Non-blocking library for RGBW Neopixels
thomasp
Is there a non-blocking library option available I can use with RGBW Neopixels (i.e. LEDs that have a white LED element in addition to the 3 RGB elements)?
I looked at the WS2812Serial and OctoWS2811 libraries but they seem to only support RGB LEDs unless I am missing something.
Hi !
Same question here : I've tried to make a quick and dirty tweak on WS2812Serial to be able to drive my RGBW LED ring and I'm able to drive R, G and B elements but not W.
(@PaulStoffregen : sorry to destroy your code like this...)
If someone has an idea...
Please note that in this state, the included files are not meant to work with RGB pixels : only RGBW as I've quickly moved everything to integrate the 4th element...
WS2812SerialRGBW.cpp :
/*  WS2812Serial - Non-blocking WS2812 LED Display Library
    https://github.com/PaulStoffregen/WS2812Serial
    Copyright (c) 2017 Paul Stoffregen, PJRC.COM, LLC
    Permission is hereby granted, free of charge, to any person obtaining a copy
    of this software and associated documentation files (the "Software"), to deal
    in the Software without restriction, including without limitation the rights
    to use, copy, modify, merge, publish, distribute, sublicense, and/or sell
    copies of the Software, and to permit persons to whom the Software is
    furnished to do so, subject to the following conditions:
    The above copyright notice and this permission notice shall be included in
    all copies or substantial portions of the Software.
    THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
    IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
    FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
    AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
    LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
    OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN
    THE SOFTWARE.
#include "WS2812SerialRGBW.h"
bool WS2812SerialRGBW::begin()
	uint32_t divisor, portconfig, hwtrigger;
	KINETISK_UART_t *uart;
	switch (pin) {
#if defined(KINETISK) // Teensy 3.x
	  case 1: // Serial1
	  case 5:
	#if defined(__MK64FX512__) || defined(__MK66FX1M0__)
	  case 26:
		uart = &KINETISK_UART0;
		divisor = BAUD2DIV(4000000);
		portconfig = PORT_PCR_DSE | PORT_PCR_SRE | PORT_PCR_MUX(3);
		hwtrigger = DMAMUX_SOURCE_UART0_TX;
		SIM_SCGC4 |= SIM_SCGC4_UART0;
	  case 10: // Serial2
	#if defined(__MK20DX128__) || defined(__MK20DX256__)
	  case 31:
	#elif defined(__MK64FX512__) || defined(__MK66FX1M0__)
	  case 58:
		uart = &KINETISK_UART1;
		divisor = BAUD2DIV2(4000000);
		hwtrigger = DMAMUX_SOURCE_UART1_TX;
		SIM_SCGC4 |= SIM_SCGC4_UART1;
	  case 8: // Serial3
	  case 20:
		uart = &KINETISK_UART2;
		divisor = BAUD2DIV3(4000000);
		hwtrigger = DMAMUX_SOURCE_UART2_TX;
		SIM_SCGC4 |= SIM_SCGC4_UART2;
	  case 32: // Serial4
	  case 62:
		uart = &KINETISK_UART3;
		hwtrigger = DMAMUX_SOURCE_UART3_TX;
		SIM_SCGC4 |= SIM_SCGC4_UART3;
	  case 33: // Serial5
		uart = &KINETISK_UART4;
		hwtrigger = DMAMUX_SOURCE_UART4_RXTX;
		SIM_SCGC1 |= SIM_SCGC1_UART4;
	  case 48: // Serial6
		uart = &KINETISK_UART5;
		hwtrigger = DMAMUX_SOURCE_UART5_RXTX;
		SIM_SCGC1 |= SIM_SCGC1_UART5;
#elif defined(KINETISL)	// Teensy LC
	  case 1: // Serial1
	  case 5:
		divisor = 1;
	  case 4:
		divisor = 1;
		portconfig = PORT_PCR_DSE | PORT_PCR_SRE | PORT_PCR_MUX(2);
	  case 24:
		divisor = 1;
		portconfig = PORT_PCR_DSE | PORT_PCR_SRE | PORT_PCR_MUX(4);
	  default:
		return false; // pin not supported
	if (!dma) {
		dma = new DMAChannel;
		if (!dma) return false; // unable to allocate DMA channel
	uart->BDH = (divisor >> 13) & 0x1F;
	uart->BDL = (divisor >> 5) & 0xFF;
	uart->C4 = divisor & 0x1F;
	uart->BDH = (divisor >> 8) & 0x1F;
	uart->BDL = divisor & 0xFF;
	uart->C4 = 11;
	uart->C1 = 0;
	uart->C2 = UART_C2_TE | UART_C2_TIE;
	uart->C3 = UART_C3_TXINV;
	uart->C5 = UART_C5_TDMAS;
	uart->PFIFO = 0; // TODO: is this ok for Serial3-6?
	*(portConfigRegister(pin)) = portconfig;
	dma->destination(uart->D);
	dma->triggerAtHardwareEvent(hwtrigger);
	memset(drawBuffer, 0, numled * 4);
	return true;
void WS2812SerialRGBW::show()
	// wait if prior DMA still in progress
	while ((DMA_ERQ & (1 << dma->channel))) {
		yield();
	while ((dma->CFG->DCR & DMA_DCR_ERQ)) {
		yield();
	// copy drawing buffer to frame buffer
	const uint8_t *p = drawBuffer;
	const uint8_t *end = p + (numled * 4);
	uint8_t *fb = frameBuffer;
	while (p < end) {
		uint8_t b = *p++;
		uint8_t g = *p++;
		uint8_t r = *p++;
		uint8_t w = *p++;
		uint32_t n=0;
		switch (config) {
		  case WS2812_RGB: n = (r << 16) | (g << 8) | b; break;
		  case WS2812_RBG: n = (r << 16) | (b << 8) | g; break;
		  case WS2812_GRB: n = (g << 16) | (r << 8) | b; break;
		  case WS2812_GBR: n = (g << 16) | (b << 8) | r; break;
		  case WS2812_BRG: n = (b << 16) | (r << 8) | g; break;
		  case WS2812_BGR: n = (b << 16) | (g << 8) | r; break;
		  case WS2812_RGBW: n = (r << 24) | (g << 16) | (b << 8) | w; break;
		const uint8_t *stop = fb + 16;
		do {
			uint8_t x = 0x08;
			if (!(n & 0x00800000)) x |= 0x07;
			if (!(n & 0x00400000)) x |= 0xE0;
			n <<= 2;
			*fb++ = x;
		} while (fb < stop);
	// wait 300us WS2812 reset time
	uint32_t min_elapsed = (numled * 30) + 300;
	if (min_elapsed < 2500) min_elapsed = 2500;
	uint32_t m;
	while (1) {
		m = micros();
		if ((m - prior_micros) > min_elapsed) break;
		yield();
	prior_micros = m;
	// start DMA transfer to update LEDs  :-)
	dma->sourceBuffer(frameBuffer, numled * 16);
	dma->transferSize(1);
	dma->transferCount(numled * 16);
	dma->disableOnCompletion();
	dma->enable();
	dma->CFG->SAR = frameBuffer;
	dma->CFG->DSR_BCR = 0x01000000;
	dma->CFG->DSR_BCR = numled * 16;
	dma->CFG->DCR = DMA_DCR_ERQ | DMA_DCR_CS | DMA_DCR_SSIZE(1) |
		DMA_DCR_SINC | DMA_DCR_DSIZE(1) | DMA_DCR_D_REQ;
WS2812SerialRGBW.h :
    THE SOFTWARE.
#ifndef WS2812SerialRGBW_h_
#define WS2812SerialRGBW_h_
#include <Arduino.h>
#include "DMAChannel.h"
#define WS2812_RGB      0       // The WS2811 datasheet documents this way
#define WS2812_RBG      1
#define WS2812_GRB      2       // Most LED strips are wired this way
#define WS2812_GBR      3
#define WS2812_BRG      4
#define WS2812_BGR      5
#define WS2812_RGBW     6
class WS2812SerialRGBW {
public:
	constexpr WS2812SerialRGBW(uint16_t num, void *fb, void *db, uint8_t pin, uint8_t cfg) :
		numled(num), pin(pin), config(cfg),
		frameBuffer((uint8_t *)fb), drawBuffer((uint8_t *)db) {
	bool begin();
	void setPixel(uint32_t num, int color) {
		if (num >= numled) return;
		num *= 4;
		drawBuffer[num+0] = color & 255;
		drawBuffer[num+1] = (color >> 8) & 255;
		drawBuffer[num+2] = (color >> 16) & 255;
		drawBuffer[num+3] = (color >> 24) & 255;
	void setPixel(uint32_t num, uint8_t red, uint8_t green, uint8_t blue, uint8_t white) {
		num *= 4;
		drawBuffer[num+0] = blue;
		drawBuffer[num+1] = green;
		drawBuffer[num+2] = red;
		drawBuffer[num+3] = white;
	void show();
	bool busy();
	uint16_t numPixels() {
		return numled;
private:
	const uint16_t numled;
	const uint8_t pin;
	const uint8_t config;
	uint8_t *frameBuffer;
	uint8_t *drawBuffer;
	DMAChannel *dma = nullptr;
	uint32_t prior_micros = 0;
Regards,
Jérémie
