We would really appreciate some help with finding a thermistor (and accompanying resistors) in order to do some current limiting in high-ambient temperatures. The circuit comes from the LT3741 datasheet (below).
LT3741 Datasheet Snip http://cds.linear.com/docs/en/datasheet/37411ff.pdf
Options A, B, C and D show different methods of use, some which would allow better linearization of the R-T curve, but it's still not exactly what we want.
The problem is that most NTC thermistors have the largest resistance differential at a temperature lower than our application. This means that we can't get a large enough range of resistance to be useful.
Vref is 2V, and CTRL2 should be 1.5V at 80°C, falling to ~0.075V at 100°C.
For example, if R2 was 120k, then the desired resistances of the thermistor would be 360k at 70 degrees C and 4.6k (or lower) at 100 degrees C. I can't seem to find any thermistors which such a great resistance differential at that range. By my calculations this is about a 28000 beta value. Most thermistors don't go above 5000.
Do I need an op-amp to increase the voltage change? I think this blog maybe useful to your analysis. It's about Thermistor Introduction--Temperature Sensitive Component: http://www.apogeeweb.net/article/38.html
I would welcome any advice on how to manipulate a standard thermistor such that we get a large resistance differential at these temperatures, or are there known thermistors which operate around this range for the resistance change we require?
