adc->setConversionSpeed(ADC_VERY_LOW_SPEED, ADC_1) isn't working for me anymore
tarnerich
The code lines in question can be found in the examples adc_adb and analogRead.
Both of these lines fail for me under Arduino 1.8.5 and Teensyduino 1.41:
adc_pdb:45: error: 'VERY_LOW_SPEED' was not declared in this scope
     adc->setConversionSpeed(VERY_LOW_SPEED, ADC_1);
adc_pdb:45: error: 'ADC_VERY_LOW_SPEED' was not declared in this scope
     adc->setConversionSpeed(ADC_VERY_LOW_SPEED, ADC_1);
In contrast, this line does work (as seen in the analogRead example):
adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_LOW _SPEED, ADC_1);
I noticed this problem during an attempt to update a project that I had started in September 2017 (probably using Arduino 1.8.0 and whatever Teensyduino was current at that time). The code that I can't compile now was never a problem within that prior environment, throughout dozens of compile cycles.
OS: Windows 7 64-bit
Target: Teensy 3.5
My project is back on track using that working version. I posting here on the chance that there is either a bug or a new paradigm that can affect the existing projects of other people.
Thank you for that reference.
Submitted with respect to the author of the ADC library, here is a working update of adc_pdb:
/* Example for triggering the ADC with PDB
*   Valid for Teensy 3.0 and 3.1, not LC
*   In Teensyduino version 1.41 and above there are new forms of the following calls.
*     (conversionspeed can be VERY_LOW_SPEED, LOW_SPEED, MED_SPEED, HIGH_SPEED_16BITS, HIGH_SPEED or VERY_HIGH_SPEED)
*     (samplingspeed   can be VERY_LOW_SPEED, LOW_SPEED, MED_SPEED, HIGH_SPEED or VERY_HIGH_SPEED)
*     (adcnumber       can be ADC_0 or ADC_1)
*   Obsolete forms:
*     adc->setConversionSpeed(conversionspeed, adcnumber);
*     adc->setSamplingSpeed(samplingspeed, adcnumber);
*   Current forms:
*     adc->setConversionSpeed(ADC_CONVERSION_SPEED::conversionspeed, adcnumber);
*     adc->setSamplingSpeed(ADC_SAMPLING_SPEED::samplingspeed, adcnumber);
*   Serial monitor commands
*     v [Enter]    print values
*     s Hz [Enter] start pdb, frequency in Hz
*     p [Enter]    pdb stats
#include <ADC.h>
const int readPin  = A9; // ADC0
const int readPin2 = A2; // ADC1
ADC *adc = new ADC();    // adc object;
    pinMode(LED_BUILTIN, OUTPUT);
    pinMode(readPin, INPUT);
    pinMode(readPin2, INPUT);
    Serial.println("Begin setup");
    ///// ADC0 ////
    // reference can be ADC_REFERENCE::REF_3V3, ADC_REFERENCE::REF_1V2 (not for Teensy LC) or ADC_REF_EXT.
    //adc->setReference(ADC_REFERENCE::REF_1V2, ADC_0); // change all 3.3 to 1.2 if you change the reference to 1V2
    adc->setAveraging(1);  // set number of averages
    adc->setResolution(8); // set bits of resolution
    // it can be VERY_LOW_SPEED, LOW_SPEED, MED_SPEED, HIGH_SPEED_16BITS, HIGH_SPEED or VERY_HIGH_SPEED
    // see the documentation for more information
    adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_HIGH_SPEED, ADC_0); // change the conversion speed
    // it can be VERY_LOW_SPEED, LOW_SPEED, MED_SPEED, HIGH_SPEED or VERY_HIGH_SPEED
    adc->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_HIGH_SPEED, ADC_0); // change the sampling speed
    adc->enableInterrupts(ADC_0);    // it's necessary to enable interrupts for PDB to work (why?)
    adc->analogRead(readPin, ADC_0); // call this to setup everything before the pdb starts
    ////// ADC1 /////
    #if ADC_NUM_ADCS>1
    adc->setAveraging(32, ADC_1);  // set number of averages
    adc->setResolution(16, ADC_1); // set bits of resolution
    adc->setConversionSpeed(ADC_CONVERSION_SPEED::VERY_LOW_SPEED, ADC_1); // change the conversion speed
    adc->setSamplingSpeed(ADC_SAMPLING_SPEED::VERY_LOW_SPEED, ADC_1); // change the sampling speed
    adc->enableInterrupts(ADC_1);
    adc->analogRead(readPin2, ADC_1); // call this to setup everything before the pdb starts
    Serial.println("End setup");
char c=0;
int value;
int value2;
    if (Serial.available()) {
        c = Serial.read();
        if(c=='v') { // value
            Serial.print("Value ADC0: ");
            value = (uint16_t)adc->analogReadContinuous(ADC_0); // the unsigned is necessary for 16 bits, otherwise values larger than 3.3/2 V are negative!
            Serial.println(value*3.3/adc->getMaxValue(ADC_0), DEC);
            #if ADC_NUM_ADCS>1
            Serial.print("Value ADC1: ");
            value2 = (uint16_t)adc->analogReadContinuous(ADC_1); // the unsigned is necessary for 16 bits, otherwise values larger than 3.3/2 V are negative!
            Serial.println(value2*3.3/adc->getMaxValue(ADC_1), DEC);
        } else if(c=='s') { // start pdb, before pressing enter write the frequency in Hz
            uint32_t freq = Serial.parseInt();
            Serial.print("Start pdb with frequency ");
            Serial.print(freq);
            Serial.println(" Hz.");
            adc->adc0->stopPDB();
            adc->adc0->startPDB(freq); //frequency in Hz
            #if ADC_NUM_ADCS>1
            adc->adc1->stopPDB();
            adc->adc1->startPDB(freq); //frequency in Hz
        } else if(c=='p') { // pbd stats
            Serial.print("Prescaler:");
            Serial.println( (PDB0_SC&0x7000)>>12 , HEX);
            Serial.print("Mult:");
            Serial.println( (PDB0_SC&0xC)>>2, HEX);
    /* fail_flag contains all possible errors,
        They are defined in  ADC_Module.h as
        ADC_ERROR_OTHER
        ADC_ERROR_CALIB
        ADC_ERROR_WRONG_PIN
        ADC_ERROR_ANALOG_READ
        ADC_ERROR_COMPARISON
        ADC_ERROR_ANALOG_DIFF_READ
        ADC_ERROR_CONT
        ADC_ERROR_CONT_DIFF
        ADC_ERROR_WRONG_ADC
        ADC_ERROR_SYNCH
        You can compare the value of the flag with those masks to know what's the error.
    if(adc->adc0->fail_flag) {
        Serial.print("ADC0 error flags: 0x");
        Serial.println(adc->adc0->fail_flag, HEX);
        if(adc->adc0->fail_flag == ADC_ERROR_COMPARISON) {
            adc->adc0->fail_flag &= ~ADC_ERROR_COMPARISON; // clear that error
            Serial.println("Comparison error in ADC0");
    #if ADC_NUM_ADCS>1
    if(adc->adc1->fail_flag) {
        Serial.print("ADC1 error flags: 0x");
        Serial.println(adc->adc1->fail_flag, HEX);
        if(adc->adc1->fail_flag == ADC_ERROR_COMPARISON) {
            adc->adc1->fail_flag &= ~ADC_ERROR_COMPARISON; // clear that error
            Serial.println("Comparison error in ADC1");
    //digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN));
    //delay(100);
// If you enable interrupts make sure to call readSingle() to clear the interrupt.
void adc0_isr() {
        adc->adc0->readSingle();
        //digitalWriteFast(LED_BUILTIN, !digitalReadFast(LED_BUILTIN) );
#if ADC_NUM_ADCS>1
void adc1_isr() {
        adc->adc1->readSingle();
// pdb interrupt is enabled in case you need it.
void pdb_isr(void) {
        PDB0_SC &=~PDB_SC_PDBIF; // clear interrupt
All of the other provided ADC examples do work.
However, the headers in the examples readAllPins and readPin are non-relevant copies of the header from analogContinuousRead
