T3.6 USB Host - Bluetooth
@knightshade - Sounds like some reasonable changes for handling the different PS3 type controller.
I don't know much about these controllers:
But I assume if PS3, then the binding with BT addapter is the same as with other PS3...
On those, with the JoystickBT test app, we have code in place that if you hold down the Select button and press the PS3 button while both the BT and PS3 are plugged in or if you just before this you had a BT plugged in (without rebooting), The code will remember the address of the last BT adapter plugged in and then tell the PS3 (while it is connected directly to USB) to program itself to talk to that controller...
With the PS3 type controllers. You probably also need/want to make sure your app is using the version of the
BluetoothController object without the pairing stuff in the constructor:
That is use: BluetoothController bluet(myusb);
Not: BluetoothController bluet(myusb, true, "0000");
At some point I may need to pick up one of these controllers, if we can not easily find a fix for you.
Edit: Ordered a pack of 2 of them on Ebay for under $20 shipped supposedly here by Friday...
From my experience, these are effectively "half" of a DualShock 3 or Sixaxis PS3 Controller.
The "Move Motion" controller is the "right" half, and the "Move Navigation" is the left haft.
For our usage (controlling R2), we have been using one or two of the "Move Navigation" controllers.
(The joystick was key for our needs)
It is interesting to note, that we do NOT have a "Select button" on a "Move Navigation" stick.
Our controls include: X, O, Dpad, L1, L2, L3, PS and joystick
Lack of the "Select" button might cause some challenges with that approach to pairing future controllers - at least using the teensy. ;-)
In my case, I had previously paired them with my Arduino/Host Shield using UHS2.
With their setup - I start with the Dongle plugged in. Unplug it and connect the PS3 controller. It automatically programs/pairs it to the last dongle MAC address that was connected.
I did check that I was using the line 'BluetoothController bluet(myusb);' (without the "0000")
Start with a PS3 controller and dongle that are already paired (and tested working).
If I power up the Teensy 3.6 with JoystickBT.ino
USB Host Testing
960
*** Device Bluet a12:1 - connected ***
product: CSR8510 A10
BDADDR: f7:a4:ca:83:15:0
I can turn on the PS3 controller (PS button), lights flicker (on both controler and dongle) -
but nothing new in the serial monitor.
If I unplug the BT controller, and connect the PS3 controller by wire:
*** Device Bluet - disconnected ***
*** Device HID1 54c:42f - connected ***
manufacturer: Sony
product: Navigation Controller
*** HID Device Joystick1 54c:42f - connected ***
manufacturer: Sony
*** First Joystick message 54c:42f ***
manufacturer: Sony
LX: 0, LY: 0, RX: 106, RY: 115
L-Trig: 0, R-Trig: 0
Buttons: 0
[snip]
LX: 129, LY: 127, RX: 125, RY: 132
Buttons: 0
*** Device HID1 - disconnected ***
*** HID Device Joystick1 - disconnected ***
If I move the joystick, or press buttons - I see values as I expect.
I can reconnect the bluetooth Dongle:
I can now power up the PS3 joystick (PS button), and it now connects over Bluetooth.
I get the messages:
LX: 126, LY: 126, RX: 125, RY: 132
Buttons: 0
LX: 125, LY: 126, RX: 125, RY: 132
Buttons: 0
Again: if I move the joystick, or press buttons - I see values as I expect.
Mac addresses of the devices tried:
Dongle f7:a4:ca:83:15:00
Paired Controller 1: 00:07:04:B9:D2:09
Paired Controller 2: 04:76:6E:80:59:A7
Where I am at a loss:
Why will it connect via bluetooth *ONLY* if I have first connected it via wire?
Is it expected? Is that a configuration issue on my side?
My *hope* would have been that - so long as devices have been previously paired, I could have simply connected them.
That said - perhaps my expectation is what is in error here :)
@KurtE
Are there any instructions on how to adapt the keyboard code to work with other keyboards? I am trying to figure out what changes I need to make. I am capturing the packets in linux using sniffer. I read the bluetooth_app_c10.pdf but it's confusing without an example. It would be great if you provide an example with a packet.
@knightshade - will look more at this when I have the units to try out. Ebay says it should be to my mailbox by Friday... So hopefully will pickup Friday or day or so after...
@milan7 - I have never used the linux sniffer, so probably not much help there. When looking at new different type devices, I will try several things.
I will often plug it into a linux board (maybe RPI or maybe PC) and try to grab as much information from Linux that I can. Things like what does things like: lsusb -v
and things like a hid dump and ...
I also often look around to see if others have supported this board. Look for Linux driver (most complex solutions). Also see if maybe the Arduino USB Host Shield 2 code has support for the device....
I then often use my Saleae Logic Analyzer and try to capture the USB traffic associated with it...
But again it also depends on the type of device.
Example you mention Keyboard: We support several (hopefully most) USB keyboards. If it does not work, then would be good to know which one?
Bluetooth - Still a WIP - I have gotten it to work with a couple (I only have a couple)...
They can be a pain, mainly figuring out how to get the pairing and trust stuff completed. Hopefully once we get things merged, we will revisit some of the work flow for pairing and support for multiple Bluetooth devices.
Kurt
@KurtE - Thanks.
I think I was more just hoping to get an understanding of: what is the experience is currently with a dualshock controller connecting if it has been previously paired.
Can that happen without any cables being in the mix?
(I may need to pick one up for testing)
@knightshade
I tested extensively with the PS4 Dualshock and that works both wired and wirelessly with BT even when its paired. As for the PS3 Dualshock, I was using this https://www.amazon.com/gp/product/B06XDPQYB9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 to test with. Once it is paired with dongle it is paired. To pair it you use the method that @KurtE described in post in this thread:
/* For PS3 controller it must be USB paired in advance -
 * - plug in cable to PS3 - then Bt Dongle to see non-zero
 * BDADDR:
 * To initiate Bt pair - while on USB:: Hold select button and
 * press PS button to set controller associate. After that you can
 * comment out the bluetooth paring construcor and use second
 * constructor for already paired devices
BluetoothController bluet(myusb, true, "0000");   // Version does pairing to device
//BluetoothController bluet(myusb);   // version assumes it already was paired
These instructions are actually in the example joystick Bluetooth sketch.
Kurt
Thanks Kurt.
So I am trying to make it work with a bluetooth assistive switch which is basically a one button or 2 button bluetooth keyboard used by those with high level of disability to navigate their computer or phone.
https://www.ablenetinc.com/technology/switches/blue2-bluetooth-switch
So the idea is to use it with other devices other the windows computers and android phones through teensy.
It works with linux and android out of the box but two main differences are that it doesn't ask for pin code (0000) to connect and it's in discover mode only for short amount of time.
I am using bluetooth sniffer on raspberry pi and doing what you mentioned basically using bluetoothctl command and dump the recorded packets in a log file. I then use BA ADDR to filter for that device.
I'm definately not having an issue with pairing the controllers to the dongle.
I can pair a set using my Mega/HostShield combo, and that connects so long as I've connected the PS3 Move navigation contoller once via wire during the same boot cycle of the Teensy.
I can also pair a previously unpaired remote/dongle using the Teensy 3.6 (edited the code to change the key sequence to buttons that I have).
After doing that, I can move the dongle to the Mega/HostShield and they work as expected for a paired controller/dongle.
Thanks for the link for a controller.... that is inexpensive enough of a controller to buy for just playing on a test bed.
The limitation that I have is the following sequence:
1.) Connect Teensy 3.6 to a laptop
2.) Open Serial monitor
(output: USB Host Testing, 960)
3.) Connect USB dongle to Teensy USB pins
(output to serial monitors recognizes this)
4.) Grab remote previously paired with the USB dongle (and verified to be a working combo)
Press the PS button to wake up remote for it to connect
The light on the dongle changse the rate at which it flickers.
It was a flider at a steady 1sec interval, after the remote is woken up, there appears to be "chatter" and the dongle's is actively flickering.
The sketch never enters loop: " if (joystick1.available()) { "
I'm slowly going back and tracing the code, learning as I go :)
Ideally, a dongle/controller that is already paired will be able to get a connection again.
The Ebay stuff arrived today. Hard to say if they work or not..., Do they have an LEDs or lights on them that supposed to light up at all when they are in use?
I.e. wonder if batteries in these work or not.
quick looks at it on RPI:
pi@raspberrypi:~ $ lsusb -v -d 054c:042f
Bus 001 Device 004: ID 054c:042f Sony Corp. PlayStation Move navigation controller
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0x054c Sony Corp.
  idProduct          0x042f PlayStation Move navigation controller
  bcdDevice            1.00
  iManufacturer           1
  iProduct                2
  iSerial                 0
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass         3 Human Interface Device
      bInterfaceSubClass      0 No Subclass
      bInterfaceProtocol      0 None
      iInterface              0
        HID Device Descriptor:
          bLength                 9
          bDescriptorType        33
          bcdHID               1.11
          bCountryCode            0 Not supported
          bNumDescriptors         1
          bDescriptorType        34 Report
          wDescriptorLength     148
         Report Descriptors:
           ** UNAVAILABLE **
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               1
pi@raspberrypi:~ $
Now Hid Information:
pi@raspberrypi:~ $ sudo usbhid-dump -i0 | grep -v : | xxd -r -p | hidrd-convert -o spec
Usage Page (Desktop),               ; Generic desktop controls (01h)
Usage (Joystik),                    ; Joystik (04h, application collection)
Collection (Application),
    Collection (Logical),
        Report ID (1),
        Report Size (8),
        Report Count (1),
        Logical Minimum (0),
        Logical Maximum (255),
        Input (Constant, Variable),
        Report Size (1),
        Report Count (19),
        Logical Maximum (1),
        Physical Minimum (0),
        Physical Maximum (1),
        Usage Page (Button),        ; Button (09h)
        Usage Minimum (01h),
        Usage Maximum (13h),
        Input (Variable),
        Report Size (1),
        Report Count (13),
        Usage Page (FF00h),         ; FF00h, vendor-defined
        Usage (Pointer),            ; Pointer (01h, physical collection)
        Collection (Physical),
            Report Size (8),
            Report Count (4),
            Physical Maximum (255),
            Usage (X),              ; X (30h, dynamic value)
            Usage (Y),              ; Y (31h, dynamic value)
            Usage (Z),              ; Z (32h, dynamic value)
            Usage (Rz),             ; Rz (35h, dynamic value)
            Input (Variable),
        End Collection,
        Report Size (8),
        Report Count (39),
        Input (Variable),
        Report Size (8),
        Report Count (48),
        Output (Variable),
        Report Size (8),
        Report Count (48),
        Feature (Variable),
    End Collection,
        Report ID (2),
        Report Size (8),
        Report Count (48),
        Feature (Variable),
    End Collection,
        Report ID (238),
        Report Size (8),
        Report Count (48),
        Feature (Variable),
    End Collection,
        Report ID (239),
        Report Size (8),
        Report Count (48),
        Feature (Variable),
    End Collection,
End Collection
pi@raspberrypi:~ $
Batteries that aren't overly strong is probably common with the age of them.
There is a single LED that should blink while it is charging.
It also blinks when you press the PS button and it is attempting to bind to a bluetooth host.
From there, it depends on the program - as that can do various things with the LED.
They can be a bit of a challenge to charge.
Easiest is to use a mini-usb cable connected to a windows box, or to a PS3.
There is a handshake of sorts that is needed, so you cannot simply connect them to something like a phone charger.
@KurtE and @knightshade - just ordered one myself off ebay - looks like wont be until Monday I get one.....
@knightshade and @mjs513... May have to play around some, but it is interesting on Linux the sixpair program does not work with these... Probably looks at product ID...
Maybe need to hack the sources?
What do others do to pair these?
Thanks, yes they have mode a version of some of this stuff called psmove.
For the heck of it, I had previously downloaded the sixpair code as the current versions of linux did not want to install the prebuilt... No release stuff...
So I edited the source file and changed the DEVICE define to that of the Move controller and it now appears to have tried and hopefully paired the one unit with a BT dongle...
Next up try again on T4 or T3.6 to see what it shows me...
Historiclaly, I've used a sketch from Circuits@Home with one of their host shields on an Arduino.
I've also used your JoystickBT.ino script to pair these successfully (with a minor modification due to the lack of a select button)
After pairing, I was able to successfully test using the controller/dongle with a Circuits@Home host shields on an Arduino.
@knightshade and @mjs513 - I pushed up some changes which I think work for the PlayStation Move navigation controller
Two sets of changes/hacks needed:
1) For USB claim needs to use the product ID as specified earlier here and treat it as a PS3...
2) Bluetooth - needed to look at the remote name, in this case: Navigation Controller to know that it is a PS3.
To make it easier to do the pairing, I changed the button sequence which was hold down the Select button and then press PS to be holding down at least one of:
(Select, R1, L1) and then press the PS button.
Note: I think only one of the two controllers I received is working right now...
But you might try syncing up to my changes and see if it works for you
Kurt
From a learning perpective, I will want to look over the code diff - but I will say that this appears to have fixed things.
Without wires (I was already paired) - I was able to simply turn on the remote and start to get output to the screen.
I grabbed a second remote, and it appears that also bound and was outputting to the screen.
I only use the term "appears" - as the only thing differentating the output between the two controllers was the values (buttons, joysticks) and the text output would alternate between what I was doing on each of the two controllers.
With those changes, I think that this is enough to get me into trouble.
Many thanks!
In looking over the code changes, this is what I missed:
	} else if (strncmp((const char *)remoteName, "Navigation Controller", 21) == 0) {
		DBGPrintf("  JoystickController::mapNameToJoystickType %x %s - set to PS3\n", (uint32_t)this, remoteName);
		joystickType_ = PS3;
I don't have one here to test, but I suspect that the other half is called the "Motion controller" in that string and will also need to be added before it will work.
(Not needed for me - but perhaps someone down the road.)
From another thread that I googled:
[ 741.363723] input: Sony Computer Entertainment Motion Controller as
/devices/pci0000:00/0000:00:1d.0/usb2/2-1/2-1:1.0/0003:054C:03D5.000A/input/input19
[ 741.421269] hid-generic 0003:054C:03D5.000A: input,hiddev0,hidraw0:
USB HID v1.10 Gamepad [Sony Computer Entertainment Motion Controller]
on usb-0000:00:1d.0-1/input0
root@amd:~# evtest /dev/input/event7
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x54c product 0x3d5 version 0x110
Input device name: "Sony Computer Entertainment Motion Controller"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
With some additional funds :D (and little more) - I ordered a refurbished Motion Controller, which should arrive in a week or so... So I will then hopefully be able to verify it...
Also at that point it might be fun to start working on support for multiple BT devices connected at the same time.
Kurt
Morning Kurt.
Which branch did you push the changes to?
@KurtE
Well got my motion controller today and decided to give it a try. Just without any debugging yet all I get when it is wired is:
  manufacturer: Sony
  manufacturer: Sony
Will try and figure out what I did after diner and a nap :)
EDIT: Ok plug it in a couple of times and it hooked up wired and printed data no problem. Paired it using the function in the Joystick sketch, reloaded sketch and hooked right up with BT. As was mentioned there is a difference in some on the axis mapping between wired and BT which should be easy enough to adjust.
Today I received my Sony Motion Controller... Looks like it might take a little work...
Linux information from RPI3:
pi@raspberrypi:~ $
lsusb
Bus 001 Device 004: ID 054c:03d5 Sony Corp. PlayStation Move motion controller
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
pi@raspberrypi:~ $ lsusb -v -d  054c:03d5
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idProduct          0x03d5 PlayStation Move motion controller
  bcdDevice            4.60
  iManufacturer           1
  iProduct                2
  iSerial                 0
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
          bLength                 9
          bDescriptorType        33
          bcdHID               1.10
          bNumDescriptors         1
          wDescriptorLength     178
         Report Descriptors:
           ** UNAVAILABLE **
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               2
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               2
Usage (Gamepad),            ; Gamepad (05h, application collection)
    Report ID (1),
    Usage Maximum (18h),
    Report Size (1),
    Report Count (24),
    Input (Variable),
    Usage (24h),
    Report Size (8),
    Report Count (3),
    Input (Variable),
    Report Count (4),
    Input (Variable),
    Usage (20h),
    Report Count (38),
    Input (Variable),
    Report ID (2),
    Usage (21h),
    Report Count (48),
    Output (Variable),
    Report ID (6),
    Usage (27h),
    Report Count (8),
    Output (Variable),
    Report ID (3),
    Usage (23h),
    Report Count (8),
    Feature (Variable),
    Report ID (16),
    Usage (22h),
    Report Count (48),
    Feature (Variable),
    Report ID (224),
    Usage (25h),
    Report Count (48),
    Feature (Variable),
    Report ID (17),
    Usage (26h),
    Report Count (48),
    Feature (Variable),
End Collection,
Usage Page (FF02h),         ; FF02h, vendor-defined
Usage (20h),
    Usage (21h),
    Report ID (4),
    Report Size (8),
    Report Count (15),
    Feature (Variable),
    Usage (22h),
    Report ID (5),
    Report Count (22),
    Feature (Variable),
End Collection,
Usage Page (FF03h),         ; FF03h, vendor-defined
Usage (20h),
    Usage (21h),
    Report ID (160),
    Report Size (8),
    Report Count (34),
    Feature (Variable),
    Usage (22h),
    Report ID (161),
    Report Count (22),
    Feature (Variable),
End Collection
pi@raspberrypi:~ $
Try running with it plugged in to USB:
USB Host Testing
960
*** Device HID1 54c:3d5 - connected ***
  manufacturer: Sony Computer Entertainment
  product: Motion Controller
*** HID Device Joystick1 54c:3d5 - connected ***
If I turn on Debug stuff:
USB Host Testing
960
sizeof Device = 36
sizeof Pipe = 96
sizeof Transfer = 64
power up USBHS PHY
 reset waited 5
USBHS_ASYNCLISTADDR = 0
USBHS_PERIODICLISTBASE = 1FFF6000
periodictable = 1FFF6000
port change: 10001803
    connect
  begin reset
port change: 10001005
  port enabled
  end recovery
new_Device: 12 Mbit/sec
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
  12 01 00 02 00 00 00 40 4C 05 D5 03 60 04 01 02 00 01
    VendorID = 054C, ProductID = 03D5, Version = 0460
    Class/Subclass/Protocol = 0 / 0 / 0
    Number of Configurations = 1
enumeration:
enumeration:
Manufacturer: Sony Computer Entertainment
enumeration:
Product: Motion Controller
enumeration:
Config data length = 41
enumeration:
  09 02 29 00 01 01 00 80 FA
    NumInterfaces = 1
    ConfigurationValue = 1
  09 04 00 00 02 03 00 00 00
    Interface = 0
    Number of endpoints = 2
    Class/Subclass/Protocol = 3(HID) / 0 / 0
  09 21 10 01 00 01 22 B2 00
    HID, 1 report descriptor
  07 05 02 03 40 00 02
    Endpoint = 2 OUT
    Type = Interrupt
    Max Size = 64
    Polling Interval = 2
  07 05 81 03 40 00 02
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 64
enumeration:
USBHub memory usage = 960
USBHub claim_device this=1FFF2020
USBHub claim_device this=1FFF23E0
HIDParser claim this=1FFF27C0
HIDParser claim this=1FFF2DE0
HIDParser claim this=1FFF3420
HIDParser claim this=1FFF4720
HIDParser claim this=1FFF40E0
JoystickController claim this=1FFF4FC0
BluetoothController claim this=1FFF3A40
Descriptor 4 = INTERFACE
 bInterfaceClass =    3
 bInterfaceSubClass = 0
 bInterfaceProtocol = 0
HID Parser Claim: 09 04 00 00 02 03 00 00 00 09 21 10 01 00 01 22 B2 00 07 05 02 03 40 00 02 07 05 81 03 40 00 02
report descriptor size = 178
Two endpoint HID:
  endpoint = 2
   size = 64
   interval = 2
  endpoint = 81
   size = 64
   interval = 2
new_Pipe
allocate_interrupt_pipe_bandwidth
 best_bandwidth = 5, at offset = 0, shift= 0
new_Pipe
 best_bandwidth = 6, at offset = 1, shift= 0
Descriptor 33 = HID
Descriptor 5 = ENDPOINT
control callback (hid)
05 01 09 05 A1 01 85 01 05 09 19 01 29 18 15 00 25 01 35 00 45 01 75 01 95 18 81 02 06 00 FF 09 24 75 08 95 03 81 02 05 01 09 30 09 31 09 32 09 35 15 00 26 FF 00 95 04 81 02 06 00 FF 09 20 95 26 81 02 85 02 09 21 95 30 91 02 85 06 09 27 95 08 91 02 85 03 09 23 95 08 B1 02 85 10 09 22 95 30 B1 02 85 E0 09 25 95 30 B1 02 85 11 09 26 95 30 B1 02 C0 06 02 FF 09 20 A1 01 09 21 85 04 15 00 26 FF 00 75 08 95 0F B1 02 09 22 85 05 95 16 B1 02 C0 06 03 FF 09 20 A1 01 09 21 85 A0 15 00 26 FF 00 75 08 95 22 B1 02 09 22 85 A1 95 16 B1 02 C0
  mesg = 22000681
  got report descriptor
Found top level collection 10005
find_driver
  driver 1FFF4FCC
Match PID/VID: 5
Found top level collection FF020020
find_driver
  driver 1FFF4FCC
  driver 1FFF4D60
Rawhid Claim: 54c:3d5 usage: ff020020
  driver 1FFF4E00
No Driver claimed topusage: FF020020
Found top level collection FF030020
find_driver
  driver 1FFF4FCC
  driver 1FFF4D60
Rawhid Claim: 54c:3d5 usage: ff030020
  driver 1FFF4E00
No Driver claimed topusage: FF030020
send special PS3 feature command
ERROR Followup
    remove from followup list
  qtd: 88A0, token=4C10B508, next=7083788B
Now to start debugging
