I'm working on building an electronic flute/whistle. Basically, 10 notes, and depending on which buttons pressed, it outputs the relevant one. I've done a lower sound quality version on an atmega but this will be a step up. I'm looking at ideally 44k 16 bit mono sound, and as I've got the audio board, with STGL5000, it seems like a good option. Each of the sound samples is a continuous note.
I'm not sure the most efficient/easiest/cleverest way to do the sound is, or even if it's possible. I only need one sound to play at once, but it's important that they switch sounds smoothly.
I was thinking of using 10 raw sound files, one for each note, and playing them all simultaneously, with volume set to 0 for all except the note currently playing. But not sure if there is a better way to do this. My thoughts on this method were that it was probably faster to do that than to read them from SD/additional flash memory.
Thoughts?
Thanks for your ideas/inspiration!
Thoughts?
