513: My one looks similar like your amazon link, but it is an older one. Nevertheless it works with a HID binding in Python, where I have to define vendor and product ID as followed: 0x46D, 0xC628
    The same ID's are also stored in the USBHost_t36\joystick.cpp (last entry), so I assume it should be supported
    @all: the SpaceNavigator is accessable as a HID device in Windows 10 and Python. I assume, it should behave like a regular HID Joystick with 6 axis.
    The example USBHost Example: "...\USBHost_t36-master\examples\Serial\Joystick.ino" compiles without error and warning, but serial monitor only shows
    USB Host Joystick Testing
    *** Show only changed fields mode ***
    *** Show All fields mode ***
    Only notify on Basic Axis changes
    Only notify on Full Axis changes
    Could anybody please check my wiring?
  23. #148
    12,648
    Posted this the other day - does it agree with the soldered ends?
    Seems to swap + and - from post #143 ????
  24. #149
    Aug 2020
    4
    @defragster:
    YES! you made my day.
    Green and white were swapped.
    Now it works
    Sample strings from USBHost_viewer
    SB Host Testing
    *** Device HID1 46d:c628 - connected ***
    *** HID Device joystick 46d:c628 - connected ***
    Joystick: buttons = 0 0:0 1:-2 2:0
    Joystick: buttons = 0 0:-14 1:-18 2:57
    Joystick: buttons = 0 0:0 1:8 2:17
    Joystick: buttons = 0 0:18 1:4 2:0
    Joystick: buttons = 0 0:8 1:0 2:0
    Joystick: buttons = 0 0:23 1:0 2:-18
    Sample from Joystick.ino
      manufacturer: 3Dconnexion
      product: SpaceNavigator for Notebooks
    *** HID Device joystick[0H] 46d:c628 - connected ***
    Joystick(0): buttons = 0 0:0 1:0 2:0
    Joystick(0): buttons = 0 3:0 4:0 5:1
    Joystick(0): buttons = 0 0:0 1:0 2:0 3:0 4:0 5:2
    Joystick(0): buttons = 0 0:0 1:0 2:0 3:0 4:0 5:4
    Joystick(0): buttons = 0 0:0 1:0 2:1
    Joystick(0): buttons = 0 3:0 4:0 5:2
    Joystick(0): buttons = 0 0:0 1:0 2:0 3:0 4:2 5:0
    Joystick(0): buttons = 0 0:0 1:0 2:0 3:0 4:0 5:0
    Joystick(0): buttons = 1
    Joystick(0): buttons = 2
    Thank you all guys for the support.
  25. #150
    12,648
    Awesome! Working is great - Glad to help
    Good to know I found and posted that Valid/Accurate cable color map!
