Page 25 of 27 FirstFirst ... 15 23 24 25 26 27 LastLast
Results 601 to 625 of 675
Thread: T3.6 USB Host - Bluetooth
  1. #601
    Senior Member+
    New York
    3,189
    @KurtE
    Ok, did a kludge to get Bluetooth keyboard to print in the scrolling window. Only problem is that it tests on the BLUET not the keyboard.
    Is there a reason why the keyboard doesn't show up as a Bluetooth device?
    UPDATE: Figured out a fix for the kludge plus by doing one of the scroll modifications you originally suggested. Here is the new sketch:
    // Simple test of USB Host Mouse/Tablet/Joystick viewer on ili9341 display
    // Currently requires the libraries
    //    ili9341_t3n that can be located: https://github.com/KurtE/ILI9341_t3n
    //    spin: https://github.com/KurtE/SPIN
    // Teensy 3.6 Pins
    //   8 = RST
    //   9 = D/C
    //  10 = CS
    // Teensy 4.0 Beta Pins
    //  23 = RST (Marked MCLK on T4 beta breakout)
    //  10 = CS (Marked CS)
    //  9 = DC  (Marked MEMCS)
    // This example is in the public domain
    #include "USBHost_t36.h"
    #include <ili9341_t3n_font_Arial.h>
    #define TEENSY64
    // Connection configuration of ILI9341 LCD TFT
    #if defined(__MK66FX1M0__) && !defined(TEENSY64)
    #define TFT_RST 255
    #define TFT_DC 20
    #define TFT_CS 21
    ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST);
    #elif defined(__IMXRT1052__) || defined(__IMXRT1062__)
    // On Teensy 4 beta with Paul's breakout out:
    // Using pins (MOSI, MISO, SCK which are labeled on Audio board breakout location
    // which are not in the Normal processor positions
    // Also DC=10(CS), CS=9(BCLK) and RST 23(MCLK)
    #define TFT_RST 23
    #define TFT_DC 9
    #define TFT_CS 10
    #elif defined(TEENSY64)
    #define TFT_RST 255
    #define TFT_DC 20
    #define TFT_CS 21
    #define TFT_SCK 14
    #define TFT_MISO 39
    #define TFT_MOSI 28
    ILI9341_t3n tft = ILI9341_t3n(TFT_CS, TFT_DC, TFT_RST, TFT_MOSI, TFT_SCK, TFT_MISO);
    #else
    #error "This example App will only work with Teensy 3.6 or Teensy 4."
    // USB Host Ojbects
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    KeyboardController keyboard1(myusb);
    KeyboardController keyboard2(myusb);
    USBHIDParser hid1(myusb);
    USBHIDParser hid2(myusb);
    USBHIDParser hid3(myusb);
    USBHIDParser hid4(myusb);
    USBHIDParser hid5(myusb);
    MouseController mouse(myusb);
    DigitizerController tablet(myusb);
    JoystickController joystick(myusb);
    BluetoothController bluet(myusb, true, "0000");   // Version does pairing to device
    //BluetoothController bluet(myusb);   // version assumes it already was paired
    RawHIDController rawhid2(myusb);
    // Lets only include in the lists The most top level type devices we wish to show information for.
    //USBDriver *drivers[] = {&keyboard1, &keyboard2, &joystick};
    USBDriver *drivers[] = {&keyboard1, &keyboard2, &joystick, &bluet, &hid1, &hid2};
    #define CNT_DEVICES (sizeof(drivers)/sizeof(drivers[0]))
    //const char * driver_names[CNT_DEVICES] = {"KB1", "KB2", "Joystick(device)"};
    const char * driver_names[CNT_DEVICES] = {"KB1", "KB2", "Joystick(device)", "Bluet", "HID1" , "HID2"};
    //bool driver_active[CNT_DEVICES] = {false, false, false};
    bool driver_active[CNT_DEVICES] = {false, false, false, false,false};
    // Lets also look at HID Input devices
    USBHIDInput *hiddrivers[] = {&tablet, &joystick, &mouse, &rawhid2};
    #define CNT_HIDDEVICES (sizeof(hiddrivers)/sizeof(hiddrivers[0]))
    const char * hid_driver_names[CNT_HIDDEVICES] = {"tablet", "joystick", "mouse", "RawHid2"};
    bool hid_driver_active[CNT_HIDDEVICES] = {false, false, false,false};
    BTHIDInput *bthiddrivers[] = {&joystick, &mouse};
    #define CNT_BTHIDDEVICES (sizeof(bthiddrivers)/sizeof(bthiddrivers[0]))
    const char * bthid_driver_names[CNT_HIDDEVICES] = {"joystick", "mouse"};
    bool bthid_driver_active[CNT_HIDDEVICES] = {false, false};
    // Other state variables.
    // Save away values for buttons, x, y, wheel, wheelh
    int buttons_cur = 0;
    int x_cur = 0,
        y_cur = 0,
        z_cur = 0;
    int x2_cur = 0,
        y2_cur = 0,
        z2_cur = 0;
    int wheel_cur = 0;
    int wheelH_cur = 0;
    int axis_cur[10];
    String p = "KB1";
    bool BT = 0;
    int user_axis[64];
    uint32_t buttons_prev = 0;
    uint32_t buttons;
    bool show_changed_only = false;
    bool new_device_detected = false;
    int16_t y_position_after_device_info = 0;
    uint8_t joystick_left_trigger_value = 0;
    uint8_t joystick_right_trigger_value = 0;
    uint64_t joystick_full_notify_mask = (uint64_t) - 1;
    // Setup
      Serial1.begin(2000000);
      while (!Serial && millis() < 3000) ; // wait for Arduino Serial Monitor
      Serial.println("\n\nUSB Host Testing");
      myusb.begin();
      rawhid2.attachReceive(OnReceiveHidData);
      keyboard1.attachPress(OnPress);
      keyboard2.attachPress(OnPress);
      keyboard1.attachExtrasPress(OnHIDExtrasPress);
      keyboard1.attachExtrasRelease(OnHIDExtrasRelease);
      keyboard2.attachExtrasPress(OnHIDExtrasPress);
      keyboard2.attachExtrasRelease(OnHIDExtrasRelease);
      // The below forceBootProtocol will force which ever
      // next keyboard that attaches to this device to be in boot protocol
      // Only try this if you run into keyboard with issues.  If this is a combined
      // device like wireless mouse and keyboard this can cause mouse problems.
      //keyboard1.forceBootProtocol();
      tft.begin();
      tft.setRotation(3); // 180
      tft.setTextColor(ILI9341_YELLOW);
      tft.setTextSize(2);
      tft.println("Waiting for Mouse or Joystick...");
    // Loop
      myusb.Task();
      // Update the display with
      UpdateActiveDeviceInfo();
      // Now lets try displaying Tablet data
      ProcessTabletData();
      // And joystick data
      ProcessJoystickData();
      // Process Mouse Data
      ProcessMouseData();
    // UpdateActiveDeviceInfo
    void UpdateActiveDeviceInfo() {
      // First see if any high level devices
      for (uint8_t i = 0; i < CNT_DEVICES; i++) {
        if (*drivers[i] != driver_active[i]) {
          if (driver_active[i]) {
            Serial.printf("*** Device %s - disconnected ***\n", driver_names[i]);
            driver_active[i] = false;
            new_device_detected = true;
            Serial.printf("*** Device %s %x:%x - connected ***\n", driver_names[i], drivers[i]->idVendor(), drivers[i]->idProduct());
            driver_active[i] = true;
            tft.fillScreen(ILI9341_BLACK);  // clear the screen.
            tft.setCursor(0, 0);
            tft.setFont(Arial_12);
            tft.printf("Device %s %x:%x\n", driver_names[i], drivers[i]->idVendor(), drivers[i]->idProduct());
            const uint8_t *psz = drivers[i]->manufacturer();
            if (psz && *psz) tft.printf("  manufacturer: %s\n", psz);
            psz = drivers[i]->product();
            if (psz && *psz) tft.printf("  product: %s\n", psz);
            psz = drivers[i]->serialNumber();
            if (psz && *psz) tft.printf("  Serial: %s\n", psz);
    /*        if(String((char *)driver_names[i]) == "Bluet") BT=1;
            if(String((char *)driver_names[i]) == p){
              tft.enableScroll();
              tft.setScrollTextArea(20,60,280,140);
              tft.setScrollBackgroundColor(ILI9341_GREEN);
              tft.setFont(Arial_11);
              tft.setTextColor(ILI9341_BLACK);
              tft.setCursor(20, 60);
      // Then Hid Devices
      for (uint8_t i = 0; i < CNT_HIDDEVICES; i++) {
        if (*hiddrivers[i] != hid_driver_active[i]) {
          if (hid_driver_active[i]) {
            Serial.printf("*** HID Device %s - disconnected ***\n", hid_driver_names[i]);
            hid_driver_active[i] = false;
            Serial.printf("*** HID Device %s %x:%x - connected ***\n", hid_driver_names[i], hiddrivers[i]->idVendor(), hiddrivers[i]->idProduct());
            hid_driver_active[i] = true;
            tft.printf("HID Device %s %x:%x\n", hid_driver_names[i], hiddrivers[i]->idVendor(), hiddrivers[i]->idProduct());
            const uint8_t *psz = hiddrivers[i]->manufacturer();
            psz = hiddrivers[i]->product();
            psz = hiddrivers[i]->serialNumber();
      // Then Bluetooth devices
      for (uint8_t i = 0; i < CNT_BTHIDDEVICES; i++) {
        if (*bthiddrivers[i] != bthid_driver_active[i]) {
          if (bthid_driver_active[i]) {
            Serial.printf("*** BTHID Device %s - disconnected ***\n", hid_driver_names[i]);
            Serial.printf("*** BTHID Device %s %x:%x - connected ***\n", hid_driver_names[i], hiddrivers[i]->idVendor(), hiddrivers[i]->idProduct());
            bthid_driver_active[i] = true;
            tft.printf("Bluetooth Device %s %x:%x\n", bthid_driver_names[i], bthiddrivers[i]->idVendor(), bthiddrivers[i]->idProduct());
            const uint8_t *psz = bthiddrivers[i]->manufacturer();
            psz = bthiddrivers[i]->product();
            psz = bthiddrivers[i]->serialNumber();
    // ProcessTabletData
    void ProcessTabletData() {
      if (tablet.available()) {
        if (new_device_detected) {
          // Lets display the titles.
          int16_t x;
          tft.getCursor(&x, &y_position_after_device_info);
          tft.printf("Buttons:\nX:\nY:\nWheel:\nWheel H:\nAxis:");
        bool something_changed = false;
        if (tablet.getButtons() != buttons_cur) {
          buttons_cur = tablet.getButtons();
          something_changed = true;
        if (tablet.getMouseX() != x_cur) {
          x_cur = tablet.getMouseX();
        if (tablet.getMouseY() != y_cur) {
          y_cur = tablet.getMouseY();
        if (tablet.getWheel() != wheel_cur) {
          wheel_cur = tablet.getWheel();
        if (tablet.getWheelH() != wheelH_cur) {
          wheelH_cur = tablet.getWheelH();
        // BUGBUG:: play with some Axis...
        for (uint8_t i = 0; i < 10; i++) {
          int axis = tablet.getAxis(i);
          if (axis != axis_cur[i]) {
            axis_cur[i] = axis;
        if (something_changed) {
    #define TABLET_DATA_X 100
          int16_t x, y2;
          unsigned char line_space = Arial_12.line_space;
          tft.setTextColor(ILI9341_WHITE, ILI9341_BLACK);
          //tft.setTextDatum(BR_DATUM);
          int16_t y = y_position_after_device_info;
          tft.setCursor(TABLET_DATA_X, y);
          tft.printf("%d(%x)", buttons_cur, buttons_cur);
          tft.getCursor(&x, &y2);
          tft.fillRect(x, y, 320, line_space, ILI9341_BLACK);
          y += line_space; OutputNumberField(TABLET_DATA_X, y, x_cur, 320);
          y += line_space; OutputNumberField(TABLET_DATA_X, y, y_cur, 320);
          y += line_space; OutputNumberField(TABLET_DATA_X, y, wheel_cur, 320);
          y += line_space; OutputNumberField(TABLET_DATA_X, y, wheelH_cur, 320);
          // Output other Axis data
          for (uint8_t i = 0; i < 9; i += 3) {
            y += line_space;
            OutputNumberField(TABLET_DATA_X, y, axis_cur[i], 75);
            OutputNumberField(TABLET_DATA_X + 75, y, axis_cur[i + 1], 75);
            OutputNumberField(TABLET_DATA_X + 150, y, axis_cur[i + 2], 75);
        tablet.digitizerDataClear();
    // OutputNumberField
    void OutputNumberField(int16_t x, int16_t y, int val, int16_t field_width) {
      int16_t x2, y2;
      tft.setCursor(x, y);
      tft.print(val, DEC); tft.getCursor(&x2, &y2);
      tft.fillRect(x2, y, field_width - (x2-x), Arial_12.line_space, ILI9341_BLACK);
    // ProcessMouseData
    void ProcessMouseData() {
      if (mouse.available()) {
          int16_t x;
          tft.printf("Buttons:\nX:\nY:\nWheel:\nWheel H:");
        if (mouse.getButtons() != buttons_cur) {
          buttons_cur = mouse.getButtons();
        if (mouse.getMouseX() != x_cur) {
          x_cur = mouse.getMouseX();
        if (mouse.getMouseY() != y_cur) {
          y_cur = mouse.getMouseY();
        if (mouse.getWheel() != wheel_cur) {
          wheel_cur = mouse.getWheel();
        if (mouse.getWheelH() != wheelH_cur) {
          wheelH_cur = mouse.getWheelH();
    #define MOUSE_DATA_X 100
          int16_t x, y2;
          y += line_space; OutputNumberField(MOUSE_DATA_X, y, x_cur, 320);
          y += line_space; OutputNumberField(MOUSE_DATA_X, y, y_cur, 320);
          y += line_space; OutputNumberField(MOUSE_DATA_X, y, wheel_cur, 320);
          y += line_space; OutputNumberField(MOUSE_DATA_X, y, wheelH_cur, 320);
        mouse.mouseDataClear();
    // ProcessJoystickData
    void ProcessJoystickData() {
      if (joystick.available()) {
        uint64_t axis_mask = joystick.axisMask();
        uint64_t axis_changed_mask = joystick.axisChangedMask();
        Serial.print("Joystick: buttons = ");
        buttons = joystick.getButtons();
        Serial.print(buttons, HEX);
        //Serial.printf(" AMasks: %x %x:%x", axis_mask, (uint32_t)(user_axis_mask >> 32), (uint32_t)(user_axis_mask & 0xffffffff));
        //Serial.printf(" M: %lx %lx", axis_mask, joystick.axisChangedMask());
        if (show_changed_only) {
          for (uint8_t i = 0; axis_changed_mask != 0; i++, axis_changed_mask >>= 1) {
            if (axis_changed_mask & 1) {
              Serial.printf(" %d:%d", i, joystick.getAxis(i));
          for (uint8_t i = 0; axis_mask != 0; i++, axis_mask >>= 1) {
            if (axis_mask & 1) {
        for (uint8_t i = 0; i < 64; i++) {
          user_axis[i] = joystick.getAxis(i);
        uint8_t ltv;
        uint8_t rtv;
        switch (joystick.joystickType()) {
          default:
          case JoystickController::PS4:
            ltv = joystick.getAxis(3);
            rtv = joystick.getAxis(4);
            if ((ltv != joystick_left_trigger_value) || (rtv != joystick_right_trigger_value)) {
              joystick_left_trigger_value = ltv;
              joystick_right_trigger_value = rtv;
              joystick.setRumble(ltv, rtv);
          case JoystickController::PS3:
            ltv = joystick.getAxis(18);
            rtv = joystick.getAxis(19);
              joystick.setRumble(ltv, rtv, 50);
          case JoystickController::XBOXONE:
          case JoystickController::XBOX360:
            ltv = joystick.getAxis(4);
            rtv = joystick.getAxis(5);
              Serial.printf(" Set Rumble %d %d", ltv, rtv);
        if (buttons != buttons_cur) {
          if (joystick.joystickType() == JoystickController::PS3) {
            joystick.setLEDs((buttons >> 12) & 0xf); //  try to get to TRI/CIR/X/SQuare
            uint8_t lr = (buttons & 1) ? 0xff : 0;
            uint8_t lg = (buttons & 2) ? 0xff : 0;
            uint8_t lb = (buttons & 4) ? 0xff : 0;
            joystick.setLEDs(lr, lg, lb);
          buttons_cur = buttons;
        TFT_joystick();
        joystick.joystickDataClear();
    // TFT_joystick
    void TFT_joystick()
      tft.drawString("BUTTONS", 100, 100);
      if (buttons == 0) {
        tft.drawString(".........", 180, 100);
        tft.drawNumber(buttons_prev, 180, 100);
        tft.drawNumber(buttons, 180, 100);
      tft.drawString("X: ", 60, 120);
      if (user_axis[0] == x_cur) {//
        tft.drawString(".........", 80, 120);
        tft.drawNumber(x_cur, 80, 120);
        tft.drawNumber(user_axis[0], 80, 120);
      x_cur = user_axis[0];
      tft.drawString("Y: ", 60, 140);
      if (user_axis[1] == y_cur) {
        tft.drawString(".........", 80, 140);
        tft.drawNumber(y_cur, 80, 140);
        tft.drawNumber(user_axis[1], 80, 140);
      y_cur = user_axis[1];
      tft.drawString("Hat: ", 40, 180);
      if (user_axis[9] == wheel_cur) {
        tft.drawString(".........", 80, 180);
        tft.drawNumber(wheel_cur, 80, 180);
        tft.drawNumber(user_axis[9], 80, 180);
      wheel_cur = user_axis[9];
      //Gamepads
      tft.drawString("X2: ", 160, 120);
      if (user_axis[2] == x_cur) {
        tft.drawString(".........", 190, 120);
        tft.drawNumber(x_cur, 190, 120);
        tft.drawNumber(user_axis[2], 190, 120);
      x2_cur = user_axis[2];
        default:
          tft.drawString("Z: ", 60, 160);
          if (user_axis[5] == z_cur) {
            tft.drawString(".........", 80, 160);
            tft.drawNumber(z_cur, 80, 140);
            tft.drawNumber(user_axis[5], 80, 160);
          z_cur = user_axis[5];
          tft.drawString("Y2: ", 160, 140);
          if (user_axis[5] == y2_cur) {
            tft.drawString(".........", 190, 140);
            tft.drawNumber(y2_cur, 190, 120);
            tft.drawNumber(user_axis[5], 190, 140);
          y2_cur = user_axis[5];
            tft.drawNumber(y2_cur, 190, 140);
          tft.drawString("Y2: ", 160, 160);
            tft.drawString(".........", 190, 160);
            tft.drawNumber(y2_cur, 190, 160);
            tft.drawNumber(user_axis[5], 190, 160);
    // ProcessMouseData
    bool OnReceiveHidData(uint32_t usage, const uint8_t *data, uint32_t len) {
      // Called for maybe both HIDS for rawhid basic test.  One is for the Teensy
      // to output to Serial. while still having Raw Hid...
      if (usage == 0xFF000080
        //Serial.print("RawHIDx data: ");
        //Serial.println(usage, HEX);
        uint8_t len1 = len;
        for (int j = 0; j < len; j++) {
          user_axis[j] = data[j];
        if (user_axis[3] != buttons_cur) {
          buttons_cur = user_axis[3];
        if (user_axis[4] != x_cur) {
          x_cur = user_axis[4];
        if (user_axis[5] != y_cur) {
          y_cur = user_axis[5];
          wheel_cur = 0;
          wheelH_cur = 0;
          tft.fillRect(45, 197, 240, 20, ILI9341_RED);
          tft.drawNumber(buttons_cur, 50, 200);
          tft.drawNumber(x_cur, 100, 200);
          tft.drawNumber(y_cur, 150, 200);
          tft.drawNumber(wheel_cur, 200, 200);
          tft.drawNumber(wheelH_cur, 250, 200);
        // Lets trim off trailing null characters.
        while ((len > 0) && (data[len - 1] == 0)) {
          len--;
        if (len) {
          //Serial.print("RawHid Serial: ");
          //Serial.write(data, len);
      return true;
    void OnPress(int key)
      if(new_device_detected) {
        BT = 0;
      if(BT == 0){
          tft.enableScroll();
          tft.setScrollTextArea(20,70,280,140);
          tft.setCursor(20, 70);
          BT = 1;
      tft.print("key: ");
      switch (key) {
        case KEYD_UP       : tft.print("UP"); break;
        case KEYD_DOWN    : tft.print("DN"); break;
        case KEYD_LEFT     : tft.print("LEFT"); break;
        case KEYD_RIGHT   : tft.print("RIGHT"); break;
        case KEYD_INSERT   : tft.print("Ins"); break;
        case KEYD_DELETE   : tft.print("Del"); break;
        case KEYD_PAGE_UP  : tft.print("PUP"); break;
        case KEYD_PAGE_DOWN: tft.print("PDN"); break;
        case KEYD_HOME     : tft.print("HOME"); break;
        case KEYD_END      : tft.print("END"); break;
        case KEYD_F1       : tft.print("F1"); break;
        case KEYD_F2       : tft.print("F2"); break;
        case KEYD_F3       : tft.print("F3"); break;
        case KEYD_F4       : tft.print("F4"); break;
        case KEYD_F5       : tft.print("F5"); break;
        case KEYD_F6       : tft.print("F6"); break;
        case KEYD_F7       : tft.print("F7"); break;
        case KEYD_F8       : tft.print("F8"); break;
        case KEYD_F9       : tft.print("F9"); break;
        case KEYD_F10      : tft.print("F10"); break;
        case KEYD_F11      : tft.print("F11"); break;
        case KEYD_F12      : tft.print("F12"); break;
        default: tft.print((char)key); break;
      tft.print("'  ");
      tft.print(key);
      tft.print(" MOD: ");
      if (keyboard1) {
        tft.print(keyboard1.getModifiers(), HEX);
        tft.print(" OEM: ");
        tft.print(keyboard1.getOemKey(), HEX);
        tft.print(" LEDS: ");
        tft.println(keyboard1.LEDS(), HEX);
        tft.print(keyboard2.getModifiers(), HEX);
        tft.print(keyboard2.getOemKey(), HEX);
        tft.println(keyboard2.LEDS(), HEX);
      //Serial.print("key ");
      //Serial.print((char)keyboard1.getKey());
      //Serial.print("  ");
      //Serial.print((char)keyboard2.getKey());
      //Serial.println();
    void OnHIDExtrasPress(uint32_t top, uint16_t key)
      tft.print("HID (");
      tft.print(top, HEX);
      tft.print(") key press:");
      tft.print(key, HEX);
      if (top == 0xc0000) {
        switch (key) {
          case  0x20 : tft.print(" - +10"); break;
          case  0x21 : tft.print(" - +100"); break;
          case  0x22 : tft.print(" - AM/PM"); break;
          case  0x30 : tft.print(" - Power"); break;
          case  0x31 : tft.print(" - Reset"); break;
          case  0x32 : tft.print(" - Sleep"); break;
          case  0x33 : tft.print(" - Sleep After"); break;
          case  0x34 : tft.print(" - Sleep Mode"); break;
          case  0x35 : tft.print(" - Illumination"); break;
          case  0x36 : tft.print(" - Function Buttons"); break;
          case  0x40 : tft.print(" - Menu"); break;
          case  0x41 : tft.print(" - Menu  Pick"); break;
          case  0x42 : tft.print(" - Menu Up"); break;
          case  0x43 : tft.print(" - Menu Down"); break;
          case  0x44 : tft.print(" - Menu Left"); break;
          case  0x45 : tft.print(" - Menu Right"); break;
          case  0x46 : tft.print(" - Menu Escape"); break;
          case  0x47 : tft.print(" - Menu Value Increase"); break;
          case  0x48 : tft.print(" - Menu Value Decrease"); break;
          case  0x60 : tft.print(" - Data On Screen"); break;
          case  0x61 : tft.print(" - Closed Caption"); break;
          case  0x62 : tft.print(" - Closed Caption Select"); break;
          case  0x63 : tft.print(" - VCR/TV"); break;
          case  0x64 : tft.print(" - Broadcast Mode"); break;
          case  0x65 : tft.print(" - Snapshot"); break;
          case  0x66 : tft.print(" - Still"); break;
          case  0x80 : tft.print(" - Selection"); break;
          case  0x81 : tft.print(" - Assign Selection"); break;
          case  0x82 : tft.print(" - Mode Step"); break;
          case  0x83 : tft.print(" - Recall Last"); break;
          case  0x84 : tft.print(" - Enter Channel"); break;
          case  0x85 : tft.print(" - Order Movie"); break;
          case  0x86 : tft.print(" - Channel"); break;
          case  0x87 : tft.print(" - Media Selection"); break;
          case  0x88 : tft.print(" - Media Select Computer"); break;
          case  0x89 : tft.print(" - Media Select TV"); break;
          case  0x8A : tft.print(" - Media Select WWW"); break;
          case  0x8B : tft.print(" - Media Select DVD"); break;
          case  0x8C : tft.print(" - Media Select Telephone"); break;
          case  0x8D : tft.print(" - Media Select Program Guide"); break;
          case  0x8E : tft.print(" - Media Select Video Phone"); break;
          case  0x8F : tft.print(" - Media Select Games"); break;
          case  0x90 : tft.print(" - Media Select Messages"); break;
          case  0x91 : tft.print(" - Media Select CD"); break;
          case  0x92 : tft.print(" - Media Select VCR"); break;
          case  0x93 : tft.print(" - Media Select Tuner"); break;
          case  0x94 : tft.print(" - Quit"); break;
          case  0x95 : tft.print(" - Help"); break;
          case  0x96 : tft.print(" - Media Select Tape"); break;
          case  0x97 : tft.print(" - Media Select Cable"); break;
          case  0x98 : tft.print(" - Media Select Satellite"); break;
          case  0x99 : tft.print(" - Media Select Security"); break;
          case  0x9A : tft.print(" - Media Select Home"); break;
          case  0x9B : tft.print(" - Media Select Call"); break;
          case  0x9C : tft.print(" - Channel Increment"); break;
          case  0x9D : tft.print(" - Channel Decrement"); break;
          case  0x9E : tft.print(" - Media Select SAP"); break;
          case  0xA0 : tft.print(" - VCR Plus"); break;
          case  0xA1 : tft.print(" - Once"); break;
          case  0xA2 : tft.print(" - Daily"); break;
          case  0xA3 : tft.print(" - Weekly"); break;
          case  0xA4 : tft.print(" - Monthly"); break;
          case  0xB0 : tft.print(" - Play"); break;
          case  0xB1 : tft.print(" - Pause"); break;
          case  0xB2 : tft.print(" - Record"); break;
          case  0xB3 : tft.print(" - Fast Forward"); break;
          case  0xB4 : tft.print(" - Rewind"); break;
          case  0xB5 : tft.print(" - Scan Next Track"); break;
          case  0xB6 : tft.print(" - Scan Previous Track"); break;
          case  0xB7 : tft.print(" - Stop"); break;
          case  0xB8 : tft.print(" - Eject"); break;
          case  0xB9 : tft.print(" - Random Play"); break;
          case  0xBA : tft.print(" - Select DisC"); break;
          case  0xBB : tft.print(" - Enter Disc"); break;
          case  0xBC : tft.print(" - Repeat"); break;
          case  0xBD : tft.print(" - Tracking"); break;
          case  0xBE : tft.print(" - Track Normal"); break;
          case  0xBF : tft.print(" - Slow Tracking"); break;
          case  0xC0 : tft.print(" - Frame Forward"); break;
          case  0xC1 : tft.print(" - Frame Back"); break;
          case  0xC2 : tft.print(" - Mark"); break;
          case  0xC3 : tft.print(" - Clear Mark"); break;
          case  0xC4 : tft.print(" - Repeat From Mark"); break;
          case  0xC5 : tft.print(" - Return To Mark"); break;
          case  0xC6 : tft.print(" - Search Mark Forward"); break;
          case  0xC7 : tft.print(" - Search Mark Backwards"); break;
          case  0xC8 : tft.print(" - Counter Reset"); break;
          case  0xC9 : tft.print(" - Show Counter"); break;
          case  0xCA : tft.print(" - Tracking Increment"); break;
          case  0xCB : tft.print(" - Tracking Decrement"); break;
          case  0xCD : tft.print(" - Pause/Continue"); break;
          case  0xE0 : tft.print(" - Volume"); break;
          case  0xE1 : tft.print(" - Balance"); break;
          case  0xE2 : tft.print(" - Mute"); break;
          case  0xE3 : tft.print(" - Bass"); break;
          case  0xE4 : tft.print(" - Treble"); break;
          case  0xE5 : tft.print(" - Bass Boost"); break;
          case  0xE6 : tft.print(" - Surround Mode"); break;
          case  0xE7 : tft.print(" - Loudness"); break;
          case  0xE8 : tft.print(" - MPX"); break;
          case  0xE9 : tft.print(" - Volume Up"); break;
          case  0xEA : tft.print(" - Volume Down"); break;
          case  0xF0 : tft.print(" - Speed Select"); break;
          case  0xF1 : tft.print(" - Playback Speed"); break;
          case  0xF2 : tft.print(" - Standard Play"); break;
          case  0xF3 : tft.print(" - Long Play"); break;
          case  0xF4 : tft.print(" - Extended Play"); break;
          case  0xF5 : tft.print(" - Slow"); break;
          case  0x100: tft.print(" - Fan Enable"); break;
          case  0x101: tft.print(" - Fan Speed"); break;
          case  0x102: tft.print(" - Light"); break;
          case  0x103: tft.print(" - Light Illumination Level"); break;
          case  0x104: tft.print(" - Climate Control Enable"); break;
          case  0x105: tft.print(" - Room Temperature"); break;
          case  0x106: tft.print(" - Security Enable"); break;
          case  0x107: tft.print(" - Fire Alarm"); break;
          case  0x108: tft.print(" - Police Alarm"); break;
          case  0x150: tft.print(" - Balance Right"); break;
          case  0x151: tft.print(" - Balance Left"); break;
          case  0x152: tft.print(" - Bass Increment"); break;
          case  0x153: tft.print(" - Bass Decrement"); break;
          case  0x154: tft.print(" - Treble Increment"); break;
          case  0x155: tft.print(" - Treble Decrement"); break;
          case  0x160: tft.print(" - Speaker System"); break;
          case  0x161: tft.print(" - Channel Left"); break;
          case  0x162: tft.print(" - Channel Right"); break;
          case  0x163: tft.print(" - Channel Center"); break;
          case  0x164: tft.print(" - Channel Front"); break;
          case  0x165: tft.print(" - Channel Center Front"); break;
          case  0x166: tft.print(" - Channel Side"); break;
          case  0x167: tft.print(" - Channel Surround"); break;
          case  0x168: tft.print(" - Channel Low Frequency Enhancement"); break;
          case  0x169: tft.print(" - Channel Top"); break;
          case  0x16A: tft.print(" - Channel Unknown"); break;
          case  0x170: tft.print(" - Sub-channel"); break;
          case  0x171: tft.print(" - Sub-channel Increment"); break;
          case  0x172: tft.print(" - Sub-channel Decrement"); break;
          case  0x173: tft.print(" - Alternate Audio Increment"); break;
          case  0x174: tft.print(" - Alternate Audio Decrement"); break;
          case  0x180: tft.print(" - Application Launch Buttons"); break;
          case  0x181: tft.print(" - AL Launch Button Configuration Tool"); break;
          case  0x182: tft.print(" - AL Programmable Button Configuration"); break;
          case  0x183: tft.print(" - AL Consumer Control Configuration"); break;
          case  0x184: tft.print(" - AL Word Processor"); break;
          case  0x185: tft.print(" - AL Text Editor"); break;
          case  0x186: tft.print(" - AL Spreadsheet"); break;
          case  0x187: tft.print(" - AL Graphics Editor"); break;
          case  0x188: tft.print(" - AL Presentation App"); break;
          case  0x189: tft.print(" - AL Database App"); break;
          case  0x18A: tft.print(" - AL Email Reader"); break;
          case  0x18B: tft.print(" - AL Newsreader"); break;
          case  0x18C: tft.print(" - AL Voicemail"); break;
          case  0x18D: tft.print(" - AL Contacts/Address Book"); break;
          case  0x18E: tft.print(" - AL Calendar/Schedule"); break;
          case  0x18F: tft.print(" - AL Task/Project Manager"); break;
          case  0x190: tft.print(" - AL Log/Journal/Timecard"); break;
          case  0x191: tft.print(" - AL Checkbook/Finance"); break;
          case  0x192: tft.print(" - AL Calculator"); break;
          case  0x193: tft.print(" - AL A/V Capture/Playback"); break;
          case  0x194: tft.print(" - AL Local Machine Browser"); break;
          case  0x195: tft.print(" - AL LAN/WAN Browser"); break;
          case  0x196: tft.print(" - AL Internet Browser"); break;
          case  0x197: tft.print(" - AL Remote Networking/ISP Connect"); break;
          case  0x198: tft.print(" - AL Network Conference"); break;
          case  0x199: tft.print(" - AL Network Chat"); break;
          case  0x19A: tft.print(" - AL Telephony/Dialer"); break;
          case  0x19B: tft.print(" - AL Logon"); break;
          case  0x19C: tft.print(" - AL Logoff"); break;
          case  0x19D: tft.print(" - AL Logon/Logoff"); break;
          case  0x19E: tft.print(" - AL Terminal Lock/Screensaver"); break;
          case  0x19F: tft.print(" - AL Control Panel"); break;
          case  0x1A0: tft.print(" - AL Command Line Processor/Run"); break;
          case  0x1A1: tft.print(" - AL Process/Task Manager"); break;
          case  0x1A2: tft.print(" - AL Select Tast/Application"); break;
          case  0x1A3: tft.print(" - AL Next Task/Application"); break;
          case  0x1A4: tft.print(" - AL Previous Task/Application"); break;
          case  0x1A5: tft.print(" - AL Preemptive Halt Task/Application"); break;
          case  0x200: tft.print(" - Generic GUI Application Controls"); break;
          case  0x201: tft.print(" - AC New"); break;
          case  0x202: tft.print(" - AC Open"); break;
          case  0x203: tft.print(" - AC Close"); break;
          case  0x204: tft.print(" - AC Exit"); break;
          case  0x205: tft.print(" - AC Maximize"); break;
          case  0x206: tft.print(" - AC Minimize"); break;
          case  0x207: tft.print(" - AC Save"); break;
          case  0x208: tft.print(" - AC Print"); break;
          case  0x209: tft.print(" - AC Properties"); break;
          case  0x21A: tft.print(" - AC Undo"); break;
          case  0x21B: tft.print(" - AC Copy"); break;
          case  0x21C: tft.print(" - AC Cut"); break;
          case  0x21D: tft.print(" - AC Paste"); break;
          case  0x21E: tft.print(" - AC Select All"); break;
          case  0x21F: tft.print(" - AC Find"); break;
          case  0x220: tft.print(" - AC Find and Replace"); break;
          case  0x221: tft.print(" - AC Search"); break;
          case  0x222: tft.print(" - AC Go To"); break;
          case  0x223: tft.print(" - AC Home"); break;
          case  0x224: tft.print(" - AC Back"); break;
          case  0x225: tft.print(" - AC Forward"); break;
          case  0x226: tft.print(" - AC Stop"); break;
          case  0x227: tft.print(" - AC Refresh"); break;
          case  0x228: tft.print(" - AC Previous Link"); break;
          case  0x229: tft.print(" - AC Next Link"); break;
          case  0x22A: tft.print(" - AC Bookmarks"); break;
          case  0x22B: tft.print(" - AC History"); break;
          case  0x22C: tft.print(" - AC Subscriptions"); break;
          case  0x22D: tft.print(" - AC Zoom In"); break;
          case  0x22E: tft.print(" - AC Zoom Out"); break;
          case  0x22F: tft.print(" - AC Zoom"); break;
          case  0x230: tft.print(" - AC Full Screen View"); break;
          case  0x231: tft.print(" - AC Normal View"); break;
          case  0x232: tft.print(" - AC View Toggle"); break;
          case  0x233: tft.print(" - AC Scroll Up"); break;
          case  0x234: tft.print(" - AC Scroll Down"); break;
          case  0x235: tft.print(" - AC Scroll"); break;
          case  0x236: tft.print(" - AC Pan Left"); break;
          case  0x237: tft.print(" - AC Pan Right"); break;
          case  0x238: tft.print(" - AC Pan"); break;
          case  0x239: tft.print(" - AC New Window"); break;
          case  0x23A: tft.print(" - AC Tile Horizontally"); break;
          case  0x23B: tft.print(" - AC Tile Vertically"); break;
          case  0x23C: tft.print(" - AC Format"); break;
      tft.println();
    void OnHIDExtrasRelease(uint32_t top, uint16_t key)
      tft.print("HID (");
      tft.print(") key release:");
      tft.println(key, HEX);
  2. #602
    8,317
    Playing computer update games … so basically offline - one more 4.5GB download to update Adobe …
    @mjs513 - what video lib is used for post #601? I don't see a 9341 include other than FONT - does that pull in the expected lib? Want to make sure I have the right current libs for all when I get to download that.
    If I've followed posts it seems scroll is TFT_READ_rect then write_rect - not using hardware scrolling?
  3. #603
    Senior Member+
    New York
    3,189
    Morning @defragster
    Hmm - funny it uses the ILI9341_t3n library - funny thing is that it works with out it being specified - Ok - just realized why it works. The font .h includes the reference to the library
    Not sure - seems to work fine on the T4 but FB_Teensy64 seems to have an issue with the readrectangle/writerectangle…. Just can't figure out why though. Kurt's issue seemed to be a wiring issue - once he jiggle some wires it worked on the T$.
  4. #604
    4,544
    Good Morning: Assuming I can get a few minutes in between having to do something for Annie...
    I was going to hack (update) the test app to use Frame buffer... Two reasons:
    a) Speed - like scrolling your text area, will simply be moving data...
    b) does not depend on MISO...
  5. #605
    Senior Member+
    New York
    3,189
    Good morning...
    Cool - now I will learn how framebuffer works. Going to be busy today myself with plumbers and a couple of other projects.
  6. #606
    4,544
    Hi @mjs513 and ...
    Here is a version that has some frame buffer turned on... Note: Not using DMA here...
    // Simple test viewer app for several of the USB devices on ili9341 display
    // Teensy 3.6 Pins
    //   8 = RST
    //   9 = D/C
    //  10 = CS
    #define TEENSY64
    DMAMEM uint16_t frame_buffer[ILI9341_TFTWIDTH * ILI9341_TFTHEIGHT];
    #define TFT_RST 255
    #define TFT_DC 20
    #define TFT_CS 21
    #define TFT_RST 23
    #define TFT_DC 9
    #define TFT_CS 10
    #define TFT_RST 255
    #define TFT_DC 20
    #define TFT_CS 21
    #define TFT_SCK 14
    #define TFT_MISO 39
    #define TFT_MOSI 28
    #else
    // USB Host Ojbects
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    bool driver_active[CNT_DEVICES] = {false, false, false, false, false};
    bool hid_driver_active[CNT_HIDDEVICES] = {false, false, false, false};
    int x_cur = 0,
        y_cur = 0,
        z_cur = 0;
    int x2_cur = 0,
        y2_cur = 0,
        z2_cur = 0;
    int wheel_cur = 0;
    int wheelH_cur = 0;
    int axis_cur[10];
    String p = "KB1";
    bool BT = 0;
    int user_axis[64];
    uint32_t buttons;
    // Setup
      myusb.begin();
      tft.begin();
      // explicitly set the frame buffer
      tft.setFrameBuffer(frame_buffer);
      tft.setTextSize(2);
      tft.println("Waiting for Device...");
      tft.useFrameBuffer(true);
    // Loop
      myusb.Task();
      ProcessMouseData();
            tft.updateScreen(); // update the screen now
      // Then Hid Devices
          int16_t x;
            axis_cur[i] = axis;
          int16_t x, y2;
            y += line_space;
      int16_t x2, y2;
      tft.fillRect(x2, y, field_width - (x2 - x), Arial_12.line_space, ILI9341_BLACK);
    // ProcessMouseData
          int16_t x;
          int16_t x, y2;
        uint8_t ltv;
        uint8_t rtv;
          default:
        TFT_joystick();
    // TFT_joystick
    void TFT_joystick()
      if (buttons == 0) {
      //Gamepads
        default:
    // ProcessMouseData
        for (uint32_t j = 0; j < len; j++) {
          wheel_cur = 0;
          wheelH_cur = 0;
          len--;
        if (len) {
      return true;
    void MaybeSetupTextScrollArea()
        BT = 0;
      if (BT == 0) {
        tft.enableScroll();
        tft.setScrollTextArea(20, 70, 280, 140);
        BT = 1;
      MaybeSetupTextScrollArea();
      tft.print("key: ");
      switch (key) {
      tft.print("'  ");
      tft.print(key);
      if (keyboard1) {
      //Serial.println();
      tft.print("HID (");
        switch (key) {
      tft.println();
      tft.print("HID (");
    Will be interesting to see how well this works... I defined the frame_buffer so as to be able to see when you compile how big the program is... But had to specify DMAMEM on T4 as won't fit in other memory... This appears to work... May have to have some fun to see if the Async update works... Probably not in this default case, as I don't think I put in the code to force the stuff in the memory cache to physical memory and so the DMA will use semi-random values...
  7. #607
    Senior Member+
    New York
    3,189
    @KurtE and others ….
    Just tried this on the T$ and the FB_Teensy64. Used the BT Keyboard, USB Keyboard and the PS4. As expected the T$ worked with no problem didn't notice any changes to the screen except (smile) screen updates were a lot smoother.
    On the FB_Teensy64 the issues with the scrolling disappearing for previous lines worked as it does on the T$ and screen update was smooth.
    Ok, so where do we go from here … what's that I forgot we had to do?
    On a side note using framebuffer is a lot simpler than I thought, only four things to remember:
      // explicitly set the frame buffer in setup
      //in the loop
      tft.updateScreen(); // update the screen now when you are finished drawing the screen.
    Cool
  8. #608
    4,544
    Hi @mjs513 and
    Actually allocating and using setFrameBuffer is optional. If you don't do this, the first time you call useFrameBuffer(true);
    it will use malloc to allocate it.
    And this is only one (the easiest usage pattern)...
    The next levels use DMA... The usage I have used in some places is to replace the tft.updateScreen
    with updateScreenAsync()
    Or with the default parameter of false...
    This will start up a DMA update of the screen (only update once). Sometimes I know it will awhile before I update again, so I just start it and forget it.
    Other times I might uese either asyncUpdateActive() to find out if it is still running, or waitUpdateAsyncComplete(), to wait for it to complete...
    These later cases are used if I am about to update the screen and I don't want to do it until the last update completed...
    And I have the continuous updates updateScreenAsync(TRUE); which will continue to update the screen from the frame buffer until I turn it off with endUpdateAsync();
    More of Frank's usage pattern, which can be great if you set up your code to take advantage of it and for example maybe know when the screen just finishes updating the mid point or the like and start filling in the next frame...
    As for what is next, maybe we should Check in the stuff into the sample app? Also maybe update joystick display code?
  9. #609
    Senior Member+
    New York
    3,189
    Hi @mjs513 and
    Wow - that's going to take a while to set in on dma You know me....
    I forgot about updating the Joystick display code. Maybe we should do that before checking the app in. I'll take a look to see how to make it mirror the mouse.
    Guess looking at the 9488 is a little bit premature.
  10. #610
    Senior Member+
    New York
    3,189
    @KurtE/@defragster
    Here is a start for making it look like a mouse. Have to do some more playing since the data position is different whether its on Serial or Bluetooth:
    // Teensy 3.6 Pins
    //   8 = RST
    //   9 = D/C
    //  10 = CS
    #define TEENSY64
    #define TFT_RST 255
    #define TFT_DC 20
    #define TFT_CS 21
    #define TFT_RST 23
    #define TFT_DC 9
    #define TFT_CS 10
    #define TFT_RST 255
    #define TFT_DC 20
    #define TFT_CS 21
    #define TFT_SCK 14
    #define TFT_MISO 39
    #define TFT_MOSI 28
    #else
    // USB Host Ojbects
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    int x_cur = 0,
        y_cur = 0,
        z_cur = 0;
    int x2_cur = 0,
        y2_cur = 0,
        z2_cur = 0;
    int wheel_cur = 0;
    int wheelH_cur = 0;
    int axis_cur[10];
    String p = "KB1";
    bool BT = 0;
    int user_axis[64];
    uint32_t buttons;
    // Setup
      myusb.begin();
      tft.begin();
      tft.setTextSize(2);
    // Loop
      myusb.Task();
      ProcessMouseData();
      // Then Hid Devices
          int16_t x;
            axis_cur[i] = axis;
          int16_t x, y2;
            y += line_space;
      int16_t x2, y2;
    // ProcessMouseData
          int16_t x;
          int16_t x, y2;
        uint8_t ltv;
        uint8_t rtv;
          default:
        tft_JoystickData();
    // TFT_joystick
    void tft_JoystickData() {
          int16_t x;
          tft.printf("Buttons:\nX:\nY:\nX2\nY2(Z):\nHat:");
        if (buttons != buttons_prev) {  //buttons
        if (user_axis[0] != x_cur) {  //xL
        if (user_axis[1] != y_cur) {  //yL
        if (user_axis[9] != wheel_cur) {  //Hat
      //Second Axis
        if (user_axis[2] != x2_cur) {  //xR
        if (user_axis[5] != y2_cur) {  //yR or z-axis
          int16_t x, y2;
          tft.printf("%d(%x)", buttons, buttons);
          y += line_space; OutputNumberField(MOUSE_DATA_X, y, x2_cur, 320);
          y += line_space; OutputNumberField(MOUSE_DATA_X, y, y2_cur, 320);
    // ProcessMouseData
          wheel_cur = 0;
          wheelH_cur = 0;
          len--;
        if (len) {
      return true;
        BT = 0;
      if (BT == 0) {
        tft.enableScroll();
        BT = 1;
      tft.print("key: ");
      switch (key) {
      tft.print("'  ");
      tft.print(key);
      if (keyboard1) {
      //Serial.println();
      tft.print("HID (");
        switch (key) {
      tft.println();
      tft.print("HID (");
  11. #611
    4,544
    Starting to look pretty good. Wonder if we should also include some of the other axis... Example show the L2/R2 ones for ps3/4...
    Maybe soon push up current version.
  12. #612
    Senior Member+
    New York
    3,189
    Yeah was thinking about that but not sure whether to just list the values or put it left? Think you are right - its just about ready for prime time
  13. #613
    Senior Member+
    New York
    3,189
    @KurtE/@defragster
    Ok. Done = joystick code needs a little more cleaning but here it is (Tested with Logitech3d, PS4, PS3 &XBOX):
    // Teensy 3.6 Pins
    //   8 = RST
    //   9 = D/C
    //  10 = CS
    #define TEENSY64
    #define TFT_RST 255
    #define TFT_DC 20
    #define TFT_CS 21
    #define TFT_RST 23
    #define TFT_DC 9
    #define TFT_CS 10
    #define TFT_RST 255
    #define TFT_DC 20
    #define TFT_CS 21
    #define TFT_SCK 14
    #define TFT_MISO 39
    #define TFT_MOSI 28
    #else
    // USB Host Ojbects
    USBHost myusb;
    USBHub hub1(myusb);
    USBHub hub2(myusb);
    int x_cur = 0,
        y_cur = 0,
        z_cur = 0;
    int x2_cur = 0,
        y2_cur = 0,
        z2_cur = 0,
        L1_cur = 0,
        R1_cur = 0;
    int wheel_cur = 0;
    int wheelH_cur = 0;
    int axis_cur[10];
    String p = "KB1";
    bool BT = 0;
    int user_axis[64];
    uint32_t buttons;
    // Setup
      myusb.begin();
      tft.begin();
      tft.setTextSize(2);
    // Loop
      myusb.Task();
      ProcessMouseData();
      // Then Hid Devices
          int16_t x;
            axis_cur[i] = axis;
          int16_t x, y2;
            y += line_space;
      int16_t x2, y2;
    // ProcessMouseData
          int16_t x;
          int16_t x, y2;
        uint8_t ltv;
        uint8_t rtv;
          default:
        tft_JoystickData();
    // TFT_joystick
          int16_t x;
          tft.printf("Buttons:\nX:\nY:\nX2\nY2(Z):\nL1:\nR1:\nHAT:");
      //Second Axis
        //Rumble Axis
              if (user_axis[3] != L1_cur) {  //xR
                L1_cur = user_axis[3];
              if (user_axis[4] != R1_cur) {  //yR or z-axis
                R1_cur = user_axis[4];
              if (user_axis[18] != L1_cur) {  //xR
                L1_cur = user_axis[18];
              if (user_axis[19] != R1_cur) {  //yR or z-axis
                R1_cur = user_axis[19];
          int16_t x, y2;
          y += line_space; OutputNumberField(MOUSE_DATA_X, y, x_cur, 320);  //x
          y += line_space; OutputNumberField(MOUSE_DATA_X, y, y_cur, 320);  //y
          y += line_space; OutputNumberField(MOUSE_DATA_X, y, x2_cur, 320); //x2(z)
          y += line_space; OutputNumberField(MOUSE_DATA_X, y, y2_cur, 320); //y2
              y += line_space; OutputNumberField(MOUSE_DATA_X, y, L1_cur, 320);
              y += line_space; OutputNumberField(MOUSE_DATA_X, y, R1_cur, 320);
            default:
              y += line_space; OutputNumberField(MOUSE_DATA_X, y, 0, 320);
              y += line_space; OutputNumberField(MOUSE_DATA_X, y, wheel_cur, 320); //hat
    // ProcessMouseData
          wheel_cur = 0;
          wheelH_cur = 0;
          len--;
        if (len) {
      return true;
        BT = 0;
      if (BT == 0) {
        tft.enableScroll();
        BT = 1;
      tft.print("key: ");
      switch (key) {
      tft.print("'  ");
      tft.print(key);
      if (keyboard1) {
      //Serial.println();
      tft.print("HID (");
        switch (key) {
      tft.println();
      tft.print("HID (");
  14. #614
    4,544
    @mjs513 - Looks pretty good to me
    I would say check it in!
  15. #615
    Senior Member+
    New York
    3,189
    @KurtE
    What would like to call this thing?
  16. #616
    4,544
    I think I put an much earlier version up there as your suggested name (USBHost_viewer)
  17. #617
    Senior Member+
    New York
    3,189
    @KurtE
    Had to update my copy of the library first Anyway just pushed the changes and created the PR. Also on the other thread started mods to the _t3 lib. Not working of course, put the write16colors in with SPI.transfer but nothing being drawn = we'll see - just starting.
  18. #618
    4,544
    @mjs513 - PR has been merged...
    Started playing with the 9488 library version as well. I updated all of the writedata16_(cont, last) functions with writecolor_ functions and still works.
    Currently just hard coded inline functions to call the writedata...
    Still wondering if in end code will be stand alone for 9488 or shared with 9341, but updated most of the functions now that used hard coded width/height to use the _width and _height functions. Still need to update setRotation and init code to define the valid width and height.
    Again not sure yet if combined for both displays, or not. May start off combined. Then maybe function like:
    	void writecolor_cont(uint16_t d) __attribute__((always_inline)) {
    		writedata16_cont(d);
    changes to:
    void writecolor_cont(uint16_t d) {
        if (_displaytype == TFT_ILI9341)
        else {
            // Not sure if we may need to scale these color numbers or not?
    #if defined(__IMXRT1052__) || defined(__IMXRT1062__)  // Teensy 4.x
            uint32_t color_out = ((uint32_t)(d & 0xf800)<< 5) | (((uint32_t)(d & 0x0x7E0)<< 3) | (d & 0x1f);
    	maybeUpdateTCR(LPSPI_TCR_PCS(1) | LPSPI_TCR_FRAMESZ(23) | LPSPI_TCR_CONT);
    	_pimxrt_spi->TDR = d;
    	_pspin->pending_rx_count++;	//
    	_pspin->waitFifoNotFull();
    #else
            writedata8_cont((d & 0xF800) >> 11);  // R
            writedata8_cont((d & 0x07E0) >> 5);  // G
            writedata8_cont(d & 0x001F);  //B
    Senior Member+
    New York
    3,189
    @KurtE
    Cool. Was just toying with the idea to try it with the _t3n. Assuming that is what you just modified.
    The only thing I noticed was with the colors being off so not sure if that a function of converting to 565 then to what is used in the writedata function.
  20. #620
    8,317
    Hello - giving up on T$_BreakOut has me back able to do stuff. T4 breadboard as noted working 9488 - so no USBHost there.
    >> Have a Teensy64_v0.3 with an ili9341 that works with display of BtMice - this is the ones you guys got and with KurtE/ILI9341_t3n master
    >> Also have a another T_64 USBHost pinned to go with Teensy64_v0.1 assembled and working! I tied an ili9488 down on that and it runs Bhudda and GraphicsTest and has working USBHost!
    Will try to keep up on TFT developments - not sure where the scroll stuff is - or how to use it for which display.
    - My MSFT mouse has a WINDOWS button - that doesn't display on View.ino
    Re: View.ino
    - seems on both T_3.6's needs Bt plugged in before setup to work?
    - does it only work on the first device it sees?
    I need to check out Teensy64 touch connection - would be nice to touch for page/device changes?
  21. #621
    Senior Member+
    New York
    3,189
    @defragster
    Glad you are up and running again. I just added scroll to the 9488 lib but now working with the display have to go through it again. There is a scroll example in the examples folder of the _t3n library that you are using.
    Re: View.ino
    The Window button - probably have to find out what key code the mouse is using - maybe look at the raw data from serial one and see if its on the list - could be some strange number.
    Don't remember any issues with having to have BT plugged in - do know you do need something plugged into the usb adapter before it starts.
  22. #622
    4,544
    @defragster and @mjs513 - If I remember correctly the windows key does it's own special (device vendor specific) thing, which required a device driver to interpret.... So I am pretty sure I did not put in any hooks to catch it...
    Should work with BT plugged in to begin and/or later (likewise other devices). Probably need to do some more testing of startup and shutdown of devices. That is if you unplug something like the BT adapter or a mouse, are all of the devices properly notified and set into a unused state, such that if you plug it or something else back in, it should work again. Or did we leave some objects hanging...
  23. #623
    Senior Member+
    New York
    3,189
    @KurtE and @defragster,
    I did a lot of that testing with serial no problem with plugging in one device and then another. To be honest, can't remember - have to give it a another try but somehow I remember the issue was that only the dongle was identified as the device but not what was attached to the dongle. So anytime you went to try and connect a different device you had to reset the sketch.
  24. #624
    Oct 2016
    13
    It has been many months since I've looked for updates about PS3 controllers over bluetooth.
    Looks like there has been some progress. That is great to see (thank you to those contributing).
    I'll have to dig out my Teensy boards and see how things are working with PS3 Move Navigation controllers.
  25. #625
    Oct 2016
    13
    Few hiccups, and step forward with using Sony Move Navigation controllers:
    *** Device HID1 54c:42f - connected ***
    manufacturer: Sony
    product: Navigation Controller
    *** HID Device Joystick1 54c:42f - connected ***
    manufacturer: Sony
    Modified joystick.cpp:
    	{ 0x054C, 0x0268, PS3, true },
    To:
    	{ 0x054C, 0x0268, PS3, true }, { 0x054C, 0x042F, PS3, true }, { 0x054C, 0x03D5, PS3, true },
    Modified hid.cpp:
    	if (device->idVendor == 0x054C && device->idProduct == 0x0268 )  {
    To:
    	if (device->idVendor == 0x054C && ( device->idProduct == 0x0268 || device->idProduct == 0x042F || device->idProduct == 0x03D5 ))  {
    At this point, I can compile and deploy it to my Teensy 3.6 board.
    If I connect the controller over wired USB, it appears to connect ok:
    USB Host Testing
    960
    manufacturer: Sony
    manufacturer: Sony
    *** First Joystick message 54c:42f ***
    manufacturer: Sony
    LX: 134, LY: 127, RX: 125, RY: 132
    L-Trig: 0, R-Trig: 0
    Buttons: 0
    If I connect it via Bluetooth (after connecting it via wired USB)
    *** Device HID1 - disconnected ***
    *** HID Device Joystick1 - disconnected ***
    *** Device Bluet a12:1 - connected ***
    product: CSR8510 A10
    BDADDR: 0:0:0:0:0:0
    LX: 123, LY: 128, RX: 125, RY: 132
    Buttons: 0
    Over Bluetooth, L2 gives me:
    LX: 124, LY: 126, RX: 125, RY: 132
    L-Trig: 255, R-Trig: 0
    Buttons: 100
    Rumbling: 255, 0
    The first number after Rumbling appears to read the analog input from L2)
    In contrast, a wired connection never gives me the analog reading from the L2 button.
    I think that my biggest question right now is:
    If I do a clean boot, the controller doesn't want to connect to bluetooth unless I first establish a wired connection.
    Is this expected?
