Hi, I'm a complete noob when it comes to using LED strips and microcontrollers so any help would be SUPER appreciated.
I have:
1 AdaFruit DotStar 30 LED/m strip with these connections on the "in" end - VCC, CI, DI, GND - no wire
And on the "out" end - VCC, CO, DO, GND - these are all connected to 6 wires, 4 (red, yellow, green, black respectively) of them join to a plastic connector with 4 pins, and then there are just 2 other wires (black, red)
1 Teensy 3.2 connected to a PJRC Prop Shield
What should I connect to what?
Thank you so much for any help!
Edit: I am guessing it is this (?)
CI to C pin
DI to D pin
but I have read that pins 7, 11, and 13 are used for sending LED data and I do not know what to connect those to.
I have:
CI to C pin
DI to D pin
