It varies quite a lot. Using the ordinary SD library is far from optimal, since it write 1 sector at a time. The audio library Recorder example is able to write 44.1kHz 16 bit stereo to every SD card I've tested, so there's at least one data point, 88 kbytes/sec works.
But at least a couple people have reported problems writing faster streams. I have not personally investigated.
You can achieve much better performance if you write in larger blocks. Bill's SdFat library does this, or can. It's quite a bit more complex than using the simple Arduino SD library. I personally haven't used it much, so I can't really help there.
Might also be worth mentioning, that audio Recorder example uses a "queue" feature of the audio library, where data is automatically saved in a queue during times you don't read fast enough. If you have a real time data source, that sort of buffering is pretty much always required for SD card writing. The cards usually respond quickly, but sometimes they can take many milliseconds. You do need a place to buffer your data while you sometimes wait for the SD card.
