Results 1 to 4 of 4
Thread: Midi Feedback from Ableton Sync
    I'm setting up a midi controller using Teensy 2.0. All is going great except when I set the controller to receive sync from Ableton to Teensy, it resends the sync data back to the computer. Is this normal? Is there a midi thru feature I can disable?
    Senior Member oddson's Avatar
    Feb 2013
    Isle in the Salish Sea
    1,217
    I'm pretty sure there is no such feature,
    Any chance your code's send function is being triggered unexpectedly?
    There's a good chance, in fact! It turns out the pin I've assigned to at metronome LED has also been assigned to a Midi Output so I know what to troubleshoot. Thanks for the help!
    Feb 2013
    1,217
    So you're doing hardware MIDI? I might of thought of an electrical connection if you'd mentioned that. I'd assumed usbMIDI since you said you are sending to software.
    FYI the forum rule when looking for technical support is the post your code. You get better help that way too.
