I'm using a Raspberry Pi with Adafruit_PCA9685 library to talk to the I2C bus.
I'm using 2 kOhm pull-ups.
I'm using a Teensy3.2 to emulate the PCA9685 PWM controller part, by forwarding the first two channels of this part to two Servo instances.
The Raspberry Pi occasionally generates I/O Errors:
Looking at the bus with a scope, it seems as if someone (Pi or Teensy) is holding the SDA signal of the bus low for several milliseconds, and this causes the I/O error.
What can cause this error? How can I fix it?
Here's my sketch and PCAEmulation files:
Traceback (most recent call last):
File "test_pca.py", line 13, in <module>
pwm.set_pwm(0, 0, i)
File "build/bdist.linux-armv7l/egg/Adafruit_PCA9685/PCA9685.py", line 107, in set_pwm
File "build/bdist.linux-armv7l/egg/Adafruit_GPIO/I2C.py", line 115, in write8
File "build/bdist.linux-armv7l/egg/Adafruit_PureIO/smbus.py", line 236, in write_byte_data
IOError: [Errno 121] Remote I/O error
import time
import Adafruit_PCA9685 as P
pwm = P.PCA9685()
pwm.set_pwm_freq(60)
while True:
for i in range(300, 400):
pwm.set_pwm(1, 0, 380)
time.sleep(0.05)
for i in range(400, 300, -1):
pwm.set_pwm(1, 0, 390)
time.sleep(0.05)
#include "PCA9685Emulator.h"
#include <Servo.h>
PCA9685Emulator pwmEmulation;
Servo svoSteer;
Servo svoThrottle;
pinMode(PIN_STEER_OUT, OUTPUT);
svoSteer.attach(PIN_STEER_OUT);
pinMode(PIN_THROTTLE_OUT, OUTPUT);
svoThrottle.attach(PIN_THROTTLE_OUT);
pwmEmulation.begin(PCA9685_I2C_ADDRESS);
pwmEmulation.step(millis());
svoSteer.writeMicroseconds(pwmEmulation.readChannelUs(0));
svoThrottle.writeMicroseconds(pwmEmulation.readChannelUs(1));
#define PCA9685_I2C_ADDRESS 0x40
class PCA9685Emulator {
public:
PCA9685Emulator();
void begin(uint8_t address);
// Return true if there are new values
bool step(uint32_t now);
// Return servo PWM value in microseconds
uint16_t readChannelUs(uint16_t ch);
void onRequest2();
void onReceive2(int n);
static void onRequest();
static void onReceive(int n);
static PCA9685Emulator *active; // only one can be active at a time
enum {
NUM_CHANNELS = 16
uint8_t mem[6+NUM_CHANNELS*4];
uint8_t wptr;
bool gotwrite;
#include <Arduino.h>
static const uint8_t MODE1 = 0x00;
static const uint8_t MODE2 = 0x01;
static const uint8_t SUBADR1 = 0x02;
static const uint8_t SUBADR2 = 0x03;
static const uint8_t SUBADR3 = 0x04;
static const uint8_t FAKE_PRESCALE = 0x05;
static const uint8_t LED0_ON_L = 0x06;
static const uint8_t LED0_ON_H = 0x07;
static const uint8_t LED0_OFF_L = 0x08;
static const uint8_t LED0_OFF_H = 0x09;
static const uint8_t ALL_LED_ON_L = 0xFA;
static const uint8_t ALL_LED_ON_H = 0xFB;
static const uint8_t ALL_LED_OFF_L = 0xFC;
static const uint8_t ALL_LED_OFF_H = 0xFD;
static const uint8_t PRESCALE = 0xFE;
static const uint8_t SWRESET = 0x06;
static const uint8_t RESTART = 0x80;
static const uint8_t SLEEP = 0x10;
static const uint8_t ALLCALL = 0x01;
static const uint8_t INVRT = 0x10;
static const uint8_t OUTDRV = 0x04;
PCA9685Emulator *PCA9685Emulator::active;
PCA9685Emulator::PCA9685Emulator()
wptr = 0;
gotwrite = false;
void PCA9685Emulator::begin(uint8_t address)
active = this;
Wire.begin(address);
Wire.onRequest(onRequest);
Wire.onReceive(onReceive);
bool PCA9685Emulator::step(uint32_t now)
bool ret;
cli();
ret = gotwrite;
gotwrite = false;
sei();
return ret;
uint16_t PCA9685Emulator::readChannelUs(uint16_t ch) {
if (ch >= NUM_CHANNELS) {
return 0xffff;
uint16_t ret;
cli();
if ((mem[MODE1] & SLEEP) || !(mem[MODE2] & OUTDRV)) {
ret = 0;
sei();
uint32_t l_on_0 = mem[LED0_ON_L+4*ch];
uint32_t h_on_0 = mem[LED0_ON_H+4*ch];
uint32_t l_off_0 = mem[LED0_OFF_L+4*ch];
uint32_t h_off_0 = mem[LED0_OFF_H+4*ch];
uint32_t ps = mem[FAKE_PRESCALE] + 1;
sei();
ret = ((l_off_0 + (h_off_0 << 8)) - (l_on_0 + (h_on_0 << 8))) * ps / 25ul;
return ret;
void PCA9685Emulator::onRequest()
active->onRequest2();
void PCA9685Emulator::onRequest2()
// only support returning a single byte
if (wptr < sizeof(mem)) {
Wire.send(mem[wptr&0xf]);
Wire.send(0xff);
void PCA9685Emulator::onReceive(int received)
active->onReceive2(received);
void PCA9685Emulator::onReceive2(int received)
// Empty the pipe within the interrupt request, to
// make sure I don't race with the step() function.
if (received != 0) {
if (received == 1) {
// a command
wptr = Wire.read();
if (wptr == SWRESET) {
// software reset -- I don't care?
// a write
gotwrite = true;
wptr = Wire.read();
--received;
while (received > 0) {
unsigned char rb = Wire.read();
mem[wptr] = rb;
} else if (wptr == PRESCALE) {
mem[FAKE_PRESCALE] = rb;
(void)rb;
++wptr;
--received;
