Hey Everyone,
Im a beginner with using tinsy and i wanted to use the audio shield to play something from the SD card which is one of the first examples,
they way i set up the Tinsy with the shield it based on this
and power and GND are connected to the Tinsy which is connected through usb(for now)
which i also found in one of the forum this is the link: https://forum.pjrc.com/threads/41157-Just-noise-with-Teensy-3-6-and-Audio-Adaptor-Board
when i run the example code in the serial it says it's playing the file but i don't hear anything form the output.
I appreciate any help, most of the Doc or Examples i see is with Tinsy 3.2
LRCLK pin 23
TX pin 22
SCL pin 19
SDA pin 18
VOL pin 15
SCLK pin 14
RX pin 13
MISO pin 12
MCLK pin 11
SDCS pin 10
BCLK pin 9
MOSI pin 7
MEMCS pin 6
