Teensy LC and ADC library error when compiling with Teensy-duino compiler
Nidhogg
New member
Hello!
I have downloaded Teensyduino and installed it.
I'm not an expert, so I'm trying to upload someone else's script on my Teensy LC.
I'm trying to compile a script but at line 94:
adc->setReference(ADC_REF_3V3, ADC_0); // change all 3.3 to 1.2 if you change the reference to 1V2
It gives me this error when compiling:
ADC_cont_serial_test2: In function 'void setup()':
ADC_cont_serial_test2:94: error: 'ADC_REF_3V3' was not declared in this scope
ADC_cont_serial_test2:103: error: 'ADC_HIGH_SPEED' was not declared in this scope
adc->setConversionSpeed(ADC_HIGH_SPEED);
And I can't understand what's wrong with it.
I'm using the ADC library from here installed in documents/arduino/libraries
Any suggestions on how to fix this? :confused:
The whole script is this:
/* Analog sampler for Teensy LC microcontroller
Copyright (c) 2015 Ben Krasnow ben.krasnow@gmail.com
Permission is hereby granted, free of charge, to any person obtaining
a copy of this software and associated documentation files (the
"Software"), to deal in the Software without restriction, including
without limitation the rights to use, copy, modify, merge, publish,
distribute, sublicense, and/or sell copies of the Software, and to
permit persons to whom the Software is furnished to do so, subject to
the following conditions:
1. The above copyright notice and this permission notice shall be
included in all copies or substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS
BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN
ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN
CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
SOFTWARE.
// This program samples a slow-scan analog video signal and sync signal with the ADC, and sends the data over USB serial
#include <ADC.h>
#define DEBUG_PINS // Comment this to disable hardware debug pins
// Pin I/O
const int PIN_SEM_VIDEO = A9; // Pin connected to video signal from SEM
const int PIN_SEM_SYNC = 15; // Pin connected to sync signal from SEM. HIGH = beam blanked during retrace
#ifdef DEBUG_PINS
const int PIN_DEBUG1 = 2; //HIGH during ADC ISR
const int PIN_DEBUG2 = 4; //HIGH during main loop
const int PIN_DEBUG3 = 5; //HIGH during sync ISR
//SEM video signal parameters
const int SYNC_DUR_THRESH = 300; // Duration in microseconds that differentiates between a horizontal and vertical sync pulse.
//USB data parameters
const byte HSYNC_VAL = 0; //Value sent via USB that indicates a horizontal sync pulse
const byte VSYNC_VAL = 1; //Value sent via USB that indicates a vertical sync pulse
//Values 2-255 are image data
//Internal tuning
const int MAIN_BUF_LENGTH = 128; // How large is each ping-pong buffer
const int BUF_TX_TRIG = 100; // When the buffer has this many bytes in it, switch to the other buffer, and transmit now.
//Global variables
byte bufferA[MAIN_BUF_LENGTH];
byte bufferB[MAIN_BUF_LENGTH];
int bufptrA, bufptrB, usebufA; // usebufA is used as a boolean
elapsedMicros syncPulseDur; // This is a special Teensy variable type that increments in time automatically
ADC *adc = new ADC(); // adc object
int i;
usebufA = 1;
bufptrA = 0;
bufptrB = 0;
for (i = 0; i < NVIC_NUM_INTERRUPTS; i++) NVIC_SET_PRIORITY(i, 128); //The Teensy LC only uses interrupt priorities of 0, 64, 128, 192, 255
NVIC_SET_PRIORITY(IRQ_ADC0, 64); // The ADC ISR must have a higher priority (lower number) than the USB ISR
NVIC_SET_PRIORITY(IRQ_PORTCD, 0); // The sync pulse ISR needs to have the highest priority of all
Serial.begin(9600); // USB is always 12 Mbit/sec
pinMode(PIN_SEM_VIDEO, INPUT);
pinMode(PIN_SEM_SYNC, INPUT);
// Debug pins
#ifdef DEBUG_PINS
pinMode(PIN_DEBUG1, OUTPUT);
pinMode(PIN_DEBUG2, OUTPUT);
pinMode(PIN_DEBUG3, OUTPUT);
attachInterrupt(PIN_SEM_SYNC, syncfallingISR, FALLING);
///// ADC0 ////
// reference can be ADC_REF_3V3, ADC_REF_1V2 (not for Teensy LC) or ADC_REF_EXT.
adc->setAveraging(4); // set number of averages
adc->setResolution(8); // set bits of resolution
// it can be ADC_VERY_LOW_SPEED, ADC_LOW_SPEED, ADC_MED_SPEED, ADC_HIGH_SPEED_16BITS, ADC_HIGH_SPEED or ADC_VERY_HIGH_SPEED
// see the documentation for more information
// additionally the conversion speed can also be ADC_ADACK_2_4, ADC_ADACK_4_0, ADC_ADACK_5_2 and ADC_ADACK_6_2,
// where the numbers are the frequency of the ADC clock in MHz and are independent on the bus speed.
// it can be ADC_VERY_LOW_SPEED, ADC_LOW_SPEED, ADC_MED_SPEED, ADC_HIGH_SPEED or ADC_VERY_HIGH_SPEED
adc->setSamplingSpeed(ADC_HIGH_SPEED); // change the sampling speed
// always call the compare functions after changing the resolution!
//adc->enableCompare(1.0/3.3*adc->getMaxValue(ADC_0), 0, ADC_0); // measurement will be ready if value < 1.0V
//adc->enableCompareRange(1.0*adc->getMaxValue(ADC_0)/3.3, 2.0*adc->getMaxValue(ADC_0)/3.3, 0, 1, ADC_0); // ready if value lies out of [1.0,2.0] V
// In this case, we only want the raw byte vales from the ADC. No need for scaling.
adc->startContinuous(PIN_SEM_VIDEO, ADC_0);
adc->enableInterrupts(ADC_0);
#ifdef DEBUG_PINS
digitalWriteFast(PIN_DEBUG2, HIGH);
if (bufptrA > BUF_TX_TRIG && usebufA == 1)
__disable_irq();
usebufA = 0;
bufptrB = 0;
__enable_irq();
Serial.write(bufferA, bufptrA);
else if (bufptrB > BUF_TX_TRIG && usebufA == 0)
__disable_irq();
usebufA = 1;
bufptrA = 0;
__enable_irq()
Serial.write(bufferB, bufptrB);
#ifdef DEBUG_PINS
digitalWriteFast(PIN_DEBUG2, LOW);
void adc0_isr(void) {
int tempval;
__disable_irq();
#ifdef DEBUG_PINS
digitalWriteFast(PIN_DEBUG1, HIGH);
if (digitalRead(PIN_SEM_SYNC) == HIGH)
syncPulseDur = 0; //We detected the start of a sync pulse. Set the auto-incrementing value to 0 so we can measure its length.
adc->stopContinuous(); // Stop the ADC so that we can start it exactly at the end of the sync pulse
if (usebufA == 1 && bufptrA < MAIN_BUF_LENGTH)
tempval = adc->analogReadContinuous(ADC_0) + 2; // Values 0 and 1 are used for sync, so 2-255 are data
bufferA[bufptrA++] = (tempval < 255) ? tempval : 255;
if (usebufA == 0 && bufptrB < MAIN_BUF_LENGTH)
bufferB[bufptrB++] = (tempval < 255) ? tempval : 255;
#ifdef DEBUG_PINS
digitalWriteFast(PIN_DEBUG1, LOW);
__enable_irq();
void syncfallingISR(void) {
__disable_irq();
#ifdef DEBUG_PINS
digitalWriteFast(PIN_DEBUG3, HIGH);
if (syncPulseDur < SYNC_DUR_THRESH)
bufferA[bufptrA++] = HSYNC_VAL;
bufferA[bufptrA++] = VSYNC_VAL;
bufferB[bufptrB++] = HSYNC_VAL;
bufferB[bufptrB++] = VSYNC_VAL;
#ifdef DEBUG_PINS
digitalWriteFast(PIN_DEBUG3, LOW);
__enable_irq();
manitou is correct. Technically it defaults to 3V3, so unless at some point you change it to the internal reference you can just comment out that line.
Yup, I've read it on the cpp file. The original script had that value set, so I didn't change it, but as you say the def value is 3.3.
