is 2 Mbaud supported on T_3.6 at 24 Mhz
defragster
Senior Member+
I have two Teensy's connected Serial1 [ T_3.6 ] to Serial1 [ T_3.0 ] and they work at 2,000,000 baud when running at 48, 180 or 240 MHz.
When I compile at 24 MHz on the T_3.6 with the T_3.0 code unchanged - the T_3.0 acting as PROXY to a second USB (for Serial1 debug) it no longer gets valid data.
Is 2 Mbaud mathematically possible on T_3.6 at 24 MHz? Or is there a problem in the core math?
Here is a Sketch to output Serial1 data at 2Mbaud that works at 48 MHz on T_3.6 (compiled Fastest with TD_1.41b4) , but shows USB garbage through PROXY Teensy:
#define PROXY_SER Serial1
#define PROXY_BAUD 2000000
void yield() {}; // Void yield() to bypass default PJRC yield overhead
  // serial to display data
  PROXY_SER.begin( PROXY_BAUD );
  PROXY_SER.println("\n"__FILE__" "__DATE__" "__TIME__);
  Serial.println("\n"__FILE__" "__DATE__" "__TIME__);
  pinMode(LED_BUILTIN, OUTPUT);
elapsedMillis foo;
  if ( foo >= 1000) {
    PROXY_SER.println( micros() );
    Serial.println( micros() );
    foo -= 1000;
Here is what I see for 'garbage' in TyComm - the micros printed are at 48 MHz - then garbage when recompiled at 24 MHz:
19400002
20400002
21400002
4Ä���ۄ������4�D�tÄôG���
SerMon version of the garbage is this: "⸮⸮⸮4⸮⸮⸮⸮⸮⸮⸮⸮۴G۴G8⸮۴G۴G⸮G۴G۴G;⸮۴G۴GGG۴G۴G<⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮"
If I had a logic analyzer I'd hook that up to see what is happening.
The PROXY code in use { I posted here } it is this:
  char inChar;
  if ( Serial.available() )
    PROXY_SER.print( inChar = Serial.read() );
  if ( PROXY_SER.available() )
    Serial.print( inChar = PROXY_SER.read() );
Nope, not possible on Serial1. 1.5 Mbps is the max when running at 24 MHz.
More specifically, the max baud rate is F_CPU/16 on Serial1 & Serial2, and F_BUS/16 on Serial3-Serial5.
However, Serial6 on Teensy 3.6 (and Serial1 on Teensy LC) has a special hardware feature to configure the UART's oversampling ratio. I believe Serial6 can give you 1.5 Mbps, but I haven't personally tested this.
Good info, Thanks Paul.
Just incidental - rather than monitoring free CPU time for the linked Kalman filter work - I decided just to drop the speed to see it work, and set up the debug Serial to work around a JAVA app plotting data on USB.
