OmnipotentEntity
New member
Hello!
This is my first teensy3.6 project. While I've done some mbed programming in the past, nothing was nearly as technical and barebones as I'm trying to do right now. So I'm looking for some direction if possible.
Background:
I'm building an autonomous radiation detecting robot as part of a larger team. I'd like to use the teensy as a small realtime device to control servomotors on a relatively exposed area of the robot, and thus I need to test its response to radiation to see if the radiation we're dealing with is enough of a problem that we need to budget some extra shielding. I can tolerate random bitflips from radiation, I'd just like to know whether or not this device is susceptible to radiation damage.
I have several teensys, and I've irradiated one of them for 24 hours with a 1 Ci PuBe source. I've given it a few days to decay away any activation products, and I'm interested if the onboard flash and sram is still fully functional, or if they've been damaged permanently by the flux.
Goal:
I'd like to write a simple program to test the teensy's memory, akin to memtest86. Unfortunately, this means that I have to somewhat bypass the normal memory allocation procedure, because I want to ensure I get full coverage, and I'd like to test as much memory as possible.
Questions:
1. May I assume that when I receive control from the bootloader during the "setup" phase, that all of the dynamic memory that the system will need has already been allocated? May I also assume that no system calls will attempt to allocate memory during an interrupt during the "setup" function?
2. What is the best way to read malloc's (or new's!) internal allocation table?
3. Is assembly programming from within the arduino compiler as simple as just using a gcc asm directive?
4. And to double check my understanding from the documentation, the SRAM's lower address is 0x1FFF0000 and its upper address is 0x2002FFFF, correct?
Background:
Goal:
Questions:
