costelljoe
New member
I'm trying to use a teensy 3.2 (without audio adapter) to read in audio. I'm using the "PassThroughMono" example which reads in pin A2 and outputs the signal on A14. However, when I connect any input (sine wave of amplitude 1v, centered at 1.5v) the output is flat at 600mV. When I ground pin A2 the output is also flat 600mV. Why does this not see the input correctly?
AudioInputAnalog adc1; //xy=161,80
AudioOutputAnalog dac1; //xy=329,47
AudioOutputPWM pwm1; //xy=331,125
AudioConnection patchCord1(adc1, dac1);
AudioConnection patchCord2(adc1, pwm1);
// Audio connections require memory to work. For more
AudioMemory(12);
// Do nothing here. The Audio flows automatically
