Results 1 to 4 of 4
Thread: Can't get signal into AudioInputAnalog on teensy3.0
    May 2016
    Nice France, (but I'm British)
    5
    Hi, I can't seem to get audio into teensy3.0. (analog pin A2)
    Is the AudioInputAnalog object supported by teensy3.0?
    I've created a custom pcb folowing the schematic presented in the GUI.
    I have connected Agnd and ground (not sure why). Could that prevent the AudioInputAnalog object from working?
    I'll try disconnecting the traces linking Agnd and Gnd or breadboarding a new input circuit,
    but first wanted to check that is wasn't a teensy3.0 thing
    For code I'm using this (pt8211 works fine)
    AudioInputAnalog adc1; //xy=272,262
    AudioOutputPT8211 pt8211_1; //xy=534,301
    AudioConnection patchCord1(adc1, 0, pt8211_1, 0);
    AudioConnection patchCord2(adc1, 0, pt8211_1, 1);
    Thanks in advance
    Alex
    19,934
    Please post the complete program, even if it seems trivial. "Complete" means it can be copied into Arduino and I can upload it to a Teensy 3.0 here.
    May 2016
    5
    Thanks for your response, sorry here is the full code
    and here is the schematic I'm working with https://ibb.co/iQxqbw
    // Audio connections require memory to work. For more
    AudioMemory(12);
    // Do nothing here. The Audio flows automatically
    // When AudioInputAnalog is running, analogRead() must NOT be used.
    Alex
    May 2016
    5
    Solved! I breadboarded the circuit and all is fine, must be something up with my PCB. ADC Audio in working fine on Teensy 3.0!
