// Simple test of USB Host Mouse/Tablet/Joystick viewer on ili9341 display
// Currently requires the libraries
// ili9341_t3n that can be located: https://github.com/KurtE/ILI9341_t3n
// spin: https://github.com/KurtE/SPIN
// Teensy 3.6 Pins
// 8 = RST
// 9 = D/C
// 10 = CS
// Teensy 4.0 Beta Pins
// 23 = RST (Marked MCLK on T4 beta breakout)
// 10 = CS (Marked CS)
// 9 = DC (Marked MEMCS)
// This example is in the public domain
#include "USBHost_t36.h"
#include <ili9341_t3n_font_Arial.h>
// Connection configuration of ILI9341 LCD TFT
#if defined(__MK66FX1M0__)
#define TFT_RST 8
#define TFT_DC 9
#define TFT_CS 10
#elif defined(__IMXRT1052__) || defined(__IMXRT1062__)
// On Teensy 4 beta with Paul's breakout out:
// Using pins (MOSI, MISO, SCK which are labeled on Audio board breakout location
// which are not in the Normal processor positions
// Also DC=10(CS), CS=9(BCLK) and RST 23(MCLK)
#define TFT_RST 23
#define TFT_DC 9
#define TFT_CS 10
#else
#error "This example App will only work with Teensy 3.6 or Teensy 4."
ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST);
// USB Host Ojbects
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHIDParser hid1(myusb);
USBHIDParser hid2(myusb);
USBHIDParser hid3(myusb);
USBHIDParser hid4(myusb);
USBHIDParser hid5(myusb);
MouseController mouse(myusb);
DigitizerController tablet(myusb);
JoystickController joystick(myusb);
//BluetoothController bluet(myusb, true, "0000"); // Version does pairing to device
BluetoothController bluet(myusb); // version assumes it already was paired
RawHIDController rawhid2(myusb);
// Lets only include in the lists The most top level type devices we wish to show information for.
USBDriver *drivers[] = {&joystick};
#define CNT_DEVICES (sizeof(drivers)/sizeof(drivers[0]))
const char * driver_names[CNT_DEVICES] = {"Joystick(device)"};
bool driver_active[CNT_DEVICES] = {false};
// Lets also look at HID Input devices
USBHIDInput *hiddrivers[] = {&tablet, &joystick, &mouse, &rawhid2};
#define CNT_HIDDEVICES (sizeof(hiddrivers)/sizeof(hiddrivers[0]))
const char * hid_driver_names[CNT_HIDDEVICES] = {"tablet", "joystick", "mouse", "RawHid2"};
bool hid_driver_active[CNT_HIDDEVICES] = {false, false};
BTHIDInput *bthiddrivers[] = {&joystick, &mouse};
#define CNT_BTHIDDEVICES (sizeof(bthiddrivers)/sizeof(bthiddrivers[0]))
const char * bthid_driver_names[CNT_HIDDEVICES] = {"joystick", "mouse"};
bool bthid_driver_active[CNT_HIDDEVICES] = {false, false};
// Other state variables.
// Save away values for buttons, x, y, wheel, wheelh
int buttons_cur = 0;
int x_cur = 0,
y_cur = 0,
z_cur = 0;
int x2_cur = 0,
y2_cur = 0,
z2_cur = 0;
int wheel_cur = 0;
int wheelH_cur = 0;
int user_axis[64];
uint8_t digi_axis[64];
uint32_t buttons_prev = 0;
uint32_t buttons;
bool show_changed_only = false;
bool new_device_detected = false;
int16_t y_position_after_device_info = 0;
uint8_t joystick_left_trigger_value = 0;
uint8_t joystick_right_trigger_value = 0;
uint64_t joystick_full_notify_mask = (uint64_t) - 1;
// Setup
Serial1.begin(2000000);
while (!Serial && millis() < 3000) ; // wait for Arduino Serial Monitor
Serial.println("\n\nUSB Host Testing");
myusb.begin();
rawhid2.attachReceive(OnReceiveHidData);
tft.begin();
tft.setRotation(3); // 180
tft.setTextColor(ILI9341_YELLOW);
tft.setTextSize(2);
tft.println("Waiting for Mouse or Joystick...");
// Loop
myusb.Task();
// Update the display with
UpdateActiveDeviceInfo();
// Now lets try displaying Tablet data
ProcessTabletData();
// And joystick data
ProcessJoystickData();
// Process Mouse Data
ProcessMouseData();
// UpdateActiveDeviceInfo
void UpdateActiveDeviceInfo() {
// First see if any high level devices
for (uint8_t i = 0; i < CNT_DEVICES; i++) {
if (*drivers[i] != driver_active[i]) {
if (driver_active[i]) {
Serial.printf("*** Device %s - disconnected ***\n", driver_names[i]);
driver_active[i] = false;
new_device_detected = true;
Serial.printf("*** Device %s %x:%x - connected ***\n", driver_names[i], drivers[i]->idVendor(), drivers[i]->idProduct());
driver_active[i] = true;
tft.fillScreen(ILI9341_BLACK); // clear the screen.
tft.setCursor(0, 0);
tft.setFont(Arial_12);
tft.printf("Device %s %x:%x\n", driver_names[i], drivers[i]->idVendor(), drivers[i]->idProduct());
const uint8_t *psz = drivers[i]->manufacturer();
if (psz && *psz) tft.printf(" manufacturer: %s\n", psz);
psz = drivers[i]->product();
if (psz && *psz) tft.printf(" product: %s\n", psz);
psz = drivers[i]->serialNumber();
if (psz && *psz) tft.printf(" Serial: %s\n", psz);
// Then Hid Devices
for (uint8_t i = 0; i < CNT_HIDDEVICES; i++) {
if (*hiddrivers[i] != hid_driver_active[i]) {
if (hid_driver_active[i]) {
Serial.printf("*** HID Device %s - disconnected ***\n", hid_driver_names[i]);
hid_driver_active[i] = false;
Serial.printf("*** HID Device %s %x:%x - connected ***\n", hid_driver_names[i], hiddrivers[i]->idVendor(), hiddrivers[i]->idProduct());
hid_driver_active[i] = true;
tft.printf("HID Device %s %x:%x\n", hid_driver_names[i], hiddrivers[i]->idVendor(), hiddrivers[i]->idProduct());
const uint8_t *psz = hiddrivers[i]->manufacturer();
psz = hiddrivers[i]->product();
psz = hiddrivers[i]->serialNumber();
// Then Bluetooth devices
for (uint8_t i = 0; i < CNT_BTHIDDEVICES; i++) {
if (*bthiddrivers[i] != bthid_driver_active[i]) {
if (bthid_driver_active[i]) {
Serial.printf("*** BTHID Device %s - disconnected ***\n", hid_driver_names[i]);
Serial.printf("*** BTHID Device %s %x:%x - connected ***\n", hid_driver_names[i], hiddrivers[i]->idVendor(), hiddrivers[i]->idProduct());
bthid_driver_active[i] = true;
tft.printf("Bluetooth Device %s %x:%x\n", bthid_driver_names[i], bthiddrivers[i]->idVendor(), bthiddrivers[i]->idProduct());
const uint8_t *psz = bthiddrivers[i]->manufacturer();
psz = bthiddrivers[i]->product();
psz = bthiddrivers[i]->serialNumber();
// ProcessTabletData
void ProcessTabletData() {
if (tablet.available()) {
if (new_device_detected) {
// Lets display the titles.
int16_t x;
tft.getCursor(&x, &y_position_after_device_info);
tft.printf("Buttons:\nX:\nY:\nWheel:\nWheel H:");
bool something_changed = false;
if (tablet.getButtons() != buttons_cur) {
buttons_cur = tablet.getButtons();
something_changed = true;
if (tablet.getMouseX() != x_cur) {
x_cur = tablet.getMouseX();
if (tablet.getMouseY() != y_cur) {
y_cur = tablet.getMouseY();
if (tablet.getWheel() != wheel_cur) {
wheel_cur = tablet.getWheel();
if (tablet.getWheelH() != wheelH_cur) {
wheelH_cur = tablet.getWheelH();
if (something_changed) {
#define TABLET_DATA_X 100
int16_t x, y2;
unsigned char line_space = Arial_12.line_space;
tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK);
//tft.setTextDatum(BR_DATUM);
int16_t y = y_position_after_device_info;
tft.setCursor(TABLET_DATA_X, y);
tft.printf("%d(%x)", buttons_cur, buttons_cur);
tft.getCursor(&x, &y2);
tft.fillRect(x, y, 320, line_space, ILI9341_BLACK);
y+= line_space;tft.setCursor(TABLET_DATA_X, y);tft.print(x_cur, DEC); tft.getCursor(&x, &y2);tft.fillRect(x, y, 320, line_space, ILI9341_BLACK);
y+= line_space;tft.setCursor(TABLET_DATA_X, y);tft.print(y_cur, DEC); tft.getCursor(&x, &y2);tft.fillRect(x, y, 320, line_space, ILI9341_BLACK);
y+= line_space;tft.setCursor(TABLET_DATA_X, y);tft.print(wheel_cur, DEC); tft.getCursor(&x, &y2);tft.fillRect(x, y, 320, line_space, ILI9341_BLACK);
y+= line_space;tft.setCursor(TABLET_DATA_X, y);tft.print(wheelH_cur, DEC); tft.getCursor(&x, &y2);tft.fillRect(x, y, 320, line_space, ILI9341_BLACK);
/*tft.drawNumber(buttons_cur, 50, 235);
tft.drawNumber(x_cur, 100, 235);
tft.drawNumber(y_cur, 150, 235);
tft.drawNumber(wheel_cur, 200, 235);
tft.drawNumber(wheelH_cur, 250, 235);
tablet.digitizerDataClear();
// ProcessMouseData
void ProcessMouseData() {
if (mouse.available()) {
int16_t x;
if (mouse.getButtons() != buttons_cur) {
buttons_cur = mouse.getButtons();
if (mouse.getMouseX() != x_cur) {
x_cur = mouse.getMouseX();
if (mouse.getMouseY() != y_cur) {
y_cur = mouse.getMouseY();
if (mouse.getWheel() != wheel_cur) {
wheel_cur = mouse.getWheel();
if (mouse.getWheelH() != wheelH_cur) {
wheelH_cur = mouse.getWheelH();
#define MOUSE_DATA_X 100
int16_t x, y2;
y+= line_space;tft.setCursor(MOUSE_DATA_X, y);tft.print(x_cur, DEC); tft.getCursor(&x, &y2);tft.fillRect(x, y, 320, line_space, ILI9341_BLACK);
y+= line_space;tft.setCursor(MOUSE_DATA_X, y);tft.print(y_cur, DEC); tft.getCursor(&x, &y2);tft.fillRect(x, y, 320, line_space, ILI9341_BLACK);
y+= line_space;tft.setCursor(MOUSE_DATA_X, y);tft.print(wheel_cur, DEC); tft.getCursor(&x, &y2);tft.fillRect(x, y, 320, line_space, ILI9341_BLACK);
y+= line_space;tft.setCursor(MOUSE_DATA_X, y);tft.print(wheelH_cur, DEC); tft.getCursor(&x, &y2);tft.fillRect(x, y, 320, line_space, ILI9341_BLACK);
mouse.mouseDataClear();
// ProcessJoystickData
void ProcessJoystickData() {
if (joystick.available()) {
uint64_t axis_mask = joystick.axisMask();
uint64_t axis_changed_mask = joystick.axisChangedMask();
Serial.print("Joystick: buttons = ");
buttons = joystick.getButtons();
Serial.print(buttons, HEX);
//Serial.printf(" AMasks: %x %x:%x", axis_mask, (uint32_t)(user_axis_mask >> 32), (uint32_t)(user_axis_mask & 0xffffffff));
//Serial.printf(" M: %lx %lx", axis_mask, joystick.axisChangedMask());
if (show_changed_only) {
for (uint8_t i = 0; axis_changed_mask != 0; i++, axis_changed_mask >>= 1) {
if (axis_changed_mask & 1) {
Serial.printf(" %d:%d", i, joystick.getAxis(i));
for (uint8_t i = 0; axis_mask != 0; i++, axis_mask >>= 1) {
if (axis_mask & 1) {
for (uint8_t i = 0; i < 64; i++) {
user_axis[i] = joystick.getAxis(i);
uint8_t ltv;
uint8_t rtv;
switch (joystick.joystickType()) {
default:
case JoystickController::PS4:
ltv = joystick.getAxis(3);
rtv = joystick.getAxis(4);
if ((ltv != joystick_left_trigger_value) || (rtv != joystick_right_trigger_value)) {
joystick_left_trigger_value = ltv;
joystick_right_trigger_value = rtv;
joystick.setRumble(ltv, rtv);
case JoystickController::PS3:
ltv = joystick.getAxis(18);
rtv = joystick.getAxis(19);
joystick.setRumble(ltv, rtv, 50);
case JoystickController::XBOXONE:
case JoystickController::XBOX360:
ltv = joystick.getAxis(4);
rtv = joystick.getAxis(5);
Serial.printf(" Set Rumble %d %d", ltv, rtv);
if (buttons != buttons_cur) {
if (joystick.joystickType() == JoystickController::PS3) {
joystick.setLEDs((buttons >> 12) & 0xf); // try to get to TRI/CIR/X/SQuare
uint8_t lr = (buttons & 1) ? 0xff : 0;
uint8_t lg = (buttons & 2) ? 0xff : 0;
uint8_t lb = (buttons & 4) ? 0xff : 0;
joystick.setLEDs(lr, lg, lb);
buttons_cur = buttons;
TFT_joystick();
joystick.joystickDataClear();
// TFT_joystick
void TFT_joystick()
tft.drawString("BUTTONS", 100, 100);
if (buttons == 0) {
tft.drawString(".........", 180, 100);
tft.drawNumber(buttons_prev, 180, 100);
tft.drawNumber(buttons, 180, 100);
tft.drawString("X: ", 60, 120);
if (user_axis[0] == x_cur) {
tft.drawString(".........", 80, 120);
tft.drawNumber(x_cur, 80, 120);
tft.drawNumber(user_axis[0], 80, 120);
x_cur = user_axis[0];
tft.drawString("Y: ", 60, 140);
if (user_axis[1] == y_cur) {
tft.drawString(".........", 80, 140);
tft.drawNumber(y_cur, 80, 140);
tft.drawNumber(user_axis[1], 80, 140);
y_cur = user_axis[1];
tft.drawString("Hat: ", 40, 180);
if (user_axis[9] == wheel_cur) {
tft.drawString(".........", 80, 180);
tft.drawNumber(wheel_cur, 80, 180);
tft.drawNumber(user_axis[9], 80, 180);
wheel_cur = user_axis[9];
//Gamepads
tft.drawString("X2: ", 160, 120);
if (user_axis[2] == x_cur) {
tft.drawString(".........", 190, 120);
tft.drawNumber(x_cur, 190, 120);
tft.drawNumber(user_axis[2], 190, 120);
x2_cur = user_axis[2];
default:
tft.drawString("Z: ", 60, 160);
if (user_axis[5] == z_cur) {
tft.drawString(".........", 80, 160);
tft.drawNumber(z_cur, 80, 140);
tft.drawNumber(user_axis[5], 80, 160);
z_cur = user_axis[5];
tft.drawString("Y2: ", 160, 140);
if (user_axis[5] == y2_cur) {
tft.drawString(".........", 190, 140);
tft.drawNumber(y2_cur, 190, 120);
tft.drawNumber(user_axis[5], 190, 140);
y2_cur = user_axis[5];
tft.drawNumber(y2_cur, 190, 140);
tft.drawString("Y2: ", 160, 160);
tft.drawString(".........", 190, 160);
tft.drawNumber(y2_cur, 190, 160);
tft.drawNumber(user_axis[5], 190, 160);
// ProcessMouseData
bool OnReceiveHidData(uint32_t usage, const uint8_t *data, uint32_t len) {
// Called for maybe both HIDS for rawhid basic test. One is for the Teensy
// to output to Serial. while still having Raw Hid...
if (usage == 0xffc90004) {
// Lets trim off trailing null characters.
while ((len > 0) && (data[len - 1] == 0)) {
len--;
if (len) {
//Serial.print("RawHid Serial: ");
//Serial.write(data, len);
//Serial.print("RawHIDx data: ");
//Serial.println(usage, HEX);
uint8_t len1 = len;
for (int j = 0; j < len; j++) {
user_axis[j] = data[j];
while (len) {
uint8_t cb = (len > 16) ? 16 : len;
const uint8_t *p = data;
uint8_t i;
for (i = 0; i < cb; i++) {
Serial.printf("%02x ", *p++);
Serial.print(": ");
Serial.write(((*data >= ' ') && (*data <= '~')) ? *data : '.');
data++;
len -= cb;
//for (uint8_t i = 0; i<9; i++) {
//Serial.printf(" %d:%d", i, user_axis[i]);
//Serial.println();
//Serial.print("Mouse: buttons = ");
//Serial.print(user_axis[3]);
//Serial.print(", mouseX = ");
//Serial.print(user_axis[4]);
//Serial.print(", mouseY = ");
//Serial.print(user_axis[5]);
//Serial.println();
if (user_axis[3] != buttons_cur) {
buttons_cur = user_axis[3];
if (user_axis[4] != x_cur) {
x_cur = user_axis[4];
if (user_axis[5] != y_cur) {
y_cur = user_axis[5];
wheel_cur = 0;
wheelH_cur = 0;
tft.fillRect(45, 197, 240, 20, ILI9341_RED);
tft.drawNumber(buttons_cur, 50, 200);
tft.drawNumber(x_cur, 100, 200);
tft.drawNumber(y_cur, 150, 200);
tft.drawNumber(wheel_cur, 200, 200);
tft.drawNumber(wheelH_cur, 250, 200);
return true;
