Results 1 to 6 of 6
Thread: Virtual MIDIx4
    Jan 2018
    Brazil
    36
    Virtual MIDIx4
    Sorry for my poor english.
    I can't understand how to transmit messages via usbMIDI using virtual cables/ports.
    I'm not using Serial Transmission.
    I would like an example to understand the operation.
    Teensy 3.6 >> DAW
    (Port 1) - usbMIDI.sendPitchBend(value, channel);
    (Port 2) - usbMIDI.sendPitchBend(value, channel);
    (Port 3) - usbMIDI.sendPitchBend(value, channel);
    I hope someone can help me
    Thank you
    26,568
    Use usbMIDI.sendPitchBend(value, channel, cable); where "cable" is 0 to 3.
    Jan 2018
    Brazil
    36
    So simple!!!
    thanks
    Jan 2018
    2
    simple and brilliant, thank you so much. Is the same possible for reading the different cables? Where do I have to insert the cable number? I want to read from two different MIDI Mashines (cable1 = X32 (Monitor Mute); cable2 = X-Touch (Recording Light)
    int bzaehler = 0;
    int x32 = 0; //MIDI Interface (0= Anschluss 1)
      pinMode(11, OUTPUT); //Recording light
      pinMode(12, OUTPUT); //Mute Light
      pinMode(2, OUTPUT);
      pinMode(3, OUTPUT);
      pinMode(4, OUTPUT);
      pinMode(5, OUTPUT);
      digitalWrite(2, !LOW); // relay module with optocoupler, inverted signal
      digitalWrite(3, !LOW); // relay module with optocoupler, inverted signal
      digitalWrite(4, !LOW); // relay module with optocoupler, inverted signal
      digitalWrite(5, !LOW); // relay module with optocoupler, inverted signal
      usbMIDI.setHandleNoteOn(onNoteOn) ;
      usbMIDI.setHandleControlChange(onControlChange);
      usbMIDI.read();
    //Recording light
    void onNoteOn(byte kanal, byte note, byte velocity) {
      if ((kanal == 1) & (note == 95) & (velocity == 127)) {
        digitalWrite(11,HIGH);
      if ((kanal == 1) & (note == 93) & (velocity == 127)) {
        digitalWrite(11,LOW);
    // Monitor Mute On through Mute Buttons
    void onControlChange(byte kanal, byte control, byte value) {
      if ((bzaehler == 0) & (kanal == 2) & ((control == 0) || (control == 1) || (control == 2) || (control == 3) || (control == 4) || (control == 5)) & (value == 0)){
        digitalWrite(12,HIGH);
        digitalWrite(2,HIGH);
        usbMIDI.sendProgramChange(0, 2, x32);
      if ((kanal == 2) & ((control == 0) || (control == 1) || (control == 2) || (control == 3) || (control == 4) || (control == 5)) & (value == 0)){
        bzaehler++;
    // Monitor Mute Off through Mute Buttons
      if ((bzaehler == 1) & (kanal == 2) & ((control == 0) || (control == 1) || (control == 2) || (control == 3) || (control == 4) || (control == 5)) & (value == 127)){
        digitalWrite(12,LOW);
        digitalWrite(2,LOW);
        usbMIDI.sendProgramChange(1, 2, x32);
      if ((kanal == 2) & ((control == 0) || (control == 1) || (control == 2) || (control == 3) || (control == 4) || (control == 5)) & (value == 127)){
        bzaehler--;
    26,568
    Quote Originally Posted by KnutB. View Post
    Use usbMIDI.getCable() to read which cable received the message.
    Details here:
    https://www.pjrc.com/teensy/td_midi.html
    Jan 2018
    2
    Hi, thank you for the hint. I read the td_midi already but could not figure out how to use the get.cable command. With the study of some other code I think I made it. In this version the teensy listens to specific ports and triggers action only when the right commands are comming from the right ports. Great! For anyone, who is interested in the project (Behringer X32core with X-touch, working as a broadcast console, so there is the need for monitor mute (Monitor mutes if mute status of ch1-6 is changed via snippet), redlight if Mic is open (via relays) and Rec light from Reaper).
    int bzaehler = 0;
    int x32 = 0; //MIDI Port für X32 (0= Anschluss 1)
    int Xtouch = 1; //MIDI Port für XTouch (10 Anschluss 2)
      pinMode(2, OUTPUT);
      pinMode(3, OUTPUT);
      pinMode(4, OUTPUT);
      pinMode(5, OUTPUT);
      usbMIDI.read();
    //Recording light
      int midiport2;
      midiport2 = usbMIDI.getCable();
      if ((midiport2 == Xtouch) & (kanal == 1) & (note == 95) & (velocity == 127)) {
      if ((midiport2 == Xtouch) & (kanal == 1) & (note == 93) & (velocity == 127)) {
      int midiport1;
      midiport1 = usbMIDI.getCable();
      if ((midiport1 == x32) & (bzaehler == 0) & (kanal == 2) & ((control == 0) || (control == 1) || (control == 2) || (control == 3) || (control == 4) || (control == 5)) & (value == 0)){
      if ((midiport1 == x32) & (kanal == 2) & ((control == 0) || (control == 1) || (control == 2) || (control == 3) || (control == 4) || (control == 5)) & (value == 0)){
        bzaehler++;
      if ((midiport1 == x32) & (bzaehler == 1) & (kanal == 2) & ((control == 0) || (control == 1) || (control == 2) || (control == 3) || (control == 4) || (control == 5)) & (value == 127)){
      if ((midiport1 == x32) & (kanal == 2) & ((control == 0) || (control == 1) || (control == 2) || (control == 3) || (control == 4) || (control == 5)) & (value == 127)){
        bzaehler--;
Tags for this Thread
