Hello, I'm working on a project using the Teensy 3.2 with the rawhid library and am having trouble transferring data after changing the VID/PID.
As I understand it from reading around the forums, the VID and PID can be changed by editing the header file \Arduino\hardware\teensy\avr\cores\teensy3\usb_desc.h.
Following the instructions in the file, I changed the lines defining the VENDOR_ID and PRODUCT_ID under the USB_RAWHID definition. When I change these values and recompile, the rawhid library seems to break and no packets are sent. I am using the basic RAWHID.send() as shown in the built in examples.
The PID and the VID do successfully change, but I have confirmed no packets are being sent after the VID/PID change by using different usb monitoring programs. The packets are sent correctly when the VID and PID are the originals.
Any idea what could be causing this? Do the VID and the PID need to be defined/changed anywhere else for the rawhid library to function?
Thanks in advance for any help.
#include <LiquidCrystal.h>
const int rs = 11, en = 10, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
byte data[64] = {0xE2,0x00,0x00,0x32,0x80,0x00,0x00,0x00,
0x00,0x10,0x02,0xA5,0x07,0x90,0x02,0x68,
0x00,0x00,0x00,0x08,0x00,0x08,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,
0x00,0x00,0x00,0x80,0x06,0x01,0x90,0x00,
0x13,0x63,0xB3,0x24,0x00,0x00,0x00,0x10,
0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
const int ledPin = 13;
int n = 0;
unsigned int packetCount = 0;
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("Association!");
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, HIGH); // set the LED on
delay(1000); // wait for a second
digitalWrite(ledPin, LOW); // set the LED off
//byte buffer[64];
n = RawHID.send(data, 100);
if (n > 0) {
packetCount = packetCount + 1;
lcd.setCursor(0, 1);
lcd.print("Sent: ");
lcd.print(packetCount);
