KurtE
Senior Member+
@knightshade - Sounds like some reasonable changes for handling the different PS3 type controller.
I don't know much about these controllers:
But I assume if PS3, then the binding with BT addapter is the same as with other PS3...
On those, with the JoystickBT test app, we have code in place that if you hold down the Select button and press the PS3 button while both the BT and PS3 are plugged in or if you just before this you had a BT plugged in (without rebooting), The code will remember the address of the last BT adapter plugged in and then tell the PS3 (while it is connected directly to USB) to program itself to talk to that controller...
With the PS3 type controllers. You probably also need/want to make sure your app is using the version of the
BluetoothController object without the pairing stuff in the constructor:
That is use: BluetoothController bluet(myusb);
Not: BluetoothController bluet(myusb, true, "0000");
At some point I may need to pick up one of these controllers, if we can not easily find a fix for you.
Edit: Ordered a pack of 2 of them on Ebay for under $20 shipped supposedly here by Friday...
