Results 1 to 3 of 3
Thread: Teensyduino 1.41: Disable virtual MIDI cables
    Mar 2017
    15
    Hi everyone,
    is there a way to disable the virtual MIDI cables when using "USB Type: all of the above"?
    I need Serial, MIDI and Keyboard as USB Type and there is no way to (de-)select Midix16 in this combination.
    Stefan
    20,598
    Yes, there is a way, but not from the Arduino IDE. You need to edit hardware/teensy/avr/cores/teensy/usb_desc.h. You'll find detailed instructions in the comments at the top of that file.
    Mar 2017
    15
    Hi Paul,
    OK, got it!
    Changed line 796
     #define MIDI_NUM_CABLES       1
    Seems to work fine.
    Thank you so much for your support.
    cheers,
    Stefan
