Results 1 to 3 of 3
Thread: WS2812B & Teensy 3.2
    Feb 2018
    2
    Hello
    I just received my Teensy 3.2 and I meet a little problem with leds WS2812B. I use as recommended a SN74HCT245 to convert my signal from 3V3 to 5V. The problem is that I turn on all the LED glows white: / I have double checked my wiring. On the other hand, when I connect DIN directly to pin 2 the everything works oO
    I do not understand why with the 74HCT it does not work ..
    Thank you
    20,592
    Something is almost certainly wired up wrong. I know you double checked, but if you want us to help, you need to share photos of the wiring.
    Feb 2018
    2
    Thanks for your fast reply!
    I made all the cables, I always disconnect anything and I say to myself "And if it was the 74hct is the problem" I replace it with another chip and bingo it works!
    You really need to check everything ^^
    Thank you
