Results 1 to 4 of 4
Thread: Play MONO through both channels possible?
    Aug 2014
    138
    I have a circuit for sgtl5000 audio codec but have 2 amplifiers on left and right output. I can only get sound on one channel when using mono source file. Can I get it to play on both at same time?
    Otherwise, maybe just tie the pins together, but maybe noise, and I lose stereo capability. Wanted some tracks maybe mono, and sometimes stereo.
    //////////////////////// Audio Setup ///////////////////////////
    AudioPlaySdRaw raw4; //channel 4 playback
    AudioPlaySdRaw raw3; //channel 4 playback
    AudioPlaySdRaw raw2; //channel 4 playback
    AudioPlaySdRaw raw1; //channel 4 playback
    AudioMixer4 mixer1; //combines up to 4 channels, can play even more if needed by more mixers
    AudioOutputI2S i2s; //I2S type playback (opposed to I2C etc)
    AudioConnection patchCord1(raw4, 0, mixer1, 3);
    AudioConnection patchCord2(raw3, 0, mixer1, 2);
    AudioConnection patchCord3(raw2, 0, mixer1, 1);
    AudioConnection patchCord4(raw1, 0, mixer1, 0);
    AudioConnection patchCord5(mixer1, 0, i2s, 0);
    AudioControlSGTL5000 sgtl5000; //audio codec chip
    Nov 2017
    Belgium
    33
    Just add the following,
    AudioConnection patchCord6(mixer1, 0, i2s, 1);
    Aug 2014
    138
    Works perfectly!
    Thanks.
    I figured it was something not configured correctly in the library, didn't really see a place in the documentation on how to wire up stereo vs mono.
    18,355
    Several parts of the tutorial involve mono sound that's sent to both I2S channels. The first is in part 2-3 on page 14 of the PDF.
