Page 11 of 28 FirstFirst ... 9 10 11 12 13 21 ... LastLast
Results 251 to 275 of 683
Thread: T3.6 USB Host - Bluetooth
  1. #251
    5,043
    @mjs513 and @defragster and others who may like to play around,
    I pushed up the at least start for PS3 Bluetooth support.
    Note: I don't have any PS3 pairing support built in yet... I first did a bind of a Bluetooth dongle and a PS3 using an RPI3 and the sixpair program to program the PS3.
    I updated the JoystickBT example app to know if the device connecting is a PS3, it uses a different display and process function, which by default is only showing a subset of the information.
    Will add more soon,
    Also I put code on when you press the L3 button (That is the press the left joystick in to click), where it toggles it output raw full data instead.
    Also some of the rumble and leds is limping along, Still needs to be cleaned up.
    Would maybe like to go back now and see if I can find place in pairing code that we can ask for remote name and use it... Also would like to go through as mentioned and remove delays...
    And cleanup some more stuff...
    But though I would put it up there so someone could start playing with it.
    As for being the only Joysticks... The are the only BT versions so far, did at one point have XBox360 and XBoxOne I think with USB... Will look again at BT once the one I ordered arrives. Also can always configure another Teensy to be a joystick as well (USB)
    May check the actual one I have as well.
  2. #252
    Senior Member+
    New York
    3,670
    @KurtE and @defragster
    Think I got everything that a PS4 can offer going now. Attached is an updated JoystickBT sketch that includes a helperPS.h tab as a proof of concept. Again this is just a test - not final:
    JoystickBT.zip
    Quote Originally Posted by KurtE
    Will add more soon,
    Will take a look either tonight or tomorrow morning before everyone gets up
    can't seem to find sixaxis for windows anywhere.
  3. #253
    5,043
    Doing a quick look for sixpair...
    I see links for windows: http://dancingpixelstudios.com/sixax...xaxispairtool/
    https://sixaxispairtool.en.lo4d.com/
    The sources I used I believe came from: https://github.com/strawlab/joystick.../master/ps3joy
    Although not sure... Obviously would be great to setup a Teensy version, which maybe first you plug in BT dongle and it reads in the address of it, then
    you plug in the PS3, and it updates the firmware... And maybe it optionally can detect that both are there (HUB) and then does it...
  4. #254
    9,022
    For my PS3 Bt Joystick this seemed to work ?
    The first p#253 WIN link downloaded - took my BT Ser# for PanBT400 {luckily It was printed on the USB output!}
    Tried with KE github and post 252 ZIP joystickBT.ino - I see this - and no more after ... need I push a button?:
    04 0A 25 63 74 B5 39 03 40 05 00 01
    BluetoothController::find_driver  driver 1fff4a38
        control callback (bluetooth) 0
    0F 04 00 01 19 04
    07 FF 00 25 63 74 B5 39 03 50 4C 41 59 53 54 41
    54 49 4F 4E 28 52 29 33 43 6F 6E 74 65 72 6F 6C
    6C 65 72 2D 50 41 4E 48 41 49 00 00 00 00 00 00
    00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    00
    0F 04 00 01 09 04
    12 08 00 25 63 74 B5 39 03 00
    03 0B 00 0B 00 25 63 74 B5 39 03 01 00
    1B 03 0B 00 05
        tx_data(bluetooth) 0
    13 05 01 0B 00 02 00
    0E 04 01 1A 0C 00
    13 05 01 0B 00 01 00
    I swapped to the CSR 4.0 unit and I get nothing - good I didn't start with that one - the Ser# is not printed by Teensy:
    *** Device Bluet a12:1 - connected ***
    product: CSR8510 A10
    So it seems that app pushes in a valid Ser# for Pre-Binding as I ran the sketch with this line:: BluetoothController bluet(myusb);
    BTW: Also re-routed the Amazon AC Powered USB3 HUB to reach the T_3.6 and have that HUB on - and the hub and PANBT400 adapter ( the one with the Vend Specific flag) properly recognized and then so was the PS3 JoystickBt!
  5. #255
    5,043
    @mjs513 - Pairing the PS3 with BT Dongle... You of course currently have another option, which I have not tried, and use your HS2 setup. When I was briefly looking at it, you have to run something with the BT dongle in it and write down the bluetooth address, you then run a version of the PS3 program with the PS3 constructor having this address as part of it's parameters, then I assume you run it with the PS3 plugged in as USB, at which point I assume it will program the PS3 with the address...
    At some point, I was thinking about emulating this, but differently, and have an example sketch (sixpair), which waits for a BT object to be valid. Then ask this object for it's BT address, then have the program wait for a PS3 joystick to be valid, and when found use the address to program it...
    @defragster - yes once a PS3 is paired to a dongle, you need to press the PS button, to get it to start the connection process.
    Right now still getting some coffee in me orally and doing some attempt(s) to get the remote name in the pair case... Plus hopefully try delay changes soon...
    Then need to look at Mike's Joysticks changes and...
  6. #256
    Senior Member+
    New York
    3,670
    I got a version of sixaxis pairing tool working and was able to change the address on the PS3. It does pair with the two dongles I tried on HS2 but it does pair with USBHost lib. Tim got a lot farther that I did with the pairing. With my CSR4.0 dongle it gets through write scan complete and then nothing:
    D:\Users\Merli\Documents\Arduino\EchoBoth\EchoBoth.ino Feb 21 2019 06:54:04
     PORT Serial1 and BAUD=1843200
    BluetoothController claim this=1fff3be0 vid:pid=a12:1
        9 4 0 0 3 e0 1 1 0 7 5 81 3 10 0 1 7 5 2 2 40 0 1 7 5 82 2 40 0 1 9 4 1 0 2 e0 1 1 0 7 5 3 1 0 0 1 7 5 83 1 0 0 1 9 4 1 1 2 e0 1 1 0 7 5
        3 1 9 0 1 7 5 83 1 9 0 1 9 4 1 2 2 e0 1 1 0 7 5 3 1 11 0 1 7 5 83 1 11 0 1 9 4 1 3 2 e0 1 1 0 7 5 3 1 19 0 1 7 5 83 1 19 0 1 9 4 1 4 2 e0
        1 1 0 7 5 3 1 21 0 1 7 5 83 1 21 0 1 9 4 1 5 2 e0 1 1 0 7 5 3 1 31 0 1 7 5 83 1 31 0 1
          rxep=1(16) txep=2(64) rx2ep=2(64)
    HCI_RESET called (03 0c 00 )
        Control callback (bluetooth): 1 : 3 c 0
    BT rx_data(6): e 4 1 3 c 0
        Command Completed!
    HCI_WRITE_CLASS_OF_DEV called (24 0c 03 04 08 00 )
        Control callback (bluetooth): 3 : 24 c 3 4 8 0
    BT rx_data(6): e 4 1 24 c 0
        Command Completed!
    HCI_Read_BD_ADDR called (09 10 00 )
        Control callback (bluetooth): 4 : 9 10 0
    BT rx_data(12): e a 1 9 10 0 11 71 da 7d 1a 0
        Command Completed!
       BD Addr:11:71:da:7d:1a:0
    HCI_Read_Local_Version_Information called (01 10 00 )
        Control callback (bluetooth): 4 : 1 10 0
    BT rx_data(14): e c 1 1 10 0 6 bb 22 6 a 0 bb 22
        Command Completed!
        Local Version: 6
    HCI_WRITE_SCAN_ENABLE called(1a 0c 01 02 )
        Control callback (bluetooth): 0 : 1a c 1 2
    BT rx_data(6): e 4 1 1a c 0
        Command Completed!
    Write_Scan_enable Completed
    tedBT rx_data(12): 4 a 1e d4 f7 5c 26 0 40 5 0 1
        Event: Incoming Connect -  1e:d4:f7:5c:26:0 CL:540 LT:1
          Peripheral device
            Keyboard
    BluetoothController::find_driver  driver 1fff44f8
    HCI_OP_REMOTE_NAME_REQ called (19 04 0a 1e d4 f7 5c 26 00 01 00 00 00 )
        Control callback (bluetooth): 0 : 19 4 a 1e d4 f7 5c 26 0 1 0 0 0
    BT rx_data(6): f 4 0 1 19 4
        Command 419 Status 0
    BT rx_data(16): 7 ff 0 1e d4 f7 5c 26 0 50 4c 41 59 53 54 41
    BT rx_data(16): 54 49 4f 4e 28 52 29 33 20 43 6f 6e 74 72 6f 6c
    BT rx_data(16): 6c 65 72 0 0 0 0 0 0 0 0 0 0 0 0 0
    BT rx_data(16): 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
    BT rx_data(1): 0
        Event: handle_hci_remote_name_complete(0)
        Remote Name: PLAYSTATION(R)3 Controller
    HCI_OP_ACCEPT_CONN_REQ called (09 04 07 1e d4 f7 5c 26 00 00 )
        Control callback (bluetooth): 0 : 9 4 7 1e d4 f7 5c 26 0 0
    BT rx_data(6): f 4 0 1 9 4
        Command 409 Status 0
    BT rx_data(10): 12 8 0 1e d4 f7 5c 26 0 0
    BT rx_data(13): 3 b 0 48 0 1e d4 f7 5c 26 0 1 0
        Connection Complete - ST:0 LH:48
    BT rx_data(9): 20 7 1e d4 f7 5c 26 0 1
    BT rx2_data(16): 48 20 c 0 8 0 1 0 2 1 4 0 11 0 40 0
        L2CAP Connection Request: ID: 1, PSM: 11, SCID: 40
    L2CAP_CMD_CONNECTION_RESPONSE called(48 20 10 00 0c 00 01 00 03 01 08 00 70 00 40 00 01 00 00 00 )
    tx_data callback (bluetooth): 201 : 48 20 10 0 c 0 1 0 3 1 8 0 70 0 40 0 1 0 0 0
    L2CAP_CMD_CONNECTION_RESPONSE called(48 20 10 00 0c 00 01 00 03 01 08 00 70 00 40 00 00 00 00 00 )
    tx_data callback (bluetooth): 202 : 48 20 10 0 c 0 1 0 3 1 8 0 70 0 40 0 0 0 0 0
    L2CAP_ConfigRequest called(48 20 10 00 0c 00 01 00 04 02 08 00 40 00 00 00 01 02 ff ff )
    tx_data callback (bluetooth): 0 : 48 20 10 0 c 0 1 0 4 2 8 0 40 0 0 0 1 2 ff ff
    BT rx_data(5): 1b 3 48 0 5
    BT rx_data(7): 13 5 1 48 0 1 0
    BT rx2_data(16): 48 20 c 0 8 0 1 0 4 2 4 0 70 0 0 0
        L2CAP config Request: ID: 2, Dest:70, Flags:0,  Options: 0 0 0 0
          Control Configuration request
    L2CAP_ConfigResponse called(48 20 12 00 0e 00 01 00 05 02 0a 00 40 00 00 00 00 00 01 02 a0 02 )
    BT rx2_data(22): 48 20 12 0 e 0 1 0 5 2 a 0 70 0 0 0 0 0 1 2 a0 2
        L2CAP config Response: ID: 2, Source:70, Flags:0, Result:0, Config: 201
    Set HID Protocol 0 (48 20 05 00 01 00 40 00 70 )
    tx_data callback (bluetooth): 0 : 48 20 5 0 1 0 40 0 70 2 a 0 40 0 0 0 0 0 1 2 a0 2
    BT rx2_data(16): 48 20 c 0 8 0 1 0 2 3 4 0 13 0 41 0
        L2CAP Connection Request: ID: 3, PSM: 13, SCID: 41
    L2CAP_CMD_CONNECTION_RESPONSE called(48 20 10 00 0c 00 01 00 03 03 08 00 71 00 41 00 01 00 00 00 )
    tx_data callback (bluetooth): 203 : 48 20 10 0 c 0 1 0 3 3 8 0 71 0 41 0 1 0 0 0
    L2CAP_CMD_CONNECTION_RESPONSE called(48 20 10 00 0c 00 01 00 03 03 08 00 71 00 41 00 00 00 00 00 )
    tx_data callback (bluetooth): 204 : 48 20 10 0 c 0 1 0 3 3 8 0 71 0 41 0 0 0 0 0
    L2CAP_ConfigRequest called(48 20 10 00 0c 00 01 00 04 04 08 00 41 00 00 00 01 02 ff ff )
    tx_data callback (bluetooth): 0 : 48 20 10 0 c 0 1 0 4 4 8 0 41 0 0 0 1 2 ff ff
    BT rx2_data(16): 48 20 c 0 8 0 1 0 4 4 4 0 71 0 0 0
        L2CAP config Request: ID: 4, Dest:71, Flags:0,  Options: 0 0 1 2
          Interrupt Configuration request
    L2CAP_ConfigResponse called(48 20 12 00 0e 00 01 00 05 04 0a 00 41 00 00 00 00 00 01 02 a0 02 )
    BT rx2_data(22): 48 20 12 0 e 0 1 0 5 4 a 0 71 0 0 0 0 0 1 2 a0 2
        L2CAP config Response: ID: 4, Source:71, Flags:0, Result:0, Config: 201
    tx_data callback (bluetooth): 0 : 1a c 1 2 e 0 1 0 5 4 a 0 41 0 0 0 0 0 1 2 a0 2
        Command Completed!
    ted
    EDIT: With the Broadcom dongle it gets about one line further:
    BT rx_data(7): 13 5 1 b 0 1 0
     0
  7. #257
    Senior Member+
    New York
    3,670
    I am doing about the same. Wife and my little yorkie got up early to make me breakfast since its my birthday, killed my morning, but was nice. Now everyone is back to sleep and I get to play.
    My changes is just a proof of concept and should just be a plug and play to your sketch.
  8. #258
    5,043
    Hi @mjs513... Is this using the stuff I checked in?
    I will start with another dongle soon and see if something is strange...
    The thing I am noticing on quick check is: Set HID Protocol 0 (48 20 05 00 01 00 40 00 70 )
    I believe there is code in place to suppress this output for PS3...
    Maybe need to check if the String compare for Remote Name: PLAYSTATION(R)3 Controller
    is correct or we need to change it slightly?
  9. #259
    Senior Member+
    New York
    3,670
    Morning @KurtE.
    It should be - I just updated 3 files - USBHost_t36, Bluetooth and Joystick files. Think those were the only ones that changed.
    Just for ref I ran a partial dump for the PS3 on HS2:
    PS3 Bluetooth Library Started
    Bluetooth Dongle Initialized
    HCI Reset complete
    Write class of device
    Local Bluetooth Address: 5C:F3:70:7A:1C:C9
    Wait For Incoming Connection Request
    Keyboard is connecting
    Connected to Device: 00:26:5C:F7:D4:1E
    HID Control Incoming Connection Request
    L2CAP_COMMAND: 0x0B - Channel ID: 00 01
     Data:  0B 20 10 00 0C 00 01 00 03 01 08 00 40 00 40 00 01 00 00 00
     Data:  0B 20 10 00 0C 00 01 00 03 01 08 00 40 00 40 00 00 00 00 00
     Data:  0B 20 10 00 0C 00 01 00 04 02 08 00 40 00 00 00 01 02 FF FF
     Data:  0B 20 12 00 0E 00 01 00 05 02 0A 00 40 00 00 00 00 00 01 02 A0 02
    HID Control Successfully Configured
    HID Interrupt Incoming Connection Request
     Data:  0B 20 10 00 0C 00 01 00 03 03 08 00 41 00 41 00 01 00 00 00
     Data:  0B 20 10 00 0C 00 01 00 03 03 08 00 41 00 41 00 00 00 00 00
     Data:  0B 20 10 00 0C 00 01 00 04 04 08 00 41 00 00 00 01 02 FF FF
     Data:  0B 20 12 00 0E 00 01 00 05 04 0A 00 41 00 00 00 00 00 01 02 A0 02
    HID Interrupt Successfully Configured
    L2CAP_COMMAND: 0x0B - Channel ID: 00 40
     Data:  0B 20 0A 00 06 00 40 00 53 F4 42 03 00 00
    Dualshock 3 Controller Enabled
     Data:  0B 20 36 00 32 00 40 00 52 01 00 00 00 00 00 00 00 00 00 02 FF 27 10 00 32 FF 27 10 00 32 FF 27 10 00 32 FF 27 10 00 32 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
  10. #260
    5,043
    Hi Mike,
    You might try changing:
    void JoystickController::remoteNameComplete(const uint8_t *remoteName)
    	// Sort of a hack, but try to map the name given from remote to a type...
    	if (!remoteName) return;
    	if (strncmp((const char *)remoteName, "Wireless Controller", 19) == 0) {
    		DBGPrintf("  JoystickController::remoteNameComplete %s - set to PS4\n", remoteName);
    		special_process_required = SP_NEED_CONNECT; 		// We need to force this.
    		joystickType = PS4;
    	} else if (strncmp((const char *)remoteName, "PLAYSTATION(R)3 Controller", 26) == 0) {
    		DBGPrintf("  JoystickController::remoteNameComplete %s - set to PS3\n", remoteName);
    		special_process_required = SP_PS3_IDS; 		// PS3 maybe needs different IDS.
    		joystickType = PS3;
    		DBGPrintf("  JoystickController::remoteNameComplete %s - Unknown\n", remoteName);
    And see if we are not matching the name? It looks correct, but ???
    Edit, maybe change above to something likeBGPrintf(" JoystickController::remoteNameComplete (%s) - Unknown\n", remoteName);
    And/or also print out the length of the string passed in...
  11. #261
    Senior Member+
    New York
    3,670
    Kurt - Tim
    I just noticed something interesting as well in what I posted, the PS3 is being identified as a Keyboard?
          Peripheral device
            Keyboard
    EDIT: Posts crossed - will take a look - have a quick errand to do Including getting more coffee
  12. #262
    Senior Member+
    New York
    3,670
    Ok - added it but don't think it ever gets that far to call remotename:
    This call is never happening:
    	if (device_driver_) {
    		device_driver_->remoteNameComplete(&rxbuf_[9]);
    		if (device_driver_->special_process_required & BTHIDInput::SP_PS3_IDS) {
    			DBGPrintf("PS3 IDENTIFIED & remoteNameComplete called === > \n");
    			// Real hack see if PS3...
    	    	control_dcid_ = 0x40;
    	    	interrupt_dcid_ = 0x41;
  13. #263
    5,043
    Yep - that looks interesting, mine starts off like:
    BT rx_data(12): 4 a 8d cc 2d 33 24 0 8 5 0 1
        Event: Incoming Connect -  8d:cc:2d:33:24:0 CL:508 LT:1
          Peripheral device
            Gamepad
    BluetoothController::find_driver  driver 20004e18
    JoystickController::claim_bluetooth TRUE
        *** Claimed ***
    HCI_OP_REMOTE_NAME_REQ called (19 04 0a 8d cc 2d 33 24 00 01 00 00 00 )
        Control callback (bluetooth): 0 : 19 4 a 8d cc 2d 33 24 0 1 0 0 0
    BT rx_data(16): 7 ff 0 8d cc 2d 33 24 0 50 4c 41 59 53 54 41
    BT rx_data(1): 0
      JoystickController::remoteNameComplete PLAYSTATION(R)3 Controller - set to PS3
    Question is how to catch this? Currently the claim code is singular... by class:
    bool JoystickController::claim_bluetooth(BluetoothController *driver, uint32_t bluetooth_class)
    	if ((((bluetooth_class & 0xff00) == 0x2500) || (((bluetooth_class & 0xff00) == 0x500))) && ((bluetooth_class & 0x3C) == 0x08)) {
    		DBGPrintf("JoystickController::claim_bluetooth TRUE\n");
    		btdriver_ = driver;
    		btdevice = (Device_t*)driver;	// remember this way
    		return true;
    	return false;
    And Happy Birthday!
  14. #264
    Senior Member+
    New York
    3,670
    Right now I am picking up the controller as a class of 540 vs your 508. My ps3 is identified as a Dualshock PS3 - not sure if that makes a difference. Can't really tell what Tim is getting from his dump yet. Anyway, maybe we need to add a correction for class 540?
  15. #265
    5,043
    The problem is that 540 will typically be claimed by Keyboard, which does:
    bool KeyboardController::claim_bluetooth(BluetoothController *driver, uint32_t bluetooth_class)
    	USBHDBGSerial.printf("Keyboard Controller::claim_bluetooth - Class %x\n", bluetooth_class);
    	if ((((bluetooth_class & 0xff00) == 0x2500) || (((bluetooth_class & 0xff00) == 0x500))) && (bluetooth_class & 0x40)) {
    		USBHDBGSerial.printf("KeyboardController::claim_bluetooth TRUE\n");
    		//btdevice = driver;
    		return true;
    	return false;
    Which you are not seeing as you don't have keyboard object in this sketch... Temporarily to see if everything else works with yours... You could hack it up to also support 0x540...
    Right now I am thinking of doing a set of real hacks...
    That is, something like:
    Have the cliam_bluetooth code work sort of like now, but add on another parameter (Name), which in this first case will be NULL...
    Then when we get the name complete, allow the remoteNameComplete to return a value (like false - default is true), and have keyboard check for the PS3 and return false.
    Then in the place that sent out: remoteNameComplete, if either no one has claimed it yet (or) the one who claimed it, has now rejected it, then call off to
    again to claim_bluetooth - with the name, at which point keyboard will reject again and/or if joystick sees it first again check for PLAYSTATION and go ahead and accept.
    Not sure if it again needs to call off to remoteNameComplete or not...
    Again sort of a kludge, but maybe there will be other cases where this comes up...
  16. #266
    Senior Member+
    New York
    3,670
    @KurtE
    Sounds a lot better than my approach. At least yours make more sense in the longer term.
  17. #267
    5,043
    I will hack it in...
    @defragster and @mjs513 - which clone PS3 controller do you have... I think all of mine may be Sony...
    May have to pick up another cheap one, I see the have a few real cheap ones like:
    https://smile.amazon.com/dp/B06XDPQYB9
    https://smile.amazon.com/Bek-Design-.../dp/B073CLJH8J
    Wonder if any of these cheap ones have an update firmware setup... I know I saw that for some PS4 controllers...
  18. #268
    Senior Member+
    New York
    3,670
  19. #269
    5,043
    I pushed up a hack like I mentioned. I did a quick and dirty test PS3 still runs... Have not tried other things yet...
    Ordered a single PS3 (same link, but to the single option)...
  20. #270
    9,022
    Happy Birthday Mike!
    My unit is JAMSWALL PS3 Controller Wireless,Bluetooth Dualshock3 Gamepad Joystick note on back shows model # CECHZC2U
    'Hardware under test for Teensy devices with USB_HOST ports' is post #128 - I see Mjs513 not Sr+ yet.
  21. #271
    Senior Member+
    New York
    3,670
    Hi Tim = Kurt
    Thanks for the birthday wishes Officially a senior citizen today (65, argh). Anyway back to work
    Nope not SR+ member yet - I did send Robin an email though - shes probably got her hands full out there.
    Kurt - just gave you changes a try for the PS3 and nothing - I mean it never connects to the dongle - just keeps blinking. BUt the good news is that the PS4 still works.
    EDIT: It does still connect using HS2 though so its not the pairing
  22. #272
    5,043
    Good Morning @defragster...
    I ordered one of Mikes and another cheap one: https://www.amazon.com/Crifeir-Wirel...B079DBP6WK/ref
    Tim, wondering if we should hack up my first message to include #128... That way easy to find...
    AI noticed still missing the + as well...
  23. #273
    5,043
    Hi Mike,
    65! 8) - Welcome to medicare, luckily I still have a few years, until then... (very few ) Just say I am only a few days away from being able to get early Social Security...
    Note: The blinking... I don't turn off, unless the Leds is updated by pressing the square or triangle or circle...
    Would be interesting to see a trace to see if what I expected happened, that is the first pass find driver will fail as you don't have any drivers that support that code (unless you have keyboard). Then when name code is complete, it should again call find driver with the name and then Joystick controller should claim it... (Unless I screwed up)... But again would be interesting to see what happens around when name complete happens.
  24. #274
    Senior Member+
    New York
    3,670
    Time does fly doesn't it - think I am younger sometimes then I am sorry that I forgot
    Just tried pressing the buttons - but still blinking. Here's the trace I get - didn't attach last message - forgot to hook up the 3.2:
    BluetoothController claim this=1fff3be0 vid:pid=a5c:21e8
        9 4 0 0 3 ff 1 1 0 7 5 81 3 10 0 1 7 5 82 2 40 0 1 7 5 2 2 40 0 1 9 4 1 0 2 ff 1 1 0 7 5 83 1 0 0 1 7 5 3 1 0 0 1 9 4 1 1 2 ff 1 1 0 7 5
        83 1 9 0 1 7 5 3 1 9 0 1 9 4 1 2 2 ff 1 1 0 7 5 83 1 11 0 1 7 5 3 1 11 0 1 9 4 1 3 2 ff 1 1 0 7 5 83 1 19 0 1 7 5 3 1 19 0 1 9 4 1 4 2 ff
        1 1 0 7 5 83 1 21 0 1 7 5 3 1 21 0 1 9 4 1 5 2 ff 1 1 0 7 5 83 1 31 0 1 7 5 3 1 31 0 1 9 4 2 0 2 ff ff ff 0 7 5 84 2 20 0 1 7 5 4 2 20 0 1 9
        4 3 0 0 fe 1 1 0 9 21 5 88 13 40 0 10 1
        Command Completed!
        Command Completed!
    BT rx_data(12): e a 1 9 10 0 c9 1c 7a 70 f3 5c
        Command Completed!
       BD Addr:c9:1c:7a:70:f3:5c
    BT rx_data(14): e c 1 1 10 0 6 0 10 6 f 0 e 22
        Command Completed!
        Local Version: 6
        Command Completed!
          Peripheral device
            Keyboard
    BT rx_data(1): 0
    JoystickController::claim_bluetooth TRUE PS3 hack...
        *** Claimed ***
    BT rx_data(13): 3 b 0 b 0 1e d4 f7 5c 26 0 1 0
        Connection Complete - ST:0 LH:b
    BT rx_data(5): 1b 3 b 0 5
    BT rx2_data(16): b 20 c 0 8 0 1 0 2 1 4 0 11 0 40 0
    L2CAP_CMD_CONNECTION_RESPONSE called(0b 20 10 00 0c 00 01 00 03 01 08 00 40 00 40 00 01 00 00 00 )
    tx_data callback (bluetooth): 201 : b 20 10 0 c 0 1 0 3 1 8 0 40 0 40 0 1 0 0 0
    L2CAP_CMD_CONNECTION_RESPONSE called(0b 20 10 00 0c 00 01 00 03 01 08 00 40 00 40 00 00 00 00 00 )
    tx_data callback (bluetooth): 202 : b 20 10 0 c 0 1 0 3 1 8 0 40 0 40 0 0 0 0 0
    L2CAP_ConfigRequest called(0b 20 10 00 0c 00 01 00 04 02 08 00 40 00 00 00 01 02 ff ff )
    BT rx_data(7): 13 5 1 b 0 2 0
    tx_data callback (bluetooth): 0 : b 20 10 0 c 0 1 0 4 2 8 0 40 0 0 0 1 2 ff ff
    BT rx2_data(16): b 20 c 0 8 0 1 0 4 2 4 0 40 0 0 0
        L2CAP config Request: ID: 2, Dest:40, Flags:0,  Options: 0 0 0 0
    L2CAP_ConfigResponse called(0b 20 12 00 0e 00 01 00 05 02 0a 00 40 00 00 00 00 00 01 02 a0 02 )
    BT rx2_data(22): b 20 12 0 e 0 1 0 5 2 a 0 40 0 0 0 0 0 1 2 a0 2
        L2CAP config Response: ID: 2, Source:40, Flags:0, Result:0, Config: 201
    tx_data callback (bluetooth): 0 : b 20 12 0 e 0 1 0 5 2 a 0 40 0 0 0 0 0 1 2 a0 2
    BT rx2_data(16): b 20 c 0 8 0 1 0 2 3 4 0 13 0 41 0
    L2CAP_CMD_CONNECTION_RESPONSE called(0b 20 10 00 0c 00 01 00 03 03 08 00 41 00 41 00 01 00 00 00 )
    tx_data callback (bluetooth): 203 : b 20 10 0 c 0 1 0 3 3 8 0 41 0 41 0 1 0 0 0
    L2CAP_CMD_CONNECTION_RESPONSE called(0b 20 10 00 0c 00 01 00 03 03 08 00 41 00 41 00 00 00 00 00 )
    tx_data callback (bluetooth): 204 : b 20 10 0 c 0 1 0 3 3 8 0 41 0 41 0 0 0 0 0
    L2CAP_ConfigRequest called(0b 20 10 00 0c 00 01 00 04 04 08 00 41 00 00 00 01 02 ff ff )
    tx_data callback (bluetooth): 0 : b 20 10 0 c 0 1 0 4 4 8 0 41 0 0 0 1 2 ff ff
    BT rx2_data(16): b 20 c 0 8 0 1 0 4 4 4 0 41 0 0 0
        L2CAP config Request: ID: 4, Dest:41, Flags:0,  Options: 0 0 1 2
    L2CAP_ConfigResponse called(0b 20 12 00 0e 00 01 00 05 04 0a 00 41 00 00 00 00 00 01 02 a0 02 )
    tx_data callback (bluetooth): 0 : b 20 12 0 e 0 1 0 5 4 a 0 41 0 0 0 0 0 1 2 a0 2
    BT rx2_data(22): b 20 12 0 e 0 1 0 5 4 a 0 41 0 0 0 0 0 1 2 a0 2
        L2CAP config Response: ID: 4, Source:41, Flags:0, Result:0, Config: 201
        Command Completed!
      JoystickController::connectionComplete joystick type 1
    enable six axis
    sendL2CapCommand: 2002ff00 6 ffffffff
    0b 20 0a 00 06 00 40 00 53 f4 42 03 00 00 )
    tx_data callback (bluetooth): 0 : b 20 a 0 6 0 40 0 53 f4 42 3 0 0
    BT rx2_data(9): b 20 5 0 1 0 40 0 0
  25. #275
    5,043
    Looks like the hacks are being processed... May have some stuff to figure out on it... One like yours should arrive Monday...
    Right now, maybe taking diversion and maybe posting some questions up on Trossen and Robotis Forums about suggested electronics/wiring for the PhantomX (Hexapod) with XL430 - where trying to get Trossen away from proprietary boards (Arbotix microcontroller AVR Atmega644P), which they have no one technical left at the company that can/will support it... Their last official support was for Arduino 1.0.4. I have setups for them for everything since then, but...
    So trying to get them to a controller they can simply buy and someone is actually supporting, like Robotis (OpenCM, OpenCR, XEL).
    Also What input input controller to use... Their Arbotix board had an XBee connection and they have a controller Arbotix Commander (Shield) with XBee, that I also know that Trossen would like to not have to support anymore as well...
    Plus how to wire it up...
    Personally I would love to have it based on Teensy 4 or 3.6, but no commercially available controller board, and I don't want to be the one who ends up supporting it (except for my own usage)
    But enough off topic (But again T4 with USB host and PS3 would be perfect!)
