damonpence
Using a Teensy 3.2 for this project I have built a Circle LED Display that has 385 LEDS and is 23x23 in size. Currently running only on 1 transmit channel of the Teensy due to being able to balance equal lines and LEDS for each of the 8 channels.
The code i am using is the Gediator Library.
const int ledsPerStrip = 385;
const int NUM_LEDS = 385;
I found a program patcher called NLED Patcher (http://www.nledshop.com/nledpatcher/) that allows to run non-square/rectangle displays. Still working to get it working correctly but is it possible to disable the other 7 channels on the Teensy so that the software I am using will only see the actual LEDS connected?
